Niecały tydzień sprzęt znów pochodził normalnie. Dziś rano niestety już przestał...
Przesyłam logi z routera z dziś
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.000000] Kernel command line: board=TL-WR1043ND-v2 console=ttyS0,115200 rootfstype=squashfs,jffs2 noinitrd
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Memory: 61424k/65536k available (2256k kernel code, 4112k reserved, 425k data, 220k init, 0k highmem)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] NR_IRQS:51
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Calibrating delay loop... 358.80 BogoMIPS (lpj=1794048)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.060000] pid_max: default: 32768 minimum: 301
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.060000] Mount-cache hash table entries: 512
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.070000] NET: Registered protocol family 16
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.070000] gpiochip_add: registered GPIOs 0 to 23 on device: ath79
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.080000] MIPS: machine is TP-LINK TL-WR1043ND v2
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.490000] bio: create slab <bio-0> at 0
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.500000] Switching to clocksource MIPS
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.500000] NET: Registered protocol family 2
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.510000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.510000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.520000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.520000] TCP: Hash tables configured (established 2048 bind 2048)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.530000] TCP reno registered
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.530000] UDP hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.540000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.540000] NET: Registered protocol family 1
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 0.550000] PCI: CLS 0 bytes, default 32
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.560000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.560000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.570000] msgmni has been set to 119
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.580000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.590000] io scheduler noop registered
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.590000] io scheduler deadline registered (default)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.600000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.620000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.630000] console [ttyS0] enabled, bootconsole disabled
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.650000] m25p80 spi0.0: found s25fl064k, expected m25p80
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.650000] m25p80 spi0.0: s25fl064k (8192 Kbytes)
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.660000] 5 tp-link partitions found on MTD device spi0.0
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.660000] Creating 5 MTD partitions on "spi0.0":
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.670000] 0x000000000000-0x000000020000 : "u-boot"
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.670000] 0x000000020000-0x00000010ee8c : "kernel"
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.680000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.690000] 0x00000010ee8c-0x0000007f0000 : "rootfs"
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.700000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.710000] mtd: partition "rootfs" set to be root filesystem
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.720000] mtd: partition "rootfs_data" created automatically, ofs=680000, len=170000
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.730000] 0x000000680000-0x0000007f0000 : "rootfs_data"
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.730000] 0x0000007f0000-0x000000800000 : "art"
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.670000] usbcore: registered new interface driver cdc_acm
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.670000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.770000] usbcore: registered new interface driver usblp
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.800000] usbcore: registered new interface driver usbserial
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.800000] USB Serial support registered for generic
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.810000] usbcore: registered new interface driver usbserial_generic
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.820000] usbserial: USB Serial Driver core
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.880000] USB Serial support registered for Sierra USB modem
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.890000] usbcore: registered new interface driver sierra
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.890000] sierra: v.1.7.40:USB Driver for Sierra Wireless USB modems
