wszystko co wyjechało po wpisaniu komendy jaką podał Administrator
Możesz jeszcze podać cały log systemowy ze strony konfiguracyjnej routera.
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 32.220000] ath: Regpair used: 0x3a
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 32.230000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Jan 1 01:00:36 Gargoyle kern.debug kernel: [ 32.230000] Registered led device: ath9k-phy0
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 32.230000] ieee80211 phy0: Atheros AR9340 Rev:0 mem=0xb8100000, irq=47
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 32.240000] cfg80211: Calling CRDA for country: US
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 32.250000] cfg80211: Regulatory domain changed to country: US
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 32.250000] cfg80211: DFS Master region: unset
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 32.260000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 32.270000] cfg80211: (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 32.280000] cfg80211: (5140000 KHz - 5860000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 32.470000] PPP generic driver version 2.4.2
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 32.590000] ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 32.920000] NET: Registered protocol family 24
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 32.980000] nf_conntrack version 0.5.0 (456 buckets, 1824 max)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 33.490000] xt_time: kernel timezone is -0000
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 34.050000] Hooked IMQ after mangle on PREROUTING
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 34.060000] Hooked IMQ after nat on POSTROUTING
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 34.060000] IMQ driver loaded successfully. (numdevs = 2, numqueues = 1)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 34.220000] Netfilter messages via NETLINK v0.30.
Jan 1 01:00:36 Gargoyle kern.notice kernel: [ 34.250000] ip_set: protocol 6
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 34.720000] usbcore: registered new interface driver cdc_acm
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 34.720000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 34.840000] usbcore: registered new interface driver usbserial
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 34.840000] USB Serial support registered for generic
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 34.850000] usbcore: registered new interface driver usbserial_generic
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 34.850000] usbserial: USB Serial Driver core
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 34.900000] usbcore: registered new interface driver cdc_ether
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 35.010000] usbcore: registered new interface driver cdc_ncm
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 35.100000] USB Serial support registered for GSM modem (1-port)
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 35.100000] usbcore: registered new interface driver option
Jan 1 01:00:36 Gargoyle kern.info kernel: [ 35.110000] option: v0.7.2:USB Driver for GSM modems
i które polecenie:
cat /proc/bus/usb/devices
czy
cat /sys/kernel/debug/usb/devices?
ubogo coś to nie jest ani połowa logu. Postaraj się albo odłącz na chwilę modem i podłącz go ponownie, Wejdź jeszcze raz do tego logu systemowego i wklej to na forum.
Dowolne.
Zasadnicze pytanie:
modem w routerze i kabel podłączony do kompa i tworze log?
bo jak podłącze modem do routera to nie mam internetu bo router nie działa
musze się przełączać.
i ciekawe: przy podłączonym routerze kablem do kompa i modem w kompie internet też nie działa...
Jan 1 01:14:15 Gargoyle daemon.info dnsmasq[1527]: read /etc/hosts - 2 addresses
Jan 1 01:14:15 Gargoyle daemon.info dnsmasq-dhcp[1527]: read /etc/ethers - 0 addresses
Jan 1 01:14:15 Gargoyle user.info sysinit: ERROR: No valid dynamic DNS service configurations defined
Jan 1 01:14:15 Gargoyle user.info sysinit: (Did you specify correct configuration file path?)
Jan 1 01:14:15 Gargoyle user.info sysinit: setting up led WAN
Jan 1 01:14:15 Gargoyle user.info sysinit: setting up led LAN1
Jan 1 01:14:15 Gargoyle user.info sysinit: setting up led LAN2
Jan 1 01:14:15 Gargoyle user.info sysinit: setting up led LAN3
Jan 1 01:14:15 Gargoyle user.info sysinit: setting up led LAN4
Jan 1 01:14:15 Gargoyle user.info sysinit: setting up led WLAN
Jan 1 01:14:15 Gargoyle user.info sysinit: setting up led USB
Jan 1 01:14:16 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPREQUEST(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:14:16 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:14:20 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:14:20 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:14:27 Gargoyle authpriv.info dropbear[1557]: Child connection from 192.168.2.8:58624
Jan 1 01:14:48 Gargoyle authpriv.warn dropbear[1557]: Login attempt for nonexistent user from 192.168.2.8:58624
Jan 1 01:14:59 Gargoyle authpriv.warn dropbear[1557]: Login attempt for nonexistent user from 192.168.2.8:58624
Jan 1 01:15:05 Gargoyle authpriv.info dropbear[1557]: Exit before auth: Exited normally
Jan 1 01:15:14 Gargoyle authpriv.info dropbear[1636]: Child connection from 192.168.2.8:58634
Jan 1 01:15:35 Gargoyle authpriv.warn dropbear[1636]: Login attempt for nonexistent user from 192.168.2.8:58634
Jan 1 01:15:37 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:15:37 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:15:39 Gargoyle authpriv.warn dropbear[1636]: Login attempt for nonexistent user from 192.168.2.8:58634
Jan 1 01:15:45 Gargoyle authpriv.warn dropbear[1636]: Login attempt for nonexistent user from 192.168.2.8:58634
Jan 1 01:15:54 Gargoyle authpriv.info dropbear[1636]: Exit before auth: Exited normally
Jan 1 01:16:02 Gargoyle authpriv.info dropbear[1664]: Child connection from 192.168.2.8:58656
Jan 1 01:16:21 Gargoyle authpriv.warn dropbear[1664]: Login attempt for nonexistent user from 192.168.2.8:58656
Jan 1 01:16:25 Gargoyle authpriv.warn dropbear[1664]: Login attempt for nonexistent user from 192.168.2.8:58656
Jan 1 01:16:34 Gargoyle authpriv.warn dropbear[1664]: Login attempt for nonexistent user from 192.168.2.8:58656
Jan 1 01:17:23 Gargoyle authpriv.info dropbear[1664]: Exit before auth: Exited normally
Jan 1 01:18:27 Gargoyle authpriv.info dropbear[1839]: Child connection from 192.168.2.8:58764
Jan 1 01:18:49 Gargoyle authpriv.info dropbear[1839]: Exit before auth (user 'root', 0 fails): Exited normally
Jan 1 01:19:24 Gargoyle kern.info kernel: [ 364.600000] eth1: link down
Jan 1 01:19:24 Gargoyle kern.info kernel: [ 364.600000] br-lan: port 1(eth1) entered disabled state
Jan 1 01:22:36 Gargoyle kern.info kernel: [ 556.100000] eth1: link up (1000Mbps/Full duplex)
Jan 1 01:22:36 Gargoyle kern.info kernel: [ 556.100000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:22:36 Gargoyle kern.info kernel: [ 556.110000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:22:36 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPREQUEST(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:22:36 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:22:38 Gargoyle kern.info kernel: [ 558.110000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:22:39 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:22:39 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:22:58 Gargoyle authpriv.info dropbear[1842]: Child connection from 192.168.2.8:58836
Jan 1 01:24:01 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:24:01 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:24:11 Gargoyle authpriv.info dropbear[1842]: Exit before auth (user 'root', 0 fails): Exited normally
Jan 1 01:24:37 Gargoyle authpriv.info dropbear[1845]: Child connection from 192.168.2.8:58854
Jan 1 01:24:48 Gargoyle authpriv.notice dropbear[1845]: Password auth succeeded for 'root' from 192.168.2.8:58854
Jan 1 01:27:32 Gargoyle kern.info kernel: [ 852.100000] eth1: link down
Jan 1 01:27:32 Gargoyle kern.info kernel: [ 852.100000] br-lan: port 1(eth1) entered disabled state
Jan 1 01:29:46 Gargoyle kern.info kernel: [ 986.100000] eth1: link up (1000Mbps/Full duplex)
Jan 1 01:29:46 Gargoyle kern.info kernel: [ 986.100000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:29:46 Gargoyle kern.info kernel: [ 986.110000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:29:48 Gargoyle kern.info kernel: [ 988.110000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:29:49 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPREQUEST(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:29:49 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:29:53 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:29:53 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:30:30 Gargoyle authpriv.info dropbear[1910]: Child connection from 192.168.2.8:58981
Jan 1 01:30:39 Gargoyle authpriv.notice dropbear[1910]: Password auth succeeded for 'root' from 192.168.2.8:58981
Jan 1 01:31:11 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:31:11 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:32:20 Gargoyle kern.info kernel: [ 1140.890000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Jan 1 01:32:20 Gargoyle kern.info kernel: [ 1141.040000] scsi0 : usb-storage 1-1:1.0
Jan 1 01:32:21 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=0123456789ABCDEF
Jan 1 01:32:21 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Selecting /etc/usb_modeswitch.d/12d1:1f01 for mode switching
Jan 1 01:32:21 Gargoyle syslog.notice usb_modeswitch: switch device 12d1:1f01 on 001/002
Jan 1 01:32:21 Gargoyle kern.warn kernel: [ 1141.500000] usb 1-1: usbfs: process 1997 (usb_modeswitch) did not claim interface 0 before use
Jan 1 01:32:21 Gargoyle kern.info kernel: [ 1141.510000] usb 1-1: USB disconnect, device number 2
Jan 1 01:32:21 Gargoyle kern.info kernel: [ 1142.020000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Jan 1 01:32:22 Gargoyle kern.info kernel: [ 1142.170000] cdc_ether 1-1:1.0: eth2: register 'cdc_ether' at usb-ehci-platform-1, CDC Ethernet Device, 0c:5b:8f:27:9a:64
Jan 1 01:32:22 Gargoyle kern.info kernel: [ 1142.190000] scsi1 : usb-storage 1-1:1.2
Jan 1 01:32:22 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=?
Jan 1 01:32:23 Gargoyle kern.notice kernel: [ 1143.190000] scsi 1:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
Jan 1 01:32:23 Gargoyle kern.notice kernel: [ 1143.200000] sd 1:0:0:0: [sda] Attached SCSI removable disk
Jan 1 01:32:23 Gargoyle user.notice usb-modeswitch: 1-1:1.1: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=?
Jan 1 01:32:23 Gargoyle user.notice usb-modeswitch: 1-1:1.2: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=?
Jan 1 01:32:26 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:32:26 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:32:34 Gargoyle kern.info kernel: [ 1154.240000] usb 1-1: USB disconnect, device number 3
Jan 1 01:32:34 Gargoyle kern.info kernel: [ 1154.240000] cdc_ether 1-1:1.0: eth2: unregister 'cdc_ether' usb-ehci-platform-1, CDC Ethernet Device
Jan 1 01:34:11 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:34:11 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:34:19 Gargoyle kern.info kernel: [ 1259.100000] eth1: link down
Jan 1 01:34:19 Gargoyle kern.info kernel: [ 1259.100000] br-lan: port 1(eth1) entered disabled state
Jan 1 01:35:00 Gargoyle kern.info kernel: [ 1300.100000] eth1: link up (1000Mbps/Full duplex)
Jan 1 01:35:00 Gargoyle kern.info kernel: [ 1300.100000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:35:00 Gargoyle kern.info kernel: [ 1300.110000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:35:02 Gargoyle kern.info kernel: [ 1302.110000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:35:03 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPREQUEST(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:35:03 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:35:07 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:35:07 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:36:26 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:36:26 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:36:46 Gargoyle kern.info kernel: [ 1406.100000] eth1: link down
Jan 1 01:36:46 Gargoyle kern.info kernel: [ 1406.100000] br-lan: port 1(eth1) entered disabled state
Jan 1 01:38:38 Gargoyle kern.info kernel: [ 1518.600000] eth1: link up (1000Mbps/Full duplex)
Jan 1 01:38:38 Gargoyle kern.info kernel: [ 1518.600000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:38:38 Gargoyle kern.info kernel: [ 1518.610000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:38:40 Gargoyle kern.info kernel: [ 1520.610000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:38:41 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPREQUEST(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:38:41 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:38:45 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:38:45 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:38:50 Gargoyle kern.info kernel: [ 1531.060000] usb 1-1: new high-speed USB device number 4 using ehci-platform
Jan 1 01:38:51 Gargoyle kern.info kernel: [ 1531.210000] scsi2 : usb-storage 1-1:1.0
Jan 1 01:38:51 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=0123456789ABCDEF
Jan 1 01:38:51 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Selecting /etc/usb_modeswitch.d/12d1:1f01 for mode switching
Jan 1 01:38:51 Gargoyle syslog.notice usb_modeswitch: switch device 12d1:1f01 on 001/004
Jan 1 01:38:51 Gargoyle kern.warn kernel: [ 1531.420000] usb 1-1: usbfs: process 2289 (usb_modeswitch) did not claim interface 0 before use
Jan 1 01:38:51 Gargoyle kern.info kernel: [ 1531.430000] usb 1-1: USB disconnect, device number 4
Jan 1 01:38:51 Gargoyle kern.info kernel: [ 1531.920000] usb 1-1: new high-speed USB device number 5 using ehci-platform
Jan 1 01:38:52 Gargoyle kern.info kernel: [ 1532.070000] cdc_ether 1-1:1.0: eth2: register 'cdc_ether' at usb-ehci-platform-1, CDC Ethernet Device, 0c:5b:8f:27:9a:64
Jan 1 01:38:52 Gargoyle kern.info kernel: [ 1532.090000] scsi3 : usb-storage 1-1:1.2
Jan 1 01:38:52 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=?
Jan 1 01:38:53 Gargoyle kern.notice kernel: [ 1533.090000] scsi 3:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
Jan 1 01:38:53 Gargoyle kern.notice kernel: [ 1533.100000] sd 3:0:0:0: [sda] Attached SCSI removable disk
Jan 1 01:38:53 Gargoyle user.notice usb-modeswitch: 1-1:1.1: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=?
Jan 1 01:38:53 Gargoyle user.notice usb-modeswitch: 1-1:1.2: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=?
