Możliwe ze router/wifi generuje zakłócenia które powodują zrywanie połączenia.
To spróbuje na długość kabla usb oddalić modem choć w routerze wifi radio mam wyłączone bo net mam do komputerów przesyłany tylko po kablu lan.
Znowu rozłączyło :
# TL-MR3220 System Log
# Time = 2015-01-08 13:30:08 5338s
# H-Ver = MR3220 v2 00000000 : S-Ver = 3.17.1 Build 140620 Rel.42968n
# L = 192.168.0.1 : M = 255.255.255.0
# 3G : 3G = 0.0.0.0 : M = 0.0.0.0 : G = 0.0.0.0
Jan 8 12:01:18 OTHER INFO System started
Jan 8 12:01:28 DHCP NOTICE DHCP server started
Jan 8 12:01:28 SECURITY INFO PPTP Passthrough enabled
Jan 8 12:01:28 SECURITY INFO L2TP Passthrough enabled
Jan 8 12:01:28 SECURITY INFO IPSEC Passthrough enabled
Jan 8 12:01:28 SECURITY INFO FTP ALG enabled
Jan 8 12:01:28 SECURITY INFO TFTP ALG enabled
Jan 8 12:01:29 SECURITY INFO H323 ALG enabled
Jan 8 12:01:29 SECURITY INFO RTSP ALG enabled
Jan 8 12:01:36 DHCP NOTICE DHCPS:Recv DISCOVER from 54:E6:FC:A0:9C:1D
Jan 8 12:01:38 DHCP NOTICE DHCPS:Send OFFER with ip 192.168.0.100
Jan 8 12:01:38 DHCP NOTICE DHCPS:Recv REQUEST from 54:E6:FC:A0:9C:1D
Jan 8 12:01:38 DHCP NOTICE DHCPS:Send ACK to 192.168.0.100
Jan 8 12:01:42 3G/4G NOTICE handle_card start
Jan 8 12:01:42 3G/4G INFO LTE MODEM = 0, status = 1, targetVendorID = 0x0, targetProductID = 0x0
Jan 8 12:01:47 3G/4G INFO Before Mode switch VendorID = 0x12d1, ProductID = 0x14fe
Jan 8 12:01:47 3G/4G INFO Memory command is matched.
Jan 8 12:02:01 3G/4G NOTICE after switch modem vid is 0x12d1 pid is 0x1506
Jan 8 12:02:01 3G/4G INFO LTE MODEM = 2, status = 2, targetVendorID = 0x12d1, targetProductID = 0x1506
Jan 8 12:02:01 3G/4G INFO Find LTE modem drivers for 0x12d1, 0x1506
Jan 8 12:02:02 3G/4G NOTICE This is a cdc_ncm devices
Jan 8 12:02:02 3G/4G NOTICE Setting the AT interface to /dev/ttyUSB1 for E3276
Jan 8 12:02:06 3G/4G INFO Detect modem pin status.
Jan 8 12:02:07 3G/4G INFO USB modem is ready
Jan 8 12:02:07 3G/4G INFO LTE MODEM = 2, status = 2, targetVendorID = 0x12d1, targetProductID = 0x1506
Jan 8 12:02:07 3G/4G INFO Find LTE modem drivers for 0x12d1, 0x1506
Jan 8 12:02:08 3G/4G NOTICE Pin lock status 0.
Jan 8 12:02:08 3G/4G INFO SIM is not locked.
Jan 8 12:02:08 3G/4G INFO LTE dial automaticly
Jan 8 12:02:08 3G/4G INFO Set APN: internet, AuthType: 0x0
Jan 8 12:02:08 3G/4G NOTICE 3G/4G start connecting...
Jan 8 12:02:09 3G/4G NOTICE This is a cdc_ncm devices
Jan 8 12:02:09 3G/4G NOTICE Setting the AT interface to /dev/ttyUSB1 for E3276
Jan 8 12:02:09 3G/4G NOTICE This is a E3276 device
Jan 8 12:02:10 3G/4G NOTICE This is not in Hong Kong area
Jan 8 12:02:10 3G/4G NOTICE tty device name /dev/ttyUSB1
Jan 8 12:02:10 3G/4G NOTICE attach 134:atCmd:AT^NDISDUP=1,1,"internet"^M
Jan 8 12:02:10 3G/4G NOTICE Open tty sucessfull@/dev/ttyUSB1.
Jan 8 12:02:11 3G/4G NOTICE Open tty sucessfull@/dev/ttyUSB1.
Jan 8 12:02:13 3G/4G INFO Detect modem pin status.
Jan 8 12:02:14 3G/4G INFO USB modem is ready
Jan 8 12:02:14 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 1
Jan 8 12:02:14 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
Jan 8 12:02:14 DHCP NOTICE DHCPC Recv OFFER from server 1fae11d9 with ip 1fae11da
Jan 8 12:02:14 DHCP NOTICE DHCPC Send REQUEST to server 1fae11d9 with request ip 1fae11da
Jan 8 12:02:15 DHCP NOTICE DHCPC Recv ACK from server 1fae11d9 with ip 1fae11da lease time 518400
Jan 8 12:02:15 DHCP NOTICE DHCPC:GET ip:1fae11da mask:fffffffc gateway:1fae11d9 dns1:596cc314 dns2:596cca14 static route:0
Jan 8 12:02:15 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 1
Jan 8 12:02:15 DHCP INFO Update DNS1 = 0x596cc314, DNS2=0x596cca14
Jan 8 12:02:16 DHCP INFO LTE Network connected.
Jan 8 12:02:17 3G/4G INFO Modem information is updated
Jan 8 13:04:27 DHCP NOTICE DHCPS:Recv DISCOVER from F8:BC:12:69:88:CA
Jan 8 13:04:28 DHCP NOTICE DHCPS:Send OFFER with ip 192.168.0.101
Jan 8 13:04:28 DHCP NOTICE DHCPS:Recv REQUEST from F8:BC:12:69:88:CA
Jan 8 13:04:28 DHCP NOTICE DHCPS:Send ACK to 192.168.0.101
Jan 8 13:04:34 DHCP NOTICE DHCPS:Recv INFORM from F8:BC:12:69:88:CA
Jan 8 13:05:36 DHCP NOTICE DHCPS:Recv INFORM from F8:BC:12:69:88:CA
Jan 8 13:24:45 DHCP NOTICE DHCPS:Recv INFORM from F8:BC:12:69:88:CA
Jan 8 13:26:05 DHCP NOTICE DHCPS:Recv INFORM from F8:BC:12:69:88:CA
Jan 8 13:29:00 3G/4G NOTICE handle_card start
Jan 8 13:29:00 3G/4G INFO LTE MODEM = 0, status = 1, targetVendorID = 0x0, targetProductID = 0x0
Jan 8 13:29:00 3G/4G INFO LTE MODEM = 0, status = 0, targetVendorID = 0x0, targetProductID = 0x0
Jan 8 13:29:00 3G/4G INFO process_msg 448 : call dhcpcLteModemRelease
Jan 8 13:29:00 3G/4G NOTICE Send cmd 0x2 to Dhcpc.
Jan 8 13:29:00 DHCP NOTICE DHCPC Unicasting a release of 31.174.17.218 to 31.174.17.217
Jan 8 13:29:00 DHCP NOTICE DHCPC Entering released state
Jan 8 13:29:00 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 1
Jan 8 13:29:01 3G/4G NOTICE dhcpcLteModemRelease 1071 sysCmd = ifconfig lte0 0.0.0.0
Jan 8 13:29:03 3G/4G INFO 3G Modem is plugged out.
Jan 8 13:29:08 PPP WARNING 3G/4G disconnected
Jan 8 13:29:08 3G/4G NOTICE mobileLinkUpdate 394 LTE is disconnect
Jan 8 13:29:59 3G/4G NOTICE modemUnplugedTime >=60s
Znowu to samo:
1st day 00:18:21 3G/4G NOTICE mobileLinkUpdate 394 LTE is disconnect
1st day 00:18:22 3G/4G INFO 3G Modem is plugged out.
1st day 00:19:18 3G/4G NOTICE modemUnplugedTime >=60s
1st day 00:19:26 DHCP NOTICE DHCPS:Recv INFORM from F8:BC:12:69:88:CA
1st day 00:20:29 DHCP NOTICE DHCPS:Recv INFORM from F8:BC:12:69:88:CA
1st day 00:21:37 DHCP NOTICE DHCPS:Recv INFORM from F8:BC:12:69:88:CA
1st day 00:22:41 DHCP NOTICE DHCPS:Recv INFORM from F8:BC:12:69:88:CA
1st day 00:23:46 DHCP NOTICE DHCPS:Recv INFORM from F8:BC:12:69:88:CA
Gdzieś są jakieś zakłócenia. Mogą one być spowodowane wadą routera nawet.
W play ograniczyli mi prędkość do 2 mega,włożyłem do modemu kartę ORANGE po LTE trochę słaby zasięg dwie kreski 45% ale leci do 6 mega zmieniłem w modemie na tylko HSPA+ zasięg 100% prędkość się waha 13-19mega,przy ściąganiu do 2 mega i jak na razie nie rozłącza router modemu.
Ile pobrałeś Gb w okresie rozliczeniowym ?
Oj nie wiem bo sprawdzałem miałem zalogowane play na ich stronie sprawdzałem stan konta /pakiety i połączenia i ostatnio tam zatrzymali mi licznik
ale myślę że około 100 giga ,pamiętam w listopadzie pobrałem 230giga i nic nie zwolniła się prędkość.
Długo się nie nacieszyłem tym HSPA+ bo też rozłączyło:
1st day 04:25:52 PPP WARNING 3G/4G disconnected
1st day 04:25:52 3G/4G NOTICE mobileLinkUpdate 395 LTE is disconnect
1st day 04:26:43 3G/4G NOTICE modemUnplugedTime >=60s
1st day 05:17:37 DHCP NOTICE DHCPS:Recv REQUEST from 54:E6:FC:A0:9C:1D
1st day 05:17:37 DHCP NOTICE DHCPS:Send ACK to 192.168.0.100
1st day 06:17:37 DHCP NOTICE DHCPS:Recv REQUEST from 54:E6:FC:A0:9C:1D
1st day 06:17:37 DHCP NOTICE DHCPS:Send ACK to 192.168.0.100
1st day 07:17:37 DHCP NOTICE DHCPS:Recv REQUEST from 54:E6:FC:A0:9C:1D
1st day 07:17:37 DHCP NOTICE DHCPS:Send ACK to 192.168.0.100
1st day 08:17:37 DHCP NOTICE DHCPS:Recv REQUEST from 54:E6:FC:A0:9C:1D
1st day 08:17:37 DHCP NOTICE DHCPS:Send ACK to 192.168.0.100
1st day 09:17:37 DHCP NOTICE DHCPS:Recv REQUEST from 54:E6:FC:A0:9C:1D
1st day 09:17:37 DHCP NOTICE DHCPS:Send ACK to 192.168.0.100
1st day 10:17:37 DHCP NOTICE DHCPS:Recv REQUEST from 54:E6:FC:A0:9C:1D
1st day 10:17:37 DHCP NOTICE DHCPS:Send ACK to 192.168.0.100
1st day 11:17:37 DHCP NOTICE DHCPS:Recv REQUEST from 54:E6:FC:A0:9C:1D
1st day 11:17:37 DHCP NOTICE DHCPS:Send ACK to 192.168.0.100
1st day 11:28:01 DHCP NOTICE DHCPS:Recv DISCOVER from F8:BC:12:69:88:CA
1st day 11:28:02 DHCP NOTICE DHCPS:Send OFFER with ip 192.168.0.101
1st day 11:28:02 DHCP NOTICE DHCPS:Recv REQUEST from F8:BC:12:69:88:CA
1st day 11:28:02 DHCP NOTICE DHCPS:Send ACK to 192.168.0.101
1st day 11:28:11 DHCP NOTICE DHCPS:Recv INFORM from F8:BC:12:69:88:CA
nie wiadomo czy to wina routera ,modemu czy sieci GSM.
Jaką masz taryfę w Play? Pytam bo od kilku dni testuje właśnie internet z Playa
I póki co wrażenia super. Ja mam TP link WR1043ND z Gargoyle i do tego modem E3272 w wersji Hilink . Bez żadnego Huba działa super.
Play Online na Kartę 4G LTE 19zł starter i ten sam modem co ty tylko bez hilink kupiony na allegro modem wraz starterem za 199zł.Z początku też super działał bez HUB-a,problemy z rozłączaniem zaczęły się dopiero później przy pobieraniu plików a bez pobierania też czasem raz na trzy dni zerwało połączenie.
Ja E3272 miałem też jako nie Hilink lecz zależało mi na wymuszeniu pasma LTE i zrobiłem z modemu Hilink. Praktycznie bez obsługowy modem . Zasięg masz tzn usługę na modemie masz aktywną jak stracisz neta ? Wrzuć parametry sygnału z modemu jakie masz.
Jak modem mam wpięty do rutera to w tedy nie mam możliwości wejścia do menu modemu,jak włożę modem bezpośrednio do kompa to startuje mi programik modemu PLAY ONLINE i tam pokazuje zasięg i ustawienia połączenia np.AUTO lub tylko LTE lub tylko HSPA+,
Mam też stary modem 3G z hilink i tam się loguję przez przeglądarkę bez względu na to gdzie jest podpięty czy w komp lub router.
Jak to zrobiłeś że bez hilink masz z hilink czy logujesz się przez przeglądarkę do tego modemu? bo wyczytałem w necie że wszyscy wolą bez hilink !!
Tak loguję się przez przeglądarkę niezależnie czy modem mam wpięty w routerze czy w laptopie . Adres modemu to 192.168.1.1. Zapoznaj się z tym wszystko ładnie opisane:
http://www.bez-kabli.pl/viewtopic.php?t=40841
Ja wg. tego poradnika robiłem . Hilinki działają jako karta sieciowa i czasem jest problem jeśli chodzi o dostęp z zewnatrz sieci bo masz 2 razy NAT .
Jaką prędkość osiągasz na tym modemie ?
jakie jest hasło przy upgrade do hilink ?
Oddalony jestem od BTS-a 8 km , prędkość na modemie mam max 35Mb/s i upload 13Mb/s.
Kod uzyskujesz na podstawie imei modemu który masz pod klapką wpisujesz na tę stronkę i generuję Ci kod http://a-zgsm.com/freecode/
W modemie po zmianie firmware na HiLink większej różnicy nie widzę opcje połączenia identyczne do wyboru ,prędkość ta sama,jedyny plus to mogę widzieć menu modemu z każdego komputera w domu połączonego kablem.
Czy teraz, jak masz HiLinka router zrywa połączenie? Masz wymuszone LTE?
Kolego na forum Play doczytałem że operator miewa od jakiegoś czasu właśnie chwilowe zaniki LTE. Dużo osób skarży się właśnie na zerwania połączenia . Co prawda też czasem ich doświadczam .
Jak na razie nie zerwało połączenia przy zwykłym korzystaniu zobaczymy jak przy pobieraniu,korzystałem z play LTE na kartę ale promocja się skończyła ,teraz korzystam z abonamentu orange i nie ma możliwości wyłączenia kodu pin no właśnie jak miałem nie HiLink to mogłem sobie w routerze zapisać pin i zapamiętywał a teraz w HiLink niema takiej opcji zapamiętania kodu pin i po wyłączeniu prądu modem się nie połączy trzeba ręcznie wpisywać pin.
