Krótki opis:
SoC: 400MHz Broadcom BCM63168VKFEBG
RAM: 128MB Samsung K4T1G164QF
NAND: 128MB Samsung K9F1G08U0D
Switch: Realtek RTL8367RB
VDSL: BCM6302
Złącze RS232 TTL: X9 piny 1- 3V3, 2- Tx, 3- Rx, 4- GND.
Przedstawiam zdjęcia wnętrza routera Livebox 3:
Dodaję jeszcze log z uruchomienia:
NAND flash device: name <not identified>, id 0xecf1 block 128KB size 131072KB
version_sum: : 2
version_nummax: : 2
dwCurrVersionIndex: : 1
dwBackVersionIndex: : 0
dwVersionStartPhyAddr 0: 600000
dwHeadRealPhyAddr 0: 22e0000
dwIsCurrentVersion 0: 0
dwVersionIsBad 0: 0
dwVersionStartPhyAddr: 1: 3600000
dwHeadRealPhyAddr: 1: 5300000
dwIsCurrentVersion: 1: 1
dwVersionIsBad 1: 0
ZXHN H368N V2.04.03_COM for BCM963268 (32bit,SP,BE)
Build Date: 2013â–’â–’ 01â–’â–’ 17â–’â–’ â–’â–’â–’â–’â–’â–’ 18:37:30 CST (xia@njzd)
Chip ID: BCM63168D0, MIPS: 400MHz, DDR: 400MHz, Bus: 200MHz
Main Thread: TP0
Memory Test Passed
Total Memory: 134217728 bytes (128MB)
Boot Address: 0xb8000000
â–’j
Decompression OK!
Entry at 0x803e5d10
Closing network.
Disabling Switch ports.
Flushing Receive Buffers...
0 buffers found.
Closing DMA Channels.
Starting program at 0x803e5d10
Initializing cgroup subsys cpuset
Linux version 2.6.30 (@sahwbld03) (gcc version 4.4.2 (SoftAtHome 1.0.6) ) #1 SMP PREEMPT Mon Oct 8 18:59:06 CEST 2012
BCM Flash API. Flash device is not found.
963168VX prom init
Check boot para cksum...
boot para cksum error!
boot para cksum OK!
bootPara.runmode=3
KernGetTagparam: Tag mod is not initialized yet!
CPU revision is: 0002a080 (Broadcom4350)
DSL SDRAM reserved: 0x132000
Determined physical RAM map:
memory: 07ece000 @ 00000000 (usable)
Zone PFN ranges:
DMA 0x00000000 -> 0x00001000
Normal 0x00001000 -> 0x00007ece
Movable zone start PFN for each node
0: 0x00000000 -> 0x00007ece
On node 0 totalpages: 32462
free_area_init_node: node 0, pgdat 804e92c0, node_mem_map 81000000
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 4064 pages, LIFO batch:0
Normal zone: 222 pages used for memmap
Normal zone: 28144 pages, LIFO batch:7
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32208
Kernel command line: root=31:5 ro rootfstype=jffs2 console=ttyS0,115200
wait instruction: enabled
Primary instruction cache 64kB, VIPT, 4-way, linesize 16 bytes.
Primary data cache 32kB, 2-way, VIPT, cache aliases, linesize 16 bytes
RCU-based detection of stalled CPUs is enabled.
