SoC: Atheros AR9341-DL3A
Flash: 4MB - cFeon Q32B-104HIP
RAM: 32MB - WINBOND W9425G6JH-5
Zdjęcia wnętrza WA860RE:
Piny do podłączenia UART TTL RS232:
Rx - punkt TP9
Tx - punkt TP10
GND - podączyłem na ekranie anteny.
Log z uruchomienia:
U-Boot 1.1.4 (Apr 11 2014 - 14:11:16)
U-boot AP123
DRAM: 32 MB
id read 0x100000ff
Flash: 4 MB
Using default environment
In: serial
Out: serial
Err: serial
Net: ag934x_enet_initialize...
wasp reset mask:c03300
WASP ----> S27 PHY
GMAC: cfg1 0x5 cfg2 0x7114
eth0: ba:be:fa:ce:08:41
s27 reg init
athrs27_phy_setup ATHR_PHY_CONTROL 4: 0x1000
athrs27_phy_setup ATHR_PHY_SPEC_STAUS 4: 0x10
eth0 up
WASP ----> S27 PHY
GMAC: cfg1 0xf cfg2 0x7214
eth1: ba:be:fa:ce:08:41
s27 reg init lan
ATHRS27: resetting s27
ATHRS27: s27 reset done
athrs27_phy_setup ATHR_PHY_CONTROL 0: 0x1000
athrs27_phy_setup ATHR_PHY_SPEC_STAUS 0: 0x10
athrs27_phy_setup ATHR_PHY_CONTROL 1: 0x1000
athrs27_phy_setup ATHR_PHY_SPEC_STAUS 1: 0x10
athrs27_phy_setup ATHR_PHY_CONTROL 2: 0x1000
athrs27_phy_setup ATHR_PHY_SPEC_STAUS 2: 0x10
athrs27_phy_setup ATHR_PHY_CONTROL 3: 0x1000
athrs27_phy_setup ATHR_PHY_SPEC_STAUS 3: 0x10
eth1 up
eth0, eth1
Autobooting in 1 seconds
## Booting image at 9f020000 ...
Uncompressing Kernel Image ... OK
Starting kernel ...
Booting Atheros AR934x
Linux version 2.6.31--LSDK-9.2.0_U5.508 (liangliang@LL) (gcc version 4.3.3 (GCC) ) #1 Fri Mar 28 09:54:36 CST 2014
flash_size passed from bootloader = 4
Ram size passed from bootloader =33554432
CPU revision is: 0001974c (MIPS 74Kc)
ath_sys_frequency: cpu srif ddr srif cpu 535 ddr 400 ahb 200
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
Zone PFN ranges:
Normal 0x00000000 -> 0x00002000
Movable zone start PFN for each node
0: 0x00000000 -> 0x00002000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line: console=ttyS0,115200 root=31:2 rootfstype=squashfs init=/sbin/init mtdparts=ath-nor0:128k(u-boot),1024k(kernel),2816k(rootfs),64k(config),64k(art) mem=32M
PID hash table entries: 128 (order: 7, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=00000000
Readback ErrCtl register=00000000
Memory: 30132k/32768k available (1719k kernel code, 2636k reserved, 429k data, 112k init, 0k highmem)
NR_IRQS:128
plat_time_init: plat time init done
Calibrating delay loop... 267.26 BogoMIPS (lpj=534528)
ath_simple_config_init: SYS_BOOTING_LED_GPIO : c
ath_simple_config_init: SYS_BOOT_FINISH_LED_GPIO : e
Enter power on/off mode...
bio: create slab <bio-0> at 0
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
ATH GPIOC major 0
squashfs: version 4.0 (2009/01/31) Phillip Lougher
msgmni has been set to 58
io scheduler noop registered
io scheduler deadline registered (default)
Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xb8020000 (irq = 19) is a 16550A
console [ttyS0] enabled
5 cmdlinepart partitions found on MTD device ath-nor0
Creating 5 MTD partitions on "ath-nor0":
0x000000000000-0x000000020000 : "u-boot"
0x000000020000-0x000000120000 : "kernel"
0x000000120000-0x0000003e0000 : "rootfs"
0x0000003e0000-0x0000003f0000 : "config"
0x0000003f0000-0x000000400000 : "art"
->Oops: flash id 0x1c3016 .
