Archer C50
SoC - MT7620A
WiFi 5GHz - MT7612EN
Flash- Winbond 25Q64FVSIG
RAM- Zentel A3R12E40CBF-8E
Złącze UART TTL:
Trzeba zewrzeć pola gdzie mają być rezystory R600 oraz R601 inaczej nie będzie komunikacji ze sprzętem.
Log uruchomienia:
U-Boot 1.1.3 (Sep 15 2014 - 11:20:17)
Board: Ralink APSoC DRAM: 64 MB
relocate_code Pointer at: 83fb0000
enable ephy clock...done. rf reg 29 = 5
SSC disabled.
Software System Reset Occurred
Archer C50 v1.0.0
spi_wait_nsec: 29
spi device id: ef 40 17 0 0 (40170000)
find flash: W25Q64BV
Ralink UBoot Version: 4.1.2.0
ASIC 7620_MP (Port5<->None)
DRAM component: 512 Mbits DDR, width 16
DRAM bus: 16 bit
Total memory: 64 MBytes
Flash component: SPI Flash
Date:Sep 15 2014 Time:11:20:17
icache: sets:512, ways:4, linesz:32 ,total:65536
dcache: sets:256, ways:4, linesz:32 ,total:32768
##### The CPU freq = 580 MHZ ####
estimate memory size =64 Mbytes
continue to starting system. 0
disableEthForward(1158):disable switch forward...
3: System Boot system code via Flash.(0xbc020000)
do_bootm:argc=2, addr=0xbc020000
## Booting image at bc020000 ...
Uncompressing Kernel Image ... OK
No initrd
## Transferring control to Linux (at address 8000c150) ...
## Giving linux memsize in MB, 64
Starting kernel ...
怘▒▒▒▒fff▒▒~▒▒~fx▒▒▒怘▒怘▒f▒▒▒▒f▒▒▒▒f▒f▒▒▒Linux version 2.6.36 (root@localhost.localdomain) (gcc version 4.6.3 (Buildroot 2012.11.1) ) #1 Wed Mar 25 11:33:08 HKT 2015
The CPU feqenuce set to 580 MHz
MIPS CPU sleep mode enabled.
PCIE: bypass PCIe DLL.
PCIE: Elastic buffer control: Addr:0x68 -> 0xB4
disable all power about PCIe
CPU revision is: 00019650 (MIPS 24Kc)
Determined physical RAM map:
memory: 04000000 @ 00000000 (usable)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 -> 0x00004000
Movable zone start PFN for each node
0: 0x00000000 -> 0x00004000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: console=ttyS1,115200 root=/dev/mtdblock2 rootfstype=squashfs init=/sbin/init
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
Writing ErrCtl register=0003a004
Readback ErrCtl register=0003a004
Memory: 61368k/65536k available (2705k kernel code, 4168k reserved, 563k data, 164k init, 0k highmem)
NR_IRQS:128
MTK/Ralink System Tick Counter init... cd:8031ff68, m:214748, s:32
console [ttyS1] enabled
Calibrating delay loop... 386.04 BogoMIPS (lpj=772096)
pid_max: default: 4096 minimum: 301
RALINK_GPIOMODE = 5ab11d
RALINK_GPIOMODE = 58b11d
PPLL_CFG1=0xe8c000
MT7620 PPLL lock
PPLL_DRV =0x80080504
start PCIe register access
RALINK_PCI_PCICFG_ADDR = 1000f0
*************** MT7620 PCIe RC mode *************
bio: create slab <bio-0> at 0
pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x200fffff]
pci 0000:00:00.0: BAR 9: assigned [mem 0x20100000-0x201fffff pref]
pci 0000:00:00.0: BAR 1: assigned [mem 0x20200000-0x2020ffff]
pci 0000:00:00.0: BAR 1: set to [mem 0x20200000-0x2020ffff] (PCI address [0x20200000-0x2020ffff]
pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x200fffff 64bit]
pci 0000:01:00.0: BAR 0: set to [mem 0x20000000-0x200fffff 64bit] (PCI address [0x20000000-0x200fffff]
pci 0000:01:00.0: BAR 6: assigned [mem 0x20100000-0x2010ffff pref]
pci 0000:00:00.0: PCI bridge to [bus 01-01]
pci 0000:00:00.0: bridge window [io disabled]
pci 0000:00:00.0: bridge window [mem 0x20000000-0x200fffff]
pci 0000:00:00.0: bridge window [mem 0x20100000-0x201fffff pref]
BAR0 at slot 0 = 0
bus=0x0, slot = 0x0
res[0]->start = 0
res[0]->end = 0
res[1]->start = 20200000
res[1]->end = 2020ffff
res[2]->start = 0
res[2]->end = 0
res[3]->start = 0
res[3]->end = 0
res[4]->start = 0
res[4]->end = 0
res[5]->start = 0
res[5]->end = 0
bus=0x1, slot = 0x0
res[0]->start = 20000000
res[0]->end = 200fffff
res[1]->start = 0
res[1]->end = 0
res[2]->start = 0
res[2]->end = 0
res[3]->start = 0
res[3]->end = 0
res[4]->start = 0
res[4]->end = 0
res[5]->start = 0
res[5]->end = 0
Switching to clocksource Ralink external timer
NET: Registered protocol family 2
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
RT3xxx EHCI/OHCI init.