NR_IRQS:128
PID hash table entries: 512 (order: 9, 2048 bytes)
console [ttyS0] enabled
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Allocating memory for DSP module core and initialization code
Allocated DSP module memory - CORE=0x0 SIZE=0, INIT=0x0 SIZE=0
Memory: 122768k/129848k available (3959k kernel code, 6908k reserved, 1022k data, 172k init, 0k highmem)
Calibrating delay loop... 399.36 BogoMIPS (lpj=199680)
--Kernel Config--
SMP=1
PREEMPT=1
DEBUG_SPINLOCK=0
DEBUG_MUTEXES=0
Broadcom Logger v0.1 Oct 8 2012 18:53:54
Calibrating delay loop... 402.43 BogoMIPS (lpj=201216)
Brought up 2 CPUs
net_namespace: 1092 bytes
Total Flash size: 0K with -1 sectors
Internal 1P2 VREG will be shutdown if unused...Unused, turn it off (00008521-0000851f=2<300)
registering PCI controller with io_map_base unset
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pci 0000:00:00.0: reg 10 32bit mmio: [0x10004000-0x10013fff]
pci 0000:00:00.0: reg 30 32bit mmio: [0x000000-0x0007ff]
pci 0000:00:00.0: supports D1 D2
pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
pci 0000:00:00.0: PME# disabled
pci 0000:00:09.0: reg 10 32bit mmio: [0x10002600-0x100026ff]
pci 0000:00:0a.0: reg 10 32bit mmio: [0x10002500-0x100025ff]
pci 0000:01:00.0: PME# supported from D0 D3hot
pci 0000:01:00.0: PME# disabled
pci 0000:01:00.0: PCI bridge, secondary bus 0000:02
pci 0000:01:00.0: IO window: disabled
pci 0000:01:00.0: MEM window: disabled
pci 0000:01:00.0: PREFETCH window: disabled
PCI: Setting latency timer of device 0000:01:00.0 to 64
BLOG v3.0 Initialized
BLOG Rule v1.0 Initialized
Broadcom IQoS v0.1 Oct 8 2012 18:58:49 initialized
Broadcom GBPM v0.1 Oct 8 2012 18:58:49 initialized
NET: Registered protocol family 8
NET: Registered protocol family 20
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.11)
msgmni has been set to 240
io scheduler noop registered (default)
loop: module loaded
Driver 'sd' needs updating - please use bus_type methods
bcm963xx_mtd driver v1.0
Broadcom DSL NAND controller (BrcmNand Controller)
-->brcmnand_scan: CS=0, numchips=1, csi=0
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000000
Disabling XOR on CS#0
brcmnand_scan: Calling brcmnand_probe for CS=0
B4: NandSelect=40000001, nandConfig=15142200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000001, nandConfig=15142200
Block size=00020000, erase shift=17
NAND Config: Reg=15142200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
timing1 not adjusted: 6574845b
timing2 not adjusted: 00001e96
brcmnand_adjust_acccontrol: gAccControl[CS=0]=00000000, ACC=f7ff1010
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=f7ff1010, cfg=15142200, flashId=ecf10095, tim1=6574845b, tim2=00001e96
BrcmNAND version = 0x0400 128MB @00000000
brcmnand_scan: Done brcmnand_probe
brcmnand_scan: B4 nand_select = 40000001
brcmnand_scan: After nand_select = 40000001
100 CS=0, chip->ctrl->CS[0]=0
ECC level 15, threshold at 1 bits
reqEccLevel=0, eccLevel=15
190 eccLevel=15, chip->ecclevel=15, acc=f7ff1010
brcmnand_scan 10
200 CS=0, chip->ctrl->CS[0]=0
200 chip->ecclevel=15, acc=f7ff1010
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
brcmnand_scan 220
Brcm NAND controller version = 4.0 NAND flash size 128MB @18000000
brcmnand_scan 230
brcmnand_scan 40, mtd->oobsize=64, chip->ecclayout=00000000
brcmnand_scan 42, mtd->oobsize=64, chip->ecclevel=15, isMLC=0, chip->cellinfo=0
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
300 CS=0, chip->ctrl->CS[0]=0
500 chip=87a7cd90, CS=0, chip->ctrl->CS[0]=0
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table Bbt0 found at page 0000ffc0, version 0x01 for chip on CS0
Bad block table 1tbB found at page 0000ff80, version 0x01 for chip on CS0
nand_read_bbt: Bad block at 0x01fc0000
nand_read_bbt: Bad block at 0x03220000
nand_read_bbt: Bad block at 0x06380000
nand_read_bbt: Bad block at 0x07220000
brcmnandCET: Status -> Deferred
brcmnand_scan 99
Creating 7 MTD partitions on "brcmnand.0":
0x000000020000-0x000000100000 : "rip"
0x000000100000-0x000000300000 : "wlan_dect"
0x000000400000-0x000000600000 : "user"
0x000000600000-0x000003600000 : "norm"
0x000003600000-0x000006600000 : "rescue"
0x000003800000-0x000005300000 : "filesystem"
0x000006600000-0x000007600000 : "ext"
Registered led device: kLedInternetRed
Registered led device: kLedInternetGreen
Registered led device: kLedWireless
Registered led device: Backlight
kbutton_hw_init
SoftAtHome Button driver has been initialized
TagaramodInit: Tagaram module Driver Version 0.0.2.
TagaramodInit: Tagaram module registering
TagparamCoreInit: User config 1 tag para regions
TagparamCoreInit: parse tag param success
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
IPv6 over IPv4 tunneling driver
Initializing MCPD Module
Ebtables v2.0 registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
VFS: Mounted root (jffs2 filesystem) readonly on device 31:5.
Freeing unused kernel memory: 172k freed
init started: BusyBox v1.13.3 (2012-10-08 19:08:05 CEST)
starting pid 246, tty '': '/etc_ro_fs/init.d/sysinit'
Mounting tmpfs filesystem (/dev) ...
Mounting devpts filesystem (/dev/pts) ...
Mounting proc filesystem ...
Mounting sys filesystem ...
Mounting tmpfs filesystem (/var) ...
Mounting tmpfs filesystem (/var/log) ...
Mounting tmpfs filesystem (/tmp) ...
> NORMAL BOOT <
jffs2_scan_inode_node(): CRC failed on node at 0x000467c4: Read 0xffffffff, calculated 0xffffd284
> BOOT SYSTEM <
Create /dev/button files
## CV=CONFIG_VERSION_NAME_MAJOR="4.24.15" DB=CONFIG_VERSION_NAME_MAJOR="4.24.15"
cp: cannot stat '/fs/rw/dl/tls/cert0201.pem': No such file or directory
start rc.sysinit
Mounting other filesystems ...
Switching to RUNLEVEL 1 ...
*********************** Starting script /etc/rc1.d/S01EnableRebootOnCrash at: 6.91 0.00
Enabling Reboot on kernel crash
*********************** Starting script /etc/rc1.d/S01hgwcfg at: 6.99 0.00
*********************** Starting script /etc/rc1.d/S01sysbus at: 7.05 0.00
Starting pcb system bus
*********************** Starting script /etc/rc1.d/S02ext at: 8.74 0.00
UBI: attaching mtd6 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: attached mtd6 to ubi0
UBI: MTD device name: "ext"
UBI: MTD device size: 16 MiB
UBI: number of good PEBs: 127
UBI: number of bad PEBs: 1
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 256
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 127
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 2/1
UBI: background thread "ubi_bgt0dUBI device numb" started, PID 336
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "ext"
UBIFS: file system size: 14221312 bytes (13888 KiB, 13 MiB, 112 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 671707 bytes (655 KiB)
er 0, total 127 LEBs (16125952 bytes, 15.4 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
mount_ubifs_ext: Ok
*********************** Starting script /etc/rc1.d/S02hardware at: 9.38 0.00
mknod: /dev/brcmboard: File exists
mknod: /dev/bcmadsl0: File exists
mknod: /dev/bcmendpoint0: File exists
mknod: /dev/bcm: File exists
mknod: /dev/bcmxtmcfg0: File exists
mknod: /dev/pktcmf: File exists
mknod: /dev/spu: File exists
mknod: /dev/button0: File exists
mknod: /dev/button1: File exists
mknod: /dev/button2: File exists
bcm_bpm: module license 'unspecified' taints kernel.
Disabling lock debugging due to kernel taint
BPM: tot_mem_size=134217728B (128MB), buf_mem_size=20132659B (19MB), num of buffers=9605, buf size=2096
Broadcom BPM Module Char Driver v0.1 Oct 8 2012 18:54:25 Registered<244>
[NTC bpm] bpm_set_status: BPM status : enabled
NBUFF v1.0 Initialized
Initialized fcache state
Broadcom Packet Flow Cache Char Driver v2.2 Oct 8 2012 18:56:42 Registered<242>
Created Proc FS /procfs/fcache
Broadcom Packet Flow Cache registered with netdev chain
Broadcom Packet Flow Cache learning via BLOG enabled.
Constructed Broadcom Packet Flow Cache v2.2 Oct 8 2012 18:56:42
chipId 0x631680D0
Broadcom Forwarding Assist Processor (FAP) Char Driver v0.1 Oct 8 2012 18:56:28 Registered <241>
FAP Debug values at 0x00000010 0x00000010
Enabling SMISBUS PHYS_FAP_BASE[0] is 0x10c01000
FAP Soft Reset Done
4ke Reset Done
Enabling SMISBUS PHYS_FAP_BASE[1] is 0x10c01000
FAP Soft Reset Done
4ke Reset Done
Allocated FAP0 GSO Buffers (0xA5E3C594) : 1048576 bytes @ 0xA5F00000
Allocated FAP1 GSO Buffers (0xA5E5C594) : 1048576 bytes @ 0xA5800000
[NTC fapProto] fapReset : Reset FAP Protocol layer
bcmPktDma_bind: FAP Driver binding successfull
[FAP0] DSPRAM : stack <0x80000000><1024>, global <0x80000400><7112>, free <56>, total<8192>
[FAP1] DSPRAM : stack <0x80000000><1024>, global <0x80000400><7112>, free <56>, total<8192>
[FAP0] PSM : addr<0x80002000>, used <24536>, free <40>, total <24576>
[FAP1] PSM : addr<0x80002000>, used <24536>, free <40>, total <24576>
[FAP0] Flows supported: 238 (dsp 61, psm 75, qsm 102)
[FAP1] Flows supported: 238 (dsp 61, psm 75, qsm 102)
[FAP0] DQM : availableMemory 14012 bytes, nextByteAddress 0xE0010944
[FAP1] DQM : availableMemory 14012 bytes, nextByteAddress 0xE0010944
[FAP0] GSO Buffer set to 0xA5F00000
[FAP1] GSO Buffer set to 0xA5800000
[FAP0] FAP BPM Initialized.
[FAP1] FAP BPM Initialized.
Broadcom Ingress QoS Module Char Driver v0.1 Oct 8 2012 18:56:41 Registered<243>
Broadcom Ingress QoS ver 0.1 initialized
bcmxtmcfg: bcmxtmcfg_init entry
adsl: adsl_init entry
Broadcom BCM63168D0 Ethernet Network Device v0.1 Oct 8 2012 18:58:22
fapDrv_psmAlloc: fapIdx=0, size: 3600, offset=b08206f0 bytes remaining 7408
ETH Init: Ch:0 - 180 tx BDs at 0xb08206f0
fapDrv_psmAlloc: fapIdx=1, size: 3600, offset=b0a206f0 bytes remaining 7408
ETH Init: Ch:1 - 180 tx BDs at 0xb0a206f0
fapDrv_psmAlloc: wastage 8 bytes
fapDrv_psmAlloc: fapIdx=0, size: 4808, offset=b0821500 bytes remaining 2592
ETH Init: Ch:0 - 600 rx BDs at 0xb0821500
fapDrv_psmAlloc: fapIdx=1, size: 4808, offset=b0a21500 bytes remaining 2592
ETH Init: Ch:1 - 600 rx BDs at 0xb0a21500
dgasp: kerSysRegisterDyingGaspHandler: bcmsw registered
eth0: MAC Address: F0:84:C9:5C:CC:19
eth1: MAC Address: F0:84:C9:5C:CC:18
eth2: MAC Address: F0:84:C9:5C:CC:18
eth1 Link UP 1000 mbps full duplex
eth2 Link UP 1000 mbps full duplex
message received before monitor task is initialized kerSysSendtoMonitorTask
â–’â–’wl: dsl_tx_pkt_flush_len=338
wl: high_wmark_tot=6243
PCI: Setting latency timer of device 0000:00:00.0 to 64
wl: passivemode=1
wl: napimode=0
wl0: allocskbmode=1 currallocskbsz=512
otp_read_pci: bad crc
Neither SPROM nor OTP has valid image
wl:srom/otp not programmed, using main memory mapped srom info(wombo board)
wl:loading /etc/wlan/bcm6362_vars.bin
Failed to open srom image from '/etc/wlan/bcm6362_vars.bin'.
wl: Read srom from RIP successful.
wl0: Broadcom BCM435f 802.11 Wireless Controller 5.100.138.2008.cpe4.12L06RC3.4
dgasp: kerSysRegisterDyingGaspHandler: wl0 registered
modprobe: Module p8021ag not found.
Broadcom 802.1Q VLAN Interface, v0.1
fb0: ZTE frame buffer device, using 8K of video memory
ZteSpiOpen ret is 0
*********************** Starting script /etc/rc1.d/S02hardware.adsl.96362 at: 17.14 0.00
Starting ADSL...
pktflow... ok
bcmxtmcfg... ok
adsldd... ok
*********************** Starting script /etc/rc1.d/S04bcm_bridge_qos at: 18.88 0.00
*********************** Starting script /etc/rc1.d/S05wlan_celeno at: 19.07 0.00
*********************** Starting script /etc/rc1.d/S10netmodeconfig1 at: 19.17 0.00
Success
Success
initing...*********************** Starting script /etc/rc1.d/S15syslogd at: 20.14 0.00
*********************** Starting script /etc/rc1.d/S16usermngt at: 20.19 0.00
*********************** Starting script /etc/rc1.d/S20nemo-core at: 20.72 0.00
*********************** Starting script /etc/rc1.d/S20network at: 22.09 0.00
Hostname configuration : LIVEBOX
*********************** Starting script /etc/rc1.d/S21geniodb at: 22.20 0.00
Loading geniodb kernel module...
Thomson geniodb driver: Loading ...
Thomson geniodb driver: Loading finished with SUCCESS
*********************** Starting script /etc/rc1.d/S21nemo-extensions1 at: 22.29 0.00
*********************** Starting script /etc/rc1.d/S21netdev at: 23.04 0.00
ADDRCONF(NETDEV_UP): eth0: link is not ready
*********************** Starting script /etc/rc1.d/S21www-backend at: 23.41 0.00
Starting www-backend plugin
*********************** Starting script /etc/rc1.d/S22firewall at: 23.63 0.00
<6>RT3883iNIC: 802.11n WLAN MII driver v2.3.0.0 (Jan. 15, 2010)
===> Get MAC from iNIC
============= Init Thread ===================
RacfgTaskThread pid = 681
RacfgBacklogThread pid = 682
*********************** Starting script /etc/rc1.d/S22gatewayd at: 26.26 0.00
gatewayd start ...
hco_upgrade_get_partition_info paBcmAdsl_Initialize=0xC0379B44, g_pFnNotifyCallback=0xC03B5524
rt_type(PART_TYPE_NORM) bufflen(64)
hco_upgrade_get_partition_info: Version Len(10) Version String(4.24.15.17)
hco_upgrade_get_partition_info success version(4.24.15.17)
hco_upgrade_get_partition_info part_type(PART_TYPE_RESC) bufflen(64)
lmemhdr[2]=0x100CE000, pAdslLMem[2]=0x100CE000
pSdramPHY=0xA7FFFFF8, 0x40000 0x4010
*** XfaceOffset: 0x5FF90 => 0x5FF90 ***
*** PhySdramSize got adjusted: 0xD95BC => 0x10FCC0 ***
AdslCoreSharedMemInit: shareMemSize=140061(140064)
AdslCoreHwReset: pLocSbSta=84fa0000 bkupThreshold=3072
AdslCoreHwReset: AdslOemDataAddr = 0xA7F9A49C
dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
[libxdsl]: xTU-R serial is too long
[libxdsl]: Failed to configure serial number
initing...End of initialisation
*********************** Starting script /etc/rc1.d/S22screen at: 31.37 0.00
*********************** Starting script /etc/rc1.d/S23bcmeth at: 32.90 0.00
*********************** Starting script /etc/rc1.d/S23nemo-clients at: 33.02 0.00
device bridge entered promiscuous mode
device wl0 entered promiscuous mode
device eth1_lan entered promiscuous mode
device eth1 entered promiscuous mode
bridge: port 2(eth1_lan) entering forwarding state
fapDrv_psmAlloc: fapIdx=1, size: 1600, offset=b0a227d0 bytes remaining 992
XTM Init: Ch:0 - 200 rx BDs at 0xb0a227d0
fapDrv_psmAlloc: fapIdx=1, size: 128, offset=b0a22e10 bytes remaining 864
XTM Init: Ch:1 - 16 rx BDs at 0xb0a22e10
rxdma[0]: skbs_p(848c0000), size(44816), SKB_ALIGNED_SIZE(224)
rxdma[1]: skbs_p(84888000), size(3600), SKB_ALIGNED_SIZE(224)
device vlan_iptv1 entered promiscuous mode
device eth0 entered promiscuous mode
bridge_viptv: port 1(vlan_iptv1) entering forwarding state
device vlan_iptv2 entered promiscuous mode
bridge_viptv: port 2(vlan_iptv2) entering forwarding state
bcmxtmrt: MAC address: f0 84 c9 5c cc 1b
[DoCreateDeviceReq.3018]: register_netdev
*********************** Starting script /etc/rc1.d/S24resolvd at: 35.26 0.00
[DoCreateDeviceReq.3020]: register_netdev done
[FAP0] xtmCreateDevice : devId 0, encapType 0, headerLen 0
[FAP1] xtmCreateDevice : devId 0, encapType 0, headerLen 0
Resolv daemon start ...
bcmxtmrt: MAC address: f0 84 c9 5c cc 18
*********************** Starting script /etc/rc1.[DoCreateDeviceReq.3020]: register_netdev done
d/S25dnsplugin a[FAP0] xtmCreateDevice : devId 1, encapType 0, headerLen 0
t: 35.48 0.00
[FAP1] xtmCreateDevice : devId 1, encapType 0, headerLen 0
device atm_iptv1 entered promiscuous mode
bridge_aiptv: port 1(atm_iptv1) entering forwarding state
[FAP0] xtmCreateDevice : devId 2, encapType 0, headerLen 0
[FAP1] xtmCreateDevice : devId 2, encapType 0, headerLen 0
device atm_iptv2 entered promiscuous mode
bridge_aiptv: port 2(atm_iptv2) entering forwarding state
[FAP0] xtmCreateDevice : devId 3, encapType 0, headerLen 0
[FAP1] xtmCreateDevice : devId 3, encapType 0, headerLen 0
device atm_iptv3 entered promiscuous mode
bridge_aiptv: port 3(atm_iptv3) entering forwarding state
[FAP0] xtmCreateDevice : devId 4, encapType 0, headerLen 0
[FAP1] xtmCreateDevice : devId 4, encapType 0, headerLen 0
device vvlan_iptv1 entered promiscuous mode
device ptm0 entered promiscuous mode
bridge_vviptv: port 1(vvlan_iptv1) entering forwarding state
dnsmasq already stopped...
dnsmasq start ...
device vvlan_iptv2 entered promiscuous mode
bridge_vviptv: port 2(vvlan_iptv2) entering forwarding state
TagparamGet: No param has id 0x606 !
Failed to load calibration data from RIP
Physical EEPROM mode
Commit crc = 360e24eb
Passing firmware to driver
No RIP calibration data, hoping for a physical EEPROM
Trying bootloader /etc/wireless/CL1800/iNIC_boot.bin
Trying bootloader /usr/lib/wireless/CL1800/ce_inic_image/iNIC_boot.bin
*********************** Starting script /etc/rc1.d/S40nlplugd at: 38.27 0.00
nlplugd start ...
Initializing.
Starting netlink plugin
Daemonize netlink plugin
*********************** Starting script /etc/rc1.d/S420fuse at: 38.48 0.00
Fuse filesystem already available.
Mounting fuse control filesystem.
*********************** Starting script /etc/rc1.d/S42usb-host at: 38.57 0.00
Starting usbmgr
*********************** Starting script /etc/rc1.d/S44igmpsnooping at: 39.26 0.00
uboot ...linux ...gen_eeprom ...nvram.
Target mode = operational
Broadcom Packet Flow Cache Learning of multicast flows IPv4<ENABLED> IPv6<DISABLED>
*********************** Starting script /etc/rc1.d/S45dhccd at: 40.64 0.00
Uploading firmware to target
Wait for boot notify...
Waiting for boot done indication...
dhccd start ...
Daemonize dhccd
*********************** Starting script /etc/rc1.d/S50deviceinfo at: 40.98 0.00
Starting deviceinfo plugin
*********************** Starting script /etc/rc1.d/S50wld_bcm at: 41.02 0.00
RACFG_CMD_BOOT_NOTIFY (new boot)
Wait for MAC address...
