Archer C2600
SoC - Qualcomm Atheros IPQ8064
WiFi - 2x Qualcomm Atheros QCA9980
Flash - Macronix MX25U25635F - 32MB
RAM- 2x Micron MT41K128M16JT-125:K - 512MB
Log uruchomienia:
U-Boot 2012.07 [Standard IPQ806X.LN,unknown] (Aug 28 2015 - 19:57:21)
smem ram ptable found: ver: 0 len: 5
DRAM: 491 MiB
PCI0 Link Intialized
PCI1 Link Intialized
SF: Detected MX25U25635F with page size 4 KiB, total 32 MiB
00:01.0 - 17cb:0101 - Bridge device
01:00.0 - 168c:0040 - Network controller
02:01.0 - 17cb:0101 - Bridge device
03:00.0 - 168c:0040 - Network controller
NAND: ipq_nand: unknown NAND device manufacturer: 0 device: 0
ipq_nand: failed to identify device
ipq_spi: page_size: 0x100, sector_size: 0x1000, size: 0x2000000
32 MiB
MMC:
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: MAC1 addr:0:3:7f:ba:db:1
athrs17_reg_init: complete
athrs17_vlan_config ...done
S17c init done
MAC2 addr:0:3:7f:ba:db:2
eth0, eth1
boot in 2 seconds
FirmwareRecovery: Now doing bootipq
MMC Device 0 not found
Loading from nand1, offset 0x1f0000
Image Name: Linux-3.4.103
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1869128 Bytes = 1.8 MiB
Load Address: 41508000
Entry Point: 41508000
Automatic boot of image at addr 0x44000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
info: "mtdparts" not set
Using machid 0x1260 from environment
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Linux version 3.4.103 (kingke@kingke-ubuntu) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #2 SMP PREEMPT Tue Sep 1 11:26:14 CST 2015
[ 0.000000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: Qualcomm Atheros AP148 reference board
[ 0.000000] msm_reserve_memory: 0x44000000, 0x600000
[ 0.000000] msm_reserve_memory: 0x44600000, 0x200000
[ 0.000000] memory pool 3 (start 5fc00000 size 400000) initialized
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] smem_find(137, 80): wrong size 72
[ 0.000000] socinfo_init: v6, id=202, ver=2.0, raw_id=2064, raw_ver=2064, hw_plat=0, hw_plat_ver=65536
[ 0.000000] accessory_chip=0 hw_plat_subtype=0
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c0c48000 s10240 r8192 d14336 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 121642
[ 0.000000] Kernel command line: console=ttyHSL1,115200n8 root=mtd:rootfs rootfstype=squashfs
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 43MB 436MB = 479MB total
[ 0.000000] Memory: 477424k/489712k available, 13072k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdf000000 - 0xff000000 ( 512 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdeb00000 ( 491 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0514000 (5168 kB)
[ 0.000000] .init : 0xc0600000 - 0xc0702800 (1034 kB)
[ 0.000000] .data : 0xc0704000 - 0xc07a0898 ( 627 kB)
[ 0.000000] .bss : 0xc07a08bc - 0xc0844b60 ( 657 kB)
[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:1689
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 31240ns, wraps every 134175798ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.150452] Calibrating delay using timer specific routine.. 12.55 BogoMIPS (lpj=62796)
[ 0.150484] pid_max: default: 32768 minimum: 301
[ 0.150952] Mount-cache hash table entries: 512
[ 0.152389] CPU: Testing write buffer coherency: ok
[ 0.152577] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.152608] Setting up static identity map for 0x4189b628 - 0x4189b6b0
[ 0.154889] CPU1: Booted secondary processor
[ 0.154982] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.155076] Brought up 2 CPUs
[ 0.155076] SMP: Total of 2 processors activated (25.11 BogoMIPS).
[ 0.171383] dummy:
[ 0.172102] NET: Registered protocol family 16
[ 0.172852] AXI: msm_bus_fabric_init_driver(): msm_bus_fabric_init_driver
[ 0.175164] meminfo_init: smem ram ptable found: ver: 0 len: 5
[ 0.175164] Found 1 memory banks grouped into 8 memory regions
[ 0.175195] TP-LINK Archer C2600 v1
[ 0.175195] Force flash type to SPI!
[ 0.175476] gpiochip_add: registered GPIOs 0 to 151 on device: msmgpio
[ 0.176132] smem_find(137, 80): wrong size 72
[ 0.176163] socinfo_init: v6, id=202, ver=2.0, raw_id=2064, raw_ver=2064, hw_plat=0, hw_plat_ver=65536
[ 0.176163] accessory_chip=0 hw_plat_subtype=0
[ 0.176194] msm_rpm_init: RPM firmware 3.0.16777342
[ 0.184067] clk_tbl_nss - loaded
[ 0.212121] msm_dmov_memcpy_init: Success
[ 0.219493] sps:BAM 0x12244000 enabled: ver:0x5, number of pipes:20
[ 0.219525] sps:BAM 0x12244000 is registered.
[ 0.219743] sps:sps is ready.
[ 0.260918] msm_pcie_setup: link initialized
[ 0.261293] PCI host bridge to bus 0000:00
[ 0.261324] pci_bus 0000:00: root bus resource [mem 0x08000000-0x0fefffff]
[ 0.261793] PCI: bus0: Fast back to back transfers disabled
[ 0.261824] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.262542] PCI: bus1: Fast back to back transfers disabled
[ 0.300999] msm_pcie_setup: link initialized
[ 0.301343] PCI host bridge to bus 0000:02
[ 0.301374] pci_bus 0000:02: root bus resource [mem 0x2e000000-0x31efffff]
[ 0.301843] PCI: bus2: Fast back to back transfers disabled
[ 0.301874] pci 0000:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.302686] PCI: bus3: Fast back to back transfers disabled
[ 0.421368] msm_pcie_setup: link initialization failed
[ 0.421587] pci 0000:02:00.0: BAR 8: assigned [mem 0x2e000000-0x2e1fffff]
[ 0.421618] pci 0000:03:00.0: BAR 0: assigned [mem 0x2e000000-0x2e1fffff 64bit]
[ 0.421680] pci 0000:02:00.0: PCI bridge to [bus 03-03]
[ 0.421680] pci 0000:02:00.0: bridge window [mem 0x2e000000-0x2e1fffff]
[ 0.421743] PCI: enabling device 0000:02:00.0 (0140 -> 0143)
[ 0.421805] pci 0000:00:00.0: BAR 8: assigned [mem 0x08000000-0x081fffff]
[ 0.421836] pci 0000:01:00.0: BAR 0: assigned [mem 0x08000000-0x081fffff 64bit]
[ 0.421868] pci 0000:00:00.0: PCI bridge to [bus 01-01]
[ 0.421899] pci 0000:00:00.0: bridge window [mem 0x08000000-0x081fffff]
[ 0.421930] PCI: enabling device 0000:00:00.0 (0140 -> 0143)
[ 0.443111] bio: create slab <bio-0> at 0
[ 0.444673] SCSI subsystem initialized
[ 0.446579] spi_qsd spi_qsd.5: master is unqueued, this is deprecated
[ 0.449015] spi_qsd spi_qsd.6: master is unqueued, this is deprecated
[ 0.454014] Switching to clocksource gp_timer
[ 0.474445] NET: Registered protocol family 2
[ 0.484223] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.484723] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.484910] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.485129] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.485129] TCP: reno registered
[ 0.485129] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.485160] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.485598] NET: Registered protocol family 1
[ 0.487691] smd: register irq failed on wcnss_a11
[ 0.487722] smd: deregistering IRQs
[ 0.487785] SMD: smd_core_platform_init() failed
[ 0.488753] Partition(from smem) ART -- Offset:1b0000 Size:40000
[ 0.488753] Partition(from smem) rootfs -- Offset:3f0000 Size:1b00000
[ 0.488784] get_bootconfig_partition: magic not found
[ 0.505279] acpuclk-ipq806x acpuclk-ipq806x: SPEED BIN: 0
[ 0.505279] acpuclk-ipq806x acpuclk-ipq806x: ACPU PVS: 1
[ 0.511965] acpuclk-ipq806x acpuclk-ipq806x: CPU0: 6 frequencies supported
[ 0.511996] acpuclk-ipq806x acpuclk-ipq806x: CPU1: 6 frequencies supported
[ 0.513589] msm_rpm_log_probe: OK
[ 0.533770] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.533801] jffs2: version 2.2. (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) © 2001-2006 Red Hat, Inc.