squashfs: version 4.0 (2009/01/31) Phillip Lougher
fuse init (API version 7.15)
msgmni has been set to 119
io scheduler noop registered
io scheduler deadline registered (default)
Ralink gpio driver initialized
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250: ttyS0 at MMIO 0x10000500 (irq = 37) is a 16550A
serial8250: ttyS1 at MMIO 0x10000c00 (irq = 12) is a 16550A
loop: module loaded
deice id : ef 40 17 0 0 (40170000)
W25Q64BV(ef 40170000) (8192 Kbytes)
mtd .name = raspi, .size = 0x00800000 (0M) .erasesize = 0x00000008 (0K) .numeraseregions = 65536
Creating 7 MTD partitions on "raspi":
0x000000000000-0x000000020000 : "boot"
0x000000020000-0x000000160000 : "kernel"
0x000000160000-0x0000007c0000 : "rootfs"
mtd: partition "rootfs" set to be root filesystem
0x0000007c0000-0x0000007d0000 : "config"
0x0000007d0000-0x0000007e0000 : "romfile"
0x0000007e0000-0x0000007f0000 : "rom"
0x0000007f0000-0x000000800000 : "radio"
Register flash device:flash0
Mirror/redirect action on
u32 classifier
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (2874 buckets, 11496 max)
ip_tables: (C) 2000-2006 Netfilter Core Team, Type=Restricted Cone
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
IPv6 over IPv4 tunneling driver
Ebtables v2.0 registered
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing unused kernel memory: 164k freed
starting pid 172, tty '': '/etc/init.d/rcS'
rdm_major = 253
SCSI subsystem initialized
spiflash_ioctl_read, Read from 0x007df100 length 0x6, ret 0, retlen 0x6
Read MAC from flash(0x7DF100) 60-ffffffe3-27-ffffffad-ffffffa9-2a
SMACCR1 -- : 0x000060e3
SMACCR0 -- : 0x27ada92a
Ralink APSoC Ethernet Driver Initilization. v3.0 256 rx/tx descriptors allocated, mtu = 1500!
PROC INIT OK!
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
rt3xxx-ehci rt3xxx-ehci: Ralink EHCI Host Controller
rt3xxx-ehci rt3xxx-ehci: new USB bus registered, assigned bus number 1
rt3xxx-ehci rt3xxx-ehci: irq 18, io mem 0x101c0000
rt3xxx-ehci rt3xxx-ehci: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
rt3xxx-ohci rt3xxx-ohci: RT3xxx OHCI Controller
rt3xxx-ohci rt3xxx-ohci: new USB bus registered, assigned bus number 2
rt3xxx-ohci rt3xxx-ohci: irq 18, io mem 0x101c1000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
tp_domain init ok
L2TP core driver, V2.0
PPPoL2TP kernel driver, V2.0
Please press Enter to activate this console. [ util_execSystem ] 135: ipt_init cmd is "/var/tmp/dconf/rc.router"
[ dm_readFile ] 2042: can not open xml file /var/tmp/pc/reduced_data_model.xml!, about to open file /etc/reduced_data_model.xml
spiflash_ioctl_read, Read from 0x007c0000 length 0x10000, ret 0, retlen 0x10000
spiflash_ioctl_read, Read from 0x007c0000 length 0x8094, ret 0, retlen 0x8094
spiflash_ioctl_read, Read from 0x007df200 length 0x4, ret 0, retlen 0x4
spiflash_ioctl_read, Read from 0x00020000 length 0x1d0, ret 0, retlen 0x1d0
sendto: No such file or directory
pid 250 send 2001 error
[ util_execSystem ] 135: oal_startDynDns cmd is "dyndns /var/tmp/dconf/dyndns.conf"
[ oal_sys_getOldTZInfo ] 333: Open TZ file error!
[ util_execSystem ] 135: oal_sys_unsetTZ cmd is "echo "" > /etc/TZ"
[ util_execSystem ] 135: oal_startNoipDns cmd is "noipdns /var/tmp/dconf/noipdns.conf"
[ util_execSystem ] 135: oal_startCmxDns cmd is "cmxdns /var/tmp/dconf/cmxdns.conf"
ioctl: No such device
[ util_execSystem ] 135: oal_br_addBridge cmdspiflash_ioctl_read, Read from 0x007df100 length 0x6, ret 0, retlen 0x6
is "brctl addbr br0;brctl setfd br0 0;brctl stp br0 off"
[ util_execSystem ] 135: oal_ipt_addLanRules cmd is "iptables -t filter -A INPUT -i br+ -j ACCEPT
[ util_execSystem ] 135: oal_intf_setIntf cmd is "ifconfig br0 192.168.0.1 netmask 255.255.255.0 up"
[ util_execSystem ] 135: oal_util_setProcLanAddr cmd is "echo "br0 16820416," > /proc/net/coRaeth v3.0 (nntrWorkqueueac)
t_LocalA
phy_tx_ring = 0x030c4000, tx_ring = 0xa30c4000
phy_rx_ring0 = 0x030c5000, rx_ring0 = 0xa30c5000
ddCDMA_CSG_CFG = 81000000
r"GDMA1_FWD_CFG = 20710000
[ util_execSystem ] 135: oal_intf_enableIntf cmd is "ifconfig eth0 up"
[ util_execSystem ] 135: rsl_initLanEthIntfObj cmd is "vconfig add eth0 3"
[ util_execSystem ] 135: rsl_initLanEthIntfObj cmd is "ifconfig eth0.3 up"
[ util_execSystem ] 135: oal_br_addIntfIntoBridgedevice eth0.3 entered promiscuous mode
cdevice eth0 entered promiscuous mode
md br0: port 1(eth0.3) entering forwarding state
isbr0: port 1(eth0.3) entering forwarding state
"brctl addif br0 eth0.3"
[ util_execSystem ] 135: rsl_initLanEthIntfObj cmd is "vconfig add eth0 2"
[ util_execSystem ] 135: rsl_initLanEthIntfObj cmd is "ifconfig eth0.2 up"
[ util_execSystem ] 135: oal_eth_setIGMPSnoopParam cmd is "brctl setbrsnooping br0 1"
[ util_execSystem ] 135: oal_wlan_ra_setCountryRegion cmd is "cp /etc/SingleSKU_FCC.dat /var/Wireless/RT2860AP/SingleSKU.dat"
[ util_execSystem ] 135: oal_wlan_ra_setCountryRegion cmd is "iwpriv ra0 set CountryRegion=0"
ra0 no private ioctls.