*********************** Starting script /etc/rc1.d/S50wld_celeno at: 41.80 0.00
device wl0 left promiscuous mode
bridge: port 1(wl0) entering disabled state
*********************** Starting script /etc/rc1.d/S70stopload at: 41.92 0.00
Wait until configuration load reaches phase 10 (now -1)
RACFG_CMD_BOOT_UPLOAD(0)
RACFG_CMD_BOOT_UPLOAD(1)
RACFG_CMD_BOOT_UPLOAD(2)
Send STARTUP to RT3883iNIC
RACFG_CMD_BOOT_STARTUP
appbox: start loading after [ 13015ms ]
Wait until configuration load reaches phase 10 (now 4)
appbox: end loading
*********************** Starting script /etc/rc1.d/S71mbusmap at: 44.04 0.00
Starting mbus mapper
PPP
PPP.Scan
*********************** Starting script /etc/rc1.d/S71start_wlan at: 44.55 0.00
eth1_lan: no IPv6 routers present
*********************** Starting script /etc/rc1.d/S72nemo-extensions2 at: 44.61 0.00
eth1_iptv1: no IPv6 routers present
*********************** Starting script /etc/rc1.d/S72netmodeconfig2 at: 44.80 0.00
vlan_data: no IPv6 routers present
vlan_iptv1: no IPv6 routers present
vlan_celeno: no IPv6 routers present
vlan_iptv2: no IPv6 routers present
atm_data: no IPv6 routers present
atm_iptv1: no IPv6 routers present
atm_iptv2: no IPv6 routers present
vvlan_data: no IPv6 routers present
atm_iptv3: no IPv6 routers present
vvlan_iptv2: no IPv6 routers present
*********************** Starting script /etc/rc1.d/S73eventmanager at: 47.07 0.00
Starting pcb eventmanager
ptm0: no IPv6 routers present
*********************** Starting script /etc/rc1.d/S73httpd at: 47.20 0.00
Starting http server
vvlan_iptv1: no IPv6 routers present
RACFG_CMD_BOOT_CONTINUE
Starting httpd watchdog
*********************** Starting script /etc/rc1.d/S74devdiscd at: 47.97 0.00
warning: `httpd' uses 32-bit capabilities (legacy support in use)
*********************** Starting script /etc/rc1.d/S75captiveportal at: 49.30 0.00
*********************** Starting script /etc/rc1.d/S76pwrledstop at: 50.39 0.00
pwrledstart stop ...
*********************** Starting script /etc/rc1.d/S78dyndns at: 50.67 0.00
Starting dyndns plug-in
*********************** Starting script /etc/rc1.d/S78openntpd_plugin at: 51.35 0.00
Starting openntpd plugin
*********************** Starting script /etc/rc1.d/S80telnetd at: 52.12 0.00
telnetd start ...
open telnet in the firewall ...
*********************** Starting script /etc/rc1.d/S81phonebook_plugin at: 52.21 0.00
Starting phonebook_plugin plugin
*********************** Starting script /etc/rc1.d/S81voicecfgload at: 52.50 0.00
Restoring voice datamodel from file
Done! Configuration restored using the backup configuration
*********************** Starting script /etc/rc1.d/S82voipapp at: 52.68 0.00
â–’â–’kâ–’â–’â–’read_firmware_buffer: Gen EEPROM upload 0/2048
***benson,read_firmware_buffer: Gen EEPROM upload 1024/2048
***benson,read_firmware_buffer: Gen EEPROM upload 2048/2048
RACFG_CMD_BOOT_CFG
Target's operation mode = operational.
bridge: port 1(wl0) entering forwarding state
qgin.Plugin
*********************** Starting script /etc/rc1.d/S85scheduler at: 60.93 0.00
Starting Scheduler plug-in
*********************** Starting script /etc/rc1.d/S87usbhosts at: 61.42 0.00
Starting usbhosts plug-in
*********************** Starting script /etc/rc1.d/S89usb_modeswitch_boot at: 61.65 0.00
*********************** Starting script /etc/rc1.d/S90dlnaserver at: 61.89 0.00
*********************** Starting script /etc/rc1.d/S90tod at: 62.04 0.00
Starting ToD plug-in
*********************** Starting script /etc/rc1.d/S90wlanscheduler at: 62.28 0.00
Starting WLanScheduler plug-in
*********************** Starting script /etc/rc1.d/S91cups at: 62.71 0.00
Creating /dev/usb/lp0
*********************** Starting script /etc/rc1.d/S97igd at: 63.22 0.00
Starting pcb igd mapper
*********************** Starting script /etc/rc1.d/S98avahi at: 64.93 0.00
*********************** Starting script /etc/rc1.d/S98cwmp at: 65.47 0.00
Starting cwmp plug-in
Starting ippingdiagnostics plug-in
Starting cwmpd
*********************** Starting script /etc/rc1.d/S98remoteaccess at: 66.44 0.00
Starting remote access plug-in
*********************** Starting script /etc/rc1.d/S98upgraded at: 66.79 0.00
upgraded started
*********************** Starting script /etc/rc1.d/S98voipaad at: 67.26 0.00
Starting voipaad plugin
*********************** Starting script /etc/rc1.d/S99cifscl at: 67.60 0.00
Update MAC(0)=f0:84:c9:5c:cc:19
Warning! MAC addr (f0:84:c9:5c:cc:19) not equal to MII master (f0:84:c9:5c:cc:18) => <6>[syncmiimac] disabled?
