Archer MR200
SoC - MT7620A
WiFi 5GHz - MT7610EN
Flash- Winbond 25Q64FVSIG
RAM- Winbond W9751G8KB-25
Modem LTE:
Złącze UART TTL:
Log uruchomienia:
U-Boot 1.1.3 (Jan 27 2015 - 17:52:47)
Board: Ralink APSoC DRAM: 64 MB
relocate_code Pointer at: 83fb0000
enable ephy clock...done. rf reg 29 = 5
SSC disabled.
LTE AC750 v1.0.0
Now running in RAM - U-Boot at: 83fb0000, MONITOR BASE: bc000000
uboot_end: aaea2e2e 83fcd74c
spi_wait_nsec: 29
spi device id: ef 40 17 0 0 (40170000)
find flash: W25Q64BV
Ralink UBoot Version: 4.1.2.0
ASIC 7620_MP (Port5<->GigaSW)
DRAM component: 512 Mbits DDR, width 16
DRAM bus: 16 bit
Total memory: 64 MBytes
Flash component: SPI Flash
Date:Jan 27 2015 Time:17:52:47
icache: sets:512, ways:4, linesz:32 ,total:65536
dcache: sets:256, ways:4, linesz:32 ,total:32768
##### The CPU freq = 580 MHZ ####
estimate memory size =64 Mbytes
BootType = 3
continue to starting system. 0
disableEthForward(1158):disable switch forward...
3: System Boot system code via Flash.(0xbc020000)
## Booting image at bc020000 ...
Uncompressing Kernel Image ... OK
No initrd
## Transferring control to Linux (at address 8000c150) ...
## Giving linux memsize in MB, 64
Starting kernel ...
怘▒▒▒▒fff▒▒~▒▒~fx▒▒▒怘▒怘▒f▒▒▒▒f▒▒▒▒f▒f▒▒▒Linux version 2.6.36 (jenkins@dev-serv er) (gcc version 4.6.3 (Buildroot 2012.11.1) ) #139 Thu Nov 5 11:38:40 CST 2015
The CPU feqenuce set to 580 MHz
MIPS CPU sleep mode enabled.
PCIE: bypass PCIe DLL.
PCIE: Elastic buffer control: Addr:0x68 -> 0xB4
disable all power about PCIe
CPU revision is: 00019650 (MIPS 24Kc)
Determined physical RAM map:
memory: 04000000 @ 00000000 (usable)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 -> 0x00004000
Movable zone start PFN for each node
0: 0x00000000 -> 0x00004000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: console=ttyS1,115200 root=/dev/mtdblock2 rootfstype=squashf s init=/sbin/init
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
Writing ErrCtl register=0003e91f
Readback ErrCtl register=0003e91f
Memory: 61188k/65536k available (2854k kernel code, 4348k reserved, 593k data, 1 64k init, 0k highmem)
NR_IRQS:128
MTK/Ralink System Tick Counter init... cd:8034bf68, m:214748, s:32
console [ttyS1] enabled
Calibrating delay loop... 386.04 BogoMIPS (lpj=772096)
pid_max: default: 4096 minimum: 301
RALINK_GPIOMODE = 1ab01d
RALINK_GPIOMODE = 18b01d
PPLL_CFG1=0xe68000
MT7620 PPLL lock
PPLL_DRV =0x80080504
start PCIe register access
RALINK_PCI_PCICFG_ADDR = 1000f0
*************** MT7620 PCIe RC mode *************
bio: create slab <bio-0> at 0
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x201fffff]
pci 0000:00:00.0: BAR 1: assigned [mem 0x20200000-0x2020ffff]
pci 0000:00:00.0: BAR 1: set to [mem 0x20200000-0x2020ffff] (PCI address [0x2020 0000-0x2020ffff]
pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x200fffff]
pci 0000:01:00.0: BAR 0: set to [mem 0x20000000-0x200fffff] (PCI address [0x2000 0000-0x200fffff]
pci 0000:01:00.1: BAR 0: assigned [mem 0x20100000-0x201fffff]
pci 0000:01:00.1: BAR 0: set to [mem 0x20100000-0x201fffff] (PCI address [0x2010 0000-0x201fffff]
pci 0000:00:00.0: PCI bridge to [bus 01-01]
pci 0000:00:00.0: bridge window [io disabled]