[ util_execSystem ] 135: oal_wlan_ra_loadDriver cmd is "insmod /lib/modules/kmdir/kernel/drivers/net/wireless/rt2860v2_ap/rt2860v2_ap.ko"
rt2860v2_ap: module license 'unspecified' taints kernel.
Disabling lock debugging due to kernel taint
=== pAd = c0979000, size = 966392 ===
<-- RTMPAllocTxRxRingMemory, Status=0
<-- RTMPAllocAdapterBlock, Status=0
AP Driver version-2.7.1.6_edcca_monitor_20131227
[ util_execSystem ] 135: oal_wlan_ra_initWlan cmd is "ifconfig ra0 up"
RX DESC a3226000 size = 4096
RTMP_TimerListAdd: add timer obj c0a26a40!
RTMP_TimerListAdd: add timer obj c09dea40!
RTMP_TimerListAdd: add timer obj c09e12a4!
RTMP_TimerListAdd: add timer obj c09e1364!
RTMP_TimerListAdd: add timer obj c09e1424!
RTMP_TimerListAdd: add timer obj c09e14e4!
RTMP_TimerListAdd: add timer obj c09e15a4!
RTMP_TimerListAdd: add timer obj c09e1664!
RTMP_TimerListAdd: add timer obj c09e1724!
RTMP_TimerListAdd: add timer obj c09e17e4!
RTMP_TimerListAdd: add timer obj c09e18a4!
RTMP_TimerListAdd: add timer obj c09e1964!
RTMP_TimerListAdd: add timer obj c09e1a24!
RTMP_TimerListAdd: add timer obj c09e1ae4!
RTMP_TimerListAdd: add timer obj c09e1ba4!
RTMP_TimerListAdd: add timer obj c09e1c64!
RTMP_TimerListAdd: add timer obj c09e1d24!
RTMP_TimerListAdd: add timer obj c09e1de4!
RTMP_TimerListAdd: add timer obj c09dea14!
RTMP_TimerListAdd: add timer obj c09e1278!
RTMP_TimerListAdd: add timer obj c09e1338!
RTMP_TimerListAdd: add timer obj c09e13f8!
RTMP_TimerListAdd: add timer obj c09e14b8!
RTMP_TimerListAdd: add timer obj c09e1578!
RTMP_TimerListAdd: add timer obj c09e1638!
RTMP_TimerListAdd: add timer obj c09e16f8!
RTMP_TimerListAdd: add timer obj c09e17b8!
RTMP_TimerListAdd: add timer obj c09e1878!
RTMP_TimerListAdd: add timer obj c09e1938!
RTMP_TimerListAdd: add timer obj c09e19f8!
RTMP_TimerListAdd: add timer obj c09e1ab8!
RTMP_TimerListAdd: add timer obj c09e1b78!
RTMP_TimerListAdd: add timer obj c09e1c38!
RTMP_TimerListAdd: add timer obj c09e1cf8!
RTMP_TimerListAdd: add timer obj c09e1db8!
RTMP_TimerListAdd: add timer obj c09de9e8!
RTMP_TimerListAdd: add timer obj c09e12d0!
RTMP_TimerListAdd: add timer obj c09e1390!
RTMP_TimerListAdd: add timer obj c09e1450!
RTMP_TimerListAdd: add timer obj c09e1510!
RTMP_TimerListAdd: add timer obj c09e15d0!
RTMP_TimerListAdd: add timer obj c09e1690!
RTMP_TimerListAdd: add timer obj c09e1750!
RTMP_TimerListAdd: add timer obj c09e1810!
RTMP_TimerListAdd: add timer obj c09e18d0!
RTMP_TimerListAdd: add timer obj c09e1990!
RTMP_TimerListAdd: add timer obj c09e1a50!
RTMP_TimerListAdd: add timer obj c09e1b10!
RTMP_TimerListAdd: add timer obj c09e1bd0!
RTMP_TimerListAdd: add timer obj c09e1c90!
RTMP_TimerListAdd: add timer obj c09e1d50!
RTMP_TimerListAdd: add timer obj c09e1e10!
RTMP_TimerListAdd: add timer obj c09859c0!
RTMP_TimerListAdd: add timer obj c09855a4!
RTMP_TimerListAdd: add timer obj c0985990!
RTMP_TimerListAdd: add timer obj c0985d38!
RTMP_TimerListAdd: add timer obj c0985a88!
RTMP_TimerListAdd: add timer obj c0985ab8!
RTMP_TimerListAdd: add timer obj c0985c78!
RTMP_TimerListAdd: add timer obj c0985ca8!
RTMP_TimerListAdd: add timer obj c0988c08!
RTMP_TimerListAdd: add timer obj c09887ec!
RTMP_TimerListAdd: add timer obj c0988bd8!
RTMP_TimerListAdd: add timer obj c0988f80!
RTMP_TimerListAdd: add timer obj c0988cd0!
RTMP_TimerListAdd: add timer obj c0988d00!
RTMP_TimerListAdd: add timer obj c0988ec0!
RTMP_TimerListAdd: add timer obj c0988ef0!
RTMP_TimerListAdd: add timer obj c098be50!
RTMP_TimerListAdd: add timer obj c098ba34!
RTMP_TimerListAdd: add timer obj c098be20!
RTMP_TimerListAdd: add timer obj c098c1c8!
RTMP_TimerListAdd: add timer obj c098bf18!
RTMP_TimerListAdd: add timer obj c098bf48!
RTMP_TimerListAdd: add timer obj c098c108!
RTMP_TimerListAdd: add timer obj c098c138!
RTMP_TimerListAdd: add timer obj c098f098!
