Tu masz jeszcze odczyt ze startu
ROM VER: 1.1.4
CFG 05
ROM VER: 1.1.4
CFG 05
DDR autotuning Rev 0.3d
DDR size from 0xa0000000 - 0xa3ffffff
DDR check ok... start booting...
U-Boot 2010.06-LANTIQ-v-2.0.40-svn2583 (Oct 26 2012 - 12:15:55)
CLOCK CPU 500M RAM 250M
DRAM: 64 MiB
Using default environment
In: serial
Out: serial
Err: serial
Net: Internal phy(GE) firmware version: 0x841d
vr9 Switch8192 KiB EN25Q64 at 0:3 is now current device
Type "run flash_nfs" to mount root filesystem over NFS
Uncompressing ...
Starting kernel ...
[ 0.000000] Linux version 3.10.36 (lukasz@lukasz-laptop) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.01 r40526) ) #6 Sun Apr 20 20:37:44 CEST 2014
[ 0.000000] SoC: VR9 rev 1.2
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019556 (MIPS 34Kc)
[ 0.000000] MIPS: machine is TDW8970 - TP-LINK TD-W8970
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x03ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x03ffffff]
[ 0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyLTQ0,115200 init=/etc/preinit
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Writing ErrCtl register=000010a0
[ 0.000000] Readback ErrCtl register=000010a0
[ 0.000000] Memory: 60880k/65536k available (2993k kernel code, 4656k reserved, 631k data, 204k init, 0k highmem)
[ 0.000000] NR_IRQS:256
[ 0.000000] CPU Clock: 500MHz
[ 0.000000] Calibrating delay loop... 332.54 BogoMIPS (lpj=665088)
[ 0.032000] pid_max: default: 32768 minimum: 301
[ 0.036000] Mount-cache hash table entries: 512
[ 0.040000] pinctrl core: initialized pinctrl subsystem
[ 0.044000] NET: Registered protocol family 16
[ 0.056000] pinctrl-xway 1e100b10.pinmux: Init done
[ 0.060000] dma-xway 1e104100.dma: Init done - hw rev: 7, ports: 7, channels: 28
[ 0.068000] dcdc-xrx200 1f106a00.dcdc: Core Voltage : 1016 mV
[ 0.072000] arch/mips/pci/ifxmips_pcie_vr9.h:pcie_device_rst_assert[185]
[ 0.184000] arch/mips/pci/ifxmips_pcie_vr9.h:pcie_device_rst_deassert[193]
[ 0.188000] ath9k,eeprom ath9k_eep.8: failed to find mtd device
[ 0.200000] bio: create slab <bio-0> at 0
[ 0.204000] usbcore: registered new interface driver usbfs
[ 0.208000] usbcore: registered new interface driver hub
[ 0.212000] usbcore: registered new device driver usb
[ 0.216000] PCI host bridge to bus 0000:00
[ 0.220000] pci_bus 0000:00: root bus resource [mem 0x1c000000-0x1cffffff]
[ 0.224000] pci_bus 0000:00: root bus resource [io 0x1d800000-0x1d8fffff]
[ 0.228000] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 0.232000] ifx_pcie_rc_class_early_fixup: fixed pcie host bridge to pci-pci bridge
[ 0.244000] pci 0000:00:00.0: BAR 8: assigned [mem 0x1c000000-0x1c0fffff]
[ 0.248000] pci 0000:00:00.0: BAR 9: assigned [mem 0x1c100000-0x1c1fffff pref]
[ 0.252000] pci 0000:01:00.0: BAR 0: assigned [mem 0x1c000000-0x1c01ffff 64bit]
[ 0.256000] pci 0000:01:00.0: BAR 6: assigned [mem 0x1c100000-0x1c10ffff pref]
[ 0.260000] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.264000] pci 0000:00:00.0: bridge window [mem 0x1c000000-0x1c0fffff]
[ 0.268000] pci 0000:00:00.0: bridge window [mem 0x1c100000-0x1c1fffff pref]
[ 0.272000] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
[ 0.276000] ifx_pcie_bios_map_irq port 0 dev 0000:00:00.0 slot 0 pin 1
[ 0.280000] ifx_pcie_bios_map_irq dev 0000:00:00.0 irq 144 assigned
[ 0.284000] ifx_pcie_bios_map_irq port 0 dev 0000:01:00.0 slot 0 pin 1
[ 0.288000] ifx_pcie_bios_map_irq dev 0000:01:00.0 irq 144 assigned
[ 0.292000] Switching to clocksource MIPS
[ 0.300000] NET: Registered protocol family 2
[ 0.304000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.312000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.316000] TCP: Hash tables configured (established 512 bind 512)
[ 0.324000] TCP: reno registered
[ 0.328000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.332000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.340000] NET: Registered protocol family 1
[ 0.344000] gptu: totally 6 16-bit timers/counters
[ 0.348000] gptu: misc_register on minor 63
[ 0.352000] gptu: succeeded to request irq 126
[ 0.356000] gptu: succeeded to request irq 127
[ 0.360000] gptu: succeeded to request irq 128
[ 0.368000] gptu: succeeded to request irq 129
[ 0.372000] gptu: succeeded to request irq 130
