Cały log od momentu uruchomienia routera z włożonym modemem:
Jan 1 01:00:40 Gargoyle kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Jan 1 01:00:40 Gargoyle kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 0.000000] Memory: 29044k/32768k available (2224k kernel code, 3724k reserved, 391k data, 184k init, 0k highmem)
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 0.000000] NR_IRQS:51
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 0.080000] pid_max: default: 32768 minimum: 301
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 0.080000] Mount-cache hash table entries: 512
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 0.090000] NET: Registered protocol family 16
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 6.420000] Registered led device: tp-link:green:system
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 6.420000] Registered led device: tp-link:green:wan
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 6.420000] Registered led device: tp-link:green:wlan
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 6.420000] Registered led device: tp-link:green:3g
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 7.860000] eth0: link up (1000Mbps/Full duplex)
Jan 1 01:00:40 Gargoyle kern.notice kernel: [ 9.740000] JFFS2 notice: (445) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (0 unchecked, 0 orphan) and 20 of xref (0 dead, 3 orphan) found.
Jan 1 01:00:40 Gargoyle kern.notice kernel: [ 10.480000] SCSI subsystem initialized
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 10.650000] usbcore: registered new interface driver usbfs
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 10.650000] usbcore: registered new interface driver hub
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 10.660000] usbcore: registered new device driver usb
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.120000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.130000] ehci-platform ehci-platform: Generic Platform EHCI Controller
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.130000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.170000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.190000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.190000] hub 1-0:1.0: USB hub found
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.190000] hub 1-0:1.0: 1 port detected
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.210000] Initializing USB Mass Storage driver...
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.220000] usbcore: registered new interface driver usb-storage
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.220000] USB Mass Storage support registered.
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.520000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 11.680000] scsi0 : usb-storage 1-1:1.0
Jan 1 01:00:40 Gargoyle kern.notice kernel: [ 12.680000] scsi 0:0:0:0: CD-ROM TP-LINK MMC Storage 2.31 PQ: 0 ANSI: 2
Jan 1 01:00:40 Gargoyle kern.notice kernel: [ 12.690000] scsi 0:0:0:1: Direct-Access TP-LINK MMC Storage 2.31 PQ: 0 ANSI: 2
Jan 1 01:00:40 Gargoyle kern.notice kernel: [ 12.700000] sd 0:0:0:1: [sda] 7626752 512-byte logical blocks: (3.90 GB/3.63 GiB)
Jan 1 01:00:40 Gargoyle kern.notice kernel: [ 12.700000] sd 0:0:0:1: [sda] Write Protect is off
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 12.710000] sd 0:0:0:1: [sda] Mode Sense: 0f 0e 00 00
Jan 1 01:00:40 Gargoyle kern.notice kernel: [ 12.710000] sd 0:0:0:1: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 12.730000] sda: sda1
Jan 1 01:00:40 Gargoyle kern.notice kernel: [ 12.730000] sd 0:0:0:1: [sda] Attached SCSI removable disk
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 32.770000] eth0: link down
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 33.300000] Loading modules backported from Linux version master-2014-01-23-0-g62c147d
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 33.310000] Backport generated by backports.git backports-20140124-0-g1256d3e
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 33.490000] cfg80211: Calling CRDA to update world regulatory domain
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 33.490000] cfg80211: World regulatory domain updated:
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 33.500000] cfg80211: DFS Master region: unset
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 33.500000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 33.510000] cfg80211: (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 3000 mBm)
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 33.520000] cfg80211: (5140000 KHz - 5860000 KHz @ 40000 KHz), (N/A, 3000 mBm)
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 34.620000] ath: EEPROM regdomain: 0x0
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 34.620000] ath: EEPROM indicates default country code should be used
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 34.620000] ath: doing EEPROM country->regdmn map search
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 34.620000] ath: country maps to regdmn code: 0x3a
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 34.620000] ath: Country alpha2 being used: US
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 34.620000] ath: Regpair used: 0x3a
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 34.630000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Jan 1 01:00:40 Gargoyle kern.debug kernel: [ 34.640000] Registered led device: ath9k-phy0
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 34.640000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 34.640000] cfg80211: Calling CRDA for country: US
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 34.650000] cfg80211: Regulatory domain changed to country: US
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 34.650000] cfg80211: DFS Master region: unset
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 34.660000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 34.670000] cfg80211: (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 3000 mBm)
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 34.670000] cfg80211: (5140000 KHz - 5860000 KHz @ 40000 KHz), (N/A, 3000 mBm)
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 34.910000] PPP generic driver version 2.4.2
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 35.060000] ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 35.480000] NET: Registered protocol family 24
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 35.550000] nf_conntrack version 0.5.0 (456 buckets, 1824 max)
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 36.190000] xt_time: kernel timezone is -0000
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 36.910000] Hooked IMQ after mangle on PREROUTING
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 36.910000] Hooked IMQ after nat on POSTROUTING
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 36.920000] IMQ driver loaded successfully. (numdevs = 2, numqueues = 1)
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 37.120000] Netfilter messages via NETLINK v0.30.