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Port Status 1c000004
ath-ehci ath-ehci.0: ATH EHCI
ath-ehci ath-ehci.0: new USB bus registered, assigned bus number 1
ehci_reset Intialize USB CONTROLLER in host mode: 13
ehci_reset Port Status 1c000000
ath-ehci ath-ehci.0: irq 3, io mem 0x1b000000
ath-ehci ath-ehci.0: USB 2.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
TCP cubic registered
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
athwdt_init: Registering WDT success
ath_otp_init: Registering OTP success
ath_clksw_init: Registering Clock Switch Interface success
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing unused kernel memory: 112k freed
usb 1-1: new full speed USB device using ath-ehci and address 2
usb 1-1: device descriptor read/64, error -71
init started: BusyBox v1.01 (2014.03.28-01:55+0000) multi-call binary
usb 1-1: new full speed USB device using ath-ehci and address 3
This Board use 2.6.31
xt_time: kernel timezone is -0000
nf_conntrack version 0.5.0 (512 buckets, 5120 max)
usb 1-1: new full speed USB device using ath-ehci and address 4
ip_tables: (C) 2000-2006 Netfilter Core Team
insmod: cannot open module `/lib/modules/2.6.31/kernel/iptable_raw.ko': No such file or directory
usb 1-1: device not accepting address 4, error -71
usb 1-1: new full speed USB device using ath-ehci and address 5
insmod: cannot open module `/lib/modules/2.6.31/kernel/flashid.ko': No such file or directory
PPPoL2TP kernel driver, V1.0
PPTP driver version 0.8.3
insmod: cannot open module `/lib/modules/2.6.31/kernel/harmony.ko': No such file or directory
usb 1-1: device not accepting address 5, error -71
hub 1-0:1.0: unable to enumerate USB device on port 1
(none) mips #1 Fri Mar 28 09:54:36 CST 2014 (none)
(none) login: Now flash open!
Now flash open!
====>>>>product id: 8600001
ATHR_GMAC: Length per segment 1536
ATHR_GMAC: fifo cfg 3 01f00140
ATHR_GMAC: RX TASKLET - Pkts per Intr:32
mac:1 Registering S27....
ATHR_GMAC: Max segments per packet : 1
ATHR_GMAC: Max tx descriptor count : 40
ATHR_GMAC: Max rx descriptor count : 128
ATHR_GMAC: Mac capability flags : 2D82
mac:0 Registering S27....
ATHR_GMAC: Mac capability flags : 2582
athr_gmac_ring_alloc Allocated 640 at 0x81e8dc00
athr_gmac_ring_alloc Allocated 2048 at 0x81ccc000
WASP ----> S27 PHY MDIO
Setting Drop CRC Errors, Pause Frames and Length Error frames
Setting PHY...
athr_gmac_ring_alloc Allocated 640 at 0x81e8d800
athr_gmac_ring_alloc Allocated 2048 at 0x81eba800
Setting PHY...
device eth1 entered promiscuous mode
Now flash open!
athr_gmac_ring_free Freeing at 0x81e8dc00
athr_gmac_ring_free Freeing at 0x81ccc000
athr_gmac_ring_alloc Allocated 2048 at 0x81e9e800
Setting PHY...
nf_conntrack_rtsp v0.6.21 loading
nf_nat_rtsp v0.6.21 loading
asf: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, WRITE_EEPROM, 11D)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
ath_ahb: 9.2.0_U10.1020 (Atheros/multi-bss)
__ath_attach: Set global_scn[0]
ACBKMinfree = 48
ACBEMinfree = 32
ACVIMinfree = 16
ACVOMinfree = 0
CABMinfree = 48
UAPSDMinfree = 0
Restoring Cal data from Flash
ath_get_caps[5124] rx chainmask mismatch actual 3 sc_chainmak 0
ath_get_caps[5099] tx chainmask mismatch actual 3 sc_chainmak 0
wifi0: Atheros 9340: mem=0xb8100000, irq=2
====>>>>SystemMode : Standard AP
wlan_vap_create : enter. devhandle=0x80d402c0, opmode=IEEE80211_M_HOSTAP, flags=0x1
wlan_vap_create : exit. devhandle=0x80d402c0, opmode=IEEE80211_M_HOSTAP, flags=0x1.
VAP device ath0 created
====>>>>wlan: rand channel 11
DES SSID SET=TP-LINK_Extender_2E10EC
ieee80211_ioctl_siwmode: imr.ifm_active=131712, new mode=3, valid=1
ath_vap_up... Ind rpt is set
athr_gmac_ring_free Freeing at 0x81e9e800
br0: port 1(eth1) entering disabled state
athr_gmac_ring_alloc Allocated 2048 at 0x81e9e000
Setting PHY...
device ath0 entered promiscuous mode
br0: port 2(ath0) entering forwarding state
RetCode in regn of misc ev handler 0
VAP device ath2 created
ieee80211_ioctl_siwmode: imr.ifm_active=917632, new mode=2, valid=1
br0: starting userspace STP failed, starting kernel STP
ieee80211_ioctl_siwmode: imr.ifm_active=918144, new mode=3, valid=1
br0: port 2(ath0) entering disabled state
DEVICE IS DOWN ifname=ath0
br0: topology change detected, propagating
====>>>>------------swWlanExtenderStart---------------
====>>>>swWlanExtenderThread
====>>>>create extender thread ok,pid:6151
====>>>>************:DISCONNECT reboot_flag:0 swIsWanConnected(0):0 lanCfg.bLanType:1
====>>>>create ssid thread success, pid:8201
====>>>>create monitorLoop thread success, pid:14351.