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.910000] usbcore: registered new interface driver sierra_net
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.070000] usbcore: registered new interface driver cdc_wdm
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.090000] usbcore: registered new interface driver cdc_ether
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.200000] usbcore: registered new interface driver cdc_ncm
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.250000] usbcore: registered new interface driver qmi_wwan
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.270000] usbcore: registered new interface driver rndis_host
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.330000] USB Serial support registered for GSM modem (1-port)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.340000] usbcore: registered new interface driver option
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.350000] option: v0.7.2:USB Driver for GSM modems
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.360000] USB Serial support registered for Qualcomm USB modem
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.370000] usbcore: registered new interface driver qcserial
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.470000] fuse init (API version 7.18)
Jan 1 01:00:42 Gargoyle kern.info kernel: [ 42.600000] eth1: link up (1000Mbps/Full duplex)
Jan 1 01:00:42 Gargoyle kern.info kernel: [ 42.600000] device eth1 entered promiscuous mode
Jan 1 01:00:42 Gargoyle kern.info kernel: [ 42.610000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:00:42 Gargoyle daemon.notice netifd: Interface 'lan' is now up
Jan 1 01:00:42 Gargoyle daemon.notice netifd: Interface 'loopback' is now up
Jan 1 01:00:42 Gargoyle user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Jan 1 01:00:43 Gargoyle kern.info kernel: [ 43.600000] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Jan 1 01:00:44 Gargoyle kern.info kernel: [ 44.610000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:00:45 Gargoyle user.notice usb-modeswitch: 1-0:1.0: Manufacturer=Linux_3.3.8_ehci_hcd Product=Generic_Platform_EHCI_Controller Serial=ehci-platform.0
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.110000] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.120000] device wlan0 entered promiscuous mode
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.280000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.290000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.290000] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Jan 1 01:00:50 Gargoyle kern.info kernel: [ 50.290000] br-lan: port 2(wlan0) entered forwarding state
Jan 3 08:00:01 Gargoyle user.notice usb-modeswitch: 2-0:1.0: Manufacturer=Linux_3.3.8_ehci_hcd Product=Generic_Platform_EHCI_Controller Serial=ehci-platform.1
Jan 3 08:00:02 Gargoyle authpriv.info dropbear[1316]: Running in background
Jan 3 08:00:02 Gargoyle daemon.crit httpd_gargoyle[1347]: bind 0.0.0.0 - Address already in use
Jan 3 08:00:02 Gargoyle daemon.warn httpd_gargoyle[1350]: started as root without requesting chroot(), warning only
Jan 3 08:00:02 Gargoyle daemon.notice httpd_gargoyle[1350]: httpd_gargoyle/1.0 14mar2008 starting on Gargoyle, port 80
Jan 3 08:00:04 Gargoyle user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Jan 3 08:00:04 Gargoyle user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Jan 3 08:00:04 Gargoyle user.notice dnsmasq: Allowing RFC1918 responses for domain free.aero2.net.pl
Jan 3 08:00:07 Gargoyle daemon.info dnsmasq[1725]: started, version 2.66 cachesize 150
Jan 3 08:00:07 Gargoyle daemon.info dnsmasq[1725]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan 3 08:00:07 Gargoyle daemon.info dnsmasq-dhcp[1725]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Jan 3 08:00:07 Gargoyle daemon.info dnsmasq[1725]: using local addresses only for domain lan
Jan 3 08:00:07 Gargoyle daemon.info dnsmasq[1725]: reading /tmp/resolv.conf.auto
Jan 3 08:00:07 Gargoyle daemon.warn dnsmasq[1725]: ignoring nameserver 192.168.1.1 - local interface
Jan 3 08:00:07 Gargoyle daemon.info dnsmasq[1725]: read /etc/hosts - 2 addresses
Jan 3 08:00:07 Gargoyle daemon.info dnsmasq-dhcp[1725]: read /etc/ethers - 0 addresses
Jan 3 08:00:07 Gargoyle user.err syslog: error starting threads: errno 89 (Function not implemented)
Jan 3 08:00:07 Gargoyle user.info sysinit: exportfs: could not open /var/lib/nfs/.etab.lock for locking: errno 2 (No such file or directory)
Jan 3 08:00:07 Gargoyle user.info sysinit: exportfs: can't lock /var/lib/nfs/etab for writing
Jan 3 08:00:07 Gargoyle user.info sysinit: exportfs: could not open /var/lib/nfs/.xtab.lock for locking: errno 2 (No such file or directory)
Jan 3 08:00:07 Gargoyle user.info sysinit: exportfs: can't lock /var/lib/nfs/xtab for writing
Jan 3 08:00:08 Gargoyle user.info sysinit: ERROR: No valid dynamic DNS service configurations defined
Jan 3 08:00:08 Gargoyle user.info sysinit: (Did you specify correct configuration file path?)
Jan 3 08:00:33 Gargoyle user.notice root: vsftpd init: mounted = 0
Jan 3 08:00:33 Gargoyle user.info sysinit: ERROR: No drives attached, no directories to share!