[ 0.376000] gptu: succeeded to request irq 131
[ 0.380000] phy-xrx200 gphy-xrx200.5: requesting lantiq/vr9_phy11g_a2x.bin
[ 0.388000] phy-xrx200 gphy-xrx200.5: booting GPHY0 firmware at 3CC0000
[ 0.396000] phy-xrx200 gphy-xrx200.5: booting GPHY1 firmware at 3CC0000
[ 0.504000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.512000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.520000] msgmni has been set to 118
[ 0.524000] io scheduler noop registered
[ 0.528000] io scheduler deadline registered (default)
[ 0.536000] 1e100c00.serial: ttyLTQ0 at MMIO 0x1e100c00 (irq = 112) is a lantiq,asc
[ 0.544000] console [ttyLTQ0] enabled, bootconsole disabled
[ 0.560000] spi_gpio spi.7: master is unqueued, this is deprecated
[ 0.564000] m25p80 spi32766.0: en25q64 (8192 Kbytes)
[ 0.568000] 4 ofpart partitions found on MTD device spi32766.0
[ 0.572000] Creating 4 MTD partitions on "spi32766.0":
[ 0.580000] 0x000000000000-0x000000020000 : "u-boot"
[ 0.584000] 0x000000020000-0x0000007c0000 : "firmware"
[ 0.592000] 0x00000015950c-0x0000007c0000 : "rootfs"
[ 0.596000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[ 0.612000] mtd: device 2 (rootfs) set to be root filesystem
[ 0.616000] mtd: partition "rootfs_data" created automatically, ofs=0x4b0000, len=0x310000
[ 0.624000] 0x0000004b0000-0x0000007c0000 : "rootfs_data"
[ 1.624000] 0x0000007c0000-0x0000007d0000 : "config"
[ 1.628000] 0x0000007d0000-0x000000800000 : "boardconfig"
[ 1.740000] libphy: lantiq,xrx200-mdio: probed
[ 1.748000] net-xrx200: invalid MAC, using random
[ 1.752000] eth0: attached PHY [Lantiq XWAY PEF7071] (phy_addr=0:00, irq=-1)
[ 1.760000] eth0: attached PHY [Lantiq XWAY PEF7071] (phy_addr=0:05, irq=-1)
[ 1.764000] eth0: attached PHY [Lantiq XWAY VR9 GPHY 11G v1.4] (phy_addr=0:11, irq=-1)
[ 1.772000] eth0: attached PHY [Lantiq XWAY VR9 GPHY 11G v1.4] (phy_addr=0:13, irq=-1)
[ 1.784000] wdt 1f8803f0.watchdog: Init done
[ 1.784000] leds-gpio gpio-leds.10: pins are not configured from the driver
[ 1.796000] TCP: cubic registered
[ 1.796000] NET: Registered protocol family 17
[ 1.800000] 8021q: 802.1Q VLAN Support v1.8
[ 1.884000] ath9k,eeprom ath9k_eep.8: using random mac
[ 1.888000] ath9k,eeprom ath9k_eep.8: using led pin 0.
[ 1.896000] ath9k,eeprom ath9k_eep.8: loaded ath9k eeprom
[ 1.988000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[ 1.996000] Freeing unused kernel memory: 204K (8038d000 - 803c0000)
[ 2.764000] eth0: port 0 got link
procd: Console is alive
procd: - watchdog -
procd: - preinit -
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 41.800000] SCSI subsystem initialized
[ 41.812000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 41.832000] IFXUSB: ifxusb_hcd: version 3.2 B110801
[ 41.836000] Chip Version :000c BurstSize=4
[ 42.440000] IFXUSB: USB core #0 soft-reset
[ 42.740000] IFXUSB: USB core #0 soft-reset
[ 42.744000] ifxusb_hcd ifxusb_hcd: IFX USB Controller
[ 42.748000] ifxusb_hcd ifxusb_hcd: new USB bus registered, assigned bus number 1
[ 42.756000] ifxusb_hcd ifxusb_hcd: irq 62, io mem 0xbe101000
[ 42.764000] IFXUSB: Init: Power Port (0)
[ 42.780000] ehci-platform: EHCI generic platform driver
[ 42.804000] hub 1-0:1.0: USB hub found
[ 42.804000] hub 1-0:1.0: 1 port detected
[ 43.308000] IFXUSB: USB core #1 soft-reset
[ 43.612000] IFXUSB: USB core #1 soft-reset
[ 43.616000] ifxusb_hcd ifxusb_hcd: IFX USB Controller
[ 43.620000] ifxusb_hcd ifxusb_hcd: new USB bus registered, assigned bus number 2
[ 43.628000] ifxusb_hcd ifxusb_hcd: irq 91, io mem 0xbe106000
[ 43.632000] IFXUSB: Init: Power Port (0)
[ 43.640000] hub 2-0:1.0: USB hub found
[ 43.640000] hub 2-0:1.0: 1 port detected
[ 43.644000] ifxusb_hcd ifxusb_hcd: requested GPIO 233
[ 43.656000] usbcore: registered new interface driver usb-storage
kmod: ran 10 iterations
kmod: 8 modules could not be probed
kmod: dependency not loaded mbcache
kmod: dependency not loaded jbd2
kmod: - ext4 - 2
kmod: - gpio-button-hotplug - 0
kmod: - jbd2 - 0
kmod: - ltq_hcd_vr9 - 0
kmod: - mbcache - 0
kmod: - scsi_mod - 0
kmod: dependency not loaded scsi_mod
kmod: - sd_mod - 1
kmod: - usb-storage - 1
[ 50.600000] jffs2: notice: (280) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (0 unchecked, 0 orphan) and 14 of xref (0 dead, 2 orphan) found.
