Mam problem z routerem TP-LINK MR3220. Otóż problem polega na tym, że po wgraniu najnowszego softu - router nie chce połączyć się z modemem 4G LTE z PLAY. Pomimo tego że modem jest "Identified" i kliknięciu na Connect w dalszym ciągu jest "Disconnected" (jak na screenie poniżej). I tak cały czas, nie wiem już co mam robić, czy jedyną opcją będzie zakup nowego routera? mam nadzieję że nie, a więc pomocy!
Dołączę jeszcze log (może coś pomoże):
# TL-MR3220 System Log
# Time = 1970-01-01 0:06:02 363s
# H-Ver = MR3220 v2 00000000 : S-Ver = 3.17.1 Build 140929 Rel.40245n
# L = 192.168.0.1 : M = 255.255.255.0
# 3G : 3G = 0.0.0.0 : M = 0.0.0.0 : G = 0.0.0.0
1st day 00:02:43 3G/4G INFO LTE dial automaticly
1st day 00:02:43 3G/4G NOTICE 3G/4G start connecting...
1st day 00:02:44 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbnet.ko
1st day 00:02:44 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_enc.ko
1st day 00:02:44 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ncm.ko
1st day 00:02:44 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ether.ko
1st day 00:02:44 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/qmi_wwan.ko
1st day 00:02:44 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc-acm.ko
1st day 00:02:44 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbserial.ko vendor=0x19D2 product=0x1403
1st day 00:02:44 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/option.ko
1st day 00:02:44 3G/4G NOTICE tty device name /dev/ttyUSB0
1st day 00:02:44 3G/4G NOTICE attach 137:atCmd:AT^NDISDUP=1,1,""^M
1st day 00:02:44 3G/4G INFO Attach to LTE with command:AT^NDISDUP=1,1,""^M
1st day 00:02:44 3G/4G NOTICE Open tty sucessfull@/dev/ttyUSB0.
1st day 00:02:53 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:02:54 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:02:55 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:02:56 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:02:57 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:02:58 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:02:59 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:03:00 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:03:01 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:03:02 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:03:02 3G/4G INFO LTE dial automaticly
1st day 00:03:02 3G/4G NOTICE 3G/4G start connecting...
1st day 00:03:02 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbnet.ko
1st day 00:03:02 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_enc.ko
1st day 00:03:02 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ncm.ko
1st day 00:03:02 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ether.ko
1st day 00:03:02 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/qmi_wwan.ko
1st day 00:03:03 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc-acm.ko
1st day 00:03:03 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbserial.ko vendor=0x19D2 product=0x1403
1st day 00:03:03 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/option.ko
1st day 00:03:03 3G/4G NOTICE Setting the device to ttyUSB0
1st day 00:03:03 3G/4G NOTICE attach 137:atCmd:AT^NDISDUP=1,1,""^M
1st day 00:03:03 3G/4G INFO Attach to LTE with command:AT^NDISDUP=1,1,""^M
1st day 00:03:03 3G/4G NOTICE Open tty sucessfull@/dev/ttyUSB0.
1st day 00:03:11 PPP WARNING 3G/4G disconnected
1st day 00:03:11 3G/4G INFO Modem information is updated
1st day 00:03:12 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:03:13 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:03:14 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:03:15 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:03:16 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:03:16 3G/4G INFO Modem information is updated
1st day 00:03:16 3G/4G INFO USB modem reset, please wait.
1st day 00:03:16 3G/4G NOTICE Reset the 3G modem, please wait.
1st day 00:03:17 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:03:17 3G/4G NOTICE handle_card start
1st day 00:03:17 3G/4G INFO LTE MODEM = 0, status = 1, targetVendorID = 0x0, targetProductID = 0x0
1st day 00:03:17 3G/4G INFO LTE MODEM = 0, status = 0, targetVendorID = 0x0, targetProductID = 0x0
1st day 00:03:17 3G/4G NOTICE delete usb_reset file
1st day 00:03:17 3G/4G INFO process_msg 553 : call dhcpcLteModemRelease
1st day 00:03:17 3G/4G NOTICE dhcpcLteModemRelease 1053 Dhcpc has stopped;
1st day 00:03:20 3G/4G INFO 3G Modem is plugged out.
