WItam.
Proszę o pomoc w skonfigurowaniu, modem E3272 w komputerze działa za każdym razem w routerze co któryś raz dioda na modemie świeci na niebiesko ale router nie widzi modemu
Modem dołączony do routera przez aktywny hub
Ustawienia i logi:
Jan 1 01:00:36 Gargoyle syslog.info syslogd started: BusyBox v1.19.4
Jan 1 01:00:36 Gargoyle kern.notice kernel: klogd started: BusyBox v1.19.4 (2014-02-15 08:41:58 CET)
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.000000] Linux version 3.3.8 (cezary@eko.one.pl) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #41 Sat Feb 15 08:47:58 CET 2014
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] bootconsole [early0] enabled
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] CPU revision is: 0001974c (MIPS 74Kc)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] SoC: Atheros AR9341 rev 1
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Clocks: CPU:535.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Determined physical RAM map:
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] memory: 02000000 @ 00000000 (usable)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Zone PFN ranges:
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Normal 0x00000000 -> 0x00002000
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Movable zone start PFN for each node
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Early memory PFN ranges
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] 0: 0x00000000 -> 0x00002000
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] On node 0 totalpages: 8192
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 802ed700, node_mem_map 81000000
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] Normal zone: 64 pages used for memmap
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] Normal zone: 8128 pages, LIFO batch:0
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.000000] Kernel command line: board=TL-MR3420-v2 console=ttyS0,115200 rootfstype=squashfs,jffs2 noinitrd
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Memory: 29044k/32768k available (2224k kernel code, 3724k reserved, 391k data, 184k init, 0k highmem)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] NR_IRQS:51
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Calibrating delay loop... 266.64 BogoMIPS (lpj=1333248)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.080000] pid_max: default: 32768 minimum: 301
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.080000] Mount-cache hash table entries: 512
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.090000] NET: Registered protocol family 16
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.090000] gpiochip_add: registered GPIOs 0 to 22 on device: ath79
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.100000] MIPS: machine is TP-LINK TL-MR3420 v2
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.510000] bio: create slab <bio-0> at 0
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.520000] Switching to clocksource MIPS
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.530000] NET: Registered protocol family 2
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.530000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.530000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.540000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.540000] TCP: Hash tables configured (established 1024 bind 1024)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.550000] TCP reno registered
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.550000] UDP hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.560000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.560000] NET: Registered protocol family 1
Jan 1 01:00:37 Gargoyle kern.debug kernel: [ 0.570000] PCI: CLS 0 bytes, default 32
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.580000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.590000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.600000] msgmni has been set to 56
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.600000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.610000] io scheduler noop registered
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.620000] io scheduler deadline registered (default)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.620000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.650000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.660000] console [ttyS0] enabled, bootconsole disabled
Jan 1 01:00:37 Gargoyle kern.warn kernel: [ 0.670000] m25p80 spi0.0: found s25sl032a, expected m25p80
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 0.680000] m25p80 spi0.0: s25sl032a (4096 Kbytes)
Jan 1 01:00:37 Gargoyle kern.notice kernel: [ 0.680000] 5 tp-link partitions found on MTD device spi0.0
Jan 1 01:00:37 Gargoyle kern.notice kernel: [ 0.690000] Creating 5 MTD partitions on "spi0.0":
Jan 1 01:00:37 Gargoyle kern.notice kernel: [ 0.690000] 0x000000000000-0x000000020000 : "u-boot"
Jan 1 01:00:37 Gargoyle kern.notice kernel: [ 0.700000] 0x000000020000-0x000000109718 : "kernel"
Jan 1 01:00:37 Gargoyle kern.warn kernel: [ 0.710000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan 1 01:00:37 Gargoyle kern.notice kernel: [ 0.720000] 0x000000109718-0x0000003f0000 : "rootfs"
Jan 1 01:00:37 Gargoyle kern.warn kernel: [ 0.730000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan 1 01:00:37 Gargoyle kern.notice kernel: [ 0.740000] mtd: partition "rootfs" set to be root filesystem
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 32.320000] ieee80211 phy0: Atheros AR9340 Rev:0 mem=0xb8100000, irq=47
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 32.330000] cfg80211: Calling CRDA for country: US
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 32.330000] cfg80211: Regulatory domain changed to country: US
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 32.340000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 32.350000] cfg80211: (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 3000 mBm)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 32.360000] cfg80211: (5140000 KHz - 5860000 KHz @ 40000 KHz), (N/A, 3000 mBm)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 32.550000] PPP generic driver version 2.4.2
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 32.680000] ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 32.870000] NET: Registered protocol family 24
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 33.000000] nf_conntrack version 0.5.0 (456 buckets, 1824 max)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 33.640000] xt_time: kernel timezone is -0000
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 34.330000] Hooked IMQ after mangle on PREROUTING
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 34.340000] Hooked IMQ after nat on POSTROUTING
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 34.340000] IMQ driver loaded successfully. (numdevs = 2, numqueues = 1)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 34.500000] Netfilter messages via NETLINK v0.30.
Jan 1 01:00:37 Gargoyle kern.notice kernel: [ 34.550000] ip_set: protocol 6
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.070000] usbcore: registered new interface driver cdc_acm
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.080000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.260000] usbcore: registered new interface driver usbserial
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.270000] USB Serial support registered for generic
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.270000] usbcore: registered new interface driver usbserial_generic
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.280000] usbserial: USB Serial Driver core
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.320000] usbcore: registered new interface driver cdc_ether
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.360000] usbcore: registered new interface driver cdc_ncm
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.450000] USB Serial support registered for GSM modem (1-port)
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.460000] usbcore: registered new interface driver option
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.470000] option: v0.7.2:USB Driver for GSM modems
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.560000] USB Serial support registered for Sierra USB modem
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.560000] usbcore: registered new interface driver sierra
Jan 1 01:00:37 Gargoyle kern.info kernel: [ 35.570000] sierra: v.1.7.16:USB Driver for Sierra Wireless USB modems
Jan 1 01:00:39 Gargoyle user.notice usb-modeswitch: 1-0:1.0: Manufacturer=Linux_3.3.8_ehci_hcd Product=Generic_Platform_EHCI_Controller Serial=ehci-platform
Jan 1 01:00:40 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=? Product=USB2.0_Hub Serial=?
Jan 1 01:00:40 Gargoyle user.notice usb-modeswitch: 1-1.4:1.0: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=FFFFFFFFFFFFFFFF
Jan 1 01:00:40 Gargoyle user.notice usb-modeswitch: 1-1.4:1.0: Selecting /etc/usb_modeswitch.d/12d1:1f01 for mode switching
Jan 1 01:00:40 Gargoyle syslog.notice usb_modeswitch: switching device 12d1:1f01 on 001/003
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 40.980000] usb 1-1.4: USB disconnect, device number 3
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 41.320000] usb 1-1.4: new high-speed USB device number 4 using ehci-platform
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 41.430000] cdc_ether 1-1.4:1.0: eth2: register 'cdc_ether' at usb-ehci-platform-1.4, CDC Ethernet Device, 58:2c:80:13:92:63
Jan 1 01:00:42 Gargoyle daemon.notice netifd: Interface 'lan' is now up
Jan 1 01:00:42 Gargoyle kern.info kernel: [ 42.690000] device eth1 entered promiscuous mode
Jan 1 01:00:42 Gargoyle daemon.notice netifd: Interface 'loopback' is now up
Jan 1 01:00:42 Gargoyle daemon.notice netifd: Interface 'wan' is now down
Jan 1 01:00:42 Gargoyle user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Jan 1 01:00:43 Gargoyle kern.info kernel: [ 43.790000] eth1: link up (1000Mbps/Full duplex)
Jan 1 01:00:43 Gargoyle kern.info kernel: [ 43.790000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:00:43 Gargoyle kern.info kernel: [ 43.800000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:00:45 Gargoyle kern.info kernel: [ 45.800000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:00:47 Gargoyle kern.info kernel: [ 47.060000] device wlan0 entered promiscuous mode
Jan 1 01:00:47 Gargoyle kern.info kernel: [ 47.300000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:00:49 Gargoyle kern.info kernel: [ 49.300000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:00:02 Gargoyle authpriv.info dropbear[1156]: Running in background
Jan 1 01:00:02 Gargoyle daemon.warn httpd_gargoyle[1181]: started as root without requesting chroot(), warning only
Jan 1 01:00:02 Gargoyle daemon.notice httpd_gargoyle[1181]: httpd_gargoyle/1.0 14mar2008 starting on Gargoyle, port 80
Jan 1 01:00:03 Gargoyle user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Jan 1 01:00:03 Gargoyle user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Jan 1 01:00:03 Gargoyle daemon.info dnsmasq[1206]: started, version 2.66 cachesize 150
Jan 1 01:00:03 Gargoyle daemon.info dnsmasq[1206]: compile time options: no-IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan 1 01:00:03 Gargoyle daemon.info dnsmasq[1206]: using local addresses only for domain lan
Jan 1 01:00:03 Gargoyle daemon.info dnsmasq[1206]: reading /tmp/resolv.conf.auto
Jan 1 01:00:03 Gargoyle daemon.warn dnsmasq[1206]: ignoring nameserver 192.168.0.1 - local interface
Jan 1 01:00:03 Gargoyle daemon.info dnsmasq[1206]: read /etc/hosts - 2 addresses
Jan 1 01:00:03 Gargoyle user.info sysinit: ERROR: No valid dynamic DNS service configurations defined
Jan 1 01:00:03 Gargoyle user.info sysinit: (Did you specify correct configuration file path?)
Jan 1 01:00:03 Gargoyle user.info sysinit: setting up led WAN
Jan 1 01:00:03 Gargoyle user.info sysinit: setting up led LAN1
Jan 1 01:00:03 Gargoyle user.info sysinit: setting up led LAN2
Jan 1 01:00:03 Gargoyle user.info sysinit: setting up led LAN3
Jan 1 01:00:03 Gargoyle user.info sysinit: setting up led LAN4
Jan 1 01:00:03 Gargoyle user.info sysinit: setting up led WLAN
Jan 1 01:00:03 Gargoyle user.info sysinit: setting up led USB
Jan 1 01:00:30 Gargoyle user.notice usb-modeswitch: 1-1.4:1.0: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Jan 1 01:00:30 Gargoyle user.notice usb-modeswitch: 1-1.4:1.1: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Success