[ 0.537894] msgmni has been set to 932
[ 0.539050] io scheduler noop registered
[ 0.539050] io scheduler deadline registered (default)
[ 0.540393] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.543049] msm_serial_hs.0: ttyHS0 at MMIO 0x12490000 (irq = 227) is a MSM HS UART
[ 0.543642] msm_serial_hs module loaded
[ 0.543798] msm_serial_hsl: detected port #1
[ 0.543923] msm_serial_hsl.1: ttyHSL1 at MMIO 0x16340000 (irq = 184) is a MSM
[ 0.544361] msm_serial_hsl: console setup on port #1
[ 1.235832] console [ttyHSL1] enabled
[ 1.239050] msm_serial_hsl: driver initialized
[ 1.248516] ahci ahci.0: forcing PORTS_IMPL to 0x1
[ 1.252327] ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 1.260731] ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
[ 1.269322] scsi0 : ahci_platform
[ 1.272321] ata1: SATA max UDMA/133 mmio [mem 0x29000000-0x2900017f] port 0x100 irq 241
[ 1.282474] m25p80 spi5.0: found mx25u25635f, expected s25fl512s
[ 1.287472] m25p80 spi5.0: mx25u25635f (32768 Kbytes)
[ 1.293033] Creating 2 MTD partitions on "m25p80":
[ 1.297532] 0x0000001b0000-0x0000001f0000 : "ART"
[ 1.304248] 0x0000003f0000-0x000001ef0000 : "rootfs"
[ 1.310621] mtd: partition "rootfs" set to be root filesystem
[ 1.315651] flash_chrdev : flash_chrdev_init
[ 1.351858] GPIO Bitbanged MDIO: probed
[ 1.361543] cpuidle: using governor ladder
[ 1.365135] cpuidle: using governor menu
[ 1.370134] TCP: cubic registered
[ 1.372414] NET: Registered protocol family 17
[ 1.377194] Bridge firewalling registered
[ 1.380849] 8021q: 802.1Q VLAN Support v1.8
[ 1.385192] VFP support v0.3: implementor 51 architecture 64 part 4d variant 2 rev 0
[ 1.392752] Registering SWP/SWPB emulation handler
[ 1.398000] clock_late_init: Removing enables held for handed-off clocks
[ 1.412777] ipq_nss_get_mac_addr: MAC[0]: ff:ff:ff:ff:ff:ff
[ 1.417432] ipq_nss_get_mac_addr: MAC[1]: ff:ff:ff:ff:ff:ff
[ 1.422992] ipq_nss_get_mac_addr: MAC[2]: ff:ff:ff:ff:ff:ff
[ 1.428553] ipq_nss_get_mac_addr: MAC[3]: ff:ff:ff:ff:ff:ff
[ 1.434208] no pmic restart interrupt specified
[ 1.633989] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.664323] VFS: Mounted root (squashfs filesystem) readonly on device 31:1.
[ 1.670915] Freeing init memory: 1032K
[ 5.140549] tfat: module license 'Commercial. For support email exfat-support@tuxera.com' taints kernel.
[ 5.149047] Disabling lock debugging due to kernel taint
[ 5.155638] Tuxera FAT 12/16/32 driver version 3014.9.10 [Flags: R/W MODULE].
[ 5.394001] Tuxera exFAT driver version 3014.9.10 [Flags: R/W MODULE].
[ 5.692845] Tuxera NTFS driver 3015.1.29 [Flags: R/W MODULE].
[ 5.701905] Tuxera HFS+ driver 3014.7.28- preinit -
Press the [f] key and hit [enter] to enter failsafe mode
- regular preinit -
jffs2 not ready yet; using ramdisk
- init -
Please press Enter to activate this console. ssdk_plat_init start
[ 8.858825] Register QCA PHY driver
[ 10.510684] qca-ssdk module init succeeded!
[ 10.570509] NET: Registered protocol family 10
[ 10.876351] usbcore: registered new interface driver usbfs
[ 10.880943] usbcore: registered new interface driver hub
[ 10.886316] usbcore: registered new device driver usb
[ 11.297157] md: linear personality registered for level -1
[ 11.545954] md: raid0 personality registered for level 0
[ 11.558700] md: raid1 personality registered for level 1
[ 11.850702] NTFS driver 2.1.30 [Flags: R/O MODULE].
[ 12.047766] PPP generic driver version 2.4.2
[ 12.166354] PPP MPPE Compression module registered
[ 12.218088] **********************************************************
[ 12.223398] * Driver :NSS GMAC Driver for RTL v(3.72a)
[ 12.228834] * Version :1.0
[ 12.231646] * Copyright :Copyright (c) 2013-2014 The Linux Foundation. All rights reserved.
[ 12.240018] **********************************************************
[ 12.246985] GMAC1(dd3da480) Invalid MAC@ - using 92:93:94:95:96:97
[ 12.258856] GMAC2(dd3dbc80) Invalid MAC@ - using 5a:5b:5c:5d:5e:5f
[ 12.395189] L2TP core driver, V2.0
[ 12.405810] L2TP netlink interface
[ 12.523024] nss_driver - fw of size 354048 bytes copied to load addr: 40000000, nss_id : 0
[ 12.550109] nss_driver - Turbo Support 1
[ 12.554264] bf3982c9: NSS Shaping is enabled, handler id: 0
[ 12.581880] nss_driver - fw of size 5392 bytes copied to load addr: 40800000, nss_id : 1
[ 12.589971] Error - Duplicate Interface CB Registered for interface 75
[ 12.595532] Error - Duplicate Interface CB Registered for interface 78
[ 12.667447] IPv6 over IPv4 tunneling driver
[ 12.727928] nss_macsec init success
[ 12.771790] gre: GRE over IPv4 demultiplexor driver
[ 12.783848] ip_gre: GRE over IPv4 tunneling driver
[ 12.838644] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[ 12.994064] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 13.109778] NET: Registered protocol family 24
[ 13.275445] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 13.281037] msm_hsusb_host msm_hsusb_host: unable to find transceiver
[ 13.339300] nf_conntrack version 0.5.0 (7475 buckets, 29900 max)
[ 13.494407] PPPoL2TP kernel driver, V2.0
[ 13.544829] PPTP driver version 0.8.5
[ 13.950328] xt_time: kernel timezone is -0000
[ 14.274664] nf_conntrack_rtsp v0.6.21 loading
[ 14.286066] nf_nat_rtsp v0.6.21 loading
[ 14.338175] Netfilter messages via NETLINK v0.30.
