Jako że lubię kombinować to chciał bym wgrać do tego Range Extendera wgrać OpenWRT lub coś podobnego.
Procesor: Atheros AR9341-AL1A
Ram: 32MB ( ESMT M13S2561616A )
Flash: 4MB ( SPANSION FL032PIF )
Zdjęcia MB:
Oraz dołączam log uruchomienia:
U-boot AP123
DRAM: 32 MB
id read 0x100000ff
Flash: 4 MB
Using default environment
In: serial
Out: serial
Err: serial
Net: ag934x_enet_initialize...
wasp reset mask:c03300
WASP
----> S27 PHY
GMAC: cfg1 0x5 cfg2 0x7114
eth0: ba:be:fa:ce:08:41
s27 reg init
athrs27_phy_setup ATHR_PHY_CONTROL 4: 0x1000
athrs27_phy_setup ATHR_PHY_SPEC_STAUS 4: 0x10
eth0 up
WASP
----> S27 PHY
GMAC: cfg1 0xf cfg2 0x7214
eth1: ba:be:fa:ce:08:41
s27 reg init lan
ATHRS27: resetting s27
ATHRS27: s27 reset done
athrs27_phy_setup ATHR_PHY_CONTROL 0: 0x1000
athrs27_phy_setup ATHR_PHY_SPEC_STAUS 0: 0x10
athrs27_phy_setup ATHR_PHY_CONTROL 1: 0x1000
athrs27_phy_setup ATHR_PHY_SPEC_STAUS 1: 0x10
athrs27_phy_setup ATHR_PHY_CONTROL 2: 0x1000
athrs27_phy_setup ATHR_PHY_SPEC_STAUS 2: 0x10
athrs27_phy_setup ATHR_PHY_CONTROL 3: 0x1000
athrs27_phy_setup ATHR_PHY_SPEC_STAUS 3: 0x10
eth1 up
eth0, eth1
Autobooting in 1 seconds
## Booting image at 9f020000 ...
Uncompressing Kernel Image ... OK
Starting kernel ...
Booting Atheros AR934x
Linux version 2.6.31--LSDK-9.2.0_U5.508 (root@localhost.localdomain) (gcc versi2
flash_size passed from bootloader = 4
Ram size passed from bootloader =33554432
CPU revision is: 0001974c (MIPS 74Kc)
ath_sys_frequency: cpu srif ddr srif cpu 535 ddr 400 ahb 200
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
Zone PFN ranges:
Normal 0x00000000 -> 0x00002000
Movable zone start PFN for each node
0: 0x00000000 -> 0x00002000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line: console=ttyS0,115200 root=31:2 rootfstype=squashfs init=/sM
PID hash table entries: 128 (order: 7, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=00000000
Readback ErrCtl register=00000000
Memory: 30132k/32768k available (1723k kernel code, 2636k reserved, 425k data, )
NR_IRQS:128
plat_time_init: plat time init done
Calibrating delay loop... 267.26 BogoMIPS (lpj=534528)
bio: create slab <bio-0> at 0
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
ATH GPIOC major 0
squashfs: version 4.0 (2009/01/31) Phillip Lougher
msgmni has been set to 58
io scheduler noop registered
io scheduler deadline registered (default)
Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xb8020000 (irq = 19) is a 16550A
console [ttyS0] enabled
5 cmdlinepart partitions found on MTD device ath-nor0
Creating 5 MTD partitions on "ath-nor0":
0x000000000000-0x000000020000 : "u-boot"
0x000000020000-0x000000120000 : "kernel"
0x000000120000-0x0000003e0000 : "rootfs"
0x0000003e0000-0x0000003f0000 : "config"
0x0000003f0000-0x000000400000 : "art"
->Oops: flash id 0x10215 .
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Port Status 1c000004
ath-ehci ath-ehci.0: ATH EHCI
ath-ehci ath-ehci.0: new USB bus registered, assigned bus number 1
ehci_reset Intialize USB CONTROLLER in host mode: 13
ehci_reset Port Status 1c000000
ath-ehci ath-ehci.0: irq 3, io mem 0x1b000000
ath-ehci ath-ehci.0: USB 2.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
TCP cubic registered
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
athwdt_init: Registering WDT success
ath_otp_init: Registering OTP success
ath_clksw_init: Registering Clock Switch Interface success
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing unused kernel memory: 112k freed
init started: BusyBox v1.01 (2012.09.06-08:33+0000) multi-call binary
This Board use 2.6.31
xt_time: kernel timezone is -0000
nf_conntrack version 0.5.0 (512 buckets, 5120 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
insmod: cannot open module `/lib/modules/2.6.31/kernel/iptable_raw.ko': No suchy
insmod: cannot open module `/lib/modules/2.6.31/kernel/flashid.ko': No such fily
PPPoL2TP kernel driver, V1.0
PPTP driver version 0.8.3
insmod: cannot open module `/lib/modules/2.6.31/kernel/harmony.ko': No such fily
(none) mips #27 Mon Dec 3 15:19:30 CST 2012 (none)
(none) login: Now flash open!
Now flash open!
ATHR_GMAC: Length per segment 1536
ATHR_GMAC: fifo cfg 3 01f00140
ATHR_GMAC: RX TASKLET - Pkts per Intr:32
mac:1 Registering S27....
ATHR_GMAC: Max segments per packet : 1
ATHR_GMAC: Max tx descriptor count : 40
ATHR_GMAC: Max rx descriptor count : 128
ATHR_GMAC: Mac capability flags : 2D82
mac:0 Registering S27....
ATHR_GMAC: Mac capability flags : 2582
athr_gmac_ring_alloc Allocated 640 at 0x81e88c00
athr_gmac_ring_alloc Allocated 2048 at 0x81ccc000
WASP
----> S27 PHY MDIO
Setting Drop CRC Errors, Pause Frames and Length Error frames
Setting PHY...
athr_gmac_ring_alloc Allocated 640 at 0x81e88800
athr_gmac_ring_alloc Allocated 2048 at 0x81e93800
WASP
----> S27 PHY MDIO
++++ athrs27_igmp_setup once
port0 vid is 0xb000b
port1 vid is 0x30003
port2 vid is 0x50005
port3 vid is 0x70007
port4 vid is 0x90009
++ PVID: 0x0000000b, bitmap: 0x0000001f
++ PVID: 0x00000003, bitmap: 0x0000001f
++ PVID: 0x00000005, bitmap: 0x0000001f
++ PVID: 0x00000007, bitmap: 0x0000001f
++ PVID: 0x00000009, bitmap: 0x0000001f
vtable vid: 0x00000002, bitmap 0x00000003
vtable vid: 0x00000004, bitmap 0x00000005
vtable vid: 0x00000006, bitmap 0x00000007
vtable vid: 0x00000008, bitmap 0x00000009
vtable vid: 0x0000000a, bitmap 0x0000000b
vtable vid: 0x0000000c, bitmap 0x0000000d
vtable vid: 0x0000000e, bitmap 0x0000000f
vtable vid: 0x00000010, bitmap 0x00000011
vtable vid: 0x00000012, bitmap 0x00000013
vtable vid: 0x00000014, bitmap 0x00000015
vtable vid: 0x00000016, bitmap 0x00000017
vtable vid: 0x00000018, bitmap 0x00000019
vtable vid: 0x0000001a, bitmap 0x0000001b
vtable vid: 0x0000001c, bitmap 0x0000001d
vtable vid: 0x0000001e, bitmap 0x0000001f
vtable vid: 0x00000020, bitmap 0x00000021
Setting PHY...
device eth1 entered promiscuous mode
Now flash open!
athr_gmac_ring_free Freeing at 0x81e88c00
athr_gmac_ring_free Freeing at 0x81ccc000
athr_gmac_ring_alloc Allocated 2048 at 0x81ea5800
WASP
----> S27 PHY MDIO
Setting PHY...
====>>>>DHCP start.dhcpc.c,dhcpcStart,894
====>>>>DHCP end.dhcpc.c,dhcpcStart,954
nf_conntrack_rtsp v0.6.21 loading
nf_nat_rtsp v0.6.21 loading
asf: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, WRITE_EEPROM, 11D)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Righd
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reservd
ath_ahb: 9.2.0_U10.1020 (Atheros/multi-bss)
__ath_attach: Set global_scn[0]
ACBKMinfree = 48
ACBEMinfree = 32
ACVIMinfree = 16
ACVOMinfree = 0
CABMinfree = 48
UAPSDMinfree = 0
Restoring Cal data from Flash
ath_get_caps[5105] rx chainmask mismatch actual 3 sc_chainmak 0
ath_get_caps[5080] tx chainmask mismatch actual 3 sc_chainmak 0
wifi0: Atheros 9340: mem=0xb8100000, irq=2
====>>>>SystemMode : Standard AP
wlan_vap_create : enter. devhandle=0x81fe42c0, opmode=IEEE80211_M_HOSTAP, flags1
wlan_vap_create : exit. devhandle=0x81fe42c0, opmode=IEEE80211_M_HOSTAP, flags=.
VAP device ath0 created
====>>>>wlan: rand channel 9
DES SSID SET=1234
ieee80211_ioctl_siwmode: imr.ifm_active=131712, new mode=3, valid=1
athr_gmac_ring_free Freeing at 0x81ea5800
br0: port 1(eth1) entering disabled state
athr_gmac_ring_alloc Allocated 2048 at 0x81ea5000
WASP
----> S27 PHY MDIO
Setting PHY...
device ath0 entered promiscuous mode
br0: port 2(ath0) entering forwarding state
ieee80211_ioctl_siwmode: imr.ifm_active=918144, new mode=3, valid=1
br0: port 2(ath0) entering disabled state
DES SSID SET=1234
====>>>>ssss_1352
====>>>>cmdCtrl open success
====>>>>eventCtrl open success
====>>>>Can't attach event ctrl
====>>>>************wps not start ************
====>>>>wlan: rand channel 7
DES SSID SET=1234
athr_gmac_ring_free Freeing at 0x81ea5000
athr_gmac_ring_alloc Allocated 2048 at 0x81ec2800
WASP
----> S27 PHY MDIO
Setting PHY...
DES SSID SET=1234
VAP device ath2 created
ieee80211_ioctl_siwmode: imr.ifm_active=917632, new mode=2, valid=1
device ath2 entered promiscuous mode
br0: port 3(ath2) entering forwarding state
br0: port 3(ath2) entering disabled state
---swWlanExtenderStart
====>>>>swWlanExtenderThread
====>>>>create extender thread ok,pid:4101
====>>>>************:CONNECT,lantype=1
====>>>>create ssid thread success, pid:6151
DES SSID SET=1234
====>>>>DhcpSendMsg.dhcpcSendMsgNow flash open!
,979
Erase from 0X3E0000 to 0X3ED144:.
Program from 0X3E0000 to 0X3ED144:
write successfully
====>>>>ssss_1352
====>>>>lan type detect start.
Now flash open!
write successfully
ATHR_GMAC: GE0 RX DMA ENABLE
====>>>>lan type detect retry.
====>>>>lan type detect ok.
Taki procesor używa też MR3420 V2 który ma obsługę USB. Może dało by się wyprowadzić nawet USB z procesora.
Zanim zacznę go flashować innym softem potrzebował bym orginalny soft ( bez boot w nazwie). Tylko skąd go dostać?
