Jak w temacie posiadam router TP-Link TL-WR1043ND z gargoyle i huawei e5377
mam problem z konfiguracją, tp link nie widzi żadnego mobilnego routera i nie mam już pojęcia jak inaczej próbować
usb w routerze sprawne bo ładuje modem
Pokaż logi systemowe z podłączonym routerem e5377.
nie wiem czy o to chodzi
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.000000] Early memory PFN ranges
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.000000] 0: 0x00000000 -> 0x00004000
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 0.000000] On node 0 totalpages: 16384
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 802fdf20, node_mem_map 81000000
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 0.000000] Normal zone: 128 pages used for memmap
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 0.000000] Normal zone: 16256 pages, LIFO batch:3
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.000000] Kernel command line: board=TL-WR1043ND-v2 console=ttyS0,115200 rootfstype=squashfs,jffs2 noinitrd
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Memory: 61424k/65536k available (2256k kernel code, 4112k reserved, 425k data, 220k init, 0k highmem)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] NR_IRQS:51
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.000000] Calibrating delay loop... 358.80 BogoMIPS (lpj=1794048)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.060000] pid_max: default: 32768 minimum: 301
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.060000] Mount-cache hash table entries: 512
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.070000] NET: Registered protocol family 16
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.070000] gpiochip_add: registered GPIOs 0 to 23 on device: ath79
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.080000] MIPS: machine is TP-LINK TL-WR1043ND v2
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.490000] bio: create slab <bio-0> at 0
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.500000] Switching to clocksource MIPS
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.500000] NET: Registered protocol family 2
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.510000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.510000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.520000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.520000] TCP: Hash tables configured (established 2048 bind 2048)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.530000] TCP reno registered
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.530000] UDP hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.540000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.540000] NET: Registered protocol family 1
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 0.550000] PCI: CLS 0 bytes, default 32
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.560000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.560000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.570000] msgmni has been set to 119
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.580000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.590000] io scheduler noop registered
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.590000] io scheduler deadline registered (default)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.600000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.630000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.630000] console [ttyS0] enabled, bootconsole disabled
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.650000] m25p80 spi0.0: found s25fl064k, expected m25p80
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.650000] m25p80 spi0.0: s25fl064k (8192 Kbytes)
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.660000] 5 tp-link partitions found on MTD device spi0.0
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.660000] Creating 5 MTD partitions on "spi0.0":
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.670000] 0x000000000000-0x000000020000 : "u-boot"
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.670000] 0x000000020000-0x00000010ee8c : "kernel"
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.680000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.690000] 0x00000010ee8c-0x0000007f0000 : "rootfs"
Jan 1 01:00:38 Gargoyle kern.warn kernel: [ 0.700000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.710000] mtd: partition "rootfs" set to be root filesystem
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.720000] mtd: partition "rootfs_data" created automatically, ofs=680000, len=170000
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.730000] 0x000000680000-0x0000007f0000 : "rootfs_data"
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.730000] 0x0000007f0000-0x000000800000 : "art"
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 0.740000] 0x000000020000-0x0000007f0000 : "firmware"
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.890000] ag71xx_mdio: probed
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 0.890000] eth0: Atheros AG71xx at 0xb9000000, irq 4
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 1.470000] eth0: Atheros AR8327 switch driver attached.