Jan 1 01:40:04 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:40:04 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:40:32 Gargoyle kern.info kernel: [ 1632.190000] usb 1-1: USB disconnect, device number 5
Jan 1 01:40:32 Gargoyle kern.info kernel: [ 1632.200000] cdc_ether 1-1:1.0: eth2: unregister 'cdc_ether' usb-ehci-platform-1, CDC Ethernet Device
Jan 1 01:40:53 Gargoyle kern.info kernel: [ 1653.120000] eth1: link down
Jan 1 01:40:53 Gargoyle kern.info kernel: [ 1653.120000] br-lan: port 1(eth1) entered disabled state
Jan 1 01:43:23 Gargoyle kern.info kernel: [ 1803.620000] eth1: link up (1000Mbps/Full duplex)
Jan 1 01:43:23 Gargoyle kern.info kernel: [ 1803.620000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:43:23 Gargoyle kern.info kernel: [ 1803.630000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:43:23 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPREQUEST(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:43:23 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:43:25 Gargoyle kern.info kernel: [ 1805.630000] br-lan: port 1(eth1) entered forwarding state
Jan 1 01:43:27 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPINFORM(br-lan) 192.168.2.8 b8:2a:72:af:b3:62
Jan 1 01:43:27 Gargoyle daemon.info dnsmasq-dhcp[1527]: DHCPACK(br-lan) 192.168.2.8 b8:2a:72:af:b3:62 Marcin-Komputer
Jan 1 01:43:36 Gargoyle kern.info kernel: [ 1816.080000] usb 1-1: new high-speed USB device number 6 using ehci-platform
Jan 1 01:43:36 Gargoyle kern.info kernel: [ 1816.230000] scsi4 : usb-storage 1-1:1.0
Jan 1 01:43:36 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=0123456789ABCDEF
Jan 1 01:43:36 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Selecting /etc/usb_modeswitch.d/12d1:1f01 for mode switching
Jan 1 01:43:36 Gargoyle syslog.notice usb_modeswitch: switch device 12d1:1f01 on 001/006
Jan 1 01:43:36 Gargoyle kern.warn kernel: [ 1816.440000] usb 1-1: usbfs: process 2446 (usb_modeswitch) did not claim interface 0 before use
Jan 1 01:43:36 Gargoyle kern.info kernel: [ 1816.450000] usb 1-1: USB disconnect, device number 6
Jan 1 01:43:36 Gargoyle kern.info kernel: [ 1816.940000] usb 1-1: new high-speed USB device number 7 using ehci-platform
Jan 1 01:43:37 Gargoyle kern.info kernel: [ 1817.090000] cdc_ether 1-1:1.0: eth2: register 'cdc_ether' at usb-ehci-platform-1, CDC Ethernet Device, 0c:5b:8f:27:9a:64
Jan 1 01:43:37 Gargoyle kern.info kernel: [ 1817.100000] scsi5 : usb-storage 1-1:1.2
Jan 1 01:43:37 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=?
Jan 1 01:43:38 Gargoyle kern.notice kernel: [ 1818.110000] scsi 5:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
Jan 1 01:43:38 Gargoyle kern.notice kernel: [ 1818.120000] sd 5:0:0:0: [sda] Attached SCSI removable disk
Jan 1 01:43:38 Gargoyle user.notice usb-modeswitch: 1-1:1.1: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=?
Jan 1 01:43:38 Gargoyle user.notice usb-modeswitch: 1-1:1.2: Manufacturer=HUAWEI_MOBILE Product=HUAWEI_MOBILE Serial=?
Success
co z tymi poleceniami?
po wpisaniu ich w tej formie jak podał admin, komunikat "not found"
wg loga wszystko jest OK.
Włóż modem do portu USB routera. Wejdź na stronę konfiguracyjną routera.
Wybierz ten interfejs WAN na eth2. zapisz ustawienia i już powinien być internet na komputerze.
Niestety nie działa; połączono z siecią brak dostępu do internetu
Ustawiłeś na eth2?
Jeśli modem jest w routerze a internet nie działa to dajesz radę wejść na stronę konfiguracyjną modemu http://192.168.8.1/ ?
tak jest eth2 i dhcp kablowe.
po wejściu na stronę HiLink 192.168.8.1. i połączeniu ręcznym działa
natomiast nie łączy automatycznie
jak to rozwiązać?
to już konfiguracja modemu. Może na tej stronie HiLinka jest opcja Autoconnect?
Zgadza się.
Wszystko teraz działa elegancko.
Dziękuje Panowie za pomoc! Sprzedawca zapewniał mnie że instalacja jest intuicyjna
Najważniejsze że działa
pozdrawiam!
Zaloguj się do modemu i podaj software version i Web UI version.