[ 14.367104] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 14.476226] ctnetlink v0.93: registering with nfnetlink.
[ 14.591721] ipq-dwc3 ipq-dwc3.0: unable to read platform data num of dbm eps
[ 14.698344] xhci-hcd xhci-hcd.0: xHCI Host Controller
[ 14.702436] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 1
[ 14.709684] xhci-hcd xhci-hcd.0: irq 142, io mem 0x11000000
[ 14.715838] hub 1-0:1.0: USB hub found
[ 14.718869] hub 1-0:1.0: 1 port detected
[ 14.722899] xhci-hcd xhci-hcd.0: xHCI Host Controller
[ 14.727835] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 2
[ 14.735551] hub 2-0:1.0: USB hub found
[ 14.738737] hub 2-0:1.0: 1 port detected
[ 14.744267] ipq-dwc3 ipq-dwc3.1: unable to read platform data num of dbm eps
[ 14.850859] xhci-hcd xhci-hcd.1: xHCI Host Controller
[ 14.854951] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 3
[ 14.862168] xhci-hcd xhci-hcd.1: irq 237, io mem 0x10000000
[ 14.868291] hub 3-0:1.0: USB hub found
[ 14.871383] hub 3-0:1.0: 1 port detected
[ 14.875445] xhci-hcd xhci-hcd.1: xHCI Host Controller
[ 14.880318] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 4
[ 14.888066] hub 4-0:1.0: USB hub found
[ 14.891252] hub 4-0:1.0: 1 port detected
[ 15.197969] ECM init
[ 15.201624] ECM init complete
[ 15.245517] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 15.357357] Initializing USB Mass Storage driver...
[ 15.361387] usbcore: registered new interface driver usb-storage
[ 15.367197] USB Mass Storage support registered.
[ 15.381443] fuse init (API version 7.18)
-------------------- Load config start --------------------
reloadconfig() begin:
reloadconfig() end:
-------------------- Load config end ----------------------
-------------------- Load profile start -------------------
reload_profile() begin:
reload_profile() end:
-------------------- Load profile end ---------------------
-------------------- Load QoS DB start --------------------
-------------------- Load QoS DB end ----------------------
GMT+08:00
[ 23.322149] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 26.065666] device eth1 entered promiscuous mode
[ 26.069603] br-lan: port 1(eth1) entered forwarding state
[ 26.074664] br-lan: port 1(eth1) entered forwarding state
[ 26.080537] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 26.089909] ADDRCONF(NETDEV_UP): eth0: link is not ready
usbshare boot start
usbshare boot end
[ 40.087316] ath_hal: 0.9.17.1 (AR5416, AR9380, WRITE_EEPROM, 11D)
[ 40.508341] ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
[ 40.527303] ath_dfs: Version 2.0.0
[ 40.527303] Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
[ 40.594782] ath_spectral: Version 2.0.0
[ 40.594782] Copyright (c) 2005-2009 Atheros Communications, Inc. All Rights Reserved
[ 40.605779] SPECTRAL module built on Sep 18 2015 16:55:18
[ 40.660512] ath_tx99: Version 2.0
[ 40.660512] Copyright (c) 2010 Atheros Communications, Inc, All Rights Reserved
[ 40.762417] ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
[ 42.171196] ath_pci: (Atheros/multi-bss)
[ 42.179006] ath_pci_probe
[ 42.180599] PCI device id is 0040 :0040
[ 42.184879] PCI: enabling device 0000:01:00.0 (0140 -> 0142)
[ 42.190440] ath_pci 0000:01:00.0: ath DEBUG: sc=0xd8f4b200
[ 42.196032]
[ 42.196032] ol_ath_pci_configure : num_desired MSI set to 0
[ 42.202655]
[ 42.202655] Using PCI Legacy Interrupt
[ 42.208684] chip_id 9 chip_revision 1
[ 42.212121]
[ 42.212121] address 4008f8 data d8fb9c20
[ 42.218931]
[ 42.218931] address 401e90 data d8fb9c24
[ 42.226304]
[ 42.226304] address 401e94 data d8fb9c28
[ 42.233052]
[ 42.233052] address 401eb0 data d8fb9c2c
[ 42.240674]
[ 42.240674] address 400900 data d8fb9c2c
[ 42.248109]
[ 42.248109] CLOCK PLL skipped
[ 42.251671] HIF_PCIDeviceProbed: setting the target pll frac ffffffff intval ffffffff
[ 42.260168] HIF_PCIDeviceProbed: no frac provided, skipping pre-configuring PLL
[ 42.267041] HIF_PCIDeviceProbed: ar900b_20_targ_clk is not provided, skipping pre-configuring PLL
[ 42.276538]
[ 42.276538] address 4008cc data d8fb9c2c
[ 42.282286] __ol_ath_attach: ath_attach TODO
[ 42.290471] __ol_ath_attach 1765 host_enable 0 nss_nwifi_offload 0
[ 42.295970] __ol_ath_attach: dev name wifi0
[ 42.299781] ol_ath_set_default_tgt_config : AC Minfree buffer allocation through module param (umac.ko)
[ 42.309590] OL_ACBKMinfree : 0
[ 42.312277] OL_ACBEMinfree : 0
[ 42.315870] OL_ACVIMinfree : 0
[ 42.318525] OL_ACVOMinfree : 0
[ 42.321805] ol_ath_attach() BMI inited.
[ 42.326148] ol_ath_attach() BMI Get Target Info.
[ 42.330084] ol_ath_attach() TARGET TYPE: 9 Vers 0x1000000
[ 42.335895]
[ 42.335895] CE WAR Disabled
[ 42.339925] NUM_DEV=1 FWMODE=0x2 FWSUBMODE=0x0 FWBR_BUF 0
[ 42.345923] ol_ath_attach() configure Target .
[ 42.349671]
[ 42.349671] Target Version is 1000000
[ 42.355420]
[ 42.355420] Flash Download Address c0000
[ 42.360449] ol_transfer_bin_file: flash data file defined
[ 42.366416] Cal location [0]: 00000000
[ 42.369790]
[ 42.369790] Wifi0 Select OFFSET 1000
[ 42.394251] qc98xx_verify_checksum: flash checksum passed: 0x360c
[ 42.399312] ol_transfer_bin_file 2934: Download Flash data len 12064
[ 42.406341] Board extended Data download address: 0x0
[ 42.430834]
[ 42.430834] Board data initialized
[ 42.434926] Flash download ADDRESS 0xc0000
[ 42.438894]
[ 42.438894] Selecting OTP binary for CHIP Version 1
[ 42.456107] Enabling NSS RPS
[ 43.012183]
[ 43.012183] First OTP send param 8000
[ 43.118806] kcg 333 :GPL NetUSB up!
[ 43.161668] kc 90 : run_telnetDBGDServer start
[ 43.166323] kc 227 : init_DebugD end
[ 43.168978] INFO187A: NetUSB 1.02.64, 00030467 : Mar 27 2015 10:14:48
[ 43.175820] INFO187C: 7437: Archer C2600 :Archer C2600
[ 43.181255] INFO187D: AUTH ISOC
[ 43.183817] INFO187E: MOVE_HEAD filterAudio
[ 43.189128] usbcore: registered new interface driver KC NetUSB General Driver
[ 43.195907] INFO174F: infomap bfb00c00
[ 43.199125] INFO1752: sleep to wait br-lan to wake up
[ 43.204654] INFO18D6: Reset device when disconnect
[ 43.209028] INFO0145: init proc : PAGE_SIZE 4096
[ 43.213745] INFO02CE: use dev Name br-lan
[ 43.218494] INFO175B: sleep to wait br-lan end.
[ 43.222461] INFO1774: UDP_BROAD 7437 tcpPort:20005
[ 43.227928] INFO02CE: use dev Name br-lan
[ 43.231771] INFO1623: tcpConnector() started...
General shell run!
[ 44.604904] Button Hotplug driver version 0.4.1
[ 45.546485] msm_thermal: Max frequency reset for cpu0
[ 45.550515] msm_thermal: Max frequency reset for cpu1
[ 45.555576] msm_thermal: enabled = 0
[ 46.293939] INFO14FC: Bind to br-lan
[ 47.630396] ol_ath_download_firmware :First OTP download and Execute is good return param 33792
[ 47.638300]
[ 47.638300] ##Board Id 1
[ 47.642236]
[ 47.642236] ##CHIP Id 1
[ 47.646298]
[ 47.646298] BOARDDATA DOWNLOAD TO address c0000
[ 47.752671] ol_transfer_bin_file: Board data file: AR900B/hw.2/boardData_AR900B_CUS239_5G_v2_001.bin ARXXXX v=0x1
[ 48.475632] Board extended Data download address: 0x0
[ 48.500031] ol_ath_download_firmware: Using 0x1234 for the remainder of init
[ 48.506279]
[ 48.506310] Selecting OTP binary for CHIP Version 1
[ 48.643361]
[ 48.643361] Second otp download Param 10000
[ 53.270009] ol_ath_download_firmware : OTP download and Execute is good
[ 53.275945]
[ 53.275945] FIRMWARE : Beeliner CHIP Version 1
[ 53.328459] ol_swap_seg_alloc: Successfully allocated memory for SWAP size=131072
[ 53.428959] Swap: bytes_left to copy: fw:16; dma_page:25287
[ 53.433520] Swap: wrong length read:0
[ 53.437457] ol_swap_wlan_memory_expansion: Swap total_bytes copied: 105785 Target address 417608
[ 53.446329] scn=d90c0480 target_write_addr=417608 seg_info=ddfc6610
[ 53.452421] ol_transfer_swap_struct:Code swap structure successfully downloaded for bin type =2
[ 53.461543] bin_filename=AR900B/hw.2/athwlan.bin swap_filename=/lib/firmware/AR900B/hw.2/athwlan.codeswap.bin
[ 54.612027] ol_ath_attach() Download FW.
[ 54.615245] ol_ath_attach() HT Create .
[ 54.619275] ol_ath_attach() HIF Claim.
[ 54.622649] ol_ath_attach() BMI Done.
[ 54.626398] ol_ath_attach() WMI attached. wmi_handle d8480000
[ 54.632114] +HWT
[ 54.638394] CE_recv_buf_enqueue 809 Populate last entry 512 for CE 5
[ 54.643705] CE_recv_buf_enqueue 818 CE 5 wi 511 dest_ptr 0x59155040 nbytes 0 recv_ctxt 0xd9223300
[ 54.653202] Target:da8c4800 HTC Service:0x0001, ULpipe:0 DLpipe:1 id:0 Ready
[ 54.659731] -HWT
[ 54.661449]
[ 54.661449] <=== cfg max peer id 1056 ====>
[ 54.667260] Target:da8c4800 HTC Service:0x0300, ULpipe:4 DLpipe:5 id:1 Ready
[ 54.674164] HTC Service:0x0300 ep:1 TX flow control disabled
[ 54.682599] CE_pkt_dl_len_set CE 4 Pkt download length 64
[ 54.687066] ol_txrx_pdev_attach: 1424 tx desc's allocated ; range starts from d7960000
[ 54.695251] Target:da8c4800 HTC Service:0x0100, ULpipe:3 DLpipe:2 id:2 Ready
[ 54.701936] HTC Service:0x0100 ep:2 TX flow control disabled
[ 54.708778] wmi_service_ready_event_rx: WMI UNIFIED SERVICE READY event
[ 54.714526] num_rf_chain : 00000004
[ 54.717994] ht_cap_info: : 0000085b
[ 54.721493] vht_cap_info : 339b79b2
[ 54.724960] vht_supp_mcs : 0000ffea
[ 54.728428] ol_ath_service_ready_event: tt_support: 1
[ 54.733458] Peer Caching Enabled ; num_peers = 528, num_active_peers = 66 num_tids = 132, num_vdevs = 16
[ 54.742924] idx 0 req 1 num_units 0 num_unit_info 2 unit size 1296 actual units 529
[ 54.751265] idx 1 req 2 num_units 1 num_unit_info 4 unit size 256 actual units 67
[ 54.758419] idx 2 req 3 num_units 1 num_unit_info 4 unit size 1024 actual units 67
[ 54.766166] idx 3 req 4 num_units 1 num_unit_info 4 unit size 4096 actual units 67
[ 54.774070] idx 4 req 6 num_units 35 num_unit_info 0 unit size 3072 actual units 35
[ 54.781693] idx 5 req 7 num_units 1 num_unit_info 0 unit size 6144 actual units 1
[ 54.789315] idx 6 req 5 num_units 0 num_unit_info 2 unit size 1628 actual units 529
[ 54.797594] chunk 0 len 685584 requested ,ptr 0x58f00000
[ 54.802561] chunk 1 len 17152 requested ,ptr 0x58ea0000
[ 54.807966] chunk 2 len 68608 requested ,ptr 0x58ec0000
[ 54.813308] chunk 3 len 274432 requested ,ptr 0x58800000
[ 54.818806] chunk 4 len 107520 requested ,ptr 0x58ee0000
[ 54.824273] chunk 5 len 6144 requested ,ptr 0x5a6da000
[ 54.829553] chunk 6 len 861212 requested ,ptr 0x58900000
[ 54.886316] wmi_ready_event_rx: WMI UNIFIED READY event
[ 54.890784] ol_ath_connect_htc() WMI is ready
[ 54.895095] ol_ath_set_host_app_area TODO
[ 54.899094] target uses HTT version 2.1; host uses 2.1
[ 54.909278] ol_ath_attach() connect HTC.
[ 54.912246] ol_regdmn_start: reg-domain param: regdmn=0, countryName=, wModeSelect=FFFFFFFF, netBand=FFFFFFFF, extendedChanMode=0.
[ 54.924086] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2) flags 0x2150
[ 54.931021] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4) flags 0xa0
[ 54.937894] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x8) flags 0xc0
[ 54.944767] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x20) flags 0xd0
[ 54.951671] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x40) flags 0x150
[ 54.958731] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x800) flags 0x10080
[ 54.966010] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2000) flags 0x20080
[ 54.973383] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4000) flags 0x40080
[ 54.980943] Add VHT80 channel: 5210
[ 54.984254] Add VHT80 channel: 5290
[ 54.987691] Add VHT80 channel: 5530
[ 54.991159] Add VHT80 channel: 5610
[ 54.994657] Add VHT80 channel: 5690
[ 54.998125] Add VHT80 channel: 5775
[ 55.001593] Skipping VHT80 channel 5825
[ 55.005935] ol_ath_phyerr_attach: called
[ 55.009403] OL Resmgr Init-ed
[ 55.012308] ieee80211_bsteering_attach: Band steering initialized
[ 55.018400] ol_if_spectral_setup
[ 55.021587] SPECTRAL : get_capability not registered
[ 55.026522] HAL_CAP_PHYDIAG : Capable
[ 55.030146] SPECTRAL : Need to fix the capablity check for RADAR (spectral_attach : 231)
[ 55.038269] SPECTRAL : get_capability not registered
[ 55.043236] HAL_CAP_RADAR : Capable
[ 55.046922] SPECTRAL : Need to fix the capablity check for SPECTRAL
[ 55.046922] (spectral_attach : 236)
[ 55.056638] SPECTRAL : get_capability not registered
[ 55.061574] HAL_CAP_SPECTRAL_SCAN : Capable
[ 55.065760] SPECTRAL : get_tsf64 not registered
[ 55.070259] spectral_init_netlink 65 NULL SKB
[ 55.074726] Green-AP : Green-AP : Attached
[ 55.074726]
[ 55.080131] Green-AP : Attached
[ 55.083255] rate power table override is only supported for AR98XX
[ 55.089659] ieee80211com_init_netlink: 3223: Wifipos 1st Netlink socket created:db0e5e00
[ 55.097532] ol_if_dfs_setup: called
[ 55.101062] ol_if_dfs_attach: called; ptr=d845d984, radar_info=d8fb9bc8
[ 55.108028] ol_ath_rtt_meas_report_attach: called
[ 55.112933] ol_ath_attach() UMAC attach .
[ 55.116494] ol_if_dfs_configure: called
[ 55.120243] ol_if_dfs_configure: FCC domain
[ 55.124461] ol_if_dfs_disable: called
[ 55.128116] ol_ath_attach: Calling ol_if_dfs_configure
[ 55.133239]
[ 55.133270] BURSTING enabled by default
[ 55.138831] osif_wrap_attach:400 osif wrap attached
[ 55.143455] osif_wrap_devt_init:361 osif wrap dev table init done
[ 55.149547] Wrap Attached: Wrap_com =daa20c00 ic->ic_wrap_com=daa20c00 &wrap_com->wc_devt=daa20c00
[ 55.158637] __ol_ath_attach: init tx/rx TODO
[ 55.162886] __ol_ath_attach: needed_headroom reservation 44
[ 55.169290] ol_ath_thermal_mitigation_attach: ++
[ 55.173070] ol_ath_thermal_mitigation_attach: --
[ 55.177850] ath_pci_probe
[ 55.180224] PCI device id is 0040 :0040
[ 55.184098] PCI: enabling device 0000:03:00.0 (0140 -> 0142)
[ 55.189971] ath_pci 0000:03:00.0: ath DEBUG: sc=0xdd3a9600
[ 55.195189]
[ 55.195189] ol_ath_pci_configure : num_desired MSI set to 0
[ 55.202311]
[ 55.202311] Using PCI Legacy Interrupt
[ 55.207622] chip_id 9 chip_revision 1
[ 55.211621]
[ 55.211621] address 4008f8 data d8fb9c20
[ 55.217931]
[ 55.217931] address 401e90 data d8fb9c24
[ 55.224554]
[ 55.224554] address 401e94 data d8fb9c28
[ 55.231146]
[ 55.231177] address 401eb0 data d8fb9c2c
[ 55.237831]
[ 55.237831] address 400900 data d8fb9c2c
[ 55.244423]
[ 55.244423] CLOCK PLL skipped
[ 55.248047] HIF_PCIDeviceProbed: setting the target pll frac ffffffff intval ffffffff
[ 55.255888] HIF_PCIDeviceProbed: no frac provided, skipping pre-configuring PLL
[ 55.263136] HIF_PCIDeviceProbed: ar900b_20_targ_clk is not provided, skipping pre-configuring PLL
[ 55.272039]
[ 55.272039] address 4008cc data d8fb9c2c
[ 55.279756] __ol_ath_attach: ath_attach TODO
[ 55.283005] __ol_ath_attach 1765 host_enable 0 nss_nwifi_offload 0
[ 55.289222] __ol_ath_attach: dev name wifi1
[ 55.293345] ol_ath_set_default_tgt_config : AC Minfree buffer allocation through module param (umac.ko)
[ 55.302749] OL_ACBKMinfree : 0
[ 55.307403] OL_ACBEMinfree : 0
[ 55.309528] OL_ACVIMinfree : 0
[ 55.312652] OL_ACVOMinfree : 0
[ 55.315995] ol_ath_attach() BMI inited.
[ 55.319681] ol_ath_attach() BMI Get Target Info.
[ 55.324211] ol_ath_attach() TARGET TYPE: 9 Vers 0x1000000
[ 55.329584]
[ 55.329584] CE WAR Disabled
[ 55.334083] NUM_DEV=1 FWMODE=0x2 FWSUBMODE=0x0 FWBR_BUF 0
[ 55.339550] ol_ath_attach() configure Target .
[ 55.343830]
[ 55.343830] Target Version is 1000000
[ 55.348953]
[ 55.348953] Flash Download Address c0000
[ 55.354607] ol_transfer_bin_file: flash data file defined
[ 55.359950] Cal location [1]: 00004000
[ 55.363980]
[ 55.363980] Wifi1 Select OFFSET 5000
[ 55.389534] qc98xx_verify_checksum: flash checksum passed: 0x5aa4
[ 55.395001] ol_transfer_bin_file 2934: Download Flash data len 12064
[ 55.401155] Board extended Data download address: 0x0
[ 55.426398]
[ 55.426398] Board data initialized
[ 55.430427] Flash download ADDRESS 0xc0000
[ 55.434457]
[ 55.434457] Selecting OTP binary for CHIP Version 1
[ 55.574445]
[ 55.574445] First OTP send param 8000
[ 55.630740] [wifi0] FWLOG: [55965] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x518, 0x518, 0x0 )
[ 55.638331] [wifi0] FWLOG: [55965] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x518, 0x518, 0x0 )
[ 55.646985] [wifi0] FWLOG: [55965] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x518, 0x518, 0x0 )
[ 55.655701] [wifi0] FWLOG: [55965] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x518, 0x518, 0x0 )
[ 60.192627] ol_ath_download_firmware :First OTP download and Execute is good return param 34816
[ 60.200749]
[ 60.200781] ##Board Id 2
[ 60.204717]
[ 60.204748] ##CHIP Id 1
[ 60.208497]
[ 60.208497] BOARDDATA DOWNLOAD TO address c0000
[ 60.214901] ol_transfer_bin_file: Board data file: AR900B/hw.2/boardData_AR900B_CUS260_2G_v2_002.bin ARXXXX v=0x1
[ 60.345454] Board extended Data download address: 0x0
[ 60.370040] ol_ath_download_firmware: Using 0x1234 for the remainder of init
[ 60.376288]
[ 60.376288] Selecting OTP binary for CHIP Version 1
[ 60.430021]
[ 60.430021] Second otp download Param 10000
[ 65.056669] ol_ath_download_firmware : OTP download and Execute is good
[ 65.062355]
[ 65.062355] FIRMWARE : Beeliner CHIP Version 1
[ 65.084192] ol_swap_seg_alloc: Successfully allocated memory for SWAP size=131072
[ 65.106029] Swap: bytes_left to copy: fw:16; dma_page:25287
[ 65.110621] Swap: wrong length read:0
[ 65.114620] ol_swap_wlan_memory_expansion: Swap total_bytes copied: 105785 Target address 417608
[ 65.123305] scn=d75c0480 target_write_addr=417608 seg_info=d7367c10
[ 65.129834] ol_transfer_swap_struct:Code swap structure successfully downloaded for bin type =2
[ 65.138550] bin_filename=AR900B/hw.2/athwlan.bin swap_filename=/lib/firmware/AR900B/hw.2/athwlan.codeswap.bin
[ 66.252327] ol_ath_attach() Download FW.
[ 66.255576] ol_ath_attach() HT Create .
[ 66.259137] ol_ath_attach() HIF Claim.
[ 66.262949] ol_ath_attach() BMI Done.
[ 66.266979] ol_ath_attach() WMI attached. wmi_handle d7660000
[ 66.272446] +HWT
[ 66.278631] CE_recv_buf_enqueue 809 Populate last entry 512 for CE 5
[ 66.284005] CE_recv_buf_enqueue 818 CE 5 wi 511 dest_ptr 0x5871c040 nbytes 0 recv_ctxt 0xd9226180
[ 66.294001] Target:da8c7800 HTC Service:0x0001, ULpipe:0 DLpipe:1 id:0 Ready
[ 66.300062] -HWT
[ 66.301874]
[ 66.301874] <=== cfg max peer id 1056 ====>
[ 66.309559] Target:da8c7800 HTC Service:0x0300, ULpipe:4 DLpipe:5 id:1 Ready
[ 66.315807] HTC Service:0x0300 ep:1 TX flow control disabled
[ 66.324054] CE_pkt_dl_len_set CE 4 Pkt download length 64
[ 66.328491] ol_txrx_pdev_attach: 1424 tx desc's allocated ; range starts from d6720000
[ 66.336957] Target:da8c7800 HTC Service:0x0100, ULpipe:3 DLpipe:2 id:2 Ready
[ 66.343392] HTC Service:0x0100 ep:2 TX flow control disabled
[ 66.350452] wmi_service_ready_event_rx: WMI UNIFIED SERVICE READY event
[ 66.356232] num_rf_chain : 00000004
[ 66.359668] ht_cap_info: : 0000085b
[ 66.363136] vht_cap_info : 339b79b2
[ 66.366635] vht_supp_mcs : 0000ffea
[ 66.370071] ol_ath_service_ready_event: tt_support: 1
[ 66.375132] Peer Caching Enabled ; num_peers = 528, num_active_peers = 66 num_tids = 132, num_vdevs = 16
[ 66.384598] idx 0 req 1 num_units 0 num_unit_info 2 unit size 1296 actual units 529
[ 66.392877] idx 1 req 2 num_units 1 num_unit_info 4 unit size 256 actual units 67
[ 66.400093] idx 2 req 3 num_units 1 num_unit_info 4 unit size 1024 actual units 67
[ 66.407841] idx 3 req 4 num_units 1 num_unit_info 4 unit size 4096 actual units 67
[ 66.415713] idx 4 req 6 num_units 35 num_unit_info 0 unit size 3072 actual units 35
[ 66.423367] idx 5 req 7 num_units 1 num_unit_info 0 unit size 6144 actual units 1
[ 66.430959] idx 6 req 5 num_units 0 num_unit_info 2 unit size 1628 actual units 529
[ 66.439237] chunk 0 len 685584 requested ,ptr 0x57d00000
[ 66.444236] chunk 1 len 17152 requested ,ptr 0x57c60000
[ 66.449609] chunk 2 len 68608 requested ,ptr 0x57c80000
[ 66.454982] chunk 3 len 274432 requested ,ptr 0x57e00000
[ 66.460449] chunk 4 len 107520 requested ,ptr 0x57ca0000
[ 66.465916] chunk 5 len 6144 requested ,ptr 0x58874000
[ 66.471227] chunk 6 len 861212 requested ,ptr 0x57f00000
[ 66.529553] wmi_ready_event_rx: WMI UNIFIED READY event
[ 66.534020] ol_ath_connect_htc() WMI is ready
[ 66.538238] ol_ath_set_host_app_area TODO
[ 66.542299] target uses HTT version 2.1; host uses 2.1
[ 66.547297] ol_ath_attach() connect HTC.
[ 66.547328] ol_regdmn_start: reg-domain param: regdmn=0, countryName=, wModeSelect=FFFFFFFF, netBand=FFFFFFFF, extendedChanMode=0.
[ 66.547328] ol_regdmn_init_channels: !avail mode 0x680c (0x2) flags 0x2150
[ 66.547360] ol_regdmn_init_channels: !avail mode 0x680c (0x1) flags 0x140
[ 66.547391] ol_regdmn_init_channels: !avail mode 0x680c (0x20) flags 0xd0
[ 66.547391] ol_regdmn_init_channels: !avail mode 0x680c (0x40) flags 0x150
[ 66.547422] ol_regdmn_init_channels: !avail mode 0x680c (0x1000) flags 0x10100
[ 66.547422] ol_regdmn_init_channels: !avail mode 0x680c (0x8000) flags 0x20100
[ 66.547422] ol_regdmn_init_channels: !avail mode 0x680c (0x10000) flags 0x40100
[ 66.547453] ol_regdmn_init_channels: !avail mode 0x680c (0x20000) flags 0x100100
[ 66.547453] ol_regdmn_init_channels: !avail mode 0x680c (0x40000) flags 0x200100
[ 66.547453] ol_regdmn_init_channels: !avail mode 0x680c (0x80000) flags 0x400100
[ 66.547485] ol_regdmn_init_channels: !avail mode 0x680c (0x100000) flags 0x800100
[ 66.547547] ol_ath_phyerr_attach: called
[ 66.547610] OL Resmgr Init-ed
[ 66.547672] ieee80211_bsteering_attach: Band steering initialized
[ 66.547672] ol_if_spectral_setup
[ 66.547703] SPECTRAL : get_capability not registered
[ 66.547703] HAL_CAP_PHYDIAG : Capable
[ 66.547703] SPECTRAL : Need to fix the capablity check for RADAR (spectral_attach : 231)
[ 66.547703] HAL_CAP_RADAR : Capable
[ 66.547735] SPECTRAL : Need to fix the capablity check for SPECTRAL
[ 66.547735] (spectral_attach : 236)
[ 66.547735] SPECTRAL : get_capability not registered
[ 66.547735] HAL_CAP_SPECTRAL_SCAN : Capable
[ 66.547735] SPECTRAL : get_tsf64 not registered
[ 66.547766] spectral_init_netlink 65 NULL SKB
[ 66.547766] Green-AP : Green-AP : Attached
[ 66.547766]
[ 66.547766] Green-AP : Attached
[ 66.547766] rate power table override is only supported for AR98XX
[ 66.547828] ieee80211com_init_netlink: Socket already created db0e5e00
[ 66.547828] ol_if_dfs_setup: called
[ 66.547860] ol_if_dfs_attach: called; ptr=d7349984, radar_info=d8fb9bc8
[ 66.548234] ol_ath_rtt_meas_report_attach: called
[ 66.548422] ol_ath_attach() UMAC attach .
