Archer C9v1
SoC: Broadcom BCM4709A0KFEBG 1000MHz dualcore
RAM: 128MB SK hynix H5TQ1G63EFR
Flash: Spansion FL128SAIF00
WLAN: 2x Broadcom BCM4360KMLG
Port J6 - UART:
Log systemowy:
Digital core power voltage set to 1.0V
Decompressing...done
SHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S300001EF
00001580
RDLYW0 00000004
RDENW0 00000031
RDQSW0
0000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00
-----++++++++++++++++++++++++++++X+++++++++++++++++++++++++--
01
---++++++++++++++++++++++++++X+++++++++++++++++++++++++
02
-----++++++++++++++++++++++++X++++++++++++++++++++++++
03
-----++++++++++++++++++++++++++++X+++++++++++++++++++++++++++
04
----++++++++++++++++++++++++++X+++++++++++++++++++++++++
05
---+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
06
-----++++++++++++++++++++++++++X+++++++++++++++++++++++++
07
----+++++++++++++++++++++++++++X++++++++++++++++++++++++++
08 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++
09
10 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++
11
-----+++++++++++++++++++++++++++X++++++++++++++++++++++++++
12
13
14
----++++++++++++++++++++++++++X++++++++++++++++++++++++++
15
----++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-
PW0
00
---+++++++++++++++++++++++++++X+++++++++++++++++++++++++--
01
02
03
---+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
04 -+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
05
----++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
06
07
08 --+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
09
-----+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-
10 -++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
11
12
13
---+++++++++++++++++++++++++++++X++++++++++++++++++++++++++--
14
15
NW0
00
01
02
----+++++++++++++++++++++++++X++++++++++++++++++++++++
03
04
05
06
07
09
11
12
13
14
15
---+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-
WRDQW0
00 +++++++++++++++++++++++++X++++++++++++++++++++++++
01 ++++++++++++++++++++++++++X++++++++++++++++++++++++++
02 +++++++++++++++++++++++++X+++++++++++++++++++++++++
03 ++++++++++++++++++++++++++X++++++++++++++++++++++++++
04 +++++++++++++++++++++++X++++++++++++++++++++++
05 ++++++++++++++++++++++++++X++++++++++++++++++++++++++
06 ++++++++++++++++++++++++X+++++++++++++++++++++++
07 +++++++++++++++++++++++++X+++++++++++++++++++++++++
08 ++++++++++++++++++++++++X+++++++++++++++++++++++
09 ++++++++++++++++++++++++++X+++++++++++++++++++++++++
10 +++++++++++++++++++++++X+++++++++++++++++++++++
11 ++++++++++++++++++++++++++X+++++++++++++++++++++++++
12 +++++++++++++++++++++++X+++++++++++++++++++++++
13 ++++++++++++++++++++++++++X++++++++++++++++++++++++++
14 +++++++++++++++++++++++++X+++++++++++++++++++++++++
15 ++++++++++++++++++++++++++X+++++++++++++++++++++++++
WRDMW0 00000025
WRDMW0 00000024
ADDR
00 +++++++++++++++++++++S+++++++++X++++++++++++++++++++++++++++++++
CFE version 6.37.14.93 (r469350) based on BBP 1.0.37 for BCM947XX (32bit,SP,)
Build Date: Wed Nov 12 12:27:07 CST 2014 (root@localhost.localdomain)
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 262144(0x40000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.93 (r469350)
CPU type 0x0: 1000MHz
Tot mem: 131072 KBytes
CFE mem: 0x00F00000 - 0x02F80E04 (34082308)
Data: 0x00F48AE8 - 0x00F48FBC (1236)
BSS: 0x00F48FC8 - 0x00F7EE04 (220732)
Heap: 0x00F7EE04 - 0x02F7EE04 (33554432)
Stack: 0x02F7EE04 - 0x02F80E04 (8192)
Text: 0x00F00000 - 0x00F3F23C (258620)
Device eth0: hwaddr 14-CC-20-D1-DC-AA, ipaddr 192.168.0.1, mask 255.255.255.0
gateway not set, nameserver not set
Loader:raw Filesys:raw Dev:flash0.os File: Options:(null)
Loading: .... 4232512 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550
brd: module loaded
loop: module loaded
pflash: found no supported devices
bcmsflash: squash filesystem found at block 36
Creating 5 MTD partitions on "bcmsflash":
0x000000000000-0x000000040000 : "boot"
0x000000040000-0x000000240000 : "linux"
0x000000240000-0x000000ee0000 : "rootfs"
0x000000fe0000-0x000000ff0000 : "radio"
0x000000ff0000-0x000001000000 : "nvram"
nflash: found no supported devices
usbmon: debugfs is not available
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:0b.1: EHCI Host Controller
ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000
ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci_hcd 0000:00:0b.0: OHCI Host Controller
ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
xhci_hcd 0000:00:0c.0: xHCI Host Controller
xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3
xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000
xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
usb usb3: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
xHCI xhci_add_endpoint called for root hub