====>>>>[monitorLoop:332]monitor pid:655 taskCnt:4
ATHR_GMAC: GE0 RX DMA ENABLE
ath_vap_up... Ind rpt is NOT SET
br0: port 2(ath0) entering forwarding state```
Jako że sprzęt nie różni się zbytnio od WA850RE V1.20 to podmieniłem nagłówek firmware gargoyle aby pasował do WA860RE.
Po wgraniu przez aktualizację oprogramowania w oryginalnym oprogramowaniu system uruchomił się:
```br0: topology change detected, propagating
ath_net80211_rate_node_update... ni_chwidth 1 .. ic_cw-width 1
Now flash open!
Erase from 0X20000 to 0X3E0000:............................................................
Program from 0X20000 to 0X3E0000:............................................................
write successfully
reboot...
====>>>>reboot system from web server.
Restarting system.
U-boot AP123
DRAM: 32 MB
id read 0x100000ff
Flash: 4 MB
In: serial
Out: serial
Err: serial
WASP ----> S27 PHY
s27 reg init
eth0 up
WASP ----> S27 PHY
s27 reg init lan
eth1 up
eth0, eth1
Starting kernel ...
[ 0.000000] Linux version 3.3.8 (cezary@eko.one.pl) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #19 Sat Jun 14 10:29:13 CEST 2014
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 0001974c (MIPS 74Kc)
[ 0.000000] SoC: Atheros AR9341 rev 3
[ 0.000000] Clocks: CPU:535.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 02000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00002000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00002000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: board=TL-WA850RE console=ttyS0,115200 rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 28936k/32768k available (2256k kernel code, 3832k reserved, 425k data, 220k init, 0k highmem)
[ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Calibrating delay loop... 266.64 BogoMIPS (lpj=1333248)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.090000] NET: Registered protocol family 16
[ 0.090000] gpiochip_add: registered GPIOs 0 to 22 on device: ath79
[ 0.100000] MIPS: machine is TP-LINK TL-WA850RE
[ 0.310000] bio: create slab <bio-0> at 0
[ 0.320000] Switching to clocksource MIPS
[ 0.330000] NET: Registered protocol family 2
[ 0.330000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.330000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.340000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.340000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.350000] TCP reno registered
[ 0.350000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.360000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.360000] NET: Registered protocol family 1
[ 0.380000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.390000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.400000] msgmni has been set to 56
[ 0.400000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[ 0.410000] io scheduler noop registered
[ 0.420000] io scheduler deadline registered (default)
[ 0.420000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.450000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
[ 0.460000] console [ttyS0] enabled, bootconsole disabled
[ 0.470000] m25p80 spi0.0: found en25q32b, expected m25p80
[ 0.480000] m25p80 spi0.0: en25q32b (4096 Kbytes)
[ 0.480000] 5 tp-link partitions found on MTD device spi0.0
[ 0.490000] Creating 5 MTD partitions on "spi0.0":
[ 0.500000] 0x000000000000-0x000000020000 : "u-boot"
[ 0.500000] 0x000000020000-0x00000010ef48 : "kernel"
[ 0.510000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[ 0.520000] 0x00000010ef48-0x0000003f0000 : "rootfs"
[ 0.530000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[ 0.540000] mtd: partition "rootfs" set to be root filesystem
[ 0.550000] mtd: partition "rootfs_data" created automatically, ofs=380000, len=70000
[ 0.560000] 0x000000380000-0x0000003f0000 : "rootfs_data"
[ 0.560000] 0x0000003f0000-0x000000400000 : "art"
[ 0.570000] 0x000000020000-0x0000003f0000 : "firmware"
[ 0.600000] ag71xx_mdio: probed
[ 0.600000] eth0: Atheros AG71xx at 0xb9000000, irq 4
[ 1.160000] ag71xx ag71xx.0: eth0: connected to PHY at ag71xx-mdio.1:00 [uid=004dd042, driver=Generic PHY]
[ 1.170000] TCP cubic registered
[ 1.170000] NET: Registered protocol family 17
[ 1.180000] Bridge firewalling registered
[ 1.180000] Ebtables v2.0 registered
