Tp link mr 3220 v1 i huawei e3131 problem
(grzechu297792) #1
Witam, posiadam router tp link mr 3220 v1 i modem huawei e3131 który nie łączy się z siecią po podłączeniu go do routera, przez hub aktywny jest to samo. Do najbliższego BTS-a mam około 50 km . Modem i łączy sie z siecią po bezpośrednim podłączeniu do laptopa. Być może trzeba coś skonfigurować w routerze. Ja nie znam sie na tych sprawach, poniżej podaję logi z routera , z aktywnym hubem
Index	Time	Type	Level	Log Content
69	1st day 00:14:29	DHCP	NOTICE	DHCPS:Recv INFORM from 00:22:43:4C:44:18
68	1st day 00:14:26	DHCP	NOTICE	DHCPS:Send ACK to 192.168.1.101
67	1st day 00:14:26	DHCP	NOTICE	DHCPS:Recv REQUEST from 00:22:43:4C:44:18
66	1st day 00:09:46	DHCP	NOTICE	DHCPS:Recv INFORM from 00:22:43:4C:44:18
65	1st day 00:09:42	DHCP	NOTICE	DHCPS:Send ACK to 192.168.1.101
64	1st day 00:09:42	DHCP	NOTICE	DHCPS:Recv REQUEST from 00:22:43:4C:44:18
63	1st day 00:09:42	DHCP	NOTICE	DHCPS:Send OFFER with ip 192.168.1.101
62	1st day 00:09:41	DHCP	NOTICE	DHCPS:Recv DISCOVER from 00:22:43:4C:44:18
61	1st day 00:08:10	DHCP	NOTICE	DHCPS:Recv INFORM from 00:23:54:5D:77:1C
60	1st day 00:08:10	DHCP	NOTICE	DHCPS:Send ACK to 192.168.1.100
59	1st day 00:08:10	DHCP	NOTICE	DHCPS:Recv REQUEST from 00:23:54:5D:77:1C
58	1st day 00:08:10	3G	NOTICE	Line 1444 : The command file /etc/usb_modeswitch.d/12d1_15ca not found.
57	1st day 00:08:10	3G	NOTICE	Switch 3G modem mode with the command file: /etc/usb_modeswitch.d/12d1_15ca
56	1st day 00:08:10	3G	INFO	Line 264: Switch 3G modem mode failed
55	1st day 00:08:09	3G	INFO	3G Modem vendorID: 0x12d1; productID: 0x15ca
54	1st day 00:08:09	3G	INFO	3G Modem vendorID: 0x1a40; productID: 0x0101
53	1st day 00:08:08	3G	INFO	3G Modem vendorID: 0x12d1; productID: 0x15ca
52	1st day 00:08:08	3G	INFO	3G Modem vendorID: 0x1a40; productID: 0x0101
51	1st day 00:08:02	3G	INFO	3G Modem vendorID: 0x12d1; productID: 0x15ca
50	1st day 00:08:02	3G	INFO	3G Modem vendorID: 0x1a40; productID: 0x0101
49	1st day 00:08:01	3G	INFO	3G Modem vendorID: 0x12d1; productID: 0x15ca
48	1st day 00:08:01	3G	INFO	3G Modem vendorID: 0x1a40; productID: 0x0101
47	1st day 00:08:01	3G	INFO	3G Modem vendorID: 0x12d1; productID: 0x15ca
46	1st day 00:08:01	3G	INFO	3G Modem vendorID: 0x1a40; productID: 0x0101
45	1st day 00:08:01	3G	INFO	3G Modem vendorID: 0x12d1; productID: 0x15ca
44	1st day 00:08:01	3G	INFO	3G Modem vendorID: 0x1a40; productID: 0x0101
43	1st day 00:02:07	DHCP	NOTICE	DHCPS:Recv INFORM from 00:23:54:5D:77:1C
42	1st day 00:00:39	3G	NOTICE	Line 1444 : The command file /etc/usb_modeswitch.d/12d1_15ca not found.
41	1st day 00:00:39	3G	NOTICE	Switch 3G modem mode with the command file: /etc/usb_modeswitch.d/12d1_15ca
40	1st day 00:00:39	3G	INFO	Line 264: Switch 3G modem mode failed
Time = 2000-01-01 0:14:48 889s
H-Ver = MR3220 v1 00000000 : S-Ver = 3.12.19 Build 110617 Rel.39329n
L = 192.168.1.1 : M = 255.255.255.0
3G : 3G = 0.0.0.0 : M = 0.0.0.0 : G = 0.0.0.0
(Marcin) #2
http://www.tp-link.com.pl/Resources/software/TL-MR3220_V1.0_121123.zip - w pierwszej kolejności zrób aktualizację oprogramowania do najnowszej dostępnej wersji.
Widać że router ma jakiś problem z poprawnym odczytaniem modemu
(Heinz) #3
Modem nie jest obsługiwany w tym oprogramowaniu lub w ogóle nie wspierany przez ten router.
Zostaje spróbować Gargoyle 1.6.2.2 ze strony eko.one.pl
(grzechu297792) #4
wgrałem gargoyle ale tam wogóle nie widzi modemu
(Heinz) #5
pokaż co menu system - log systemowy pokazuje
(grzechu297792) #6
w gargoyle ?
(Heinz) #7
Oczywiście. wg tego potem będziemy mogli ustawić połączenie i będzie widać czy modem jest rozpoznawany.
(grzechu297792) #8
teraz nawet nie mogę wejść na stronę routera, witryna jest nieosiągalna
(grzechu297792) #9
dobra mam, w którym miejscu szukać logów w tym FM ?
(Heinz) #10
w menu po lewej stronie. Masz System - log systemowy
(grzechu297792) #11
ogarnąłem , modem wykrywa ale nie łączy podaję logi
Jan  1 01:00:02 Gargoyle kern.notice kernel: [    0.790000] 0x00000010b600-0x0000003f0000 : "rootfs"
Jan  1 01:00:02 Gargoyle kern.info kernel: [   13.710000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
Jan  1 01:00:02 Gargoyle kern.info kernel: [   13.710000] hub 1-0:1.0: USB hub found
Jan  1 01:00:02 Gargoyle kern.info kernel: [   13.720000] hub 1-0:1.0: 1 port detected
Jan  1 01:00:02 Gargoyle kern.info kernel: [   13.830000] nf_conntrack version 0.5.0 (456 buckets, 1824 max)
Jan  1 01:00:02 Gargoyle kern.info kernel: [   14.110000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Jan  1 01:00:02 Gargoyle kern.info kernel: [   14.630000] xt_time: kernel timezone is -0000
Jan  1 01:00:02 Gargoyle kern.info kernel: [   15.400000] 	Hooked IMQ after mangle on PREROUTING
Jan  1 01:00:02 Gargoyle kern.info kernel: [   15.410000] 	Hooked IMQ after nat on POSTROUTING
Jan  1 01:00:02 Gargoyle kern.info kernel: [   15.410000] IMQ driver loaded successfully. (numdevs = 2, numqueues = 1)
Jan  1 01:00:02 Gargoyle kern.info kernel: [   15.530000] Netfilter messages via NETLINK v0.30.
Jan  1 01:00:02 Gargoyle kern.notice kernel: [   15.560000] ip_set: protocol 6
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.150000] usbcore: registered new interface driver cdc_acm
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.160000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.290000] usbcore: registered new interface driver usbserial
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.300000] USB Serial support registered for generic
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.300000] usbcore: registered new interface driver usbserial_generic
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.310000] usbserial: USB Serial Driver core
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.440000] Initializing USB Mass Storage driver...
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.450000] scsi0 : usb-storage 1-1:1.0
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.450000] usbcore: registered new interface driver usb-storage
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.460000] USB Mass Storage support registered.
