coś chyba przekombinowałem.
Log na ten moment wygląda następująco
->Oops: flash id 0x1c3116 .
NET: Registered protocol family 2
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
TCP bic registered
NET: Registered protocol family 1
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
VFS: Mounted root (squashfs filesystem) readonly.
Freeing unused kernel memory: 128k freed
init started: BusyBox v1.01 (2010.06.28-04:54+0000) multi-call binary
Starting pid 14, console /dev/ttyS0: '/etc/rc.d/rcS'
Algorithmics/MIPS FPU Emulator v1.5
insmod: cannot open module `/lib/modules/2.6.15/kernel/ip_tables.ko': No such fi
le or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ip_conntrack.ko': No such
file or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ip_nat.ko': No such file
or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_MASQUERADE.ko': No su
ch file or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_comment.ko': No such
file or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_conntrack.ko': No suc
h file or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_iprange.ko': No such
file or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_mac.ko': No such file
or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_multiport.ko': No suc
h file or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_state.ko': No such fi
le or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_string.ko': No such f
ile or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/iptable_nat.ko': No such
file or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/iptable_filter.ko': No su
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_time.ko': No such fil
e or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_TRIGGER.ko': No such
file or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ip_conntrack_pptp.ko': No
such file or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_TCPMSS.ko': No such f
ile or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_multiurl.ko': No such
file or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ip_conntrack_h323.ko': No
insmod: cannot open module `/lib/modules/2.6.15/kernel/ipt_MARK.ko': No such fil
e or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/sch_htb.ko': No such file
or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/sch_prio.ko': No such fil
e or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/sch_sfq.ko': No such file
or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/cls_basic.ko': No such fi
le or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/cls_fw.ko': No such file
or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/ts_kmp.ko': No such file
or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/flashid.ko': No such file
or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/br_filter.ko': No such fi
le or directory
insmod: cannot open module `/lib/modules/2.6.15/kernel/harmony.ko': No such file
or directory
Starting pid 52, console /dev/ttyS0: '/sbin/getty'
Now flash open!
Now flash open!
sys_mode=3 mac:8106c000 ag7240_macs[0]:0 ag7240_macs[1]:8106c000
2
sys_mode=3 mac:81320000 ag7240_macs[0]:81320000 ag7240_macs[1]:8106c000
1
sys_mode 3 force 100Mbps full-duplex
Attention: PHY4 Class A setting in debug 5 register which is not described in D
S added by tiger
phy_setup ethUnit:0 phyUnit:4
S added by tiger
Port 4, Neg Success
++++ phy_up is 1, fdx is 1, speed is 1
ATHRS26: resetting s26
ATHRS26: s26 reset done
sys_mode 3 PHY0 auto-negotiation enable
Attention: PHY 0 Class A setting in debug 5 register which is not described in D
S
sys_mode 3 PHY1 auto-negotiation enable
Attention: PHY 1 Class A setting in debug 5 register which is not described in D
S
sys_mode 3 PHY2 auto-negotiation enable
Attention: PHY 2 Class A setting in debug 5 register which is not described in D
S
sys_mode 3 PHY3 auto-negotiation enable
Attention: PHY 3 Class A setting in debug 5 register which is not described in D
S
++++ vlan setting once
phy_setup ethUnit:1 phyUnit:0
phy_setup ethUnit:1 phyUnit:1
phy_setup ethUnit:1 phyUnit:2
phy_setup ethUnit:1 phyUnit:3
Port 0, Neg Success
Port 1, Neg Success
Port 2, Neg Success
Port 3, Neg Success
(none) mips #28 Wed Dec 1 16:42:54 CST 2010 (none)
(none) login: device eth0 entered promiscuous mode
device eth1 entered promiscuous mode
Port 0, Neg Success
Port 1, Neg Success
Port 2, Neg Success
Port 3, Neg Success
S added by tiger
Port 4, Neg Success
ath_hal: module license 'Proprietary' taints kernel.
ath_hal: 0.9.17.1 (AR5416, DEBUG, REGOPS_FUNC, WRITE_EEPROM, 11D)
wlan: 0.8.4.2 (Atheros/multi-bss)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Right
s Reserved
AG7240: enet unit:0 phy:4 is up...Mii 100Mbps full duplex
AG7240: enet unit 0 phy 4 mode 0x4c04
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserve
d
ath_pci: 0.9.4.5 (Atheros/multi-bss)
wifi0: Atheros 9285: mem=0x10000000, irq=48 hw_base=0xb0000000
wlan_me: Version 0.1
Copyright (c) 2008 Atheros Communications, Inc. All Rights Reserved
AG7240: enet unit:1 phy:0 is up...Mii 100Mbps full duplex
AG7240: enet unit 1 phy 0 mode 0x4c04
br0: port 2(eth1) entering learning state
br0: topology change detected, propagating
br0: port 2(eth1) entering forwarding state
br0: port 1(eth0) entering learning state
br0: port 1(eth0) entering forwarding state
wlan: mac acl policy registered
TP_Flags:6****
The selected channel is 4
Country ie is US
Country ie is US
maxrate = 300000
Country ie is US
br0: port 1(eth0) entering disabled state
Port 0, Neg Success
Port 1, Neg Success
Port 2, Neg Success
Port 3, Neg Success
device ath0 entered promiscuous mode
br0: port 3(ath0) entering learning state
br0: port 3(ath0) entering forwarding state
br0: port 3(ath0) entering disabled state
Country ie is US
TP_Flags:6****
TP_Flags:0****
Country ie is US
+++ GE0 RX DMA ENABLE
Inteference detected
rx_clear=100, rx_frame=0, tx_frame=0
U-Boot 1.1.4 (Jun 28 2010 - 12:51:24)
AP91 (ar7240) U-boot
DRAM:
sri
#### TAP VALUE 1 = 9, 2 = 9
32 MB
id read 0x100000ff
flash size 4194304, sector count = 64
Flash: 4 MB
Using default environment
In: serial
Out: serial
Err: serial
Net: ag7240_enet_initialize...
No valid address in Flash. Using fixed address
: cfg1 0xf cfg2 0x7014
eth0: 00:03:7f:09:0b:ad
eth0 up
: cfg1 0xf cfg2 0x7214
eth1: 00:03:7f:09:0b:ad
eth1 up
eth0, eth1
Autobooting in 1 seconds
ar7240> erase 0xbf020000
Usage:
erase - erase FLASH memory
ar7240> erase7c0000
Unknown command 'erase7c0000' - try 'help'
ar7240> erase 7c0000
Usage:
ar7240> tftpboot 0x81000000 code.bin
dup 1 speed 1000
Using eth1 device
TFTP from server 192.168.1.100; our IP address is 192.168.1.123
Filename 'code.bin'.
Load address: 0x81000000
Loading: #################################################################
done
Bytes transferred = 4938046 (4b593e hex)
ar7240> cp.b 0x81000000
Usage:
cp - memory copy
ar7240> cp.b 0xbf020000
Usage:
cp - memory copy
ar7240> cp.b 0x7c0000
Usage:
cp - memory copy
ar7240> bootm 0xbf020000
## Booting image at bf020000 ...
Uncompressing Kernel Image ... OK
Starting kernel ...
Booting AR7240(Python)...
Linux version 2.6.15--LSDK-7.3.0.300 gcc version 3.4.4 #28 Wed Dec 1 16:42:54 CS
T 2010
flash_size passed from bootloader = 4
CPU revision is: 00019374
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
User-defined physical RAM map:
Built 1 zonelists
Kernel command line: console=ttyS0,115200 root=/dev/mtdblock2 rootfstype=squashf
s init=/sbin/init mtdparts=ar7100-nor0:128k(u-boot),1024k(kernel),2816k(rootfs),
64k(config),64k(art) mem=32M
Primary instruction cache 64kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
Cache parity protection disabled
PID hash table entries: 256 (order: 8, 4096 bytes)
Using 175.000 MHz high precision timer.
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 30548k/32768k available (1368k kernel code, 2204k reserved, 291k data, 1
28k init, 0k highmem)
Checking for 'wait' instruction... available.
Returning IRQ 48
AR7240 GPIOC major 0
squashfs: version 3.3 (2007/10/31) Phillip Lougher
squashfs: LZMA suppport for slax.org by jro
Initializing Cryptographic API
io scheduler noop registered
io scheduler deadline registered
Serial: 8250/16550 driver $Revision: #1 $ 1 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x0 (irq = 19) is a 16550A
RAMDISK driver initialized: 1 RAM disks of 8192K size 1024 blocksize
cmdlinepart partition parsing not available
Searching for RedBoot partition table
5 RedBoot partitions found on MTD device ar7240-nor0
Creating 5 MTD partitions on "ar7240-nor0":
0x00000000-0x00020000 : "boot"
0x00020000-0x00120000 : "kernel"
0x00120000-0x00220000 : "rootfs"
0x00220000-0x00230000 : "config"
0x003f0000-0x00400000 : "art"
TCP reno registered
TCP bic registered
le or directory
file or directory
or directory
file or directory
h file or directory
file or directory
or directory
h file or directory
le or directory
ile or directory
file or directory
e or directory
file or directory
ile or directory
file or directory
e or directory
or directory
e or directory
or directory
le or directory
or directory
or directory
or directory
le or directory
or directory
Now flash open!
Now flash open!
2
1
S added by tiger
S added by tiger
Port 4, Neg Success
S
S
S
S
Port 0, Neg Success
Port 1, Neg Success
Port 2, Neg Success
Port 3, Neg Success
Port 0, Neg Success
Port 1, Neg Success
Port 2, Neg Success
Port 3, Neg Success
S added by tiger
Port 4, Neg Success
s Reserved
d
TP_Flags:6****
Country ie is US
Country ie is US
maxrate = 300000
Country ie is US
Port 0, Neg Success
Port 1, Neg Success
Port 2, Neg Success
Port 3, Neg Success
Country ie is US
TP_Flags:6****
TP_Flags:0****
Country ie is US
które komórki powinienem wykasować i wgrać?
co ciekawe podczas kasowania albo kopiowania nie ma żadnej informacji o wykonaniu polecenia jak w logu z poradnika. co robię źle?