pci 0000:00:00.0: bridge window [mem 0x20000000-0x201fffff]
pci 0000:00:00.0: bridge window [mem pref disabled]
BAR0 at slot 0 = 0
bus=0x0, slot = 0x0
res[0]->start = 0
res[0]->end = 0
res[1]->start = 20200000
res[1]->end = 2020ffff
res[2]->start = 0
res[2]->end = 0
res[3]->start = 0
res[3]->end = 0
res[4]->start = 0
res[4]->end = 0
res[5]->start = 0
res[5]->end = 0
bus=0x1, slot = 0x0
res[0]->start = 20000000
res[0]->end = 200fffff
res[1]->start = 0
res[1]->end = 0
res[2]->start = 0
res[2]->end = 0
res[3]->start = 0
res[3]->end = 0
res[4]->start = 0
res[4]->end = 0
res[5]->start = 0
res[5]->end = 0
bus=0x1, slot = 0x0
res[0]->start = 20100000
res[0]->end = 201fffff
res[1]->start = 0
res[1]->end = 0
res[2]->start = 0
res[2]->end = 0
res[3]->start = 0
res[3]->end = 0
res[4]->start = 0
res[4]->end = 0
res[5]->start = 0
res[5]->end = 0
Switching to clocksource Ralink external timer
NET: Registered protocol family 2
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
RT3xxx EHCI/OHCI init.
squashfs: version 4.0 (2009/01/31) Phillip Lougher
fuse init (API version 7.15)
msgmni has been set to 119
io scheduler noop registered
io scheduler deadline registered (default)
Ralink gpio driver initialized
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250: ttyS0 at MMIO 0x10000500 (irq = 37) is a 16550A
serial8250: ttyS1 at MMIO 0x10000c00 (irq = 12) is a 16550A
loop: module loaded
deice id : ef 40 17 0 0 (40170000)
W25Q64BV(ef 40170000) (8192 Kbytes)
mtd .name = raspi, .size = 0x00800000 (0M) .erasesize = 0x00000008 (0K) .numeras eregions = 65536
Creating 6 MTD partitions on "raspi":
0x000000000000-0x000000020000 : "boot"
0x000000020000-0x000000160000 : "kernel"
0x000000160000-0x0000007d0000 : "rootfs"
mtd: partition "rootfs" set to be root filesystem
0x0000007d0000-0x0000007e0000 : "romfile"
0x0000007e0000-0x0000007f0000 : "config"
0x0000007f0000-0x000000800000 : "radio"
Register flash device:flash0
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
rt3xxx-ehci rt3xxx-ehci: Ralink EHCI Host Controller
rt3xxx-ehci rt3xxx-ehci: new USB bus registered, assigned bus number 1
rt3xxx-ehci rt3xxx-ehci: irq 18, io mem 0x101c0000
rt3xxx-ehci rt3xxx-ehci: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
rt3xxx-ohci rt3xxx-ohci: RT3xxx OHCI Controller
rt3xxx-ohci rt3xxx-ohci: new USB bus registered, assigned bus number 2
rt3xxx-ohci rt3xxx-ohci: irq 18, io mem 0x101c1000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Mirror/redirect action on
u32 classifier
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (2868 buckets, 11472 max)
ip_tables: (C) 2000-2006 Netfilter Core Team, Type=Linux
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 15
Ebtables v2.0 registered
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing unused kernel memory: 164k freed
starting pid 195, tty '': '/etc/init.d/rcS'
rdm_major = 253
spiflash_ioctl_read, Read from 0x007df100 length 0x6, ret 0, retlen 0x6
Read MAC from flash(0x7DF100) 3c-46-ffffffd8-ffffffaa-ffffff89-4f
SMACCR1 -- : 0x00003c46
SMACCR0 -- : 0xd8aa894f
Ralink APSoC Ethernet Driver Initilization. v3.0 256 rx/tx descriptors allocate d, mtu = 1500!
PROC INIT OK!
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
SCSI subsystem initialized
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver rndis_host
dns_init
domain_name:tplinkmodem.net
Raeth v3.0 (Workqueue)
phy_tx_ring = 0x03f4e000, tx_ring = 0xa3f4e000
phy_rx_ring0 = 0x03f4f000, rx_ring0 = 0xa3f4f000
Pseudo Close vlan...
ESW: Link Status Changed - Port5 Link Down
CDMA_CSG_CFG = 81000000
GDMA1_FWD_CFG = 20710000
L2TP core driver, V2.0
PPPoL2TP kernel driver, V2.0
Please press Enter to activate this console. usb 1-1: new high speed USB device using rt3xxx-ehci and address 2
rndis_host 1-1:1.0: lte0: register 'rndis_host' at usb-rt3xxx-1, RNDIS device, f e:ed:b6:44:10:31
usbserial_generic 1-1:1.2: generic converter detected
usb 1-1: generic converter now attached to ttyUSB0
option 1-1:1.4: GSM modem (1-port) converter detected
usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
option 1-1:1.5: GSM modem (1-port) converter detected
usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
scsi0 : usb-storage 1-1:1.6
[ dm_readFile ] 2042: can not open xml file /var/tmp/pc/reduced_data_model.xml! , about to open file /etc/reduced_data_model.xml
spiflash_ioctl_read, Read from 0x007e0000 length 0x10000, ret 0, retlen 0x10000
spiflash_ioctl_read, Read from 0x007e0000 length 0x7089, ret 0, retlen 0x7089
spiflash_ioctl_read, Read from 0x007df200 length 0x4, ret 0, retlen 0x4
spiflash_ioctl_read, Read from 0x00020000 length 0x1d0, ret 0, retlen 0x1d0
scsi 0:0:0:0: Direct-Access TP-LINK MMC Storage PQ: 0 ANSI: 2
sd 0:0:0:0: [sda] Attached SCSI removable disk
[initMpPointer 234] [AT NOTICE] - memory pool : start 0x661138, end 0x6780a8, si ze 94064
[isValidReply 396] Fail to find result flag, but OK flag found...
]sendAtCmdAndGetReply 538] cmd [ate0
[sendAtCmdAndGetReply 539] reply [ate0
OK]
]sendAtCmdAndGetReply 538] cmd [at+tpweb="{"module":"status","action":0}"
+tpweb:{"commit":"Socket Send Error"}
OK]
sendto: No such file or directory
pid 268 send 2001 error
[initMpPointer 234] [AT NOTICE] - memory pool : start 0x8e3150, end 0x8fa0c0, si ze 94064
OK]
OK]
[ oal_sys_getOldTZInfo ] 462: Open TZ file error!
[sendAtCmdAndGetReply 538] cmd [at+tpweb="{"module":"time","action":2,"timeZone" ]"0"}"
OK]
[sendAtCmdAndGetReply 538] cmd spiflash_ioctl_read, Read from 0x007df100 length 0x6, ret 0, retlen 0x6
]at+tpweb="{"module":"status","action":0}"
OK]
ioctl: No such device
[sendAtCmdAndGetReply 538] cmd [at+tpweb="{"module":"time","action":3,"year":"de vice eth0 entered promiscuous mode
197br0: port 1(eth0) entering forwarding state
0"br0: port 1(eth0) entering forwarding state
]"month":"1","date":"1","hour":"0","minute":"0","second":"6"}"
[sendAtCmdAdevice eth0 left promiscuous mode
ndbr0: port 1(eth0) entering forwarding state
OK]
device eth0.6 entered promiscuous mode
device eth0 entered promiscuous mode
br0: port 1(eth0.6) entering forwarding state
OK]
ra0 no private ioctls.
rt2860v2_ap: module license 'unspecified' taints kernel.