1st day 00:03:28 3G/4G NOTICE handle_card start
1st day 00:03:28 3G/4G INFO LTE MODEM = 0, status = 1, targetVendorID = 0x0, targetProductID = 0x0
1st day 00:03:33 3G/4G INFO Before Mode switch VendorID = 0x19d2, ProductID = 0x1225
1st day 00:03:42 3G/4G INFO This is a LTE modem which needs mode switch.
1st day 00:03:42 3G/4G INFO Memory command is matched.
1st day 00:03:59 3G/4G NOTICE after switch modem vid is 0x19d2 pid is 0x1403
1st day 00:03:59 3G/4G INFO LTE MODEM = 2, status = 2, targetVendorID = 0x19d2, targetProductID = 0x1403
1st day 00:03:59 3G/4G INFO device name = LG_VL600 vendor = 0x1004 product = 0x61AA
1st day 00:03:59 3G/4G INFO Find vid 0x19D2, pid 0x1403 failed
1st day 00:03:59 3G/4G INFO device name = USB551L vendor = 0x1410 product = 0xB001
1st day 00:03:59 3G/4G INFO device name = MF182 vendor = 0x19D2 product = 0x1403
1st day 00:03:59 3G/4G INFO Find vid 0x19D2, pid 0x1403 succeed
1st day 00:03:59 3G/4G INFO Find LTE modem drivers for 0x19d2, 0x1403
1st day 00:04:00 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbnet.ko
1st day 00:04:00 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_enc.ko
1st day 00:04:00 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ncm.ko
1st day 00:04:00 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ether.ko
1st day 00:04:00 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/qmi_wwan.ko
1st day 00:04:00 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc-acm.ko
1st day 00:04:00 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbserial.ko vendor=0x19D2 product=0x1403
1st day 00:04:00 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/option.ko
1st day 00:04:04 3G/4G INFO Detect modem pin status.
1st day 00:04:12 3G/4G INFO USB modem is ready
1st day 00:04:13 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:13 3G/4G INFO LTE dial automaticly
1st day 00:04:13 3G/4G NOTICE 3G/4G start connecting...
1st day 00:04:13 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbnet.ko
1st day 00:04:13 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_enc.ko
1st day 00:04:13 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ncm.ko
1st day 00:04:13 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ether.ko
1st day 00:04:13 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/qmi_wwan.ko
1st day 00:04:13 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc-acm.ko
1st day 00:04:14 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbserial.ko vendor=0x19D2 product=0x1403
1st day 00:04:14 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/option.ko
1st day 00:04:14 3G/4G NOTICE tty device name /dev/ttyUSB0
1st day 00:04:14 3G/4G NOTICE attach 137:atCmd:AT^NDISDUP=1,1,""^M
1st day 00:04:14 3G/4G INFO Attach to LTE with command:AT^NDISDUP=1,1,""^M
1st day 00:04:14 3G/4G NOTICE Open tty sucessfull@/dev/ttyUSB0.
1st day 00:04:22 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:23 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:24 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:25 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:26 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:27 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:28 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:29 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:30 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:31 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:31 3G/4G INFO LTE dial automaticly
1st day 00:04:31 3G/4G NOTICE 3G/4G start connecting...
1st day 00:04:32 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbnet.ko
1st day 00:04:32 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_enc.ko
1st day 00:04:32 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ncm.ko
1st day 00:04:32 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ether.ko
1st day 00:04:32 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/qmi_wwan.ko
1st day 00:04:32 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc-acm.ko
1st day 00:04:32 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbserial.ko vendor=0x19D2 product=0x1403
1st day 00:04:33 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/option.ko
1st day 00:04:33 3G/4G NOTICE tty device name /dev/ttyUSB0
1st day 00:04:33 3G/4G NOTICE attach 137:atCmd:AT^NDISDUP=1,1,""^M
1st day 00:04:33 3G/4G INFO Attach to LTE with command:AT^NDISDUP=1,1,""^M
1st day 00:04:33 3G/4G NOTICE Open tty sucessfull@/dev/ttyUSB0.
1st day 00:04:41 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:42 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:43 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:44 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:45 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:46 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:47 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:48 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:49 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:50 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:04:50 3G/4G INFO LTE dial automaticly
1st day 00:04:50 3G/4G NOTICE 3G/4G start connecting...
1st day 00:04:51 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbnet.ko
1st day 00:04:51 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_enc.ko
1st day 00:04:51 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ncm.ko
1st day 00:04:51 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ether.ko
1st day 00:04:51 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/qmi_wwan.ko
1st day 00:04:51 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc-acm.ko
1st day 00:04:51 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbserial.ko vendor=0x19D2 product=0x1403
1st day 00:04:51 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/option.ko
1st day 00:04:51 3G/4G NOTICE tty device name /dev/ttyUSB0
1st day 00:04:51 3G/4G NOTICE attach 137:atCmd:AT^NDISDUP=1,1,""^M
1st day 00:04:51 3G/4G INFO Attach to LTE with command:AT^NDISDUP=1,1,""^M
1st day 00:04:51 3G/4G NOTICE Open tty sucessfull@/dev/ttyUSB0.
1st day 00:05:00 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:01 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:02 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:03 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:04 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:05 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:06 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:07 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:08 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:09 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:09 3G/4G INFO LTE dial automaticly
1st day 00:05:09 3G/4G NOTICE 3G/4G start connecting...
1st day 00:05:09 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbnet.ko
1st day 00:05:09 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_enc.ko
1st day 00:05:10 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ncm.ko
1st day 00:05:10 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc_ether.ko
1st day 00:05:10 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/qmi_wwan.ko
1st day 00:05:10 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/cdc-acm.ko
1st day 00:05:10 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/usbserial.ko vendor=0x19D2 product=0x1403
1st day 00:05:10 3G/4G INFO cmd = insmod /lib/modules/2.6.31/kernel/option.ko
1st day 00:05:10 3G/4G NOTICE Setting the device to ttyUSB0
1st day 00:05:10 3G/4G NOTICE attach 137:atCmd:AT^NDISDUP=1,1,""^M
1st day 00:05:10 3G/4G INFO Attach to LTE with command:AT^NDISDUP=1,1,""^M
1st day 00:05:10 3G/4G NOTICE Open tty sucessfull@/dev/ttyUSB0.
1st day 00:05:19 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:20 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:21 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:22 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:23 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:24 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:25 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:26 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:27 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:28 3G/4G INFO Good, SIM is not locked or unlocked.
1st day 00:05:28 3G/4G INFO LTE dial automaticly
1st day 00:05:28 3G/4G INFO USB modem reset, please wait.
1st day 00:05:28 3G/4G NOTICE Reset the 3G modem, please wait.
1st day 00:05:28 3G/4G NOTICE handle_card start
1st day 00:05:28 3G/4G INFO LTE MODEM = 0, status = 1, targetVendorID = 0x0, targetProductID = 0x0
1st day 00:05:28 3G/4G INFO LTE MODEM = 0, status = 0, targetVendorID = 0x0, targetProductID = 0x0
1st day 00:05:28 3G/4G NOTICE delete usb_reset file
1st day 00:05:28 3G/4G INFO process_msg 553 : call dhcpcLteModemRelease
1st day 00:05:28 3G/4G NOTICE dhcpcLteModemRelease 1053 Dhcpc has stopped;
1st day 00:05:31 3G/4G INFO 3G Modem is plugged out.
1st day 00:05:39 3G/4G NOTICE handle_card start
1st day 00:05:39 3G/4G INFO LTE MODEM = 0, status = 1, targetVendorID = 0x0, targetProductID = 0x0
1st day 00:05:44 3G/4G INFO Before Mode switch VendorID = 0x19d2, ProductID = 0x1225
1st day 00:05:53 3G/4G INFO This is a LTE modem which needs mode switch.
1st day 00:05:53 3G/4G INFO Memory command is matched.
juz wpisalem hasło: "password" i weszło.