[ 66.548422] ol_if_dfs_configure: called
[ 66.548453] ol_if_dfs_configure: FCC domain
[ 66.548453] ol_if_dfs_disable: called
[ 66.548516] ol_ath_attach: Calling ol_if_dfs_configure
[ 66.548516]
[ 66.548516] BURSTING enabled by default
[ 66.548578] osif_wrap_attach:400 osif wrap attached
[ 66.548609] osif_wrap_devt_init:361 osif wrap dev table init done
[ 66.548609] Wrap Attached: Wrap_com =d8f4c200 ic->ic_wrap_com=d8f4c200 &wrap_com->wc_devt=d8f4c200
[ 66.548609] __ol_ath_attach: init tx/rx TODO
[ 66.548609] __ol_ath_attach: needed_headroom reservation 44
[ 66.551140] ol_ath_thermal_mitigation_attach: ++
[ 66.551171] ol_ath_thermal_mitigation_attach: --
[ 66.813089] Initializing Pktlogs for 11ac
[ 66.816338] Initializing Pktlogs for 11ac
[ 66.907935] __sa_init_module
[ 67.270696] [wifi1] FWLOG: [67842] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x518, 0x518, 0x0 )
[ 67.278288] [wifi1] FWLOG: [67842] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x518, 0x518, 0x0 )
[ 67.295720] [wifi1] FWLOG: [67842] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x518, 0x518, 0x0 )
[ 67.307966] [wifi1] FWLOG: [67842] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x518, 0x518, 0x0 )
[ 67.444954] [ol_ath_iw_setcountry][1641] *p=50, *(p+1)=4c
[ 67.449359] isCountryCodeValid: EEPROM regdomain 0x0
[ 67.455014] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2) flags 0x2150
[ 67.461324] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4) flags 0xa0
[ 67.468728] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x8) flags 0xc0
[ 67.475320] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x20) flags 0xd0
[ 67.481974] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x40) flags 0x150
[ 67.489440] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x800) flags 0x10080
[ 67.496532] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x2000) flags 0x20080
[ 67.503686] ol_regdmn_init_channels: !avail mode 0x1f9001 (0x4000) flags 0x40080
[ 67.511527] Add VHT80 channel: 5210
[ 67.514745] Add VHT80 channel: 5290
[ 67.517994] Add VHT80 channel: 5530
[ 67.521462] Add VHT80 channel: 5610
[ 67.549796] set TXBF_SND_PERIOD: value 100 wmi_status 0
[ 67.614026] ath_ioctl: SIOC80211IFCREATE CALLED
[ 67.617588] wmi_unified_vdev_create_send: ID = 0 Type = 1, Subtype = 0 VAP Addr = ec:08:6b:2c:a0:4b:
[ 67.627741] __ieee80211_smart_ant_init: Smart Antenna is not supported
[ 67.633333] Enabling SG bit for the vap ath0 features 4000
[ 67.639362] Enabling TSO bit for the vap ath0 features 4000
[ 67.644798] Enabling LRO bit for the vap ath0 features 4000
[ 67.650171] VAP device ath0 created osifp: (da8c0480) os_if: (d8f08000)
[ 67.688284] WARNING: Fragmentation with HT mode NOT ALLOWED!!
[ 67.723523] ME Pool succesfully initialized vaddr - d6400000 paddr - 0
[ 67.723523] num_elems = 10424 buf_size - 64 pool_size = 708832
[ 67.735488] Enable MCAST_TO_UCAST
[ 67.767572] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 3
[ 67.783255]
[ 67.783255] DES SSID SET=
[ 67.789597]
[ 67.789597] DES SSID SET=TP-LINK_A04C_5G
[ 68.323930] ieee80211_ioctl_siwmode: imr.ifm_active=66176, new mode=3, valid=1
[ 68.364261] DEVICE IS DOWN ifname=ath0
[ 68.367104] DEVICE IS DOWN ifname=ath0
[ 68.563667] [ol_ath_iw_setcountry][1641] *p=50, *(p+1)=4c
[ 68.568166] isCountryCodeValid: EEPROM regdomain 0x0
[ 68.573008] ol_regdmn_init_channels: !avail mode 0x680c (0x2) flags 0x2150
[ 68.579881] ol_regdmn_init_channels: !avail mode 0x680c (0x1) flags 0x140
[ 68.586847] ol_regdmn_init_channels: !avail mode 0x680c (0x20) flags 0xd0
[ 68.593408] ol_regdmn_init_channels: !avail mode 0x680c (0x40) flags 0x150
[ 68.600281] ol_regdmn_init_channels: !avail mode 0x680c (0x1000) flags 0x10100
[ 68.607497] ol_regdmn_init_channels: !avail mode 0x680c (0x8000) flags 0x20100
[ 68.614682] ol_regdmn_init_channels: !avail mode 0x680c (0x10000) flags 0x40100
[ 68.621961] ol_regdmn_init_channels: !avail mode 0x680c (0x20000) flags 0x100100
[ 68.629397] ol_regdmn_init_channels: !avail mode 0x680c (0x40000) flags 0x200100
[ 68.636738] ol_regdmn_init_channels: !avail mode 0x680c (0x80000) flags 0x400100
[ 68.644142] ol_regdmn_init_channels: !avail mode 0x680c (0x100000) flags 0x800100
[ 68.665448] [wifi0] FWLOG: [69867] WAL_DBGID_SECURITY_ENCR_EN ( )
[ 68.670571] [wifi0] FWLOG: [69867] WAL_DBGID_SECURITY_MCAST_KEY_SET ( 0x1 )
[ 68.687316] set TXBF_SND_PERIOD: value 100 wmi_status 0
[ 68.709934] ath_ioctl: SIOC80211IFCREATE CALLED
[ 68.713495] wmi_unified_vdev_create_send: ID = 0 Type = 1, Subtype = 0 VAP Addr = ec:08:6b:2c:a0:4c:
[ 68.723024] __ieee80211_smart_ant_init: Smart Antenna is not supported
[ 68.729240] Enabling SG bit for the vap ath1 features 4000
[ 68.734895] Enabling TSO bit for the vap ath1 features 4000
[ 68.740362] Enabling LRO bit for the vap ath1 features 4000
[ 68.746141] VAP device ath1 created osifp: (dd5e6c80) os_if: (d8428000)
[ 68.784754] WARNING: Fragmentation with HT mode NOT ALLOWED!!
[ 68.818181] ME Pool succesfully initialized vaddr - d6600000 paddr - 0
[ 68.818181] num_elems = 10424 buf_size - 64 pool_size = 708832
[ 68.829615] Enable MCAST_TO_UCAST
[ 68.869478] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 3
[ 68.884973]
[ 68.884973] DES SSID SET=
[ 68.891190]
[ 68.891190] DES SSID SET=TP-LINK_A04C
[ 69.064323] ieee80211_ioctl_siwmode: imr.ifm_active=131712, new mode=3, valid=1
[ 69.104123] DEVICE IS DOWN ifname=ath1
[ 69.106997] DEVICE IS DOWN ifname=ath1
[ 69.223117] device ath0 entered promiscuous mode
[ 69.232677] OL vap_stop +
[ 69.234551] wmi_unified_vdev_stop_send for vap 0 (d8480000)
[ 69.239831] OL vap_stop -
[ 69.239893] STOPPED EVENT for vap 0 (d8480000)
[ 69.275226] br-lan: port 2(ath0) entered forwarding state
[ 69.275445] [wifi1] FWLOG: [70568] WAL_DBGID_SECURITY_ENCR_EN ( )
[ 69.275476] [wifi1] FWLOG: [70568] WAL_DBGID_SECURITY_MCAST_KEY_SET ( 0x1 )
[ 69.292752] br-lan: port 2(ath0) entered forwarding state
[ 69.298219] 8021q: adding VLAN 0 to HW filter on device ath0
[ 69.308309] device ath1 entered promiscuous mode
[ 69.319556] OL vap_stop +
[ 69.321149] wmi_unified_vdev_stop_send for vap 0 (d7660000)
[ 69.326866] OL vap_stop -
[ 69.326897] STOPPED EVENT for vap 0 (d7660000)
[ 69.355232] br-lan: port 3(ath1) entered forwarding state
[ 69.359606] br-lan: port 3(ath1) entered forwarding state
[ 69.365073] 8021q: adding VLAN 0 to HW filter on device ath1
[ 69.668166] [wifi0] FWLOG: [70686] WAL channel change freq=5180, mode=0 flags=0 rx_ok=1 tx_ok=1
[ 69.676038] [wifi0] FWLOG: [70978] WAL channel change freq=5200, mode=0 flags=0 rx_ok=1 tx_ok=1
[ 70.305279] [wifi1] FWLOG: [70754] WAL channel change freq=2412, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 70.312964] [wifi1] FWLOG: [71046] WAL channel change freq=2417, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 70.321774] [wifi1] FWLOG: [71359] WAL channel change freq=2422, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 70.330334] [wifi1] FWLOG: [71672] WAL channel change freq=2427, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 70.501749] OL vap_start +
[ 70.503405] wmi_unified_vdev_start_send for vap 0 (d8480000)
[ 70.509153] OL vap_start -
[ 70.850390] ol_vdev_start_resp_ev for vap 0 (d8480000)
[ 70.854514] ol_ath_vap_join: join operation is only for STA/IBSS mode
[ 70.860887] ol_ath_wmm_update:
[ 70.864011] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 3
[ 70.870977] wmi_unified_vdev_up_send for vap 0 (d8480000)
[ 70.876382] __ieee80211_smart_ant_init: Smart Antenna is not supported
[ 70.882942] Notification to UMAC VAP layer
[ 70.887066] [wifi0] FWLOG: [71291] WAL channel change freq=5220, mode=0 flags=0 rx_ok=1 tx_ok=1
[ 70.897375] [wifi0] FWLOG: [71604] WAL channel change freq=5240, mode=0 flags=0 rx_ok=1 tx_ok=1
[ 70.905279] [wifi0] FWLOG: [71962] vap-0 VDEV_MGR_VDEV_START ( 0x143c, 0x2, 0x0, 0x0 )
[ 70.912964] [wifi0] FWLOG: [71962] WAL channel change freq=5180, mode=10 flags=0 rx_ok=1 tx_ok=1
[ 71.307747] [wifi1] FWLOG: [71985] WAL channel change freq=2432, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 71.315463] [wifi1] FWLOG: [72298] WAL channel change freq=2437, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 71.324211] [wifi1] FWLOG: [72612] WAL channel change freq=2442, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 71.853264] [wifi0] FWLOG: [72300] VDEV_MGR_HP_START_TIME ( 0x0, 0x143c, 0xf55001 )
[ 71.859856] [wifi0] FWLOG: [72300] RESMGR_OCS_GEN_PERIODIC_NOA ( 0x1 )
[ 71.866385] [wifi0] FWLOG: [72300] RESMGR_OCS_GEN_PERIODIC_NOA ( 0x0 )
[ 71.872883] [wifi0] FWLOG: [72300] VDEV_MGR_AP_TBTT_CONFIG ( 0x0, 0x143c, 0x0, 0x0 )
[ 72.310153] [wifi1] FWLOG: [72924] WAL channel change freq=2447, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 72.317838] [wifi1] FWLOG: [73238] WAL channel change freq=2452, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 72.326616] [wifi1] FWLOG: [73551] WAL channel change freq=2457, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 73.312589] [wifi1] FWLOG: [73864] WAL channel change freq=2462, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 73.320243] [wifi1] FWLOG: [74177] WAL channel change freq=2467, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 73.329053] [wifi1] FWLOG: [74490] WAL channel change freq=2472, mode=1 flags=0 rx_ok=1 tx_ok=1
[ 73.339393] OL vap_start +
[ 73.341080] wmi_unified_vdev_start_send for vap 0 (d7660000)
[ 73.346797] OL vap_start -
[ 73.703342] ol_vdev_start_resp_ev for vap 0 (d7660000)
[ 73.707435] ol_ath_vap_join: join operation is only for STA/IBSS mode
[ 73.713870] ol_ath_wmm_update:
[ 73.716963] su bfee 1 mu bfee 0 su bfer 1 mu bfer 1 impl bf 0 sounding dim 3
[ 73.723930] wmi_unified_vdev_up_send for vap 0 (d7660000)
[ 73.729334] __ieee80211_smart_ant_init: Smart Antenna is not supported
[ 73.735926] Notification to UMAC VAP layer
[ 74.314995] [wifi1] FWLOG: [74847] vap-0 VDEV_MGR_VDEV_START ( 0x985, 0x2, 0x0, 0x0 )
[ 74.321805] [wifi1] FWLOG: [74847] WAL channel change freq=2437, mode=7 flags=0 rx_ok=1 tx_ok=1
[ 74.330552] [wifi1] FWLOG: [75202] VDEV_MGR_HP_START_TIME ( 0x0, 0x985, 0x6ef001 )
[ 74.338019] [wifi1] FWLOG: [75202] RESMGR_OCS_GEN_PERIODIC_NOA ( 0x1 )
[ 74.344517] [wifi1] FWLOG: [75202] RESMGR_OCS_GEN_PERIODIC_NOA ( 0x0 )
[ 74.351046] [wifi1] FWLOG: [75202] VDEV_MGR_AP_TBTT_CONFIG ( 0x0, 0x985, 0x0, 0x0 )
