Poniżej logi po aktualizacji:
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] SoC: Atheros AR9330 rev 1
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Determined physical RAM map:
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] memory: 02000000 @ 00000000 (usable)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Zone PFN ranges:
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Normal 0x00000000 -> 0x00002000
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Movable zone start PFN for each node
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Early memory PFN ranges
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] 0: 0x00000000 -> 0x00002000
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] On node 0 totalpages: 8192
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 802ed700, node_mem_map 81000000
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] Normal zone: 64 pages used for memmap
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] Normal zone: 8128 pages, LIFO batch:0
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.000000] Kernel command line: board=TL-MR3020 console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Memory: 29044k/32768k available (2224k kernel code, 3724k reserved, 391k data, 184k init, 0k highmem)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] NR_IRQS:51
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.080000] pid_max: default: 32768 minimum: 301
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.080000] Mount-cache hash table entries: 512
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.090000] NET: Registered protocol family 16
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.100000] MIPS: machine is TP-LINK TL-MR3020
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.350000] bio: create slab <bio-0> at 0
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.360000] Switching to clocksource MIPS
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.360000] NET: Registered protocol family 2
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.370000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.370000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.370000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.380000] TCP: Hash tables configured (established 1024 bind 1024)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.390000] TCP reno registered
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.390000] UDP hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.400000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.400000] NET: Registered protocol family 1
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 0.410000] PCI: CLS 0 bytes, default 32
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.430000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.430000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.440000] msgmni has been set to 56
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.440000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.450000] io scheduler noop registered
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.450000] io scheduler deadline registered (default)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.460000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.470000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.480000] console [ttyATH0] enabled, bootconsole disabled
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.490000] m25p80 spi0.0: found s25sl032a, expected m25p80
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.490000] m25p80 spi0.0: s25sl032a (4096 Kbytes)
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.500000] 5 tp-link partitions found on MTD device spi0.0
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.510000] Creating 5 MTD partitions on "spi0.0":
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.510000] 0x000000000000-0x000000020000 : "u-boot"
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.520000] 0x000000020000-0x000000109708 : "kernel"
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.520000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.530000] 0x000000109708-0x0000003f0000 : "rootfs"
Jan 1 01:00:36 Gargoyle kern.warn kernel: [ 0.540000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.550000] mtd: partition "rootfs" set to be root filesystem
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.560000] mtd: partition "rootfs_data" created automatically, ofs=3A0000, len=50000
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.560000] 0x0000003a0000-0x0000003f0000 : "rootfs_data"
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.570000] 0x0000003f0000-0x000000400000 : "art"
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 0.580000] 0x000000020000-0x0000003f0000 : "firmware"
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.600000] ag71xx_mdio: probed
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 0.600000] eth0: Atheros AG71xx at 0xb9000000, irq 4
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 1.160000] ag71xx ag71xx.0: eth0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 1.170000] TCP cubic registered
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 1.170000] NET: Registered protocol family 17
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 1.170000] Bridge firewalling registered
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 1.180000] Ebtables v2.0 registered
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 1.180000] 8021q: 802.1Q VLAN Support v1.8
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 1.190000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 1.200000] Freeing unused kernel memory: 184k freed
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 3.580000] Registered led device: tp-link:green:3g
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 3.590000] Registered led device: tp-link:green:wlan
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 3.590000] Registered led device: tp-link:green:lan
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 3.590000] Registered led device: tp-link:green:wps
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 6.160000] eth0: link up (100Mbps/Full duplex)
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 6.920000] JFFS2 notice: (434) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (0 unchecked, 0 orphan) and 20 of xref (0 dead, 4 orphan) found.
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 7.660000] SCSI subsystem initialized
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 7.830000] usbcore: registered new interface driver usbfs
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 7.830000] usbcore: registered new interface driver hub
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 7.840000] usbcore: registered new device driver usb
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.310000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.310000] ehci-platform ehci-platform: Generic Platform EHCI Controller
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.320000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.360000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.380000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.380000] hub 1-0:1.0: USB hub found
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.380000] hub 1-0:1.0: 1 port detected
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.410000] Initializing USB Mass Storage driver...
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.410000] usbcore: registered new interface driver usb-storage
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.410000] USB Mass Storage support registered.
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.710000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 8.870000] scsi0 : usb-storage 1-1:1.0
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 9.870000] scsi 0:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 9.880000] scsi 0:0:0:1: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 9.890000] sd 0:0:0:1: [sda] Attached SCSI removable disk
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 29.790000] eth0: link down
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 30.310000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 30.320000] Backport generated by backports.git backports-20140320-37-g5c33da0
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 30.500000] cfg80211: Calling CRDA to update world regulatory domain
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 30.500000] cfg80211: World regulatory domain updated:
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 30.510000] cfg80211: DFS Master region: unset
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 30.510000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 30.520000] cfg80211: (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 30.530000] cfg80211: (5140000 KHz - 5860000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 31.540000] ath: EEPROM regdomain: 0x0
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 31.540000] ath: EEPROM indicates default country code should be used
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 31.540000] ath: doing EEPROM country->regdmn map search
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 31.540000] ath: country maps to regdmn code: 0x3a
Jan 1 01:00:39 Gargoyle user.notice usb-modeswitch: 1-0:1.0: Manufacturer=Linux_3.3.8_ehci_hcd Product=Generic_Platform_EHCI_Controller Serial=ehci-platform
Jan 1 01:00:40 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=0123456789ABCDEF
Jan 1 01:00:43 Gargoyle daemon.notice netifd: Interface 'lan' is now up
Jan 1 01:00:43 Gargoyle daemon.notice netifd: Interface 'loopback' is now up
Jan 1 01:00:43 Gargoyle kern.info kernel: [ 43.320000] device eth0 entered promiscuous mode
Jan 1 01:00:43 Gargoyle kern.info kernel: [ 43.510000] eth0: link up (100Mbps/Full duplex)
Jan 1 01:00:43 Gargoyle kern.info kernel: [ 43.510000] br-lan: port 1(eth0) entered forwarding state
Jan 1 01:00:43 Gargoyle kern.info kernel: [ 43.520000] br-lan: port 1(eth0) entered forwarding state
Jan 1 01:00:43 Gargoyle user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Jan 1 01:00:43 Gargoyle daemon.notice netifd: Interface 'wan' is now down
Jan 1 01:00:45 Gargoyle kern.info kernel: [ 45.520000] br-lan: port 1(eth0) entered forwarding state
Jan 1 01:00:47 Gargoyle kern.info kernel: [ 47.910000] device wlan0 entered promiscuous mode
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.590000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:00:50 Gargoyle kern.info kernel: [ 50.590000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:02:28 Gargoyle authpriv.info dropbear[1491]: Running in background
Jan 1 01:02:28 Gargoyle daemon.warn httpd_gargoyle[1516]: started as root without requesting chroot(), warning only
Jan 1 01:02:28 Gargoyle daemon.notice httpd_gargoyle[1516]: httpd_gargoyle/1.0 14mar2008 starting on Gargoyle, port 80
Jan 1 01:02:29 Gargoyle user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Jan 1 01:02:29 Gargoyle user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Jan 1 01:02:29 Gargoyle user.notice dnsmasq: Allowing RFC1918 responses for domain free.aero2.net.pl
Jan 1 01:02:32 Gargoyle daemon.info dnsmasq[1549]: started, version 2.66 cachesize 150
Jan 1 01:02:32 Gargoyle daemon.info dnsmasq[1549]: compile time options: no-IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan 1 01:02:32 Gargoyle daemon.info dnsmasq-dhcp[1549]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Jan 1 01:02:32 Gargoyle daemon.info dnsmasq[1549]: using local addresses only for domain lan
Jan 1 01:02:32 Gargoyle daemon.info dnsmasq[1549]: reading /tmp/resolv.conf.auto
Jan 1 01:02:32 Gargoyle daemon.warn dnsmasq[1549]: ignoring nameserver 192.168.1.1 - local interface
Jan 1 01:02:32 Gargoyle daemon.info dnsmasq[1549]: read /etc/hosts - 2 addresses
Jan 1 01:02:32 Gargoyle daemon.info dnsmasq-dhcp[1549]: read /etc/ethers - 0 addresses
Jan 1 01:02:33 Gargoyle user.info sysinit: ERROR: No valid dynamic DNS service configurations defined
Jan 1 01:02:33 Gargoyle user.info sysinit: (Did you specify correct configuration file path?)
Jan 1 01:02:33 Gargoyle user.info sysinit: setting up led USB
Jan 1 01:02:33 Gargoyle user.info sysinit: setting up led WLAN
Jan 1 01:02:33 Gargoyle user.info sysinit: setting up led LAN
Success
Po aktualizacji taki sam efekt.
Jeżeli konieczny jest HUB USB. To proszę o podpowiedz jaki byłby okey z oferty Komputronik .
Zależy mi na czasie - a sklep niezbyt daleko:)
Po drugie nie chce kupic czegos co nie będzie działało.