RTMP_TimerListAdd: add timer obj c098ec7c!
RTMP_TimerListAdd: add timer obj c098f068!
RTMP_TimerListAdd: add timer obj c098f410!
RTMP_TimerListAdd: add timer obj c098f160!
RTMP_TimerListAdd: add timer obj c098f190!
RTMP_TimerListAdd: add timer obj c098f350!
RTMP_TimerListAdd: add timer obj c098f380!
RTMP_TimerListAdd: add timer obj c09922e0!
RTMP_TimerListAdd: add timer obj c0991ec4!
RTMP_TimerListAdd: add timer obj c09922b0!
RTMP_TimerListAdd: add timer obj c0992658!
RTMP_TimerListAdd: add timer obj c09923a8!
RTMP_TimerListAdd: add timer obj c09923d8!
RTMP_TimerListAdd: add timer obj c0992598!
RTMP_TimerListAdd: add timer obj c09925c8!
RTMP_TimerListAdd: add timer obj c0995528!
RTMP_TimerListAdd: add timer obj c099510c!
RTMP_TimerListAdd: add timer obj c09954f8!
RTMP_TimerListAdd: add timer obj c09958a0!
RTMP_TimerListAdd: add timer obj c09955f0!
RTMP_TimerListAdd: add timer obj c0995620!
RTMP_TimerListAdd: add timer obj c09957e0!
RTMP_TimerListAdd: add timer obj c0995810!
RTMP_TimerListAdd: add timer obj c0998770!
RTMP_TimerListAdd: add timer obj c0998354!
RTMP_TimerListAdd: add timer obj c0998740!
RTMP_TimerListAdd: add timer obj c0998ae8!
RTMP_TimerListAdd: add timer obj c0998838!
RTMP_TimerListAdd: add timer obj c0998868!
RTMP_TimerListAdd: add timer obj c0998a28!
RTMP_TimerListAdd: add timer obj c0998a58!
RTMP_TimerListAdd: add timer obj c099b9b8!
RTMP_TimerListAdd: add timer obj c099b59c!
RTMP_TimerListAdd: add timer obj c099b988!
RTMP_TimerListAdd: add timer obj c099bd30!
RTMP_TimerListAdd: add timer obj c099ba80!
RTMP_TimerListAdd: add timer obj c099bab0!
RTMP_TimerListAdd: add timer obj c099bc70!
RTMP_TimerListAdd: add timer obj c099bca0!
RTMP_TimerListAdd: add timer obj c09e0e5c!
RTMP_TimerListAdd: add timer obj c09e0a40!
RTMP_TimerListAdd: add timer obj c09e0e2c!
RTMP_TimerListAdd: add timer obj c09e11d4!
RTMP_TimerListAdd: add timer obj c09e0f24!
RTMP_TimerListAdd: add timer obj c09e0f54!
RTMP_TimerListAdd: add timer obj c09e0e8c!
RTMP_TimerListAdd: add timer obj c09e0ebc!
RTMP_TimerListAdd: add timer obj c09e0eec!
RTMP_TimerListAdd: add timer obj c09fd3ac!
RTMP_TimerListAdd: add timer obj c09fd4c8!
RTMP_TimerListAdd: add timer obj c09fd3d8!
RTMP_TimerListAdd: add timer obj c09e2f94!
RTMP_TimerListAdd: add timer obj c0982e70!
RTMP_TimerListAdd: add timer obj c09860b8!
RTMP_TimerListAdd: add timer obj c0989300!
RTMP_TimerListAdd: add timer obj c098c548!
RTMP_TimerListAdd: add timer obj c098f790!
RTMP_TimerListAdd: add timer obj c09929d8!
RTMP_TimerListAdd: add timer obj c0995c20!
RTMP_TimerListAdd: add timer obj c0998e68!
RTMP_TimerListAdd: add timer obj c09e2ca4!
!!! use RTMP_RBUS_SUPPORT: AP_PROFILE_PATH_RBUS is /var/Wireless/RT2860AP/RT2860AP.dat
APSDCapable[0]=0
APSDCapable[1]=0
APSDCapable[2]=0
APSDCapable[3]=0
APSDCapable[4]=0
APSDCapable[5]=0
APSDCapable[6]=0
APSDCapable[7]=0
APSDCapable[8]=0
APSDCapable[9]=0
APSDCapable[10]=0
APSDCapable[11]=0
APSDCapable[12]=0
APSDCapable[13]=0
APSDCapable[14]=0
APSDCapable[15]=0
default ApCliAPSDCapable[0]=0
Key1Str is Invalid key length(0) or Type(0)
Key2Str is Invalid key length(0) or Type(0)
Key3Str is Invalid key length(0) or Type(0)
Key4Str is Invalid key length(0) or Type(0)
1. Phy Mode = 9
2. Phy Mode = 9
exec!
spiflash_ioctl_read, Read from 0x007f0000 length 0x200, ret 0, retlen 0x200
eeFlashId = 0x7620!
E2PROM: D0 target power=0xff1e
E2PROM: 40 MW Power Delta= 0
3. Phy Mode = 9
RTMP_TimerListAdd: add timer obj c0982a68!
AntCfgInit: primary/secondary ant 0/1
Initialize RF Central Registers for E2 !!!
Initialize RF Central Registers for E3 !!!
Initialize RF Channel Registers for E2 !!!
Initialize RF Channel Registers for E3 !!!
Initialize RF DCCal Registers for E2 !!!
Initialize RF DCCal Registers for E3 !!!
D1 = -1, D2 = 8, CalCode = 21 !!!