xHCI xhci_check_bandwidth called for root hub
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
nf_conntrack version 0.5.0 (1960 buckets, 7840 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 10
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012
brcmnand: found no supported devices
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing init memory: 216K
init started: BusyBox v1.01 (2014.11.12-04:38+0000) multi-call binary
This board use 2.6.36
ctf: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
et_module_init: passivemode set to 0x0
et_module_init: txworkq set to 0x0
et_module_init: et_txq_thresh set to 0x400
si_doattach: incoming bus is PCI but it's a lie, switching to SI devid:0x4715
Found chip type NAI (0x3f00cf12)
Chipc: rev 42, caps 0x48000a, chipst 0x0 pmurev 0, pmucaps 0x0
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.93 (r469350)
xt_time: kernel timezone is -0000
u32 classifier
Actions configured
L2TP core driver, V2.0
PPPoL2TP kernel driver, V2.0
PPTP driver version 0.8.3
(none) armv7l #1 SMP PREEMPT Wed Nov 12 12:33:55 CST 2014 (none)
(none) login: ====>>>>@@@@@@size is 49340@@@@@@
start uclited
====>>>>*****total size is 49340******
check size inited
device eth0.1 entered promiscuous mode
device eth0 entered promiscuous mode
br0: port 1(eth0.1) entering forwarding state
Attempt to kill tasklet from interrupt
device eth0 left promiscuous mode
checkSizeThread 457 1 49340 49340
====>>>>DHCP start.dhcpc.c,dhcpcStart,1100
====>>>>DHCP end.dhcpc.c,dhcpcStart,1164
nf_conntrack_rtsp v0.6.21 loading
nf_nat_rtsp v0.6.21 loading
wl_module_init: msglevel set to 0x1
wl_module_init: msglevel2 set to 0x0
wl_module_init: phymsglevel set to 0x1
wl_module_init: passivemode set to 0x0
wl_module_init: txworkq set to 0x0
Found chip type AI (0x15134360)
Chipc: rev 43, caps 0x58680001, chipst 0x9a6d pmurev 17, pmucaps 0x10a22b11
srom rev:0
HTAVAIL is set, so not updating BBPLL Frequency
Changing rsrc 6 res_updn_timer to 0x100001
wl0: wlc_attach: Overriding device id: 0x43a1 instead of 0x4360
Overriding device id = 0x43a1
wl0: wlc_bmac_phy_reset: band not yet set
wlc_bmac_attach, deviceid 0x43a1 nbands 1
wl0: wlc_bmac_attach: chiprev 3 corerev 42 cccap 0x58680001 maccap 0x30518c05 band 2.4G, phy_type 11 phy_rev 1
wl0: wlc_stf_txcore_shmem_write: No clock
wl0: wlc_ampdu_tx_set: AGG Mode = MAC+AQM txmaxpkts 1024
wl0: online cpus 2
eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.93 (r469350 WLTEST) (Compiled in . at 12:35:49 on Nov 12 2014)
srom rev:0
Overriding boardvendor: 0x14e4 instead of 0x14e4
wl1: wlc_attach: Overriding device id: 0x43a2 instead of 0x4360
Overriding device id = 0x43a2
wl1: wlc_bmac_phy_reset: band not yet set
wlc_bmac_attach, deviceid 0x43a2 nbands 1
wl1: wlc_bmac_attach: chiprev 3 corerev 42 cccap 0x58680001 maccap 0x30518c05 band 5G, phy_type 11 phy_rev 1
wl1: wlc_stf_txcore_shmem_write: No clock
wl1: wlc_ampdu_tx_set: AGG Mode = MAC+AQM txmaxpkts 1024
wl1: online cpus 2
eth2: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.93 (r469350 WLTEST) (Compiled in . at 12:35:49 on Nov 12 2014)
device eth1 entered promiscuous mode
wl0: wlc_enable_probe_req: state down, deferring setting of host flags
br0: port 2(eth1) entering forwarding state
====>>>>start: eth1.
wl0: wlc_iovar_op: BCME -20 (Bad Channel)
device eth2 entered promiscuous mode
wl1: wlc_enable_probe_req: state down, deferring setting of host flags
br0: port 3(eth2) entering forwarding state
====>>>>start: eth2.
wl1: wlc_iovar_op: BCME -20 (Bad Channel)
acsd: scan in progress ...
acsd: selected channel spec: 0x100b
acsd: Adjusted channel spec: 0x100b
acsd: selected DFS-exit channel spec: 0x100b
acsd: selected channel spec: 0xe09b
acsd: Adjusted channel spec: 0xe09b
acsd: selected DFS-exit channel spec: 0xe09b
wl0: link up (eth1)
wl1: link up (eth2)
====>>>>task[6151]: start ok!
====>>>>startup: start ok!
kcg 323 :GPL NetUSB up!
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
kc 90 : run_telnetDBGDServer start
kc 227 : init_DebugD end
INFO17F1: NetUSB 1.02.47, 00020624 : Feb 12 2014 10:44:29
INFO17F3: AUTH ISOC
INFO17F4: filterAudio
usbcore: registered new interface driver KC NetUSB General Driver
INFO013F: init proc : PAGE_SIZE 4096
INFO16C5: infomap bf807a14
INFO16C8: sleep to wait br0 to wake up
INFO02D0: use dev Name br0
INFO16D1: sleep to wait br0 end.
INFO16EA: UDP_BROAD 7437 tcpPort:20005
INFO15D1: tcpConnector() started...
IPv6 over IPv4 tunneling driver
INFO14AE: Bind to br0
start check
check success
Archer_C9 armv7l #1 SMP PREEMPT Wed Nov 12 12:33:55 CST 2014 (none)
Archer_C9 login: root
Password:
Jan 1 00:00:46 login[425]: root login on `ttyS0'
BusyBox v1.01 (2014.11.12-04:38+0000) Built-in shell (msh)
Enter 'help' for a list of built-in commands.
Login: root Password: sohoadmin
nvram:
# nvram show
wl_radius_port=1812
qos_reset=0
wl1_wme=on
wan_unit=0
qos_irates=0,0,0,0,0,0,0,0,0,0
wl1_intfer_txbad=
wl0_wmf_bss_enable=1
wl0_rxchain_pwrsave_stas_assoc_check=0
wl1_auth=0
wl0_pspretend_threshold=0
0:rxgains2gtrisoa0=7
wan_route=
wl1_hwaddr=14:CC:20:D1:DC:A8
wl0_mcast_regen_bss_enable=1
wl0_rifs_advert=auto
wan0_primary=1
0:rxgains2gtrisoa1=7
wl0_frameburst=on
wl_txstreams=0
samba_mode=
0:rxgains2gtrisoa2=7
wan_pppoe_keepalive=0
wl_rxchain_pwrsave_pps=10
0:pa2ga0=0xff2e,0x1c68,0xfc93
log_ipaddr=
wl_assoc_retry_max=3
wan0_ipaddr=0.0.0.0
1:sb20in80and160lr5ghpo=0
1:tssiposslope5g=1
0:pa2ga1=0xff30,0x1cbb,0xfc8b
boardrev=0x1102
wl1_wme_bss_disable=0
wl1_mimo_preamble=
wan0_proto=dhcp
wl0.14_hwaddr=16:CC:20:D1:DC:A7
0:pa2ga2=0xff31,0x1c54,0xfc99
br0_ifnames=eth0.1 eth1 eth2
wl1_acs_fcs_mode=0
wl1_txstreams=0
wl1_acs_dfsr_activity=30 10240
wl_dwds=0
wl_intfer_retryrate=
wl_version=6.37.14.62
et0macaddr=14:CC:20:D1:DC:AA
wl0_leddc=0x640000
1:antswitch=0
1:boardflags=0x30000000
wl0_bw_cap=3
wl1_wme_txp_vi=7 3 6 2 0
wl1.12_hwaddr=16:CC:20:D1:DC:A4
1:mcsbw805glpo=0xb9765200
wan_pppoe_passwd=
wl0_akm=psk2
wl_maxassoc=64
wl_txbf_bfr_cap=1
wl0_intf_drate=0
wl0_intf_glitch=0
devpath0=pci/1/1
watchdog=3000
boot_wait=off
wl1_bss_opmode_cap_reqd=0
wl1_acs_ci_scan_timer=4
wan0_dns=
wl1_bss_hs2_enabled=1
1:rxgains5ghelnagaina0=2
1:tempoffset=0
devpath1=pci/2/1
wl_phytypes=
wl_rxchain_pwrsave_stas_assoc_check=0
wl_leddc=0x640000
wps_modelname=Archer_C9
1:rxgains5ghelnagaina1=2
wl0_infra=1
wl1_rifs_advert=auto
1:rxgains5ghelnagaina2=3
1:sb40and80lr5gmpo=0
et0mdcport=0
fw_disable=0
wl0_country_code=Q2
0:venid=0x14e4
wl1_wep=disabled
wl1_wme_txp_vo=7 3 6 2 0
emf_rtport_entry=
wl1_intfer_swindow=
0:aa2g=7
wl1_frag=2346
wl_infra=1
reset_gpio=17
wl_chanspec=11
wl1_acs_excl_chans=
pmon_ver=CFE 6.37.14.93 (r469350)
1:mcsbw805ghpo=0xfdba9630
wl0_bcn_rotate=1
wl_stbc_tx=auto
wl1_pspretend_threshold=0
wl1_rifs=
restore_defaults=0
vlan2ports=0 5u
wl1_wpa_gtk_rekey=0
wl_acs_dfsr_immediate=300 3
wan0_ifname=eth0
wl0.1_hwaddr=12:CC:20:D1:DC:AA
wl1_ampdu_rtylimit_tid=5 5 5 5 5 5 5 5
wl1_preauth=
wl1_intf_glitch=0
wl0_intfer_txnoack=
wan_lease=86400
wan_pppoe_service=
wl1_maclist=
wl0_wme_sta_be=15 1023 3 0 0 off off
wl1_intf_speriod=50
wl1.1_hwaddr=12:CC:20:D1:DC:A9
wl1_ure=
1:sb20in80and160hr5glpo=0
1:femctrl=3
wl0_version=6.37.14.62
wl_wme_apsd=on
http_wanport=
wl_radius_ipaddr=
wl_acs_chan_dwell_time=30
wl0.7_hwaddr=16:CC:20:D1:DC:A0
lan_gateway=192.168.0.1
wl1_amsdu=auto
wl1_crypto=aes
wl0_psr_mrpt=0
wl_intf_scnt=5
wl0_ifname=eth1
0:mcsbw402gpo=0xeb987532
lan_domain=
lan_ipv6_prefix=2001:db8:1:0::/64
wl0_intfer_retryrate=
wl1_hw_txchain=7
wl1.7_hwaddr=16:CC:20:D1:DC:AF
timer_interval=3600
wl1_psr_mrpt=0
wl0_wme_sta_bk=15 1023 7 0 0 off off
gpio2=wps_led
lan1_ipaddr=192.168.2.1
0:epagain2g=0
gpio3=wps_button
forward_port0=
wl0_rxchain_pwrsave_quiet_time=1800
wl_net_reauth=36000
wl1_bss_maxassoc=64
igmp_enable=0
wl1_intfer_glitch=
wl0_rxstreams=0
wl_acs_dfsr_deferred=604800 5
wl1_intf_scnt=5
wl1_wmf_ucast_upnp=0
wan_pppoe_mru=1492
wl1_corerev=42
wl0_intfer_dmarate=
1:sb20in40lrpo=0
1:sb20in80and160hr5ghpo=0
lan_route=
wl0_radio_pwrsave_level=0
wl1_nmcsidx=-1
partialboots=0
wl0.1_wps_mode=disabled
wps_device_pin=79342513
wl0_mrate=0
wl1_rx_amsdu_in_ampdu=auto
wan_gateway=0.0.0.0
wl0_mode=ap
wl_intf_txbad=0
wl1.1_infra=1
1:rxgains5gmtrelnabypa0=1
dhcp_start=192.168.1.100
wl1_intfer_retryrate=
1:rxgains5gmtrelnabypa1=1
wl1_nmode=-1
wl0_stbc_tx=auto
wl1_intfer_speriod=
1:rxgains5gmtrelnabypa2=1
lan1_route=
wl0_ap_isolate=0
wl0_intfer_txbad=
0:mcsbw202gpo=0xeb987532
dhcp_end=192.168.1.150
wl0_rxchain_pwrsave_pps=10
wl_mrate=0
wl_wmf_bss_enable=1
wl_akm=
wl_wmf_mdata_sendup=0
wl0.15_hwaddr=16:CC:20:D1:DC:A8
1:mcsbw405glpo=0xb9765200
sromrev=8
wl0_gmode=1
wl0_ampdu=auto
wl0_wme_no_ack=off
wfi_error=
wl1_intfer_cnt=3
wl1.1_wmf_bss_enable=1
wl1_rts=2346
wl1_stbc_rx=1
wl0_wfi_pinmode=0
samba_passwd=
boardtype=0x0665
qos_sticky=1
wl0_dcs_csa_unicast=0
1:sb40and80hr5gmpo=0
is_default=1
wl_wme_bss_disable=0
wl_ampdu_rr_rtylimit_tid=2 2 2 2 2 2 2 2
wl1_ampdu_rr_rtylimit_tid=2 2 2 2 2 2 2 2
wl0_acs_dfsr_immediate=300 3
ctf_disable=0
1:mcslr5glpo=0
1:mcsbw1605glpo=0
wl_gmode=1
wl1_bw_cap=7
wl_ampdu=auto
wl0_acs_fcs_mode=0
wl0_nband=2
1:dot11agduplrpo=0
stats_server=
1:ccode=Q1
wl1.13_hwaddr=16:CC:20:D1:DC:A5
1:macaddr=14:CC:20:D1:DC:A8
wl1_txchain=7
1:rxgains5ghtrelnabypa0=1
0:legofdmbw202gpo=0x87532222
lan_netmask=255.255.255.0
lan1_ifname=
1:rxgains5ghtrelnabypa1=1
wl0_wme_txp_be=7 3 6 2 0
wl1_obss_coex=1
wl0_ssid=TP-LINK_DCA9
1:rxgains5ghtrelnabypa2=1
1:mcsbw405ghpo=0xfdba9630
lan1_hwnames=
http_username=
wl1_key=1
wl0_dtim=1
wl_wme_sta_vi=7 15 2 6016 3008 off off
wl_acs_scan_entry_expire=3600
1:rpcal5gb0=0xe648
wl1_acs_scan_entry_expire=3600
wl1_rxchain_pwrsave_stas_assoc_check=0
wl_wme_ap_be=15 63 3 0 0 off off
wan0_pppoe_ifname=
os_date=Nov 12 2014
wl1_radio_pwrsave_level=0
1:rpcal5gb3=0xec50
1:mcslr5ghpo=0
1:mcsbw1605ghpo=0
http_lanport=80
wps_random_ssid_prefix=TP-LINK_
wl1_wfi_pinmode=0
wl0_wme_txp_bk=7 3 6 2 0
0:rxchain=7
wl_plcphdr=short
wl_wme_sta_vo=3 7 2 3264 1504 off off
wl1.1_bss_enabled=0
lan1_wins=
wl_macmode=disabled
wl_mimo_preamble=
wl1_intfer_scount=
nvram_version=1
wan_hwname=
wan_domain=
wl1_wme_ap_be=15 63 3 0 0 off off
wl_wme_ap_bk=15 1023 7 0 0 off off
lan_lease=86400
wan_netmask=0.0.0.0
wl0_key1=
wl_lazywds=0
wl0_key2=
wl0_vlan_prio_mode=off
wan0_hostname=
wl0.2_hwaddr=16:CC:20:D1:DC:AB
wl1_rxchain_pwrsave_pps=10
wl0_key3=
wl_mcast_regen_bss_enable=1
wl0_key4=
wl1_radius_key=
wl_intf_rrate=0
filter_client0=
wl_intf_swin=7
wl1.2_hwaddr=16:CC:20:D1:DC:AA
lan1_lease=86400
0:cckbw20ul2gpo=0
0:tempthresh=120
filter_maclist=
wl1_wme_ap_bk=15 1023 7 0 0 off off
wl_auth_mode=none
wl0_wmf_mdata_sendup=0
wl0_acs_chan_dwell_time=30
wl_intfer_txnoack=
wl0.8_hwaddr=16:CC:20:D1:DC:A1
1:devid=0x43a2
qos_orules=
wl1_ifname=eth2
wl1_bcn=100
wl0_intf_speriod=50
wl_intf_txnoack=0x4000f
vlan2hwname=et0
wl1.8_hwaddr=16:CC:20:D1:DC:A0
wl1_intf_swin=7
http_passwd=admin
wl0_rxchain_pwrsave_enable=1
wl_wpa_psk=
wl0_acs_dfsr_deferred=604800 5
wl0_bridge=
wl0_hw_rxchain=7
wl1_auth_mode=none
lan_stp=1