Wait for boot done...
RACFG_CMD_BOOT_END
Got boot done indication after 1 retries
Add HeartBeatTimer ....
*********************** Starting script /etc/rc1.d/S99conmon at: 69.28 0.00
Starting Connectivity Monitor (ConMon) plug-in
*********************** Starting script /etc/rc1.d/S99dummy_ep at: 69.53 0.00
Boot process Completed successfully, after 29 seconds
loading ce00...
Start dummy endpointplugin ...
iNIC Open ce00
Op mode = 1
*********************** Starting script /etc/rc1.d/S99gwmonstart at: 69.64 0.00
Starting gwmonit
*********************** Starting script /etc/rc1.d/S99printkoff at: 69.74 0.00
Setting printk off
*********************** Starting script /etc/rc1.d/S99ravoice at: 69.85 0.00
Start Broadcom FXS plugin...
. Loading voice kernel modules
endpointdd
Configuring VLANs on target...
Done.
(71.073)[wld_celeno] - wld - [!]0x416c00 100 1 - (TRAP_mfn_wrad_txpow@wld.c:141)
(71.073)[wld_celeno] - wld - [!]0x416c00 1 - (TRAP_mfn_wrad_sync@wld.c:151)
Success
Success
. Starting pcb plugin
*********************** Starting script /etc/rc1.d/S99rdect at: 72.73 0.00
Start Dspgroup SPI dect plugin
TDM interface
rting to monitor the gatewayd process...
(80.089)[wld_celeno] - wld - [!]0x416c00 -1 1 - (TRAP_mfn_wrad_txpow@wld.c:141)
(80.090)[wld_celeno] - wld - [!]0x416c00 1 - (TRAP_mfn_wrad_sync@wld.c:151)
FullPath = Radio.wifi0 - 0x416a60
(80.191)[wld_celeno] - wld - [!]0x425be0 0 1 - (TRAP_mfn_wvap_enable_uapsd@wld.c:182)
(80.509)[wld_celeno] - wld - [!]0x416c00 (nil) -1 1 - (TRAP_mfn_wrad_mcs@wld.c:136)
(80.509)[wld_celeno] - wld - [!]0x416c00 -1 1 - (TRAP_mfn_wrad_txpow@wld.c:141)
*********************** Starting script /etc/rc1.d/S99saveflush at: 82.39 0.00
*********************** Starting script /etc/rc1.d/S99storage at: 82.61 0.00
Х▒▒▒script /etc/rc1.d/S99upload_client at: 86.89 0.00
Starting upload client
*********************** Starting script /etc/rc1.d/S99upnp-igd at: 87.72 0.00
Create UPnPd target directory
Start upnp-igd plugin
Start linuxigd2 (c82ec286)
RRRRRRRRRRRRRRR▒х▒ѥ▒▒▒script /etc/rc1.d/S99upnpdiscd_plugin at: 90.73 0.00
Starting upnp discovery plugin
Sysinit done.
starting pid 2014, tty '': '/etc_ro_fs/init.d/rc.sysinit'
Sysinit done.
Please press Enter to activate this console.
process '-/bin/login' (pid 2019) exited. Scheduling for restart.
process '-/bin/login' (pid 2388) exited. Scheduling for restart.
Naciśnięcie klawisza ENTER nie zezwala na dostanie się do terminala.