Jan 3 08:00:33 Gargoyle user.info sysinit: setting up led USB
Jan 3 08:00:33 Gargoyle user.info sysinit: setting up led WLAN
Jan 3 08:01:57 Gargoyle daemon.info hostapd: wlan0: STA e8:f2:e2:62:4a:c0 IEEE 802.11: authenticated
Jan 3 08:01:57 Gargoyle daemon.info hostapd: wlan0: STA e8:f2:e2:62:4a:c0 IEEE 802.11: associated (aid 1)
Jan 3 08:01:57 Gargoyle daemon.info hostapd: wlan0: STA e8:f2:e2:62:4a:c0 WPA: pairwise key handshake completed (RSN)
Jan 3 08:01:57 Gargoyle daemon.info dnsmasq-dhcp[1725]: DHCPREQUEST(br-lan) 192.168.1.190 e8:f2:e2:62:4a:c0
Jan 3 08:01:57 Gargoyle daemon.info dnsmasq-dhcp[1725]: DHCPACK(br-lan) 192.168.1.190 e8:f2:e2:62:4a:c0 LGwebOSTV
Jan 3 08:09:58 Gargoyle daemon.info hostapd: wlan0: STA e8:f2:e2:62:4a:c0 WPA: group key handshake completed (RSN)
Jan 3 08:19:58 Gargoyle daemon.info hostapd: wlan0: STA e8:f2:e2:62:4a:c0 WPA: group key handshake completed (RSN)
Jan 3 08:29:58 Gargoyle daemon.info hostapd: wlan0: STA e8:f2:e2:62:4a:c0 WPA: group key handshake completed (RSN)
Jan 3 08:39:58 Gargoyle daemon.info hostapd: wlan0: STA e8:f2:e2:62:4a:c0 WPA: group key handshake completed (RSN)
Jan 3 08:49:58 Gargoyle daemon.info hostapd: wlan0: STA e8:f2:e2:62:4a:c0 WPA: group key handshake completed (RSN)
Jan 3 08:59:58 Gargoyle daemon.info hostapd: wlan0: STA e8:f2:e2:62:4a:c0 WPA: group key handshake completed (RSN)
Jan 3 09:09:58 Gargoyle daemon.info hostapd: wlan0: STA e8:f2:e2:62:4a:c0 WPA: group key handshake completed (RSN)
Jan 3 09:19:58 Gargoyle daemon.info hostapd: wlan0: STA e8:f2:e2:62:4a:c0 WPA: group key handshake completed (RSN)
Jan 3 09:22:54 Gargoyle daemon.info hostapd: wlan0: STA 44:74:6c:6d:75:84 IEEE 802.11: authenticated
Jan 3 09:22:54 Gargoyle daemon.info hostapd: wlan0: STA 44:74:6c:6d:75:84 IEEE 802.11: associated (aid 2)
Jan 3 09:22:54 Gargoyle daemon.info hostapd: wlan0: STA 44:74:6c:6d:75:84 WPA: pairwise key handshake completed (RSN)
Jan 3 09:22:54 Gargoyle daemon.info dnsmasq-dhcp[1725]: DHCPREQUEST(br-lan) 192.168.1.100 44:74:6c:6d:75:84
Jan 3 09:22:54 Gargoyle daemon.info dnsmasq-dhcp[1725]: DHCPACK(br-lan) 192.168.1.100 44:74:6c:6d:75:84 android-c908b4fb7413d448
Jan 3 09:26:54 Gargoyle daemon.info httpd_gargoyle[2552]: 192.168.1.100 connection timed out reading
Jan 3 09:26:54 Gargoyle daemon.info httpd_gargoyle[2551]: 192.168.1.100 connection timed out reading
Jan 3 09:26:54 Gargoyle daemon.info httpd_gargoyle[2550]: 192.168.1.100 connection timed out reading
Jan 3 09:26:54 Gargoyle daemon.info httpd_gargoyle[2549]: 192.168.1.100 connection timed out reading
Jan 3 09:26:54 Gargoyle daemon.info httpd_gargoyle[2548]: 192.168.1.100 connection timed out reading
Jan 3 09:26:54 Gargoyle daemon.info hostapd: wlan0: STA 90:48:9a:9f:61:7b IEEE 802.11: authenticated
Jan 3 09:26:54 Gargoyle daemon.info hostapd: wlan0: STA 90:48:9a:9f:61:7b IEEE 802.11: associated (aid 2)
Jan 3 09:26:54 Gargoyle daemon.info hostapd: wlan0: STA 90:48:9a:9f:61:7b WPA: pairwise key handshake completed (RSN)
Jan 3 09:26:55 Gargoyle daemon.info dnsmasq-dhcp[1725]: DHCPREQUEST(br-lan) 192.168.1.101 90:48:9a:9f:61:7b
Jan 3 09:26:55 Gargoyle daemon.info dnsmasq-dhcp[1725]: DHCPACK(br-lan) 192.168.1.101 90:48:9a:9f:61:7b Tkomp
Jan 3 09:26:55 Gargoyle daemon.info httpd_gargoyle[2564]: 192.168.1.100 connection timed out reading
Success
Oraz screeny z ustawień modemu:
