Witajcie
Mam problem z konfiguracją modemu na routerze TL-MR3420. Modem Huawei e3131 jest na liście kompatybilności i router pokazuje, że wykrył go prawidłowo, jednak gdy następuje próba połączenia z siecią otrzymuję komunikaty typu PPP ERROR No network protocols running.
Cały log z łączenia poniżej. Czy ktoś jest w stanie mi pomóc w tym dość już leciwym temacie?
TL-MR3420 System Log
Time = 2018-02-05 23:36:57 1457s
H-Ver = MR3420 v1 00000000 : S-Ver = 3.13.1 Build 121123 Rel.57630n
L = 192.168.1.1 : M = 255.255.255.0
3G : 3G = 0.0.0.0 : M = 0.0.0.0 : G = 0.0.0.0
1st day 00:19:36 OTHER INFO User clear system log.
1st day 00:19:49 3G NOTICE 3G start connecting...
1st day 00:19:49 PPP NOTICE Standard authentication.
1st day 00:19:49 3G INFO Run 3G dial cmd: pppd /dev/ttyUSB2 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 00:20:42 3G NOTICE 3G start connecting...
1st day 00:20:42 3G NOTICE Reset the 3G modem, please wait.
1st day 00:20:44 3G INFO mobileCmdReq 295 mobileFormatCmd error
1st day 00:20:57 3G INFO 3G Modem vendorID: 0x12d1; productID: 0x14fe
1st day 00:20:58 3G INFO 3G Modem vendorID: 0x12d1; productID: 0x14fe
1st day 00:21:02 3G INFO Switch modem mode with the 0 command in the file usb_modeswitch.conf
1st day 00:21:10 3G INFO 3G Modem vendorID: 0x12d1; productID: 0x1506
1st day 00:21:11 3G INFO 3G Modem vendorID: 0x12d1; productID: 0x1506
1st day 00:21:57 3G INFO Main interface_index[0] = -1
1st day 00:21:57 3G INFO Vice interface_index[1] = 0
1st day 00:21:57 3G INFO Vice interface_index[2] = 2
1st day 00:22:00 3G INFO getModemParamByScript 1124 Chip type = 1
1st day 00:22:00 3G INFO get_modem_info_file 144 getModemParamByScript return valid type = 1
1st day 00:22:02 3G INFO getModemParamByScript 1124 Chip type = 1
1st day 00:22:02 3G INFO get_modem_info_file 159 getModemParamByScript return valid type = 1
1st day 00:22:04 3G INFO getModemParamByScript 1124 Chip type = 1
1st day 00:22:04 3G INFO get_modem_info_file 174 getModemParamByScript return valid type = 1
1st day 00:22:04 3G INFO get_modem_info_file 189 Return chip type = 1
1st day 00:22:04 3G INFO 3G Modem vendorID: 0x12d1; productID: 0x1506
1st day 00:22:04 3G INFO USB modem is ready
1st day 00:22:33 3G NOTICE 3G start connecting...
1st day 00:22:33 PPP NOTICE Standard authentication.
1st day 00:22:33 3G INFO Run 3G dial cmd: pppd /dev/ttyUSB0 115200 connect "chat -s -v -f /etc/ppp/conn-s
1st day 00:22:37 PPP INFO sent [LCP Req mru=1480 asyncmap=0x0 magic=0x5d4abafc]
1st day 00:22:37 PPP INFO rcvd [LCP Req accomp pcomp asyncmap=0x0 mru=1500 magic=0x543 auth=chap-MD5]
1st day 00:22:37 PPP INFO sent [LCP Rej accomp pcomp]
1st day 00:22:37 PPP INFO rcvd [LCP Ack mru=1480 asyncmap=0x0 magic=0x5d4abafc]
1st day 00:22:37 PPP INFO rcvd [LCP Req asyncmap=0x0 mru=1500 magic=0x543 auth=chap-MD5]
1st day 00:22:37 PPP INFO sent [LCP Ack asyncmap=0x0 mru=1500 magic=0x543 auth=chap-MD5]
1st day 00:22:37 PPP INFO sent [LCP EchoReq magic=0x5d4abafc]
1st day 00:22:37 PPP INFO rcvd [CHAP Challenge (225678f7910d8c26c7519cd8d6e41622), name = "HUAWEI_CHAP_SRVR"]
1st day 00:22:37 PPP INFO sent [CHAP Response (d08e9262ea2fcd97847a7e4d87a72c11), name = ""]
1st day 00:22:37 PPP INFO rcvd [LCP EchoRep magic=0x543]
1st day 00:22:37 PPP INFO rcvd [CHAP Success "Welcome!!"]
1st day 00:22:37 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:37 PPP INFO rcvd [IPCP Req]
1st day 00:22:37 PPP INFO sent [IPCP Nak addr=0.0.0.0]
1st day 00:22:37 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:37 PPP INFO sent [IPCP Ack]
1st day 00:22:38 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:38 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:39 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:39 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:40 PPP INFO rcvd [IPCP Req]
1st day 00:22:40 PPP INFO sent [IPCP Ack]
1st day 00:22:40 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:40 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:41 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:41 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:42 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:42 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:43 PPP INFO rcvd [IPCP Req]
1st day 00:22:43 PPP INFO sent [IPCP Ack]
1st day 00:22:43 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:43 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:44 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:44 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:45 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:45 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:46 PPP INFO rcvd [IPCP Req]
1st day 00:22:46 PPP INFO sent [IPCP Ack]
1st day 00:22:46 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:46 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:47 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:47 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:48 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:48 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:49 PPP INFO rcvd [IPCP Req]
1st day 00:22:49 PPP INFO sent [IPCP Ack]
1st day 00:22:49 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:49 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:50 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:50 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:51 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:51 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:52 PPP INFO rcvd [IPCP Req]
1st day 00:22:52 PPP INFO sent [IPCP Ack]
1st day 00:22:52 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:52 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:53 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:53 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:54 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:54 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:55 PPP INFO rcvd [IPCP Req]
1st day 00:22:55 PPP INFO sent [IPCP Ack]
1st day 00:22:55 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:55 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:56 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:56 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:57 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:57 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:58 PPP INFO rcvd [IPCP Req]
1st day 00:22:58 PPP INFO sent [IPCP Ack]
1st day 00:22:58 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:58 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:22:59 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:22:59 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:00 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:00 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:01 PPP INFO rcvd [IPCP Req]
1st day 00:23:01 PPP INFO sent [IPCP Ack]
1st day 00:23:01 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:01 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:02 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:02 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:03 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:03 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:04 PPP INFO rcvd [IPCP Req]
1st day 00:23:04 PPP INFO sent [IPCP Ack]
1st day 00:23:04 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:04 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:05 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:05 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:06 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:06 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:07 PPP INFO sent [LCP EchoReq magic=0x5d4abafc]
1st day 00:23:07 PPP INFO rcvd [LCP EchoRep magic=0x543]
1st day 00:23:07 PPP INFO rcvd [IPCP Req]
1st day 00:23:07 PPP INFO sent [IPCP Ack]
1st day 00:23:07 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:07 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:08 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:08 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:09 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:09 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:10 PPP INFO rcvd [IPCP Req]
1st day 00:23:10 PPP INFO sent [IPCP Ack]
1st day 00:23:10 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:10 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:11 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:11 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:12 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:12 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:13 PPP INFO rcvd [IPCP Req]
1st day 00:23:13 PPP INFO sent [IPCP Ack]
1st day 00:23:13 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:13 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:14 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:14 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:15 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:15 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:16 PPP INFO rcvd [IPCP Req]
1st day 00:23:16 PPP INFO sent [IPCP Ack]
1st day 00:23:16 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:16 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:17 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:17 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:18 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:18 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:19 PPP INFO rcvd [IPCP TermReq]
1st day 00:23:19 PPP INFO sent [IPCP TermAck]
1st day 00:23:19 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:19 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:20 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:20 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:21 PPP INFO rcvd [IPCP Nak compress VJ 0f 01]
1st day 00:23:21 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:22 PPP INFO rcvd [IPCP TermReq]
1st day 00:23:22 PPP INFO sent [IPCP TermAck]
1st day 00:23:22 PPP INFO rcvd [IPCP TermAck]
1st day 00:23:24 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:25 PPP INFO rcvd [IPCP TermAck]
1st day 00:23:27 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:28 PPP INFO rcvd [IPCP TermAck]
1st day 00:23:30 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:31 PPP INFO rcvd [IPCP TermAck]
1st day 00:23:33 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:34 PPP INFO rcvd [IPCP TermAck]
1st day 00:23:36 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:37 PPP INFO sent [LCP EchoReq magic=0x5d4abafc]
1st day 00:23:37 PPP INFO rcvd [LCP EchoRep magic=0x543]
1st day 00:23:37 PPP INFO rcvd [IPCP TermAck]
1st day 00:23:39 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:40 PPP INFO rcvd [IPCP TermAck]
1st day 00:23:42 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:43 PPP INFO rcvd [IPCP TermAck]
1st day 00:23:45 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:46 PPP INFO rcvd [IPCP TermAck]
1st day 00:23:48 PPP INFO sent [IPCP Req compress VJ 0f 01 addr=0.0.0.0]
1st day 00:23:49 PPP INFO rcvd [IPCP TermAck]
1st day 00:23:51 PPP ERROR No network protocols running
1st day 00:23:51 PPP ERROR LCP down
1st day 00:23:51 PPP WARNING LCP down
1st day 00:23:51 PPP INFO sent [LCP TermReq]
1st day 00:23:51 PPP INFO rcvd [LCP TermAck]
wygląda na bardzo przejrzysty i do tego do czego chciałbym użyć tego routera w 100% wystarczający. Dziękuję
udało mi się prawidłowo zalogować do routera przez ssh, ale niestety nie jestem w linxie obeznany i nie bardzo wiem od czego zacząć, aby zdiagnozować co to może być.