Jan 1 01:00:40 Gargoyle kern.notice kernel: [ 37.180000] ip_set: protocol 6
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 37.770000] usbcore: registered new interface driver cdc_acm
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 37.770000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 37.910000] usbcore: registered new interface driver usbserial
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 37.920000] USB Serial support registered for generic
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 37.920000] usbcore: registered new interface driver usbserial_generic
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 37.930000] usbserial: USB Serial Driver core
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 37.980000] usbcore: registered new interface driver cdc_ether
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 38.130000] usbcore: registered new interface driver cdc_ncm
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 38.230000] USB Serial support registered for GSM modem (1-port)
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 38.240000] usbcore: registered new interface driver option
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 38.240000] option: v0.7.2:USB Driver for GSM modems
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 38.370000] USB Serial support registered for Sierra USB modem
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 38.380000] usbcore: registered new interface driver sierra
Jan 1 01:00:40 Gargoyle kern.info kernel: [ 38.380000] sierra: v.1.7.16:USB Driver for Sierra Wireless USB modems
Jan 1 01:00:42 Gargoyle user.notice usb-modeswitch: 1-0:1.0: Manufacturer=Linux_3.3.8_ehci_hcd Product=Generic_Platform_EHCI_Controller Serial=ehci-platform
Jan 1 01:00:43 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=TP-LINK,_Incorporated Product=TP-LINK_HSPA+_Modem Serial=863745010341556
Jan 1 01:00:43 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Selecting /etc/usb_modeswitch.d/2357:f000 for mode switching
Jan 1 01:00:43 Gargoyle kern.notice kernel: [ 43.970000] sd 0:0:0:1: [sda] Synchronizing SCSI cache
Jan 1 01:00:43 Gargoyle syslog.notice usb_modeswitch: switch device 2357:f000 on 001/002
Jan 1 01:00:43 Gargoyle kern.warn kernel: [ 43.980000] usb 1-1: usbfs: process 807 (usb_modeswitch) did not claim interface 0 before use
Jan 1 01:00:44 Gargoyle kern.info kernel: [ 44.080000] usb 1-1: USB disconnect, device number 2
Jan 1 01:00:44 Gargoyle kern.info kernel: [ 44.430000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Jan 1 01:00:44 Gargoyle kern.info kernel: [ 44.660000] scsi1 : usb-storage 1-1:1.2
Jan 1 01:00:45 Gargoyle kern.notice kernel: [ 45.660000] scsi 1:0:0:0: CD-ROM TP-LINK MMC Storage 2.31 PQ: 0 ANSI: 2
Jan 1 01:00:45 Gargoyle kern.notice kernel: [ 45.660000] scsi 1:0:0:1: Direct-Access TP-LINK MMC Storage 2.31 PQ: 0 ANSI: 2
Jan 1 01:00:45 Gargoyle kern.notice kernel: [ 45.670000] sd 1:0:0:1: [sda] 7626752 512-byte logical blocks: (3.90 GB/3.63 GiB)
Jan 1 01:00:45 Gargoyle kern.notice kernel: [ 45.700000] sd 1:0:0:1: [sda] Write Protect is off
Jan 1 01:00:45 Gargoyle kern.debug kernel: [ 45.700000] sd 1:0:0:1: [sda] Mode Sense: 0f 0e 00 00
Jan 1 01:00:45 Gargoyle kern.notice kernel: [ 45.700000] sd 1:0:0:1: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jan 1 01:00:45 Gargoyle kern.info kernel: [ 45.770000] sda: sda1
Jan 1 01:00:45 Gargoyle kern.notice kernel: [ 45.770000] sd 1:0:0:1: [sda] Attached SCSI removable disk
Jan 1 01:00:47 Gargoyle daemon.notice netifd: Interface 'lan' is now up
Jan 1 01:00:47 Gargoyle kern.info kernel: [ 47.460000] device eth0 entered promiscuous mode
Jan 1 01:00:47 Gargoyle daemon.notice netifd: Interface 'loopback' is now up