wan_pppoe_demand=0
nat_type=sym
wl0_wme_ap_vi=7 15 1 6016 3008 off off
1:sb40and80lr5glpo=0
wl_mode=ap
wl0_bss_maxassoc=64
0:sar2g=18
wl1_wmf_mdata_sendup=0
wan0_pppoe_passwd=
wl0_mfp=0
qos_ibw=1500
0:sb20in40lrpo=0
wl0_closed=0
wl1_mcast_regen_bss_enable=1
wl0_rate=0
wl0_plcphdr=short
wl1_wet_tunnel=0
wl0_tpc_db=0
wl_intfer_dmarate=
wl0.10_hwaddr=16:CC:20:D1:DC:A3
xtalfreq=25000
wl0_macmode=disabled
wl0_assoc_retry_max=3
wl_wpa_gtk_rekey=0
wps_version2=enabled
lan_dhcp=0
wl0_radioids=BCM2069
wl0_wme_ap_vo=3 7 2 3264 1504 off off
wl1_dwds=0
wl1_wfi_enable=0
wl_wme_txp_vi=7 3 6 2 0
wl0_phytype=v
nvram_space=65536
0:gainctrlsph=0
wl0_lazywds=0
wl1_radioids=BCM2069
wl1_rxchain_pwrsave_quiet_time=1800
wl1_acs_tx_idle_cnt=5
wps_proc_status=0
boardflags2=0x00000000
wan0_pppoe_keepalive=0
wl0_intfer_period=1
1:sb40and80lr5ghpo=0
wl1_version=6.37.14.62
wl_wme_txp_vo=7 3 6 2 0
wl_acs_ci_scan_timeout=300
lan_hwaddr=
wl_wds_timeout=1
wl0_antdiv=-1
wl0_intfer_swindow=
1:maxp5ga0=96,104,104,104
wan_dns=
wl_wps_mode=enabled
1:maxp5ga1=96,104,104,104
dpsta_ifnames=
wl1_acs_chan_dwell_time=30
wl_intfer_glitch=
wl1.14_hwaddr=16:CC:20:D1:DC:A6
1:maxp5ga2=96,104,104,104
0:regrev=27
wan0_pppoe_ac=
wl_ssid=TP-LINK
wl_dtim=1
wan_pppoe_mtu=1492
wl1_frameburst=on
wl0_wpa_psk=79342513
lan_wps_oob=disabled
wl0_acs_excl_chans=
wait_time=3
wl_trf_mgmt_rssi_policy=0
wl_acs_dfs=0
1:sar5g=15
wl0_amsdu=auto
1:gainctrlsph=0
0:pdoffset40ma0=0
0:pdoffset40ma1=0
dhcp_wins=wan
wl0_country_rev=79
0:rxgains2gelnagaina0=4
0:pdoffset40ma2=0
0:pdgain2g=14
os_server=
0:rxgains2gelnagaina1=4
wl1_txbf_bfe_cap=1
0:rxgains2gelnagaina2=4
wan_proto=dhcp
wl_key1=
wl_amsdu=auto
lan_wps_reg=enabled
br0_ifname=br0
wl0_wmf_igmpq_filter=0
wl_key2=
0:sromrev=11
wl_key3=
wl1_stbc_tx=auto
wl0_unit=0
wan0_pppoe_mru=1492
1:aga0=0
0:cckbw202gpo=0
wl_country_code=US
wl_key4=
wl1_intf_drate=0
wan0_mtu=1500
1:subband5gver=0x4
1:aga1=0
wl_hwaddr=
wl0.3_hwaddr=16:CC:20:D1:DC:AC
1:aga2=0
wl_rxchain=7
wl0_bss_enabled=1
wl0_net_reauth=36000
wl1_sta_retry_time=5
wl_vlan_prio_mode=off
acs_ctrl_chan_adjust=0
wl1.3_hwaddr=16:CC:20:D1:DC:AB
lan1_stp=1
wl0_nmode=-1
wl0_wmf_ucast_upnp=0
wl_pspretend_retry_limit=0
wl1_pspretend_retry_limit=0
wl0.9_hwaddr=16:CC:20:D1:DC:A2
pci/1/1/rpcal2g=0x2bea
1:sb40and80hr5glpo=0
wan_pppoe_idletime=60
wl_rifs_advert=auto
wl1_acs_dfsr_immediate=300 3
wl1_wmf_igmpq_filter=0
wps_restart=0
wl1.9_hwaddr=16:CC:20:D1:DC:A1
wl1_country_rev=79
wl0_intf_txbad=0
wl_nmode=-1
wl1_bridge=
lan1_gateway=192.168.2.1
wl1_bcn_rotate=1
wl0_intfer_speriod=
1:sb20in40hrpo=0
wl0_acs_dfs=0
wl_rxstreams=0
wl_wps_reg=enabled
qos_ack=1
qos_burst0=
wl0_wds=
wl1_txbf_bfr_cap=1
1:mcsbw205gmpo=0xfdba9630
qos_burst1=
wl_rate=0
0:ccode=Q1
log_level=0
wl1_wme_sta_be=15 1023 3 0 0 off off
wl_intfer_scount=
wfi_cmd=
wan0_gateway=0.0.0.0
0:rpcal2g=0x2bea
ntp_server=192.5.41.40 192.5.41.41 133.100.9.2
wl1_closed=0
wl0_reg_mode=off
1:sb40and80hr5ghpo=0
wan_hwaddr=
wl1_bss_enabled=1
wps_mfstring=TP-LINK
lan_ipv6_dns=
wl1_tpc_db=0
wl0_intfer_txfail=5
wl0.11_hwaddr=16:CC:20:D1:DC:A4
1:rxchain=7
wl1_rxstreams=0
wl_intf_glitch=0