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 2.660000] ag71xx ag71xx.0: eth0: connected to PHY at ag71xx-mdio.0:00 [uid=004dd034, driver=Atheros AR8216/AR8236/AR8316]
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 2.670000] eth1: Atheros AG71xx at 0xba000000, irq 5
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 3.220000] TCP cubic registered
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 3.230000] NET: Registered protocol family 17
Jan 1 01:00:38 Gargoyle kern.notice kernel: [ 3.230000] Bridge firewalling registered
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 3.240000] Ebtables v2.0 registered
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 3.240000] 8021q: 802.1Q VLAN Support v1.8
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 3.250000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 3.260000] Freeing unused kernel memory: 220k freed
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 5.190000] Registered led device: tp-link:green:wps
Jan 1 01:00:38 Gargoyle kern.debug kernel: [ 5.190000] Registered led device: tp-link:green:system
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.860000] usbcore: registered new interface driver sierra
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.860000] sierra: v.1.7.40:USB Driver for Sierra Wireless USB modems
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 36.880000] usbcore: registered new interface driver sierra_net
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.040000] usbcore: registered new interface driver cdc_wdm
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.060000] usbcore: registered new interface driver cdc_ether
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.170000] usbcore: registered new interface driver cdc_ncm
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.220000] usbcore: registered new interface driver qmi_wwan
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.240000] usbcore: registered new interface driver rndis_host
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.310000] USB Serial support registered for GSM modem (1-port)
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.310000] usbcore: registered new interface driver option
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.320000] option: v0.7.2:USB Driver for GSM modems
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.340000] USB Serial support registered for Qualcomm USB modem
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.340000] usbcore: registered new interface driver qcserial
Jan 1 01:00:38 Gargoyle kern.info kernel: [ 37.440000] fuse init (API version 7.18)
Jan 1 01:00:42 Gargoyle kern.info kernel: [ 42.590000] eth1: link up (1000Mbps/Full duplex)
Jan 1 01:00:42 Gargoyle kern.info kernel: [ 42.600000] device eth1 entered promiscuous mode
Jan 1 01:00:42 Gargoyle kern.info kernel: [ 42.610000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:00:42 Gargoyle daemon.notice netifd: Interface 'lan' is now up
Jan 1 01:00:42 Gargoyle daemon.notice netifd: Interface 'loopback' is now up
Jan 1 01:00:42 Gargoyle kern.info kernel: [ 42.620000] ADDRCONF(NETDEV_UP): eth0: link is not ready
Jan 1 01:00:42 Gargoyle daemon.notice netifd: wan (977): udhcpc (v1.19.4) started
Jan 1 01:00:42 Gargoyle user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Jan 1 01:00:42 Gargoyle daemon.notice netifd: wan (977): Sending discover...
Jan 1 01:00:43 Gargoyle kern.info kernel: [ 43.920000] eth0: link up (1000Mbps/Full duplex)
Jan 1 01:00:43 Gargoyle kern.info kernel: [ 43.930000] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jan 1 01:00:44 Gargoyle kern.info kernel: [ 44.610000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:00:45 Gargoyle user.notice usb-modeswitch: 1-0:1.0: Manufacturer=Linux_3.3.8_ehci_hcd Product=Generic_Platform_EHCI_Controller Serial=ehci-platform.0
Jan 1 01:00:45 Gargoyle daemon.notice netifd: wan (977): Sending discover...
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.070000] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.080000] device wlan0 entered promiscuous mode
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.240000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.250000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.260000] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Jan 1 01:00:48 Gargoyle daemon.notice netifd: wan (977): Sending discover...
Jan 1 01:00:50 Gargoyle kern.info kernel: [ 50.250000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 02:08:39 Gargoyle user.notice usb-modeswitch: 2-0:1.0: Manufacturer=Linux_3.3.8_ehci_hcd Product=Generic_Platform_EHCI_Controller Serial=ehci-platform.1
Jan 1 02:08:40 Gargoyle authpriv.info dropbear[1329]: Running in background
Jan 1 02:08:40 Gargoyle daemon.crit httpd_gargoyle[1367]: bind 0.0.0.0 - Address already in use
Jan 1 02:08:40 Gargoyle daemon.warn httpd_gargoyle[1373]: started as root without requesting chroot(), warning only
Jan 1 02:08:40 Gargoyle daemon.notice httpd_gargoyle[1373]: httpd_gargoyle/1.0 14mar2008 starting on Gargoyle, port 80
Jan 1 02:08:40 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=0123456789ABCDEF
Jan 1 02:08:42 Gargoyle user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Jan 1 02:08:42 Gargoyle user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Jan 1 02:08:42 Gargoyle user.notice dnsmasq: Allowing RFC1918 responses for domain free.aero2.net.pl
Jan 1 02:08:45 Gargoyle daemon.info dnsmasq[1778]: started, version 2.66 cachesize 150
Jan 1 02:08:45 Gargoyle daemon.info dnsmasq[1778]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan 1 02:08:45 Gargoyle daemon.info dnsmasq-dhcp[1778]: DHCP, IP range 192.168.2.100 -- 192.168.2.249, lease time 12h
Jan 1 02:08:45 Gargoyle daemon.info dnsmasq[1778]: using local addresses only for domain lan
Jan 1 02:08:45 Gargoyle daemon.info dnsmasq[1778]: reading /tmp/resolv.conf.auto
Jan 1 02:08:45 Gargoyle daemon.warn dnsmasq[1778]: ignoring nameserver 192.168.2.1 - local interface
Jan 1 02:08:45 Gargoyle daemon.info dnsmasq[1778]: read /etc/hosts - 2 addresses
Jan 1 02:08:45 Gargoyle daemon.info dnsmasq-dhcp[1778]: read /etc/ethers - 0 addresses
Jan 1 02:08:45 Gargoyle user.err syslog: error starting threads: errno 89 (Function not implemented)
Jan 1 02:08:45 Gargoyle user.info sysinit: exportfs: could not open /var/lib/nfs/.etab.lock for locking: errno 2 (No such file or directory)
Jan 1 02:08:45 Gargoyle user.info sysinit: exportfs: can't lock /var/lib/nfs/etab for writing
Jan 1 02:08:45 Gargoyle user.info sysinit: exportfs: could not open /var/lib/nfs/.xtab.lock for locking: errno 2 (No such file or directory)
Jan 1 02:08:45 Gargoyle user.info sysinit: exportfs: can't lock /var/lib/nfs/xtab for writing
Jan 1 02:08:47 Gargoyle user.info sysinit: ERROR: No valid dynamic DNS service configurations defined
Jan 1 02:08:47 Gargoyle user.info sysinit: (Did you specify correct configuration file path?)