RT6352_Temperature_Init : BBPR49 = 0xffffffff
RT6352_Temperature_Init : TemperatureRef25C = 0xfffffff5
Current Temperature from BBP_R49=0xfffffff8
RT6352_TssiTableAdjust: upper_bound = 0x7F decimal: 127
RT6352_TssiTableAdjust: lower_bound = 0xFFFFFF80 decimal: -128
*** RT6352_TssiTableAdjust: G Tssi[-7 .. +7] = -128 -128 -128 -128 -128 -25 -12
- 0 - 12 28 127 127 127 127 127, offset=-11, tuning=1
RT6352_TssiTableAdjust: G Tssi[-7 .. +7] = -128 -128 -128 -128 -128 -36 -23 - -11 - 1 17 116 116 116 116 116, offset=-11, tuning=1
mp_temperature=0xfffffffc, step = +0
E2PROM: G Tssi[-7 .. +7] = -128 -128 -128 -128 -128 -36 -23 - -11 - 1 17 116 116 116 116 116, offset=-11, tuning=1
TX BW Filter Calibration !!!
RX BW Filter Calibration !!!
LOFT Calibration Done!
IQCalibration Start!
IQCalibration Done! CH = 0, (gain= f, phase=3d)
IQCalibration Done! CH = 1, (gain= 0, phase= 2)
TX IQ Calibration Done!
Change as Normal Mode(0x48b71d)
After Change, now GPIO_MODE value is 0x48b71d
RT6352_Init_ExtPA_ExtLNA: Enable Ext-LNA.
RT6352_Init_ExtPA_ExtLNA: Init Ext-LNA BBP.
bAutoTxAgcG = 1
MCS Set = ff ff 00 00 01
SYNC - BBP R4 to 20MHz.l
RTMP_TimerListAdd: add timer obj c09e32ac!
The 4-BSSID mode is enabled, the BSSID byte5 MUST be the multiple of 4
Main bssid = 60:e3:27:ad:a9:2a
<==== rt28xx_init, Status=0
0x1300 = 00064300
[ util_execSystem ] 135: oal_wlan_ra_initWlan cmd is "echo 1 > /proc/tplink/led_wlan_24G"
[ util_execSystdevice ra0 entered promiscuous mode
em br0: port 2(ra0) entering forwarding state
] br0: port 2(ra0) entering forwarding state
135: oal_br_addIntfIntoBridge cmd is "brctl addif br0 ra0"
[ util_execSystdevice apcli0 entered promiscuous mode
em ] 135: oal_br_addIntfIntoBridge cmd is "brctl addif br0 apcli0"
[ utidevice ra1 entered promiscuous mode
l_execSystem ] 135: oal_br_addIntfIntoBridge cmd is "brctl addif br0 ra1"
[ util_execSystem ] 135: oal_wlan_ra_initEnd cmd is "wlNetlinkTool &"
spiflash_ioctl_read, Read from 0x007f0000 length 0x2, ret 0, retlen 0x2
[ util_execSystem ] 135: oal_wlan_ra_initEnd cmd is "killall -q wscd"
[ util_execSystem ] 135: oal_wlan_ra_initEnd cmd is "wscd -i ra0 -m 1 -w /var/tmp/wsc_upnp/ &"
WLAN-Start wlNetlinkTool
Waiting for Wireless Events from interfaces...
swWlanChkAhbErr: netlink to do
[ util_execSystem ] 135: oal_wlan_ra_setCountryRegion cmd is "cp /etc/SingleSKU_5G_FCC.dat /var/Wireless/RT2860AP/SingleSKU_5G.dat"
[ util_execSystem ] 135: oal_wlan_ra_setCountryRegion cmd is "iwpriv rai0 set CountryRegionABand=0"
rai0 no private ioctls.
[ util_execSystem ] 135: oal_wlan_ra_loadDriver cmd is "insmod /lib/modules/kmdir/kernel/drivers/net/wireless/MT7612_ap/MT7612_ap.ko"
wscd: SSDP UDP PORT = 1900
register rt2860
=== pAd = c0f82000, size = 1699048 ===
pAd->CSRBaseAddress =0xc0e80000, csr_addr=0xc0e80000!
device_id =0x7662
==>rlt_wlan_chip_onoff(): OnOff:1, Reset= 1, pAd->WlanFunCtrl:0x0, Reg-WlanFunCtrl=0x20a
RtmpChipOpsEepromHook::e2p_type=0, inf_Type=5
RtmpEepromGetDefault::e2p_dafault=2
NVM is FLASH mode
[ util_execSystem ] 135: oal_wlan_ra_initWlan cmd is "ifconfig rabuild time =
i02 u0p"1
4
0408060640a
rom patch for E3 IC
platform =
ALPS
hw/sw version =
â–’â–’
patch version =
FW Version:0.0.00 Build:1
Build Time:201411280941____
fw for E3 IC
spiflash_ioctl_read, Read from 0x007f8000 length 0x200, ret 0, retlen 0x200
RX[0] DESC a2b79000 size = 4096
RX[1] DESC a2b7a000 size = 4096
RTMP_TimerListAdd: add timer obj c108f494!
RTMP_TimerListAdd: add timer obj c101c740!
RTMP_TimerListAdd: add timer obj c101ef7c!
RTMP_TimerListAdd: add timer obj c101f010!
RTMP_TimerListAdd: add timer obj c101f0a4!
RTMP_TimerListAdd: add timer obj c101f138!
RTMP_TimerListAdd: add timer obj c101f1cc!
RTMP_TimerListAdd: add timer obj c101f260!
RTMP_TimerListAdd: add timer obj c101f2f4!
RTMP_TimerListAdd: add timer obj c101f388!
RTMP_TimerListAdd: add timer obj c101f41c!
RTMP_TimerListAdd: add timer obj c101f4b0!
RTMP_TimerListAdd: add timer obj c101f544!
RTMP_TimerListAdd: add timer obj c101f5d8!
RTMP_TimerListAdd: add timer obj c101f66c!
RTMP_TimerListAdd: add timer obj c101f700!
RTMP_TimerListAdd: add timer obj c101f794!
RTMP_TimerListAdd: add timer obj c101f828!
RTMP_TimerListAdd: add timer obj c101c714!
RTMP_TimerListAdd: add timer obj c101c76c!
RTMP_TimerListAdd: add timer obj c101ef50!
RTMP_TimerListAdd: add timer obj c101efe4!
RTMP_TimerListAdd: add timer obj c101f078!
RTMP_TimerListAdd: add timer obj c101f10c!
RTMP_TimerListAdd: add timer obj c101f1a0!
RTMP_TimerListAdd: add timer obj c101f234!
RTMP_TimerListAdd: add timer obj c101f2c8!
RTMP_TimerListAdd: add timer obj c101f35c!
RTMP_TimerListAdd: add timer obj c101f3f0!
RTMP_TimerListAdd: add timer obj c101f484!
RTMP_TimerListAdd: add timer obj c101f518!
RTMP_TimerListAdd: add timer obj c101f5ac!
RTMP_TimerListAdd: add timer obj c101f640!
RTMP_TimerListAdd: add timer obj c101f6d4!
RTMP_TimerListAdd: add timer obj c101f768!
RTMP_TimerListAdd: add timer obj c101f7fc!
RTMP_TimerListAdd: add timer obj c101c6e8!
RTMP_TimerListAdd: add timer obj c0f980cc!
RTMP_TimerListAdd: add timer obj c0f97cb0!
RTMP_TimerListAdd: add timer obj c0f9809c!
RTMP_TimerListAdd: add timer obj c0f983d8!
RTMP_TimerListAdd: add timer obj c0f98318!
RTMP_TimerListAdd: add timer obj c0f98348!
RTMP_TimerListAdd: add timer obj c0f9b374!
RTMP_TimerListAdd: add timer obj c0f9af58!
RTMP_TimerListAdd: add timer obj c0f9b344!
RTMP_TimerListAdd: add timer obj c0f9b680!
RTMP_TimerListAdd: add timer obj c0f9b5c0!
RTMP_TimerListAdd: add timer obj c0f9b5f0!
RTMP_TimerListAdd: add timer obj c0f9e61c!
RTMP_TimerListAdd: add timer obj c0f9e200!
RTMP_TimerListAdd: add timer obj c0f9e5ec!
RTMP_TimerListAdd: add timer obj c0f9e928!
RTMP_TimerListAdd: add timer obj c0f9e868!
RTMP_TimerListAdd: add timer obj c0f9e898!
RTMP_TimerListAdd: add timer obj c0fa18c4!
RTMP_TimerListAdd: add timer obj c0fa14a8!
RTMP_TimerListAdd: add timer obj c0fa1894!
RTMP_TimerListAdd: add timer obj c0fa1bd0!
RTMP_TimerListAdd: add timer obj c0fa1b10!
RTMP_TimerListAdd: add timer obj c0fa1b40!
RTMP_TimerListAdd: add timer obj c0fa4b6c!
RTMP_TimerListAdd: add timer obj c0fa4750!
RTMP_TimerListAdd: add timer obj c0fa4b3c!
RTMP_TimerListAdd: add timer obj c0fa4e78!
RTMP_TimerListAdd: add timer obj c0fa4db8!
RTMP_TimerListAdd: add timer obj c0fa4de8!
RTMP_TimerListAdd: add timer obj c0fa7e14!
RTMP_TimerListAdd: add timer obj c0fa79f8!
RTMP_TimerListAdd: add timer obj c0fa7de4!
RTMP_TimerListAdd: add timer obj c0fa8120!
RTMP_TimerListAdd: add timer obj c0fa8060!
RTMP_TimerListAdd: add timer obj c0fa8090!
RTMP_TimerListAdd: add timer obj c0fab0bc!
RTMP_TimerListAdd: add timer obj c0faaca0!
RTMP_TimerListAdd: add timer obj c0fab08c!
RTMP_TimerListAdd: add timer obj c0fab3c8!
RTMP_TimerListAdd: add timer obj c0fab308!
RTMP_TimerListAdd: add timer obj c0fab338!
RTMP_TimerListAdd: add timer obj c0fae364!
RTMP_TimerListAdd: add timer obj c0fadf48!
RTMP_TimerListAdd: add timer obj c0fae334!
RTMP_TimerListAdd: add timer obj c0fae670!
RTMP_TimerListAdd: add timer obj c0fae5b0!
RTMP_TimerListAdd: add timer obj c0fae5e0!
RTMP_TimerListAdd: add timer obj c101ebbc!
RTMP_TimerListAdd: add timer obj c101e7a0!
RTMP_TimerListAdd: add timer obj c101eb8c!
RTMP_TimerListAdd: add timer obj c101eec8!
RTMP_TimerListAdd: add timer obj c101ebec!
RTMP_TimerListAdd: add timer obj c101ec1c!
RTMP_TimerListAdd: add timer obj c101ec4c!
RTMP_TimerListAdd: add timer obj c103ade4!
RTMP_TimerListAdd: add timer obj c103af00!
RTMP_TimerListAdd: add timer obj c103ae10!
RTMP_TimerListAdd: add timer obj c1020980!
cfg_mode=14
cfg_mode=14
wmode_band_equal(): Band Not Equal!
APSDCapable[0]=0
APSDCapable[1]=0
APSDCapable[2]=0
APSDCapable[3]=0
APSDCapable[4]=0
APSDCapable[5]=0
APSDCapable[6]=0
APSDCapable[7]=0
APSDCapable[8]=0
APSDCapable[9]=0
APSDCapable[10]=0
APSDCapable[11]=0
APSDCapable[12]=0
APSDCapable[13]=0
APSDCapable[14]=0
APSDCapable[15]=0
1. Phy Mode = 49
get_chl_grp:illegal channel (167)
get_chl_grp:illegal channel (169)
get_chl_grp:illegal channel (171)
get_chl_grp:illegal channel (173)
Country Region from e2p = ffff
2. Phy Mode = 49
RTMP_TimerListAdd: add timer obj c0f9551c!
RTMP_TimerListAdd: add timer obj c0f987c4!
RTMP_TimerListAdd: add timer obj c0f9ba6c!
RTMP_TimerListAdd: add timer obj c0f9ed14!
RTMP_TimerListAdd: add timer obj c0fa1fbc!
RTMP_TimerListAdd: add timer obj c0fa5264!
RTMP_TimerListAdd: add timer obj c0fa850c!
RTMP_TimerListAdd: add timer obj c0fab7b4!
RTMP_TimerListAdd: add timer obj c1020688!
3. Phy Mode = 49
andes_pci_fw_init
0x1300 = 00073200
andes_load_cr:cr_type(2)
ChipStructAssign(): MT76x2 hook !
TX0 power compensation = 0x38
TX1 power compensation = 0x38
RTMP_TimerListAdd: add timer obj c1020c74!
APStartUp(): AP Set CentralFreq at 42(Prim=36, HT-CentCh=38, VHT-CentCh=42, BBP_BW=2)
Main bssid = 60:e3:27:ad:a9:29
mt76x2_reinit_agc_gain:original agc_vga0 = 0x46, agc_vga1 = 0x46
mt76x2_reinit_agc_gain:updated agc_vga0 = 0x46, agc_vga1 = 0x46
mt76x2_reinit_hi_lna_gain:original hi_lna0 = 0x34, hi_lna1 = 0x34
mt76x2_reinit_hi_lna_gain:updated hi_lna0 = 0x34, hi_lna1 = 0x34
RTMPDrvOpen(1):Check if PDMA is idle!
RTMPDrvOpen(2):Check if PDMA is idle!
[ util_execSystem ] 135: oal_wlan_ra_initWlan cmd is "echo 1 > /proc/tplink/led_wlan_5G"
[ util_execSystdevice rai0 entered promiscuous mode
em ]br0: port 5(rai0) entering forwarding state
1br0: port 5(rai0) entering forwarding state
35: oal_br_addIntfIntoBridge cmd is "brctl addif br0 rai0"
[ util_execSysdevice apclii0 entered promiscuous mode
tem ] 135: oal_br_addIntfIntoBridge cmd is "brctl addif br0 apclii0"
[ udevice rai1 entered promiscuous mode
til_execSystem ] 135: oal_br_addIntfIntoBridspiflash_ioctl_read, Read from 0x007f8000 length 0x2, ret 0, retlen 0x2
ge cmd is "brctl addif br0 rai1"
wlNetlinkTool is already there.
[ util_execSystem ] 135: oal_wlan_ra_initEnd cmd is "killall -q wscd_5G"
[ util_execSystem ] 135: oal_wlan_ra_initEnd cmd is "wscd_5G -i rai0 -m 1 -w /var/tmp/wsc_upnp_5G/ &"
pid 250 send 2030 error
pid 250 send 2004 error
[ util_execSystem ] 135: oal_startDhcps cmd is "dhcpd /var/tmp/dconf/udhcpd.conf"
[ util_execSystem ] 135: oal_ipt_addDnsRules cmd is "iptables -t nat -A PREROUTING -d 192.168.0.1 -p udp --dport 53 -j DNAT --to-destination 10.1.1.1
[ util_execSystem ] 135: oal_net_addDNS cmd is "echo "nameserver 10.1.1.1" > /var/tmp/resolv.conf"
[ util_execSystem ] 135: oal_lan6_startDhcp6s cmd is "dhcp6s -c /var/tmp/dconf/dhcp6s_br0.conf -P /var/run/dhcp6s_br0.pid br0 &"
[ util_execSystem ] 135: oal_lan6_startRadvd cmd is "radvd -C /var/tmp/dconf/radvd_br0.conf -p /var/run/radvd_br0.pid &"
[ util_execSystem ] 135: oal_br_delIntfFromBridge cmd is "brctl delif br0 eth0.2"
iptables: Bad rule (does a matching rule exist in that chain?).
brctl: bridge br0: Invalid argument
[ util_execSystem ] 135: oal_intf_setIfMac cmd is "ifconfig eth0.2 down"
[ util_execSystem ] 135: oal_intf_setIfMac cmd is "ifconfig eth0.2 hw ether 60:E3:27:AD:A9:2B up"
radvd starting
[ util_execSystem ] 135: oal_intf_enableIntf cmd is "ifconfig eth0.2 up"
[ util_execSystem ] 135: oal_wan6_startDhcp6c cmd is "dhcp6c -c /var/tmp/dconf/dhcp6c_eth0.2.conf -p /var/run/dhcp6c_eth0.2.pid eth0.2 eth0.2 &"
[ util_execSystem ] 135: oal_wan6_enableAcceptRa cmd is "echo 2 > /proc/sys/net/ipv6/conf/eth0.2/accept_ra"
[ util_execSystem ] 135: oal_wan6_enableAcceptRa cmd is "echo 0 > /proc/sys/net/ipv6/conf/eth0.2/autoconf"
[ util_execSystem ] 135: prepareDropbear cmd is "dropbearkey -t rsa -f /var/tmp/dropbear/dropbear_rsa_host_key"
Will output 1024 bit rsa secret key to '/var/tmp/dropbear/dropbear_rsa_host_key'
Generating key, this may take a while...