0:rxgains2gtrelnabypa=1
lan_ifnames=eth0.1 eth1 eth2
wl1_reg_mode=off
wl1_akm=psk2
0:dot11agduplrpo=0
wl0_auth=0
wl0_wme=on
wl0_radius_port=1812
wl1_wme_sta_bk=15 1023 7 0 0 off off
wl_rxchain_pwrsave_quiet_time=1800
wl1_radio=1
wl0_wme_bss_disable=0
wl0_radius_ipaddr=
wl0_rxchain=7
wl_radio_pwrsave_pps=10
ure_disable=1
1:dot11agduphrpo=0
1:papdcap5g=0
wl0_wme_sta_vi=7 15 2 6016 3008 off off
wl1_antdiv=-1
wl_acs_cs_scan_timer=900
qos_method=0
wl1_acs_dfsr_deferred=604800 5
wl0_acs_ci_scan_timeout=300
wl1.1_wps_mode=disabled
wan_pppoe_username=
wl_acs_tx_idle_cnt=5
wl_intfer_txbad=
wl1.15_hwaddr=16:CC:20:D1:DC:A7
1:rxgains5gtrelnabypa0=1
1:regrev=27
0:ofdmlrbw202gpo=0x022
wan_ifnames=eth0
wl_intfer_swindow=
1:rxgains5gtrelnabypa1=1
wl_rateset=default
wl_crypto=tkip+aes
wl0_wme_sta_vo=3 7 2 3264 1504 off off
wan0_hwname=
wan0_domain=
1:rxgains5gtrelnabypa2=1
wl1_ap_isolate=0
wl_acs_chan_flop_period=30
wl0_bss_hs2_enabled=1
wl1_radio_pwrsave_quiet_time=1800
wl0_wps_reg=enabled
0:devid=0x43a1
wl1_wme_no_ack=off
wl_acs_excl_chans=
lan_ipaddr=192.168.0.1
clkfreq=1000,800
os_name=linux
lan_proto=dhcp
wl_radius_key=
wl1_radius_port=1812
wl_acs_fcs_mode=0
lan1_netmask=255.255.255.0
vlan1hwname=et0
wl_rxchain_pwrsave_enable=1
wl_psr_mrpt=0
wl0_maxassoc=64
wl0_intf_rrate=0
0:dot11agofdmhrbw202gpo=0x8753
wl1_plcphdr=short
wl_unit=1
wan0_route=
br1_ifname=
wl0_phytypes=v
wl1_macmode=disabled
wl1_maxassoc=64
wan0_pppoe_demand=0
wps_sta_pin=00000000
lan1_proto=dhcp
router_disable=1
wl0_wep=disabled
wl0_frag=2346
wl_nmode_protection=auto
wl0_txbf_bfe_cap=1
wan0_netmask=0.0.0.0
wl1_phytype=v
1:boardvendor=0x14e4
wl1_phytypes=v
wl_radio_pwrsave_enable=0
wl1_lazywds=0
wl0_intfer_tcptxfail=5
wl0.4_hwaddr=16:CC:20:D1:DC:AD
0:maxp2ga0=110
0:temps_hysteresis=5
0:maxp2ga1=110
sdram_config=0x014B
wl1_wme_txp_be=7 3 6 2 0
wl0_rifs=
1:pdoffset80ma0=0
0:maxp2ga2=110
wl_radio_pwrsave_stas_assoc_check=0
wl1.4_hwaddr=16:CC:20:D1:DC:AC
1:pdoffset80ma1=0
vlan1ports=1 2 3 4 5*
dmz_ipaddr=
wl0_chanspec=0
wan0_wins=
1:pdoffset80ma2=0
wl_wds=
wl1_trf_mgmt_rssi_policy=0
wl_txq_thresh=1024
wl_acs_dfsr_activity=30 10240
wl1_chanspec=0
wl1_mode=ap
wl1_wme_txp_bk=7 3 6 2 0
wl_wet_tunnel=0
wl_wmf_ucast_upnp=0
wl1_acs_ci_scan_timeout=300
wl1_rxchain_pwrsave_enable=1
wl0_rateset=default
wl0_ampdu_rr_rtylimit_tid=2 2 2 2 2 2 2 2
wl0_ure=
wl_bw_cap=3
1:temps_hysteresis=5
0:boardflags=0x1000
wl1_wpa_psk=79342513
wl_wfi_enable=0
wl0_wme_apsd=on
wl1_intfer_tcptxfail=5
wl_wfi_pinmode=0
wl0_wme_txp_vi=7 3 6 2 0
wl_acs_ci_scan_timer=4
wl_wme=on
wl0_txstreams=0
wl_wmf_psta_disable=
wl0.1_radio=0
0:sb20in40hrpo=0
wl1_wme_apsd=on
wl_intfer_speriod=
1:rxgains5gmtrisoa0=5
0:tempoffset=0
lan_ifname=br0
wan_primary=0
wl_wme_ap_vi=7 15 1 6016 3008 off off
dpsta_lan_uif=1
wl_intf_speriod=50
1:rxgains5gmtrisoa1=4
boardflags=0x00000110
lan_ipv6_6to4id=0
wl0_mimo_preamble=
1:rxgains5gmtrisoa2=4
1:tempthresh=120
0:antswitch=0
wandevs=et0
sdram_refresh=0x0c30
wl0_txbf_bfr_cap=1
wl0_acs_scan_entry_expire=3600
wan0_pppoe_mtu=1492
1:rxgains5gelnagaina0=1
qos_icmp=0
dhcp_domain=wan
wl0_wme_txp_vo=7 3 6 2 0
wl0.12_hwaddr=16:CC:20:D1:DC:A5