Disabling lock debugging due to kernel taint
=== pAd = c0a10000, size = 968080 ===
<-- RTMPAllocTxRxRingMemory, Status=0
<-- RTMPAllocAdapterBlock, Status=0
AP Driver version-2.7.1.6_edcca_monitor_20131227
[ oal_wlan_ra_lteCoexistence ] 6563:
AutoChannelSkipList = 52;56;60;64;100;104;108;112;116;RX DESC a3248000 size = 4 096
120;124;128;132;136;140
RTMP_TimerListAdd: add timer obj c0abd930!
RTMP_TimerListAdd: add timer obj c0a75940!
RTMP_TimerListAdd: add timer obj c0a78194!
RTMP_TimerListAdd: add timer obj c0a78254!
RTMP_TimerListAdd: add timer obj c0a78314!
RTMP_TimerListAdd: add timer obj c0a783d4!
RTMP_TimerListAdd: add timer obj c0a78494!
RTMP_TimerListAdd: add timer obj c0a78554!
RTMP_TimerListAdd: add timer obj c0a78614!
RTMP_TimerListAdd: add timer obj c0a786d4!
RTMP_TimerListAdd: add timer obj c0a78794!
RTMP_TimerListAdd: add timer obj c0a78854!
RTMP_TimerListAdd: add timer obj c0a78914!
RTMP_TimerListAdd: add timer obj c0a789d4!
RTMP_TimerListAdd: add timer obj c0a78a94!
RTMP_TimerListAdd: add timer obj c0a78b54!
RTMP_TimerListAdd: add timer obj c0a78c14!
RTMP_TimerListAdd: add timer obj c0a78cd4!
RTMP_TimerListAdd: add timer obj c0a75914!
RTMP_TimerListAdd: add timer obj c0a78168!
RTMP_TimerListAdd: add timer obj c0a78228!
RTMP_TimerListAdd: add timer obj c0a782e8!
RTMP_TimerListAdd: add timer obj c0a783a8!
RTMP_TimerListAdd: add timer obj c0a78468!
RTMP_TimerListAdd: add timer obj c0a78528!
RTMP_TimerListAdd: add timer obj c0a785e8!
RTMP_TimerListAdd: add timer obj c0a786a8!
RTMP_TimerListAdd: add timer obj c0a78768!
RTMP_TimerListAdd: add timer obj c0a78828!
RTMP_TimerListAdd: add timer obj c0a788e8!
RTMP_TimerListAdd: add timer obj c0a789a8!
RTMP_TimerListAdd: add timer obj c0a78a68!
RTMP_TimerListAdd: add timer obj c0a78b28!
RTMP_TimerListAdd: add timer obj c0a78be8!
RTMP_TimerListAdd: add timer obj c0a78ca8!
RTMP_TimerListAdd: add timer obj c0a758e8!
RTMP_TimerListAdd: add timer obj c0a781c0!
RTMP_TimerListAdd: add timer obj c0a78280!
RTMP_TimerListAdd: add timer obj c0a78340!
RTMP_TimerListAdd: add timer obj c0a78400!
RTMP_TimerListAdd: add timer obj c0a784c0!
RTMP_TimerListAdd: add timer obj c0a78580!
RTMP_TimerListAdd: add timer obj c0a78640!
RTMP_TimerListAdd: add timer obj c0a78700!
RTMP_TimerListAdd: add timer obj c0a787c0!
RTMP_TimerListAdd: add timer obj c0a78880!
RTMP_TimerListAdd: add timer obj c0a78940!
RTMP_TimerListAdd: add timer obj c0a78a00!
RTMP_TimerListAdd: add timer obj c0a78ac0!
RTMP_TimerListAdd: add timer obj c0a78b80!
RTMP_TimerListAdd: add timer obj c0a78c40!
RTMP_TimerListAdd: add timer obj c0a78d00!
RTMP_TimerListAdd: add timer obj c0a1c9b0!
RTMP_TimerListAdd: add timer obj c0a1c5a4!
RTMP_TimerListAdd: add timer obj c0a1c980!
RTMP_TimerListAdd: add timer obj c0a1cd28!
RTMP_TimerListAdd: add timer obj c0a1ca78!
RTMP_TimerListAdd: add timer obj c0a1caa8!
RTMP_TimerListAdd: add timer obj c0a1cc68!
RTMP_TimerListAdd: add timer obj c0a1cc98!
RTMP_TimerListAdd: add timer obj c0a1fbe8!
RTMP_TimerListAdd: add timer obj c0a1f7dc!
RTMP_TimerListAdd: add timer obj c0a1fbb8!
RTMP_TimerListAdd: add timer obj c0a1ff60!
RTMP_TimerListAdd: add timer obj c0a1fcb0!
RTMP_TimerListAdd: add timer obj c0a1fce0!
RTMP_TimerListAdd: add timer obj c0a1fea0!
RTMP_TimerListAdd: add timer obj c0a1fed0!
RTMP_TimerListAdd: add timer obj c0a22e20!
RTMP_TimerListAdd: add timer obj c0a22a14!
RTMP_TimerListAdd: add timer obj c0a22df0!
RTMP_TimerListAdd: add timer obj c0a23198!
RTMP_TimerListAdd: add timer obj c0a22ee8!
RTMP_TimerListAdd: add timer obj c0a22f18!
RTMP_TimerListAdd: add timer obj c0a230d8!
RTMP_TimerListAdd: add timer obj c0a23108!
RTMP_TimerListAdd: add timer obj c0a26058!
RTMP_TimerListAdd: add timer obj c0a25c4c!
RTMP_TimerListAdd: add timer obj c0a26028!
RTMP_TimerListAdd: add timer obj c0a263d0!
RTMP_TimerListAdd: add timer obj c0a26120!
RTMP_TimerListAdd: add timer obj c0a26150!
RTMP_TimerListAdd: add timer obj c0a26310!
RTMP_TimerListAdd: add timer obj c0a26340!
RTMP_TimerListAdd: add timer obj c0a29290!
RTMP_TimerListAdd: add timer obj c0a28e84!
RTMP_TimerListAdd: add timer obj c0a29260!
RTMP_TimerListAdd: add timer obj c0a29608!
RTMP_TimerListAdd: add timer obj c0a29358!
RTMP_TimerListAdd: add timer obj c0a29388!
RTMP_TimerListAdd: add timer obj c0a29548!
RTMP_TimerListAdd: add timer obj c0a29578!
RTMP_TimerListAdd: add timer obj c0a2c4c8!
RTMP_TimerListAdd: add timer obj c0a2c0bc!
RTMP_TimerListAdd: add timer obj c0a2c498!
RTMP_TimerListAdd: add timer obj c0a2c840!
RTMP_TimerListAdd: add timer obj c0a2c590!
RTMP_TimerListAdd: add timer obj c0a2c5c0!
RTMP_TimerListAdd: add timer obj c0a2c780!
RTMP_TimerListAdd: add timer obj c0a2c7b0!
RTMP_TimerListAdd: add timer obj c0a2f700!
RTMP_TimerListAdd: add timer obj c0a2f2f4!
RTMP_TimerListAdd: add timer obj c0a2f6d0!
RTMP_TimerListAdd: add timer obj c0a2fa78!
RTMP_TimerListAdd: add timer obj c0a2f7c8!
RTMP_TimerListAdd: add timer obj c0a2f7f8!
RTMP_TimerListAdd: add timer obj c0a2f9b8!
RTMP_TimerListAdd: add timer obj c0a2f9e8!
RTMP_TimerListAdd: add timer obj c0a32938!
RTMP_TimerListAdd: add timer obj c0a3252c!
RTMP_TimerListAdd: add timer obj c0a32908!
RTMP_TimerListAdd: add timer obj c0a32cb0!
RTMP_TimerListAdd: add timer obj c0a32a00!
RTMP_TimerListAdd: add timer obj c0a32a30!
RTMP_TimerListAdd: add timer obj c0a32bf0!
RTMP_TimerListAdd: add timer obj c0a32c20!
RTMP_TimerListAdd: add timer obj c0a77d4c!
RTMP_TimerListAdd: add timer obj c0a77940!
RTMP_TimerListAdd: add timer obj c0a77d1c!
RTMP_TimerListAdd: add timer obj c0a780c4!
RTMP_TimerListAdd: add timer obj c0a77e14!
RTMP_TimerListAdd: add timer obj c0a77e44!
RTMP_TimerListAdd: add timer obj c0a77d7c!
RTMP_TimerListAdd: add timer obj c0a77dac!
RTMP_TimerListAdd: add timer obj c0a77ddc!
RTMP_TimerListAdd: add timer obj c0a9429c!
RTMP_TimerListAdd: add timer obj c0a943b8!
RTMP_TimerListAdd: add timer obj c0a942c8!
RTMP_TimerListAdd: add timer obj c0a79e84!
RTMP_TimerListAdd: add timer obj c0a19e70!
RTMP_TimerListAdd: add timer obj c0a1d0a8!
RTMP_TimerListAdd: add timer obj c0a202e0!
RTMP_TimerListAdd: add timer obj c0a23518!
RTMP_TimerListAdd: add timer obj c0a26750!
RTMP_TimerListAdd: add timer obj c0a29988!
RTMP_TimerListAdd: add timer obj c0a2cbc0!
RTMP_TimerListAdd: add timer obj c0a2fdf8!
RTMP_TimerListAdd: add timer obj c0a79b94!
!!! use RTMP_RBUS_SUPPORT: AP_PROFILE_PATH_RBUS is /var/Wireless/RT2860AP/RT2860 AP.dat
APSDCapable[0]=0
APSDCapable[1]=0
APSDCapable[2]=0
APSDCapable[3]=0
APSDCapable[4]=0
APSDCapable[5]=0
APSDCapable[6]=0
APSDCapable[7]=0
APSDCapable[8]=0
APSDCapable[9]=0
APSDCapable[10]=0
APSDCapable[11]=0
APSDCapable[12]=0
APSDCapable[13]=0
APSDCapable[14]=0
APSDCapable[15]=0
default ApCliAPSDCapable[0]=0
Key1Str is Invalid key length(0) or Type(0)
Key2Str is Invalid key length(0) or Type(0)
Key3Str is Invalid key length(0) or Type(0)
Key4Str is Invalid key length(0) or Type(0)
1. Phy Mode = 9
2. Phy Mode = 9
exec!
spiflash_ioctl_read, Read from 0x007f0000 length 0x200, ret 0, retlen 0x200
eeFlashId = 0x7620!
E2PROM: D0 target power=0xff1c
E2PROM: 40 MW Power Delta= 2
3. Phy Mode = 9
RTMP_TimerListAdd: add timer obj c0a19a68!
AntCfgInit: primary/secondary ant 0/1
Initialize RF Central Registers for E2 !!!
Initialize RF Central Registers for E3 !!!
Initialize RF Channel Registers for E2 !!!
Initialize RF Channel Registers for E3 !!!
Initialize RF DCCal Registers for E2 !!!
Initialize RF DCCal Registers for E3 !!!
D1 = -3, D2 = 4, CalCode = 16 !!!
RT6352_Temperature_Init : BBPR49 = 0xfffffffd
RT6352_Temperature_Init : TemperatureRef25C = 0xfffffff3
Current Temperature from BBP_R49=0xffffffed
RT6352_TssiTableAdjust: upper_bound = 0x7F decimal: 127
RT6352_TssiTableAdjust: lower_bound = 0xFFFFFF80 decimal: -128
*** RT6352_TssiTableAdjust: G Tssi[-7 .. +7] = -128 -128 -128 -128 -128 -25 -12
- 0 - 12 28 127 127 127 127 127, offset=-13, tuning=1
RT6352_TssiTableAdjust: G Tssi[-7 .. +7] = -128 -128 -128 -128 -128 -38 -25 - -1 3 - -1 15 114 114 114 114 114, offset=-13, tuning=1
mp_temperature=0xfffffffc, step = +0
E2PROM: G Tssi[-7 .. +7] = -128 -128 -128 -128 -128 -38 -25 - -13 - -1 15 114 11 4 114 114 114, offset=-13, tuning=1
TX BW Filter Calibration !!!
RX BW Filter Calibration !!!
LOFT Calibration Done!
IQCalibration Start!
IQCalibration Done! CH = 0, (gain= f, phase=3a)
IQCalibration Done! CH = 1, (gain= f, phase= 1)
TX IQ Calibration Done!
bAutoTxAgcG = 1
MCS Set = ff ff 00 00 01
SYNC - BBP R4 to 20MHz.l
RTMP_TimerListAdd: add timer obj c0a7a19c!
The 4-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 4
Main bssid = 3c:46:d8:aa:89:4f
<==== rt28xx_init, Status=0
0x1300 = 00064300
device ra0 entered promiscuous mode
br0: port 2(ra0) entering forwarding state
device apcli0 entered promiscuous mode
device ra1 entered promiscuous mode
spiflash_ioctl_read, Read from 0x007f0000 length 0x2, ret 0, retlen 0x2
WLAN-Start wlNetlinkTool
Waiting for Wireless Events from interfaces...
swWlanChkAhbErr: netlink to do
rai0 no private ioctls.
wscd: SSDP UDP PORT = 1900
=== pAd = c1002000, size = 1378776 ===
device_id =0x7650
spiflash_ioctl_read, Read from 0x007f8000 length 0x200, ret 0, retlen 0x200
eeFlashId = 0x7610!
==>MT76x0_WLAN_ChipOnOff(): OnOff:1, pAd->WlanFunCtrl:0x0, Reg-WlanFunCtrl=0xff0 00002
MACVersion = 0x76502000
MAC[Ver:Rev=0x76502000 : 0x76100002]
load fw spent 16ms
RX DESC a2703000 size = 4096
RX1 DESC a2704000 size = 4096
cfg_mode=14
cfg_mode=14
wmode_band_equal(): Band Not Equal!
1. Phy Mode = 49
2. Phy Mode = 49
ERROR!!! E2PROM: WRONG VERSION 0x2, should be 1
ext_pa_current_setting = 1
MT76x0_TssiTableAdjust: upper_bound = 0x7F decimal: 127
MT76x0_TssiTableAdjust: lower_bound = 0xFFFFFF80 decimal: -128
*** MT76x0_TssiTableAdjust: A Tssi[-7 .. +7] = -128 -128 -128 -128 -14 -8 -4 * 0 * 3 14 16 127 127 127 127, offset=-4, tuning=1
MT76x0_TssiTableAdjust: A Tssi[-7 .. +7] = -128 -128 -128 -128 -18 -12 -8 * -4 * -1 10 12 123 123 123 123, offset=-4, tuning=1
*** MT76x0_TssiTableAdjust: A Tssi[-7 .. +7] = -128 -128 -128 -128 -18 -11 -6 * -4 * 4 15 20 127 127 127 127, offset=-4, tuning=1
MT76x0_TssiTableAdjust: A Tssi[-7 .. +7] = -128 -128 -128 -128 -22 -15 -10 * -4 * 0 11 16 123 123 123 123, offset=-4, tuning=1
3. Phy Mode = 49
ChipStructAssign(): RALINK6590 hook !
bAutoTxAgcG = 1
MCS Set = ff 00 00 00 01
MT76x0_ChipBBPAdjust():rf_bw=2, ext_ch=1, PrimCh=36, HT-CentCh=38, VHT-CentCh=42
MT76x0_ChipSwitchChannel: DefaultTargetPwr = 0x1c 28
APStartUp(): AP Set CentralFreq at 42(Prim=36, HT-CentCh=38, VHT-CentCh=42, BBP_ BW=2)
Main bssid = 3c:46:d8:aa:89:51
MT76x0_Calibration - Channel = 42, bPowerOn = 1, bSaveCal = 1
FullCalibration - Channel = 42, param = 0x301, bSave = 1, CalibrationMode = 255
FullCalibration - Channel = 136, param = 0x401, bSave = 1, CalibrationMode = 255
FullCalibration - Channel = 155, param = 0x501, bSave = 1, CalibrationMode = 255
FullCalibration - Channel = 42, param = 0x701, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 36, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 36, param = 0x701, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 40, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 40, param = 0x701, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 44, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 44, param = 0x701, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 48, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 48, param = 0x701, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 52, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 52, param = 0x701, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 56, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 56, param = 0x701, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 60, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 60, param = 0x701, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 64, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 64, param = 0x701, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 100, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 100, param = 0x801, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 104, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 104, param = 0x801, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 108, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 108, param = 0x801, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 112, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 112, param = 0x801, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 116, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 116, param = 0x801, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 120, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 120, param = 0x801, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 124, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 124, param = 0x801, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 128, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 128, param = 0x801, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 132, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 132, param = 0x801, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 136, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 136, param = 0x801, bSave = 0, CalibrationMode = 255
MT76x0_Calibration - Channel = 140, bPowerOn = 0, bSaveCal = 0
FullCalibration - Channel = 140, param = 0x901, bSave = 0, CalibrationMode = 255
MT76x0_ChipBBPAdjust():rf_bw=2, ext_ch=1, PrimCh=44, HT-CentCh=46, VHT-CentCh=42
APStartUp(): AP Set CentralFreq at 42(Prim=44, HT-CentCh=46, VHT-CentCh=42, BBP_ BW=2)
MT76x0_Calibration - Channel = 42, bPowerOn = 0, bSaveCal = 0
0x1300 = 00064300
RTMPDrvOpen(1):Check if PDMA is idle!
RTMPDrvOpen(2):Check if PDMA is idle!
device rai0 entered promiscuous mode
br0: port 5(rai0) entering forwarding state
device apclii0 entered promiscuous mode
device rai1 entered promiscuous mode
wlNetspiflash_ioctl_read, Read from 0x007f8000 length 0x2, ret 0, retlen 0x2
linkTool is already there.
pid 268 send 2030 error
pid 268 send 2004 error
iptables: Bad rule (does a matching rule exist in that chain?).
radvd starting
[ getPidFromPidFile ] 112: Cann't open file: /var/run/zebra.pid.
[ getPidFromPidFile ] 112: Cann't open file: /var/run/ripd.pid.
iptables: No chain/target/match by that name.
Ralink HW NAT Module Enabled
ip6tables: Bad rule (does a matching rule exist in that chain?).
[rsl_initWanLteIntfCfgObj 2157] init LTE module, set flowstat [enableDataLimit 0, enablePaymentDay 0, paymentDay 1, limitation 0, warningPercent 90]
[rsl_initLteWanCfgObj 2229] init LTE module, default roamingEnabled [false]
[rsl_initLteWanCfgObj 2249] init LTE module, default networkPreferredMode [3]
[rsl_initLteWanCfgObj 2269] init LTE module, default dataSwitchStatus [true]
[rsl_initLteWanCfgObj 2279] lte profile num [1], default profile [1], active profile [0]
[rsl_initLteWanCfgObj 2281] config profile num [1], default profile [1], active profile [0]
[checkStatus 1520] LTE internet connected.
[set_lteDns6 758] set LTE dns6 ::,::
starting pid 269, tty '': '/sbin/getty -L ttyS1 115200 vt100'
Archer MR200 login: admin
Password:
Jan 30 10:46:14 login[269]: root login on 'ttyS1'