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.480000] usbcore: registered new interface driver cdc_ether
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.530000] usbcore: registered new interface driver cdc_ncm
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.640000] USB Serial support registered for GSM modem (1-port)
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.640000] usbcore: registered new interface driver option
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.650000] option: v0.7.2:USB Driver for GSM modems
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.780000] USB Serial support registered for Sierra USB modem
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.780000] usbcore: registered new interface driver sierra
Jan  1 01:00:02 Gargoyle kern.info kernel: [   16.790000] sierra: v.1.7.16:USB Driver for Sierra Wireless USB modems
Jan  1 01:00:02 Gargoyle kern.notice kernel: [   17.460000] scsi 0:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
Jan  1 01:00:02 Gargoyle kern.notice kernel: [   17.470000] scsi 0:0:0:1: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
Jan  1 01:00:02 Gargoyle kern.notice kernel: [   17.490000] sd 0:0:0:1: [sda] Attached SCSI removable disk
Jan  1 01:00:05 Gargoyle user.notice usb-modeswitch: 1-0:1.0: Manufacturer=Linux_3.3.8_ehci_hcd Product=Generic_Platform_EHCI_Controller Serial=ehci-platform
Jan  1 01:00:05 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=FFFFFFFFFFFFFFFF
Jan  1 01:00:05 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Selecting /etc/usb_modeswitch.d/12d1:15ca for mode switching
Jan  1 01:00:06 Gargoyle syslog.notice usb_modeswitch: switch device 12d1:15ca on 001/002
Jan  1 01:00:06 Gargoyle kern.warn kernel: [   25.250000] usb 1-1: usbfs: process 1025 (usb_modeswitch) did not claim interface 0 before use
Jan  1 01:00:06 Gargoyle kern.info kernel: [   25.320000] usb 1-1: USB disconnect, device number 2
Jan  1 01:00:07 Gargoyle kern.info kernel: [   26.210000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Jan  1 01:00:07 Gargoyle kern.info kernel: [   26.710000] option 1-1:1.0: GSM modem (1-port) converter detected
Jan  1 01:00:07 Gargoyle kern.info kernel: [   26.720000] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Jan  1 01:00:07 Gargoyle kern.info kernel: [   26.770000] usb 1-1: MAC-Address: 0x00:0x1e:0x10:0x1f:0x00:0x00
Jan  1 01:00:07 Gargoyle kern.info kernel: [   26.780000] cdc_ncm 1-1:1.1: wwan0: register 'cdc_ncm' at usb-ehci-platform-1, Mobile Broadband Network Device, 00:1e:10:1f:00:00
Jan  1 01:00:07 Gargoyle kern.info kernel: [   26.790000] option 1-1:1.2: GSM modem (1-port) converter detected
Jan  1 01:00:07 Gargoyle kern.info kernel: [   26.790000] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Jan  1 01:00:07 Gargoyle kern.info kernel: [   26.800000] option 1-1:1.3: GSM modem (1-port) converter detected
Jan  1 01:00:07 Gargoyle kern.info kernel: [   26.810000] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
Jan  1 01:00:07 Gargoyle kern.info kernel: [   26.830000] scsi1 : usb-storage 1-1:1.4
Jan  1 01:00:07 Gargoyle kern.info kernel: [   26.830000] scsi2 : usb-storage 1-1:1.5
Jan  1 01:00:08 Gargoyle kern.notice kernel: [   27.840000] scsi 1:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
Jan  1 01:00:08 Gargoyle kern.notice kernel: [   27.850000] scsi 2:0:0:0: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
Jan  1 01:00:08 Gargoyle kern.notice kernel: [   27.860000] sd 2:0:0:0: [sda] Attached SCSI removable disk
Jan  1 01:00:09 Gargoyle kern.info kernel: [   28.140000] device eth0 entered promiscuous mode
Jan  1 01:00:09 Gargoyle daemon.notice netifd: Interface 'lan' is now up
Jan  1 01:00:09 Gargoyle daemon.notice netifd: Interface 'loopback' is now up
Jan  1 01:00:09 Gargoyle daemon.notice netifd: wan (1116): udhcpc (v1.19.4) started
Jan  1 01:00:09 Gargoyle user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Jan  1 01:00:09 Gargoyle daemon.notice netifd: wan (1116): Sending discover...
Jan  1 01:00:10 Gargoyle kern.info kernel: [   29.240000] eth0: link up (1000Mbps/Full duplex)
Jan  1 01:00:10 Gargoyle kern.info kernel: [   29.240000] br-lan: port 1(eth0) entered forwarding state
Jan  1 01:00:10 Gargoyle kern.info kernel: [   29.250000] br-lan: port 1(eth0) entered forwarding state
Jan  1 01:00:12 Gargoyle user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Jan  1 01:00:12 Gargoyle user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Jan  1 01:00:12 Gargoyle user.notice dnsmasq: Allowing RFC1918 responses for domain free.aero2.net.pl
Jan  1 01:00:12 Gargoyle kern.info kernel: [   31.250000] br-lan: port 1(eth0) entered forwarding state
Jan  1 01:00:12 Gargoyle daemon.notice netifd: wan (1116): Sending discover...
Jan  1 01:00:15 Gargoyle kern.info kernel: [   34.580000] device wlan0 entered promiscuous mode
Jan  1 01:00:15 Gargoyle daemon.notice netifd: wan (1116): Sending discover...
Jan  1 01:00:15 Gargoyle daemon.info dnsmasq[1544]: started, version 2.66 cachesize 150
Jan  1 01:00:15 Gargoyle daemon.info dnsmasq[1544]: compile time options: no-IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan  1 01:00:15 Gargoyle daemon.info dnsmasq-dhcp[1544]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Jan  1 01:00:15 Gargoyle daemon.info dnsmasq[1544]: using local addresses only for domain lan
Jan  1 01:00:15 Gargoyle daemon.warn dnsmasq[1544]: no servers found in /tmp/resolv.conf.auto, will retry
Jan  1 01:00:15 Gargoyle daemon.info dnsmasq[1544]: read /etc/hosts - 2 addresses
Jan  1 01:00:15 Gargoyle daemon.info dnsmasq-dhcp[1544]: read /etc/ethers - 0 addresses
Jan  1 01:00:16 Gargoyle kern.info kernel: [   35.420000] br-lan: port 2(wlan0) entered forwarding state
Jan  1 01:00:16 Gargoyle kern.info kernel: [   35.430000] br-lan: port 2(wlan0) entered forwarding state
Jan  1 01:00:18 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Jan  1 01:00:18 Gargoyle kern.info kernel: [   37.430000] br-lan: port 2(wlan0) entered forwarding state
Jan  1 01:00:18 Gargoyle user.notice usb-modeswitch: 1-1:1.1: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Jan  1 01:00:18 Gargoyle user.notice usb-modeswitch: 1-1:1.2: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Jan  1 01:00:19 Gargoyle user.notice usb-modeswitch: 1-1:1.3: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Jan  1 01:00:01 Gargoyle user.notice usb-modeswitch: 1-1:1.4: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Jan  1 01:00:01 Gargoyle user.notice usb-modeswitch: 1-1:1.5: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Jan  1 01:00:02 Gargoyle daemon.warn httpd_gargoyle[1901]: started as root without requesting chroot(), warning only
Jan  1 01:00:02 Gargoyle daemon.notice httpd_gargoyle[1901]: httpd_gargoyle/1.0 14mar2008 starting on Gargoyle, port 80
Jan  1 01:00:04 Gargoyle user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Jan  1 01:00:04 Gargoyle user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Jan  1 01:00:04 Gargoyle user.notice dnsmasq: Allowing RFC1918 responses for domain free.aero2.net.pl
Jan  1 01:00:05 Gargoyle daemon.info dnsmasq-dhcp[1544]: DHCPREQUEST(br-lan) 192.168.1.232 00:23:54:5d:77:1c
Jan  1 01:00:05 Gargoyle daemon.info dnsmasq-dhcp[1544]: DHCPACK(br-lan) 192.168.1.232 00:23:54:5d:77:1c Grzesiu
Jan  1 01:00:08 Gargoyle user.info sysinit: ERROR: No valid dynamic DNS service configurations defined
Jan  1 01:00:08 Gargoyle user.info sysinit: (Did you specify correct configuration file path?)
Jan  1 01:00:08 Gargoyle kern.warn kernel: [   46.420000] jffs2_scan_eraseblock(): End of filesystem marker found at 0x0
Jan  1 01:00:08 Gargoyle kern.warn kernel: [   46.440000] jffs2_build_filesystem(): unlocking the mtd device... done.
Jan  1 01:00:09 Gargoyle daemon.info dnsmasq-dhcp[1544]: DHCPINFORM(br-lan) 192.168.1.232 00:23:54:5d:77:1c
Jan  1 01:00:09 Gargoyle daemon.info dnsmasq-dhcp[1544]: DHCPACK(br-lan) 192.168.1.232 00:23:54:5d:77:1c Grzesiu
Jan  1 01:00:10 Gargoyle kern.warn kernel: [   46.440000] jffs2_build_filesystem(): erasing all blocks after the end marker... done.
Jan  1 01:00:10 Gargoyle kern.notice kernel: [   47.880000] JFFS2 notice: (1974) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Jan  1 01:00:11 Gargoyle user.info sysinit: copying files ... done
Jan  1 01:00:12 Gargoyle user.info sysinit: setting up led USB
Jan  1 01:00:22 Gargoyle authpriv.info dropbear[2102]: Running in background
Jan  1 01:01:16 Gargoyle daemon.info dnsmasq-dhcp[1544]: DHCPINFORM(br-lan) 192.168.1.232 00:23:54:5d:77:1c
Jan  1 01:01:16 Gargoyle daemon.info dnsmasq-dhcp[1544]: DHCPACK(br-lan) 192.168.1.232 00:23:54:5d:77:1c Grzesiu
Jan  1 01:03:16 Gargoyle kern.info kernel: [  233.700000] usb 1-1: USB disconnect, device number 3
Jan  1 01:03:16 Gargoyle kern.err kernel: [  233.700000] option: option_instat_callback: error -143
Jan  1 01:03:16 Gargoyle kern.info kernel: [  233.710000] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Jan  1 01:03:16 Gargoyle kern.info kernel: [  233.720000] option 1-1:1.0: device disconnected
Jan  1 01:03:16 Gargoyle kern.info kernel: [  233.720000] cdc_ncm 1-1:1.1: wwan0: unregister 'cdc_ncm' usb-ehci-platform-1, Mobile Broadband Network Device
Jan  1 01:03:16 Gargoyle kern.info kernel: [  233.740000] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Jan  1 01:03:16 Gargoyle kern.info kernel: [  233.740000] option 1-1:1.2: device disconnected
Jan  1 01:03:16 Gargoyle kern.info kernel: [  233.750000] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Jan  1 01:03:16 Gargoyle kern.info kernel: [  233.760000] option 1-1:1.3: device disconnected
Jan  1 01:03:20 Gargoyle kern.info kernel: [  238.030000] usb 1-1: new high-speed USB device number 4 using ehci-platform
Jan  1 01:03:20 Gargoyle kern.info kernel: [  238.180000] hub 1-1:1.0: USB hub found
Jan  1 01:03:20 Gargoyle kern.info kernel: [  238.180000] hub 1-1:1.0: 4 ports detected
Jan  1 01:03:20 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=? Product=USB_2.0_Hub Serial=?
Jan  1 01:03:24 Gargoyle daemon.info dnsmasq-dhcp[1544]: DHCPINFORM(br-lan) 192.168.1.232 00:23:54:5d:77:1c
Jan  1 01:03:24 Gargoyle daemon.info dnsmasq-dhcp[1544]: DHCPACK(br-lan) 192.168.1.232 00:23:54:5d:77:1c Grzesiu
Jan  1 01:03:28 Gargoyle kern.info kernel: [  245.620000] usb 1-1.1: new high-speed USB device number 5 using ehci-platform
Jan  1 01:03:28 Gargoyle kern.info kernel: [  245.820000] scsi3 : usb-storage 1-1.1:1.0
Jan  1 01:03:28 Gargoyle user.notice usb-modeswitch: 1-1.1:1.0: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=FFFFFFFFFFFFFFFF
Jan  1 01:03:28 Gargoyle user.notice usb-modeswitch: 1-1.1:1.0: Selecting /etc/usb_modeswitch.d/12d1:15ca for mode switching
Jan  1 01:03:28 Gargoyle syslog.notice usb_modeswitch: switch device 12d1:15ca on 001/005
Jan  1 01:03:28 Gargoyle kern.warn kernel: [  245.930000] usb 1-1.1: usbfs: process 2812 (usb_modeswitch) did not claim interface 0 before use
Jan  1 01:03:28 Gargoyle kern.info kernel: [  246.150000] usb 1-1.1: USB disconnect, device number 5
Jan  1 01:03:29 Gargoyle kern.info kernel: [  247.150000] usb 1-1.1: new high-speed USB device number 6 using ehci-platform
Jan  1 01:03:30 Gargoyle kern.info kernel: [  247.630000] option 1-1.1:1.0: GSM modem (1-port) converter detected
Jan  1 01:03:30 Gargoyle kern.info kernel: [  247.640000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
Jan  1 01:03:30 Gargoyle kern.info kernel: [  247.690000] usb 1-1.1: MAC-Address: 0x00:0x1e:0x10:0x1f:0x00:0x00
Jan  1 01:03:30 Gargoyle kern.info kernel: [  247.700000] cdc_ncm 1-1.1:1.1: wwan0: register 'cdc_ncm' at usb-ehci-platform-1.1, Mobile Broadband Network Device, 00:1e:10:1f:00:00
Jan  1 01:03:30 Gargoyle kern.info kernel: [  247.710000] option 1-1.1:1.2: GSM modem (1-port) converter detected
Jan  1 01:03:30 Gargoyle kern.info kernel: [  247.710000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB1
Jan  1 01:03:30 Gargoyle kern.info kernel: [  247.720000] option 1-1.1:1.3: GSM modem (1-port) converter detected
Jan  1 01:03:30 Gargoyle kern.info kernel: [  247.730000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
Jan  1 01:03:30 Gargoyle kern.info kernel: [  247.740000] scsi4 : usb-storage 1-1.1:1.4
Jan  1 01:03:30 Gargoyle kern.info kernel: [  247.740000] scsi5 : usb-storage 1-1.1:1.5
Jan  1 01:03:30 Gargoyle user.notice usb-modeswitch: 1-1.1:1.0: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Jan  1 01:03:31 Gargoyle user.notice usb-modeswitch: 1-1.1:1.1: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Jan  1 01:03:31 Gargoyle kern.notice kernel: [  248.750000] scsi 4:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
Jan  1 01:03:31 Gargoyle kern.notice kernel: [  248.760000] scsi 5:0:0:0: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
Jan  1 01:03:31 Gargoyle kern.notice kernel: [  248.770000] sd 5:0:0:0: [sda] Attached SCSI removable disk
Jan  1 01:03:31 Gargoyle user.notice usb-modeswitch: 1-1.1:1.2: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Jan  1 01:03:31 Gargoyle user.notice usb-modeswitch: 1-1.1:1.3: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Jan  1 01:03:31 Gargoyle user.notice usb-modeswitch: 1-1.1:1.4: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Jan  1 01:03:31 Gargoyle user.notice usb-modeswitch: 1-1.1:1.5: Manufacturer=HUAWEI Product=HUAWEI_Mobile Serial=?
Success
(Heinz) #12
Modem ładnie wykryty.
Konfiguracja jak w temacie:
(grzechu297792) #13
działa połączyło :smiley: dziękuję i jeszcze jakby można było prosić o spolszczenie czy coś w tym stylu bo mam po angielsku ?
(Heinz) #14
http://dl.eko.one.pl/gargoyle-pl/attitude_adjustment/ar71xx/gargoyle-1.6.2.2-ar71xx-tl-mr3220-v1-squashfs-sysupgrade.bin
to jest po polsku