block: extroot: no root or overlay mount defined
jffs2 is ready
[ 52.244000] jffs2: notice: (251) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (0 unchecked, 0 orphan) and 14 of xref (0 dead, 2 orphan) found.
switching to jffs2
procd: - early -
procd: - watchdog -
procd: - ubus -
procd: - init -
Please press Enter to activate this console.
BusyBox v1.19.4 (2014-04-18 13:51:35 CEST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
BARRIER BREAKER (Bleeding Edge, r40535)
* 1/2 oz Galliano Pour all ingredients into
* 4 oz cold Coffee an irish coffee mug filled
* 1 1/2 oz Dark Rum with crushed ice. Stir.
* 2 tsp. Creme de Cacao
root@(none):/# [ 63.844000] IFXOS, Version 1.5.14 (c) Copyright 2009, Lantiq Deutschland GmbH
[ 63.856000] NET: Registered protocol family 8
[ 63.856000] NET: Registered protocol family 20
[ 63.880000] PPP generic driver version 2.4.2
[ 63.908000] MEI CPE Driver, Version 1.2.0
[ 63.908000] (c) Copyright 2009, Infineon Technologies AG
### MEI CPE - MEI CPE - MEI CPE - MEI CPE ###
Lantiq CPE API Driver version: DSL CPE API V4.11.4
[ 63.952000]
[ 63.952000] Predefined debug level: 2
[ 63.996000] u32 classifier
[ 63.996000] input device check on
[ 64.000000] Actions configured
[ 64.012000] Mirror/redirect action on
[ 64.028000] nf_conntrack version 0.5.0 (954 buckets, 3816 max)
[ 64.044000] fuse init (API version 7.22)
[ 64.056000] Loading modules backported from Linux version master-2014-03-31-1-0-g5c109d2
[ 64.060000] Backport generated by backports.git backports-20140221-0-g8e94650
[ 64.084000] Infineon Technologies DEU driver version 2.0.0
[ 64.092000] IFX DEU DES initialized (multiblock).
[ 64.096000] IFX DEU AES initialized (multiblock).
[ 64.100000] IFX DEU ARC4 initialized (multiblock).
[ 64.104000] IFX DEU SHA1 initialized.
[ 64.108000] IFX DEU MD5 initialized.
[ 64.112000] IFX DEU SHA1_HMAC initialized.
[ 64.116000] IFX DEU MD5_HMAC initialized.
[ 64.136000] NET: Registered protocol family 24
[ 64.144000] usbcore: registered new interface driver usblp
[ 64.152000] usbcore: registered new interface driver usbserial
[ 64.156000] usbcore: registered new interface driver usbserial_generic
[ 64.164000] usbserial: USB Serial support registered for generic
[ 64.208000] xt_time: kernel timezone is -0000
[ 64.232000] cfg80211: Calling CRDA to update world regulatory domain
[ 64.244000] cfg80211: World regulatory domain updated:
[ 64.244000] cfg80211: DFS Master region: unset
[ 64.252000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 64.260000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 64.268000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 64.276000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 64.284000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 64.292000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 64.300000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 64.308000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 64.416000] usbcore: registered new interface driver option
[ 64.420000] usbserial: USB Serial support registered for GSM modem (1-port)
[ 64.436000] PCI: Enabling device 0000:01:00.0 (0000 -> 0002)
[ 64.464000] cfg80211: Calling CRDA for country: US
[ 64.472000] cfg80211: Regulatory domain changed to country: US
[ 64.476000] cfg80211: DFS Master region: FCC
[ 64.480000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 64.488000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 64.496000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[ 64.504000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[ 64.512000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 64.520000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 64.528000] ieee80211 phy0: Atheros AR9300 Rev:3 mem=0xbc000000, irq=144
[ 73.668000] device eth0 entered promiscuous mode
[ 73.676000] br-lan: port 1(eth0) entered forwarding state
[ 73.680000] br-lan: port 1(eth0) entered forwarding state
[ 75.684000] br-lan: port 1(eth0) entered forwarding state
procd: - init complete -
root@OpenWrt:/#