[ 1.180000] 8021q: 802.1Q VLAN Support v1.8
[ 1.190000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[ 1.200000] Freeing unused kernel memory: 220k freed
- preinit -
Press the [f] key and hit [enter] to enter failsafe mode
- regular preinit -
jffs2 not ready yet; using ramdisk
- init -
[ 7.040000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[ 7.050000] Backport generated by backports.git backports-20140320-37-g5c33da0
[ 7.200000] cfg80211: Calling CRDA to update world regulatory domain
[ 7.210000] cfg80211: World regulatory domain updated:
[ 7.210000] cfg80211: DFS Master region: unset
[ 7.220000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.230000] cfg80211: (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 7.240000] cfg80211: (5140000 KHz - 5860000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 8.040000] ieee80211 phy0: Atheros AR9340 Rev:0 mem=0xb8100000, irq=47
[ 8.050000] cfg80211: Calling CRDA for country: US
[ 8.050000] cfg80211: Regulatory domain changed to country: US
[ 8.060000] cfg80211: DFS Master region: unset
[ 8.070000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 8.080000] cfg80211: (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 8.080000] cfg80211: (5140000 KHz - 5860000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 8.150000] PPP generic driver version 2.4.2
[ 8.180000] tun: Universal TUN/TAP device driver, 1.6
[ 8.190000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 8.270000] GRE over IPv4 demultiplexor driver
[ 8.290000] ip_gre: Unknown symbol icmpv6_send (err 0)
[ 8.370000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 8.620000] NET: Registered protocol family 24
[ 8.710000] nf_conntrack version 0.5.0 (455 buckets, 1820 max)
[ 8.900000] PPTP driver version 0.8.5
[ 9.330000] xt_time: kernel timezone is -0000
[ 9.930000] Hooked IMQ after mangle on PREROUTING
[ 9.930000] Hooked IMQ after nat on POSTROUTING
[ 9.940000] IMQ driver loaded successfully. (numdevs = 2, numqueues = 1)
[ 10.110000] Netfilter messages via NETLINK v0.30.
[ 10.160000] ip_set: protocol 6
Please press Enter to activate this console. [ 22.890000] device eth0 entered promiscuous mode
BusyBox v1.19.4 (2014-06-14 08:06:10 CEST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
_____ _
| __ \ | |
| | \/ __ _ _ __ __ _ ___ _ _| | ___
| | __ / _` | '__/ _` |/ _ \| | | | |/ _ \
| |_\ \ (_| | | | (_| | (_) | |_| | | __/
\____/\__,_|_| \__, |\___/ \__, |_|\___|
__/ | __/ |
|___/ |___/
| Gargoyle PL 1.6.1.4 (8eab7c6) |
| OpenWrt Attitude Adjustment 12.09.1 (r41182) |
| Build time: 2014-06-14 10:24 CEST |
| Cezary Jackiewicz (obsy), http://eko.one.pl |
[ 28.560000] device wlan0 entered promiscuous mode
| Machine: TP-LINK TL-WA850RE |
| Uptime: 0d, 00:00:28 |
| Load: 0.56 0.13 0.04 |
| Flash: |
| Memory: total: 28.5MB, free: 16.5MB, used: 41% |
| WAN: |
| LAN: 192.168.1.1 |
| WLAN: mode: ap, ssid: Gargoyle, channel: 11, conn: |
root@Gargoyle:/# [ 29.090000] br-lan: port 2(wlan0) entered forwarding state
[ 29.100000] br-lan: port 2(wlan0) entered forwarding state
[ 31.100000] br-lan: port 2(wlan0) entered forwarding state
[ 37.990000] jffs2_scan_eraseblock(): End of filesystem marker found at 0x0
[ 38.010000] jffs2_build_filesystem(): unlocking the mtd device... done.
[ 38.010000] jffs2_build_filesystem(): erasing all blocks after the end marker... done.
[ 40.150000] JFFS2 notice: (2605) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 43.300000] ipt_bandwidth: timezone shift of 60 minutes detected, adjusting
[ 43.310000] old minutes west=0, new minutes west=-60
Teraz trzeba jeszcze pozmieniać we firmware aby były odpowiednio obsługiwane diody.
Diody jakie są na urządzeniu to:
DS0 - Power zielona
DS1 - Power pomarańcz
DS2 - WIFI zielona
DS3 - WIFI pomarańcz
DS4 - LAN zielona
Na tym firmware dobrze działa tylko dioda od portu LAN, dioda DS3 jest sterowana przez tp-link:blue:signal1, dioda DS2 jest sterowana przez tp-link:blue:signal3
Sprzęt ten nie posiada standardowej diody POWER która pali się po podłączeniu sprzętu do zasilania.
Przyciski są 3:
SW4 - RESET
SW5 - WPS
SW6 - On/Off - ten nie rozłącza zasilania
Przyciski Reset i WPS działają. Na SW6 jest brak reakcji.
Od strony LAN i WiFi to wszystko działa jak powinno.
OpenWRT - wydanie testowe:
