Archer D7v1:
SoC: QCA9558-AT4A
RAM: 2x WinbondW9751G6KB
Flash: Spansion FL127SIF10
Wlan 5GHz: QCA9880-BR4A
Switch: Atheros AR8327N-BL1A
Modem:
SoC: Broadcom BCM6318
Ram: ESMT M12L128168A
Flash: 25Q16DVSIG
Zdjęcia płytki:
SoC + 128MB Ram routera:
Karta Wlan 5GHz + Flash routera 16MB:
SoC + Ram + Flash modemu ADSL:
Chip Switcha:
Log uruchomienia:
U-Boot 1.1.4 (Jan 22 2014 - 11:54:05)
ap135 - Scorpion 1.0
DRAM: 128 MB
Flash Manuf Id 0x1, DeviceId0 0x20, DeviceId1 0x18
S25FL128P recongnized...
flash size 16MB, sector count = 256
Flash: 16 MB
Using default environment
In: serial
Out: serial
Err: serial
Net: ath_gmac_enet_initialize...
athrs_sgmii_res_cal: cal value = 0x1
ath_gmac_enet_initialize: reset mask:c02200
Scorpion ----> S17 PHY *
athrs17_reg_init: complete
: cfg1 0x80000000 cfg2 0x7114
eth0: e8:de:27:30:c3:bb
eth0 up
athrs17_reg_init_wan done
SGMII in forced mode
athr_gmac_sgmii_setup SGMII done
: cfg1 0x800c0000 cfg2 0x7214
eth1: e8:de:27:30:c3:bc
eth1 up
eth0, eth1
Setting 0x18116290 to 0x4081214f
## Booting image at 80800000 ...
Uncompressing Kernel Image ... OK
Starting kernel ...
Booting QCA955x
Linux version 2.6.31--LSDK-9.5.2.18 (swd@localhost.localdomain) (gcc version 4.3.3 (GCC) ) #10 Tue Feb 25 09:57:49 CST 2014
flash_size passed from bootloader = 16
arg 1: console=ttyS0,115200
arg 2: root=31:02
arg 3: rootfstype=squashfs
arg 4: init=/sbin/init
arg 5: mtdparts=ath-nor0:128k(u-boot),1152k(kernel),14848k(rootfs),64k(config),64k(romfs),64k(reserve),64k(radio)
arg 6: mem=128M
CPU revision is: 00019750 (MIPS 74Kc)
cpu apb ddr apb ath_sys_frequency: cpu 720 ddr 600 ahb 200
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
User-defined physical RAM map:
memory: 08000000 @ 00000000 (usable)
Zone PFN ranges:
Normal 0x00000000 -> 0x00008000
Movable zone start PFN for each node
0: 0x00000000 -> 0x00008000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: console=ttyS0,115200 root=31:02 rootfstype=squashfs init=/sbin/init mtdparts=ath-nor0:128k(u-boot),1152k(kernel),14848k(rootfs),64k(config),64k(romfs),64k(reserve),64k(radio) mem=128M
PID hash table entries: 512 (order: 9, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=00000000
Readback ErrCtl register=00000000
Memory: 112256k/131072k available (2267k kernel code, 18644k reserved, 601k data, 136k init, 0k highmem)
NR_IRQS:128
plat_time_init: plat time init done
Calibrating delay loop... 359.42 BogoMIPS (lpj=718848)
****************ALLOC***********************
Packet mem: 8030f300 (0xe00000 bytes)
ath_pcibios_init: bus 0
***** Warning PCIe 0 H/W not found !!!
registering PCI controller with io_map_base unset
ath_pcibios_init: bus 1
ath_pcibios_init(232): PCI 1 CMD write: 0x356
bio: create slab <bio-0> at 0
pci 0000:01:00.0: PME# supported from D0 D1 D3hot
pci 0000:01:00.0: PME# disabled
pcibios_map_irq: IRQ 76 for bus 1
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
ATH GPIOC major 0
squashfs: version 4.0 (2009/01/31) Phillip Lougher
fuse init (API version 7.12)
msgmni has been set to 219
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xb8020000 (irq = 19) is a 16550A
console [ttyS0] enabled
brd: module loaded
loop: module loaded
7 cmdlinepart partitions found on MTD device ath-nor0
Creating 7 MTD partitions on "ath-nor0":
0x000000000000-0x000000020000 : "u-boot"
0x000000020000-0x000000140000 : "kernel"
0x000000140000-0x000000fc0000 : "rootfs"
0x000000fc0000-0x000000fd0000 : "config"
0x000000fd0000-0x000000fe0000 : "romfs"
0x000000fe0000-0x000000ff0000 : "reserve"
0x000000ff0000-0x000001000000 : "radio"
Mirror/redirect action on
u32 classifier
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (2048 buckets, 10240 max)
CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use
nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or
sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 15
Ebtables v2.0 registered
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
arch/mips/atheros/gpio.c (ath_simple_config_init) JUMPSTART_GPIO: 16
athwdt_init: Registering WDT success
ath_otp_init: Registering OTP success
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing unused kernel memory: 136k freed
starting pid 162, tty '': '/etc/init.d/rcS'
mount: mounting devpts on /dev/pts failed: No such device
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Port Status 1c000004
ath-ehci ath-ehci.0: ATH EHCI
ath-ehci ath-ehci.0: new USB bus registered, assigned bus number 1
ehci_reset Intialize USB CONTROLLER in host mode: 13
ehci_reset Port Status 1c000000
ath-ehci ath-ehci.0: irq 3, io mem 0x1b000000
ath-ehci ath-ehci.0: USB 2.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ath-ehci1 ath-ehci1.1: ATH EHCI
ath-ehci1 ath-ehci1.1: new USB bus registered, assigned bus number 2
ath-ehci1 ath-ehci1.1: irq 3, io mem 0x1b400000
ath-ehci1 ath-ehci1.1: USB 2.0 started, EHCI 1.00
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
dns_init
domain_name:tplinkmodem.net
PPPoL2TP kernel driver, V1.0
Please press Enter to activate this console. [ dm_readFile ] 2042: can not open xml file /var/tmp/pc/reduced_data_model.xml!, about to open file /etc/reduced_data_model.xml
init system mode
qca955x_GMAC: Length per segment 1536
955x_GMAC: qca955x_gmac_attach
955x_GMAC: qca955x_set_gmac_caps
Currently in polling mode unit1
mac:1 Registering S17....
qca955x_GMAC: RX TASKLET - Pkts per Intr:200
qca955x_GMAC: Max segments per packet : 1
qca955x_GMAC: Max tx descriptor count : 220
qca955x_GMAC: Max rx descriptor count : 220
qca955x_GMAC: Mac capability flags : 12002200
Currently in polling mode unit0
mac:0 Registering S17....
qca955x_GMAC: Mac capability flags : 10002A00
955x_GMAC: Serdes PLL is locked value 0x18838116
athr_gmac_ring_alloc Allocated 3520 at 0x87a47000 for 1 (RX=0)
athr_gmac_ring_alloc Allocated 3520 at 0x87a09000 for 0 (RX=0)
@@[athr_gmac_rx_alloc]: r->ring_desc is a7bbd000 , r->ring_desc_dma is 7bbd000 , r->ring_buffer is 87a09000
955x_GMAC: eth1 in SGMII MODE
Scorpion -----> S17 PHY
[athrs17_reg_init]: entering
_athrs17_mac0_intf SGMII done
[athrs17_reg_init]: complete
955x_SGMII::athr_gmac_sgmii_setup Done
Setting Drop CRC Errors, Pause Frames and Length Error frames
Setting PHY...
[athrs17_disable_vlan_dsl]: Doing Basic init for Vlan for Grouping not enable
Phy setup Complete
955x_GMAC: enet unit:1 is up...
eth1 SGMII 1000Mbps full duplex
955x_GMAC: qca955x_soc_gmac_set_mac_duplex
955x_GMAC: qca955x_soc_gmac_set_link Done
955x_GMAC: done cfg2 0x7215 ifctl 0x0 miictrl
[ oal_sys_getOldTZInfo ] 359: Open TZ file error!
ioctl: No such device
device eth0.2 entered promiscuous mode
device eth0 entered promiscuous mode
br0: port 1(eth0.2) entering forwarding state
device eth0.3 entered promiscuous mode
br0: port 2(eth0.3) entering forwarding state
device eth0.4 entered promiscuous mode
br0: port 3(eth0.4) entering forwarding state
device eth0.5 entered promiscuous mode
br0: port 4(eth0.5) entering forwarding state
*********cal_data_2g*******
020200023537707500000000
*********cal_data_end*******
*********cal_data_5g*******
4408c09e9999090000080808
adf: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, WRITE_EEPROM, 11D)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
ath_ahb: 10.1.467 (Atheros/multi-bss)
__ath_attach: Set global_scn[0]
Enterprise mode: 0x33fc0000
Restoring Cal data from Flash
Green-AP : Green-AP : Attached
ath_get_caps[5956] rx chainmask mismatch actual 7 sc_chainmak 0
ath_get_caps[5931] tx chainmask mismatch actual 7 sc_chainmak 0
wifi0: Atheros ???: mem=0xb8100000, irq=2
ath_pci: 10.1.467 (Atheros/multi-bss)
ath_pci_probe
PCI device id is 003c :003c
ath_pci 0000:01:00.0: ath DEBUG: sc=0x86eef200
ol_ath_pci_configure : num_desired MSI set to 0
Using PCI Legacy Interrupt
Enet:1 port3 up
__ol_ath_attach: ath_attach TODO
ol_ath_attach() BMI inited.
ol_ath_attach() BMI Get Target Info.
ol_ath_attach() TARGET TYPE: 7 Vers 0x4100016c
NUM_DEV=1 FWMODE=0x2 FWSUBMODE=0x0 FWBR_BUF 0
ol_ath_attach() configure Target .
qc98xx_verify_checksum: flash checksum passed: 0x9ec0
ol_transfer_bin_file 1685: Download Flash data len 2116
ol_transfer_bin_file 1632: Download Firmware data len 190332
ol_ath_attach() Download FW.
ol_ath_attach() HT Create .
ol_ath_attach() HIF Claim.
ol_ath_attach() BMI Done.
ol_ath_attach() WMI attached. wmi_handle 865e0000
+HWT
CE_recv_buf_enqueue 457 Populate last entry 512 for CE 5
CE_recv_buf_enqueue 466 CE 5 wi 511 dest_ptr 0x64cb20 nbytes 0 recv_ctxt 0x86e2ccc0
-HWT
HTC Service:0x0300 ep:1 TX flow control disabled
CE_pkt_dl_len_set CE 4 Pkt download length 42
TXRX: Created pdev 86ecdc00
wmi_service_ready_event_rx: WMI UNIFIED SERVICE READY event
num_rf_chain : 00000003
ht_cap_info: : 0000085b
vht_cap_info : 338001b2
vht_supp_mcs : 0000ffea
LARGE_AP enabled. num_peers 144, num_vdevs 16, num_tids 256
idx 0 req 1 num_units 0 num_unit_info 2 unit size 404 actual units 145
chunk 0 len 58580 requested ,ptr 0x6c90000
FIRMWARE:P 145 V 16 T 443
wmi_ready_event_rx: WMI UNIFIED READY event
ol_ath_connect_htc() WMI is ready
ol_ath_set_host_app_area TODO
target uses HTT version 2.1; host uses 2.1
ol_ath_attach() connect HTC.
ol_regdmn_start: reg-domain param: regdmn=0, countryName=, wModeSelect=FFFFFFFF, netBand=FFFFFFFF, extendedChanMode=0.
ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2) flags 0x2150
ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4) flags 0xa0
ol_regdmn_init_channels: !avail mode 0x1f9001 (0x8) flags 0xc0
ol_regdmn_init_channels: !avail mode 0x1f9001 (0x20) flags 0xd0
ol_regdmn_init_channels: !avail mode 0x1f9001 (0x40) flags 0x150
ol_regdmn_init_channels: !avail mode 0x1f9001 (0x800) flags 0x10080
ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2000) flags 0x20080
ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4000) flags 0x40080
Skipping VHT80 channel 5825
ol_ath_phyerr_attach: called
OL Resmgr Init-ed
Green-AP : Attached
ol_ath_rtt_meas_report_attach: called
ol_ath_attach() UMAC attach .
__ol_ath_attach: init tx/rx TODO
__ol_ath_attach: hard_header_len reservation 58
__ol_ath_attach: dev name wifi1
VAP device ath0 created
ath0
VAP device ath1 created
ath1
VAP device ath2 created
ath2
DES SSID SET=TP-LINK_Archer D7 2.4GHz_30C3BB
WARNING: Fragmentation with HT mode NOT ALLOWED!!
Error for wireless request "Set Fragmentation Threshold" (8B24) :
SET failed on device ath0 ; Invalid argument.
Setting Max Stations:32
DES SSID SET=TP-LINK_Guest_2.4GHz
SET failed on device ath2 ; Invalid argument.
Reading topology file /var/Wireless/2_4G_topology.conf ...
012.178: Reading radio configuration file /var/Wireless/2_4G_80211g.ap_radio ...
012.178: Reading bss configuration file /var/Wireless/ath0.ap_bss ...
ieee80211_ioctl_siwmode: imr.ifm_active=131712, new mode=3, valid=1
Using interface ath0 with hwaddr e8:de:27:30:c3:bb and ssid 'TP-LINK_Archer D7 2.4GHz_30C3BB'
012.369: upnp_wps_device_init called
l2_packet_receive - recvfrom: Network is down
device ath0 entered promiscuous mode
br0: port 5(ath0) entering forwarding state
device ath1 entered promiscuous mode
device ath2 entered promiscuous mode
ath_ioctl: SIOC80211IFCREATE CALLED
wmi_unified_vdev_create_send: ID = 0 VAP Addr = e8:de:27:30:c3:bd:
TXRX: Created vdev 87b73a20 (e8:de:27:30:c3:bd)
Setting vdev param = 26, value = 147
Setting vdev param = 27, value = 295
Setting vdev param = 28, value = 300
VAP device ath5 created
TXRX: ol_txrx_peer_find_add_id: peer 87bd3800 ID 508
TXRX: ol_txrx_peer_find_add_id: peer 87bd3800 ID 268
ath5
wmi_unified_vdev_create_send: ID = 1 VAP Addr = ea:de:27:30:c3:bd:
wmi_unified_set_psmode:set psmode=1
TXRX: Created vdev 87b73840 (ea:de:27:30:c3:bd)
VAP device ath6 created
ath6
ol_ath_vap_set_param: VAP param unsupported param:80 value:1
wmi_unified_set_psmode:set psmode=0
Setting vdev param = 4, value = 1
Setting vdev param = f, value = 1
wmi_unified_vdev_create_send: ID = 2 VAP Addr = fa:de:27:30:c3:bd:
TXRX: Created vdev 87b73600 (fa:de:27:30:c3:bd)
VAP device ath7 created
TXRX: ol_txrx_peer_find_add_id: peer 86cf9800 ID 509
TXRX: ol_txrx_peer_find_add_id: peer 86cf9800 ID 269
ath7
DES SSID SET=TP-LINK_Archer_D7_5GHz_30C3BD
ol_ath_vap_set_param: VAP param unsupported param:35 value:0
[ol_ath_iw_setcountry][1257] *p=4a, *(p+1)=50
isCountryCodeValid: EEPROM regdomain 0x0
ol_regdmn_init_channels: !avail mode 0x21001 (0x2) flags 0x2150
ol_regdmn_init_channels: Skipping 20 freq band.
ol_regdmn_init_channels: !avail mode 0x21001 (0x4) flags 0xa0
ol_regdmn_init_channels: !avail mode 0x21001 (0x8) flags 0xc0
ol_regdmn_init_channels: !avail mode 0x21001 (0x20) flags 0xd0
ol_regdmn_init_channels: !avail mode 0x21001 (0x40) flags 0x150
ol_regdmn_init_channels: !avail mode 0x21001 (0x800) flags 0x10080
ol_regdmn_init_channels: !avail mode 0x21001 (0x2000) flags 0x20080
ol_regdmn_init_channels: !avail mode 0x21001 (0x4000) flags 0x40080
ol_regdmn_init_channels: !avail mode 0x21001 (0x8000) flags 0x20100
ol_regdmn_init_channels: !avail mode 0x21001 (0x10000) flags 0x40100
ol_regdmn_init_channels: !avail mode 0x21001 (0x40000) flags 0x200100
ol_regdmn_init_channels: !avail mode 0x21001 (0x80000) flags 0x400100
ol_regdmn_init_channels: !avail mode 0x21001 (0x100000) flags 0x800100
Interface doesn't accept private ioctl...
mode (8BF2): Invalid OL vap_stop +
argument
wmi_unified_vdev_stop_send
OL vap_stop -
STOPPED EVENT for vap 0
ol_ath_vap_set_param: VAP param unsupported param:38 value:0
ol_ath_vap_set_param: VAP param unsupported param:43 value:0
ol_ath_vap_set_param: VAP param unsupported param:41 value:0
Setting vdev param = 2a, value = 2
ol_ath_vap_set_param: VAP param is now supported param:62 value:2
Setting vdev param = 3, value = 100
SET faileSetting vdev param = d, value = 1
d on device ath5 ; Invalid argument.
Setting vdev param = 1a, value = 1
Setting vdev param = 12, value = 1
Setting vdev param = 1e, value = 1
ol_ath_vap_set_param: VAP param unsupported param:32 value:1
ol_ath_vap_set_param: VAP param unsupported param:74 value:0
ol_ath_vap_set_param: VAP param unsupported param:32 value:0
ol_ath_vap_set_param: VAP param unsupported param:33 value:0
DES SSID SET=TP-LINK_Guest_5GHz
argument
OL vap_stop -
FWLOG: [22211] WHAL_ERROR_RECV_STOPPCU ( 0x110298a, 0x3 )
FWLOG: [22211] WHAL_ERROR_RESET_PM ( )
STOPPED EVENT for vap 2
d on device ath7 ; Invalid argument.
Reading topology file /var/Wirel ieee80211_ioctl_siwmode: imr.ifm_active=66176, new mode=3, valid=1
ess/5G_topology.conf ...
017.24ol_ath_vap_set_param: VAP param unsupported param:32 value:0
9: Reading radiool_ath_vap_set_param: VAP param unsupported param:17 value:1
configuration fol_ath_vap_set_param: VAP param unsupported param:32 value:0
ile /var/Wireless/5G_80211g.ap_radio ...
017.249: Reading bss configuration file /var/Wireless/ath5.ap_bss ...
Using interface ath5 with hwaddr e8:de:27:30:c3:bd and ssid 'TP-LINK_Archer_D7_5GHz_30C3BD'
ol_ath_vap_set_param: VAP param unsupported param:74 value:1
Group Keyidx set=1
wmi_unified_vdev_install_key_send Setting Key for Macaddress:0xbdc33027dee8
Keyix=1 Keylen=16 Keyflags=1 Cipher=4
Keydata=0xb2 0x26 0x99 0x41 0xf9 0x4f 0xf4 0x7d 0x49 0xec 0xc3 0xf1 0xce 0xce 0x8b 0xbd
TXRX: ol_txrx_peer_find_add_id: peer 87bd3800 ID 300
TXRX: sec spec for peer 87bd3800 (e8:de:27:30:c3:bd): mcast key of type 6
Setting vdev param = 1f, value = 1
017.492: upnp_wps_device_init called
FWLOG: [23219] WAL_DBGID_SECURITY_ENCR_EN ( )
FWLOG: [23219] WAL_DBGID_SECURITY_MCAST_KEY_SET ( 0x1 )
ol_ath_vap_set_param: VAP param unsupported param:49 value:1
OL vap_stop +
OL vap_stop -
Invoking ACS module for Best channel selection
Function ieee80211_acs_find_best_11na_centerchan best 5G channel is 36
OL vap_start +
OL vap_start -
ol_vdev_start_resp_ev
ol_ath_vap_join: join operation is only for STA/IBSS mode
ol_ath_wmm_update:
Notification to UMAC VAP layer
OL vap_stop +
OL vap_stop -
OL vap_start +
OL vap_start -
ol_ath_wmm_update:
OL vap_start +
OL vap_start -
FWLOG: [33873] WAL_DBGID_BB_WDOG_TRIGGERED ( 0x8451, 0x200008a, 0x0, 0x24 )
device ath5 entered promiscuous mode
br0: port 8(ath5) entering forwarding state
device ath6 entered promiscuous mode
device ath7 entered promiscuous mode
iptables: Bad rule (does a matching rule exist in that chain?).
radvd starting
[ getPidFromPidFile ] 112: Cann't open file: /var/run/zebra.pid.
pppoe_init() success
PPPoE DevName Hook, the name is eth0.2000
Connected to fe:ff:ff:ff:ff:fd via interface eth0.2000
Using interface ppp0
Connect: ppp0 <--> eth0.2000
[ getPidFromPidFile ] 112: Cann't open file: /var/run/ripd.pid.
ip6tables: Bad rule (does a matching rule exist in that chain?).
[ rsl_initDslIptvCfgObj ] 1965: DSL IPTV not enable or not firstInit.
[ rsl_setStorageServiceObj ] 1019: mountFlag is 3,We start usb server
killall: ushare: no process killed
uShare (version 1.1a), a lightweight UPnP A/V and DLNA Media Server.
Benjamin Zores (C) 2005-2007, for GeeXboX Team.
See http://ushare.geexbox.org/ for updates.
kcg 323 :GPL NetUSB up!
kc 90 : run_telnetDBGDServer start
kc 227 : init_DebugD end
INFO17EA: NetUSB 1.02.44, 0002061F : Dec 20 2013 11:05:15
INFO17EC: AUTH ISOC
INFO17ED: filterAudio
usbcore: registered new interface driver KC NetUSB General Driver
INFO0135: init proc : PAGE_SIZE 4096
INFO16BE: infomap 8668ca1c
INFO16C1: sleep to wait br0 to wake up
INFO02D0: use dev Name br0
INFO16CA: sleep to wait br0 end.
INFO16E3: UDP_BROAD 7437 tcpPort:625868800
INFO15CA: tcpConnector() started...
Enable forwarding
INFO14A7: Bind to br0
LCP: timeout sending Config-Requests
Connection terminated.
Modem hangup
CHAP authentication succeeded
peer from calling number FE:FF:FF:FF:FF:FD authorized
local IP address 83.5.167.83
remote IP address 83.1.4.58
primary DNS address 194.204.152.34
secondary DNS address 194.204.159.1
iptables: No chain/target/match by that name.