Jan 1 01:00:47 Gargoyle user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Jan 1 01:00:47 Gargoyle daemon.notice netifd: Interface 'wan' is now down
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.060000] eth0: link up (1000Mbps/Full duplex)
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.060000] br-lan: port 1(eth0) entered forwarding state
Jan 1 01:00:50 Gargoyle kern.info kernel: [ 50.060000] br-lan: port 1(eth0) entered forwarding state
Jan 1 01:00:53 Gargoyle kern.info kernel: [ 53.710000] device wlan0 entered promiscuous mode
Jan 1 01:00:54 Gargoyle kern.info kernel: [ 54.300000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:00:54 Gargoyle kern.info kernel: [ 54.310000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:00:54 Gargoyle user.notice fstab: mount: mounting /dev/sda1 on /mnt/sda1 failed: Invalid argument
Jan 1 01:00:56 Gargoyle kern.info kernel: [ 56.310000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:00:03 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=TP-LINK,_Incorporated Product=TP-LINK_HSPA+_Modem Serial=XXXXXXXXXXXXXXX
Jan 1 01:00:03 Gargoyle authpriv.info dropbear[1642]: Running in background
Jan 1 01:00:03 Gargoyle user.notice usb-modeswitch: 1-1:1.1: Manufacturer=TP-LINK,_Incorporated Product=TP-LINK_HSPA+_Modem Serial=XXXXXXXXXXXXXXX
Jan 1 01:00:03 Gargoyle user.notice usb-modeswitch: 1-1:1.2: Manufacturer=TP-LINK,_Incorporated Product=TP-LINK_HSPA+_Modem Serial=XXXXXXXXXXXXXXX
Jan 1 01:00:03 Gargoyle daemon.warn httpd_gargoyle[1695]: started as root without requesting chroot(), warning only
Jan 1 01:00:03 Gargoyle daemon.notice httpd_gargoyle[1695]: httpd_gargoyle/1.0 14mar2008 starting on Gargoyle, port 80
Jan 1 01:00:03 Gargoyle user.notice usb-modeswitch: 1-1:1.3: Manufacturer=TP-LINK,_Incorporated Product=TP-LINK_HSPA+_Modem Serial=XXXXXXXXXXXXXXX
Jan 1 01:00:04 Gargoyle user.notice usb-modeswitch: 1-1:1.4: Manufacturer=TP-LINK,_Incorporated Product=TP-LINK_HSPA+_Modem Serial=XXXXXXXXXXXXXXX
Jan 1 01:00:05 Gargoyle user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Jan 1 01:00:05 Gargoyle user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Jan 1 01:00:05 Gargoyle user.notice dnsmasq: Allowing RFC1918 responses for domain free.aero2.net.pl
Jan 1 01:00:05 Gargoyle user.notice fstab: mount: mounting /dev/sda1 on /mnt/sda1 failed: Invalid argument
Jan 1 01:00:09 Gargoyle daemon.info dnsmasq[1862]: started, version 2.66 cachesize 150
Jan 1 01:00:09 Gargoyle daemon.info dnsmasq[1862]: compile time options: no-IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan 1 01:00:09 Gargoyle daemon.info dnsmasq-dhcp[1862]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Jan 1 01:00:09 Gargoyle daemon.info dnsmasq[1862]: using local addresses only for domain lan
Jan 1 01:00:09 Gargoyle daemon.info dnsmasq[1862]: reading /tmp/resolv.conf.auto
Jan 1 01:00:09 Gargoyle daemon.warn dnsmasq[1862]: ignoring nameserver 192.168.1.1 - local interface
Jan 1 01:00:09 Gargoyle daemon.info dnsmasq[1862]: read /etc/hosts - 2 addresses
Jan 1 01:00:09 Gargoyle daemon.info dnsmasq-dhcp[1862]: read /etc/ethers - 0 addresses
Jan 1 01:00:09 Gargoyle user.info sysinit: ERROR: No valid dynamic DNS service configurations defined
Jan 1 01:00:09 Gargoyle user.info sysinit: (Did you specify correct configuration file path?)
Jan 1 01:00:09 Gargoyle user.info sysinit: setting up led WAN
Jan 1 01:00:09 Gargoyle user.info sysinit: setting up led LAN1
Jan 1 01:00:09 Gargoyle user.info sysinit: setting up led LAN2
Jan 1 01:00:09 Gargoyle user.info sysinit: setting up led LAN3
Jan 1 01:00:09 Gargoyle user.info sysinit: setting up led LAN4
Jan 1 01:00:09 Gargoyle user.info sysinit: setting up led WLAN
Jan 1 01:00:09 Gargoyle user.info sysinit: setting up led USB
Success