1:rxgains5gelnagaina1=1
0:phycal_tempdelta=0
0:txchain=7
wl_auth=0
et_txq_thresh=1024
wl1_dcs_csa_unicast=0
sdram_ncdl=0x00000000
1:rxgains5gelnagaina2=1
1:sromrev=11
lan1_domain=
wl1_wme_ap_vi=7 15 1 6016 3008 off off
wl_wme_ap_vo=3 7 2 3264 1504 off off
wl1_wmf_bss_enable=1
ezc_enable=1
wl_frameburst=on
wl_bss_maxassoc=64
wl1_hw_rxchain=7
wl0_radio_pwrsave_pps=10
wl0_radio_pwrsave_stas_assoc_check=0
wl0_nmode_protection=auto
wan0_lease=86400
wl1_ssid=TP-LINK_DCA8_5G
wl1_dtim=1
wl1.10_hwaddr=16:CC:20:D1:DC:A2
qos_enable=0
wl0_acs_cs_scan_timer=900
is_modified=0
wl1_intfer_period=1
1:sb20in80and160lr5gmpo=0
wan_ipaddr=0.0.0.0
wl1_wme_ap_vo=3 7 2 3264 1504 off off
lan_ipv6_mode=3
1:phycal_tempdelta=0
wl0_rts=2346
lan1_dhcp=0
wan_wins=
wl_ifname=
0:boardflags2=0x100002
wl_wep=disabled
wl_ampdu_rtylimit_tid=5 5 5 5 5 5 5 5
wl0_trf_mgmt_rssi_policy=0
wl1_intf_txnoack=0x4000f
0:boardflags3=0x3
wl1_key1=
wl_intf_drate=0
wl1_nmode_protection=auto
wl0_hw_txchain=7
os_version=6.37.14.62
wl1_key2=
wl1_acs_dfs=0
wl1_key3=
wl_gmode_protection=auto
1:pdoffset40ma0=0x1111
wl1_key4=
wl1_leddc=0x640000
wl0_wpa_gtk_rekey=0
lan1_wps_oob=enabled
1:mcsbw205glpo=0xb9765200
1:pdoffset40ma1=0x1111
wl0_sta_retry_time=5
1:pdoffset40ma2=0x1111
wl_frag=2346
wan0_desc=Default Connection
gpio12=usbport2
wl0_key=1
wl_preauth=
wl0_wmf_psta_disable=
wan_mtu=1500
gpio13=usbport1
qos_obw=384
filter_macmode=deny
wl_maclist=
emf_entry=
1:temps_period=5
wl1_infra=1
wl_rifs=
et0phyaddr=30
console_loglevel=1
wl0_intf_scnt=5
wl0.5_hwaddr=16:CC:20:D1:DC:AE
1:venid=0x14e4
0:agbg0=0
time_zone=PST8PDT
wl_bcn_rotate=1
lan1_wps_reg=enabled
wl_ure=
1:mcsbw805gmpo=0xfdba9630
0:agbg1=0
qos_default=3
wl_bss_opmode_cap_reqd=0
wl_wps_config_state=0
wl1_rxchain=7
1:pdgain5g=4
0:agbg2=0
wl1_acs_chan_flop_period=30
acs_ifnames=eth1 eth2
wl1.5_hwaddr=16:CC:20:D1:DC:AD
1:boardflags2=0x300002
wl0_acs_dfsr_activity=30 10240
wl0_intfer_glitch=
wl1_mfp=0
1:mcsbw205ghpo=0xfdba9630
1:boardflags3=0x0
wan_ifname=eth0
wl1_intfer_txnoack=
wan0_pppoe_idletime=60
wan0_pppoe_service=
wl0_intfer_cnt=3
wl1_wps_oob=disabled
wl_wme_sta_be=15 1023 3 0 0 off off
wl1_wmf_psta_disable=
wan0_ipv6_prefix=2001:db0:1:0::/64
0:papdcap2g=0
wl_radioids=
wl_wmf_ucigmp_query=0
wan0_hwaddr=
landevs=eth0.1 wl0 wl1
wan_hostname=
wl1_rate=0
dhcp1_start=192.168.2.100
wl_corerev=
wl0_radio=1
wl_nmcsidx=-1
1:rxgains5gtrisoa0=7
1:rxgains5ghtrisoa0=5
wl0_acs_ci_scan_timer=4
1:rxgains5gtrisoa1=6
1:rxgains5ghtrisoa1=4
1:rxgains5gtrisoa2=5
1:rxgains5ghtrisoa2=4
wl1_assoc_retry_max=3
wl0_bcn=100
wl_wme_sta_bk=15 1023 7 0 0 off off
wl_pspretend_threshold=0
wl1_wps_reg=enabled
0:legofdmbw20ul2gpo=0x87532222
wl0_hwaddr=14:CC:20:D1:DC:A9
wl_radio=1
wl1_radio_pwrsave_enable=0
0:tworangetssi2g=0
wl1_net_reauth=36000
wps_wer_mode=allow
qos_orates=80-100,10-100,5-100,3-100,2-95,0-0,0-0,0-0,0-0,0-0
wl0_ampdu_rtylimit_tid=5 5 5 5 5 5 5 5
0:dot11agduphrpo=0
ezc_version=2
emf_enable=1
wl0_preauth=
wl1_intfer_dmarate=
wl0.13_hwaddr=16:CC:20:D1:DC:A6
wl0_gmode_protection=auto
wl_stbc_rx=1
1:sb20in80and160hr5gmpo=0
0:femctrl=3
wl0_maclist=
wl1_intfer_txfail=5
wl_radio_pwrsave_quiet_time=1800
wl0_obss_coex=1
sdram_init=0x0000
wl_rts=2346
wl1_intf_txbad=0
1:epagain5g=0
lan_wins=
wan_desc=
wl_ap_isolate=0
wl0_dwds=0
lan_hwnames=
wps_modelnum=123456
wl_dcs_csa_unicast=0
wl1.11_hwaddr=16:CC:20:D1:DC:A3
lan1_ifnames=
wl_country_rev=0
wl1_mrate=0
wl1_radius_ipaddr=
wl0_acs_tx_idle_cnt=5
wl_txchain=7
dhcp1_end=192.168.2.150
wl1_country_code=Q2
wl_wme_no_ack=off
wan0_pppoe_username=
wan0_unit=0
wl1_gmode_protection=auto
wl0_radius_key=
wl0_wps_config_state=0
1:rxgains5gmelnagaina0=2
1:tworangetssi5g=0
wl0_wme_ap_be=15 63 3 0 0 off off
1:rxgains5gmelnagaina1=2
wl0_corerev=42
wl0_nmcsidx=-1
wl0_pspretend_retry_limit=0
wan0_ifnames=eth0
1:rxgains5gmelnagaina2=3
0:xtalfreq=0x40000
wl_key=1
wl1_rateset=default
wl0_acs_chan_flop_period=30
wl1_gmode=0
wl1_ampdu=auto
1:aa5g=7
wl0_wds_timeout=1
wps_device_name=Wireless Router Archer C9
wl1_unit=1
wps_aplockdown=0
wl0.1_bss_enabled=0
1:xtalfreq=0x40000
wl0_wmf_ucigmp_query=0
wl0_intfer_scount=
pci/2/1/rpcal5gb0=0xe648
upnp_enable=1
dlna_dms_enable=1
wl_bss_enabled=1
wl0_wps_mode=enabled
wl0_wme_ap_bk=15 1023 7 0 0 off off
wl_bridge=
wl1.1_radio=0
wps_config_method=0x2688
wl_wme_txp_be=7 3 6 2 0
wl0_intf_txnoack=0x4000f
wan_pppoe_ac=
wan_ipv6_prefix=2001:db0:1:0::/64
wl1_nband=1
1:mcsbw405gmpo=0xfdba9630
wl1_wps_mode=enabled
wl1_wps_config_state=0
wl1_wme_sta_vi=7 15 2 6016 3008 off off
emf_uffp_entry=
wl0_rx_amsdu_in_ampdu=auto
pci/2/1/rpcal5gb3=0xec50
wl0_stbc_rx=1
lan1_hwaddr=00:00:00:00:00:00
wl0_radio_pwrsave_quiet_time=1800
wl1_radio_pwrsave_pps=10
1:pa5ga0=0xff3d,0x1970,0xfce5,0xff38,0x1a7f,0xfcc3,0xff33,0x1a66,0xfcc4,0xff4e,0x195f,0xfcf4
wl_sta_retry_time=5
wl0_intf_swin=7
1:pa5ga1=0xff30,0x1877,0xfcf7,0xff38,0x1a37,0xfccd,0xff37,0x1aa1,0xfcc0,0xff3d,0x1aa8,0xfcb3
1:txchain=7
wl_closed=0
wl0_auth_mode=none
wl_wme_txp_bk=7 3 6 2 0
wl1_acs_cs_scan_timer=900
1:pa5ga2=0xff42,0x199b,0xfced,0xff38,0x1a2a,0xfcce,0xff35,0x1a93,0xfcc1,0xff49,0x19c7,0xfce3
1:mcslr5gmpo=0
1:mcsbw1605gmpo=0
wl0_radio_pwrsave_enable=0
wl0_wet_tunnel=0
wl_tpc_db=0
wl1.1_sta_retry_time=5
wl0.6_hwaddr=16:CC:20:D1:DC:AF
autofw_port0=
wl1_wme_sta_vo=3 7 2 3264 1504 off off
wl1_wmf_ucigmp_query=0
boardnum=001
wl0_crypto=aes
0:temps_period=5
0:tssiposslope2g=1
wan_pppoe_ifname=
wl0_bss_opmode_cap_reqd=0
wl1_wds=
wl0_wfi_enable=0
wl0_txchain=7
wl1.6_hwaddr=16:CC:20:D1:DC:AE
0:macaddr=14:CC:20:D1:DC:A9
wl_bcn=100
wl1_vlan_prio_mode=off
coma_sleep=
wl1_wds_timeout=1
wl_reg_mode=off
rftestflag=4708
1:sb20in80and160lr5glpo=0
wl1_intf_rrate=0
dpsta_policy=1
wl_txbf_bfe_cap=1
wl_radio_pwrsave_level=0
wl1_radio_pwrsave_stas_assoc_check=0
wl_antdiv=-1
size: 18160 bytes (47376 left)
Archer C9 posiada tryb ratunkowy ( np po wgraniu uszkodzonego firmware. Dostęp do tego trybu przez uruchomienie routera z przyciśniętym Reset/WPS:
need firmware recovery!
register firmware recovery command
Device eth0: hwaddr 14-CC-20-D1-DC-AA, ipaddr 192.168.0.86, mask 255.255.255.0
Reading 192.168.0.66:ArcherC9v1_tp_recovery.bin: Failed.: Timeout occured
IP routera: 192.168.0.86
IP komputera: 192.168.0.66
Nazwa pliku: ArcherC9v1_tp_recovery.bin