[ util_execSystem ] 135: oal_rip_updateConfig cmd is "rm -f /var/tmp/dconf/zebra.conf"
[ util_execSystem ] 135: oal_rip_updateConfig cmd is "rm -f /var/tmp/dconf/ripd.conf"
[ util_execSystem ] 135: removeAllRIPIpTableRule cmd is "iptables -L INPUT -v --line-numbers > /var/iptable"
[ util_execSystem ] 135: prepareDropbear cmd is "dropbearkey -t dss -f /var/tmp/dropbear/dropbear_dss_host_key"
Will output 1024 bit dss secret key to '/var/tmp/dropbear/dropbear_dss_host_key'
[ util_execSystem ] 135: prepareDropbear cmd is "dropbear -p 22 -r /var/tmp/dropbear/dropbear_rsa_host_key -d /var/tmp/dropbear/dropbear_dss_host_key -A /var/tmp/dropbear/dropbearpwd"
[ getPidFromPidFile ] 112: Cann't open file: /var/run/zebra.pid.
[ util_execSystem ] 135: controlRipProcess cmd is "zebra -d -f /var/tmp/dconf/zebra.conf"
[ getPidFromPidFile ] 112: Cann't open file: /var/run/ripd.pid.
[ util_execSystem ] 135: oal_ipt_fwDdos cmd is "iptables -D FORWARD -j FIREWALL_DDOS
iptables: No chain/target/match by that name.
[ util_execSystem ] 135: oal_ipt_setDDoSRules cmd is "iptables -F FIREWALL_DDOS"
[ util_execSystem ] 135: ddos_clearAll cmd is "rm -f /var/tmp/dosHost"
[ util_execSystem ] 135: oal_initFirewallObj cmd is "ebtables -N FIREWALL"
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -F"
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -X"
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -P INPUT ACCEPT"
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -P FORWARD DROP"
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -P OUTPUT ACCEPT"
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -N FIREWALL"
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -N FWRULE"
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -A INPUT -i lo -p ALL -j ACCEPT -m comment --comment "loop back""
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT"
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -A FORWARD -i br+ -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT"
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -A FORWARD -o br+ -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT"
[ util_execSystem ] 135: oal_initIp6FirewallObj cmd is "ip6tables -A FORWARD -j FIREWALL"
[ util_execSystem ] 135: oal_fw6_setFwEnabeld cmd is "ip6tables -D FIREWALL -j ACCEPT"
ip6tables: Bad rule (does a matching rule exist in that chain?).
[ util_execSystem ] 135: oal_fw6_setFwEnabeld cmd is "ip6tables -F FIREWALL"
[ util_execSystem ] 135: oal_fw6_setFwEnabeld cmd is "ip6tables -A FIREWALL -j ACCEPT"
[ rsl_setStorageServiceObj ] 1024: mountFlag is 3,We start usb server
[ util_execSystem ] 135: oal_killDlnaMediaSeverProcess cmd is "killall ushare"
killall: ushare: no process killed
uShare (version 1.1a), a lightweight UPnP A/V and DLNA Media Server.
Benjamin Zores (C) 2005-2007, for GeeXboX Team.
See http://ushare.geexbox.org/ for updates.
[ util_execSystem ] 135: oal_ipt_setWanPort cmd is "iptables -t filter -D INPUT -p tcp --dport 21 -j ACCEPT"
[ util_execSystem ] 135: oal_ipt_setWanPort cmd is "iptables -t nat -D PREROUTING -p tcp --dport 21 -j ACCEPT"
[ util_execSystem ] 135: oal_startPrintSrv cmd is "insmod /lib/modules/GPL_NetUSB.ko"
kcg 333 :GPL NetUSB up!
[ util_execSystem ] 135: oal_startPrintSrv cmd is "insmod /lib/modules/NetUSB.ko"
kc 227 : init_DebugD end
INFO186B: NetUSB 1.02.61, 00020624 : Dec 16 2014 15:37:03
INFO186D: 7437: Archer C50 :Archer C50
INFO186E: AUTH ISOC
INFO186F: MOVE_HEAD filterAudio
kc 90 : run_telnetDBGDServer start
usbcore: registered new interface driver KC NetUSB General Driver
INFO18C7: Reset device when disconnect
INFO0145: init proc : PAGE_SIZE 4096
INFO1740: infomap c1204c74
INFO1743: sleep to wait br0 to wake up
INFO02CE: use dev Name br0
INFO174C: sleep to wait br0 end.
INFO1765: UDP_BROAD 7437 tcpPort:20005
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/netfilter/nf_conntrack_ftp.ko"
INFO161F: tcpConnector() started...
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/ipv4/netfilter/nf_nat_ftp.ko"
[ util_execSystem ] 135: oal_openAlg cmd is "iptables -D FORWARD_VPN_PASSTHROUGH -p udp --dport 500 -j DROP"
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/ipv4/netfilter/nf_nat_proto_gre.ko"
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/ipv4/netfilter/nf_nat_pptp.ko"
[ util_execSystem ] 135: oal_openAlg cmd is "iptables -D FORWARD_VPN_PASSTHROUGH -p tcp --dport 1723 -j DROP"
[ util_execSystem ] 135: oal_openAlg cmd is "iptables -D FORWARD_VPN_PASSTHROUGH -p udp --dport 1701 -j DROP"
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/netfilter/nf_conntrack_tftp.ko"
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/ipv4/netfilter/nf_nat_tftp.ko"
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/netfilter/nf_conntrack_h323.ko"
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/ipv4/netfilter/nf_nat_h323.ko"
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/netfilter/nf_conntrack_sip.ko"
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/ipv4/netfilter/nf_nat_sip.ko"
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/netfilter/nf_conntrack_rtsp.ko"
[ util_execSystem ] 135: setupModules cmd is "insmod /lib/modules/kmdir/kernel/net/ipv4/netfilter/nf_nat_rtsp.ko"
nf_nat_rtsp v0.6.21 loading
[ util_execSystem ] 135: oal_wan_HWNat_enable cmd is "insmod /lib/modules/kmdir/kernel/net/nat/hw_nat/hw_nat.ko"
Ralink HW NAT Module Enabled
INFO14F8: Bind to br0