Jan 1 02:09:12 Gargoyle user.notice root: vsftpd init: mounted = 0
Jan 1 02:09:12 Gargoyle user.info sysinit: ERROR: No drives attached, no directories to share!
Jan 1 02:09:12 Gargoyle user.info sysinit: setting up led USB
Jan 1 02:09:12 Gargoyle user.info sysinit: setting up led WLAN
Jan 1 02:09:36 Gargoyle daemon.info hostapd: wlan0: STA 94:65:9c:5c:7b:b9 IEEE 802.11: authenticated
Jan 1 02:09:36 Gargoyle daemon.info hostapd: wlan0: STA 94:65:9c:5c:7b:b9 IEEE 802.11: associated (aid 1)
Jan 1 02:09:36 Gargoyle daemon.info hostapd: wlan0: STA 94:65:9c:5c:7b:b9 WPA: pairwise key handshake completed (WPA)
Jan 1 02:09:36 Gargoyle daemon.info hostapd: wlan0: STA 94:65:9c:5c:7b:b9 WPA: group key handshake completed (WPA)
Jan 1 02:09:36 Gargoyle daemon.info dnsmasq-dhcp[1778]: DHCPREQUEST(br-lan) 192.168.2.207 94:65:9c:5c:7b:b9
Jan 1 02:09:36 Gargoyle daemon.warn dnsmasq-dhcp[1778]: Ignoring domain S2.MS.UNILEVER.com for DHCP host name KCBLW827YVZ52
Jan 1 02:09:36 Gargoyle daemon.info dnsmasq-dhcp[1778]: DHCPACK(br-lan) 192.168.2.207 94:65:9c:5c:7b:b9 KCBLW827YVZ52
Jan 1 02:09:40 Gargoyle daemon.info dnsmasq-dhcp[1778]: DHCPINFORM(br-lan) 192.168.2.207 94:65:9c:5c:7b:b9
Jan 1 02:09:40 Gargoyle daemon.info dnsmasq-dhcp[1778]: DHCPACK(br-lan) 192.168.2.207 94:65:9c:5c:7b:b9 KCBLW827YVZ52
Success
Spróbuj na eth0 lub eth1. Czyli /dev/tty/eth0 lub /dev/tty/eth1.
Nie znaleziono urządzeń.
Ok. ustaw tak jak było czyli usb0 zapisz i zastosuj. Wyłącz router i ponownie włacz.
Co masz jeszcze w zakładce połączenie? Nie lepiej wgrać Open Wrt Chaos Calmer? Jak byś wgrał to bardziej pomogę ci w tym niż w Gargulcu. Tego WR-a masz wersję V2 ja mam V3 na pokładzie z Chaos Calmer w wersji PL.
http://dl.eko.one.pl/luci/chaos_calmer/ar71xx/luci-15.05-ar71xx-generic-tl-wr1043nd-v2-squashfs-factory.bin link do pobrania.
doradzono mi żeby instalować gargoyle
Przepraszam, ta druga opcja zaznaczona na ss na niebiesko działa.
Zaloguj się po SSH ( za pomocą putty) i wydaj polecenie:
usb_modeswitch -v 12d1 -p 1f02 -M
Teraz przejdź do konfiguracji - podstawowa
Wybierz połączenie WAN na DHCP(kablowe)
Interfejs WAN na eth2
zapisz ustawienia i powinno działać
Jeśli zadziała to trzeba będzie dodać tą linię aby się "sama" wpisywała.
Sprawa już generalnie rozwiązana.
