Czy na alt opr. modem LTE e3276 zadziała bez problemu w porcie usb routera?
jakiś czas temu wgrałem, ale z braku czasu i z tego że router nie znalazł modemu- wcale go nie widział - zarzuciłem ten projekt, teraz jednak chciałbym go odpalić na 1043v1.
co wgrać by poszło LTE ( play) na tym routerze?
ma jeszcze w razie czego 740N v2.4 do testów
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.000000] Memory: 28936k/32768k available (2256k kernel code, 3832k reserved, 425k data, 220k init, 0k highmem)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.000000] NR_IRQS:51
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.080000] pid_max: default: 32768 minimum: 301
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.080000] Mount-cache hash table entries: 512
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.090000] NET: Registered protocol family 16
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.090000] gpiochip_add: registered GPIOs 0 to 21 on device: ath79
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.100000] MIPS: machine is TP-LINK TL-WR1043ND
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.360000] bio: create slab <bio-0> at 0
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.370000] Switching to clocksource MIPS
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.380000] NET: Registered protocol family 2
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.380000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.380000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.390000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.390000] TCP: Hash tables configured (established 1024 bind 1024)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.400000] TCP reno registered
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.400000] UDP hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.410000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.420000] NET: Registered protocol family 1
Jan 1 01:00:41 Gargoyle kern.debug kernel: [ 0.420000] PCI: CLS 0 bytes, default 32
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.440000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.440000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.450000] msgmni has been set to 56
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.460000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.460000] io scheduler noop registered
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.470000] io scheduler deadline registered (default)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.470000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.510000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.510000] console [ttyS0] enabled, bootconsole disabled
Jan 1 01:00:41 Gargoyle kern.warn kernel: [ 0.530000] m25p80 spi0.0: found s25sl064a, expected m25p80
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.530000] m25p80 spi0.0: s25sl064a (8192 Kbytes)
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 0.540000] 5 tp-link partitions found on MTD device spi0.0
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 0.540000] Creating 5 MTD partitions on "spi0.0":
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 0.550000] 0x000000000000-0x000000020000 : "u-boot"
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 0.560000] 0x000000020000-0x000000110e00 : "kernel"
Jan 1 01:00:41 Gargoyle kern.warn kernel: [ 0.560000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 0.570000] 0x000000110e00-0x0000007f0000 : "rootfs"
Jan 1 01:00:41 Gargoyle kern.warn kernel: [ 0.580000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 0.590000] mtd: partition "rootfs" set to be root filesystem
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.600000] mtd: partition "rootfs_data" created automatically, ofs=680000, len=170000
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 0.610000] 0x000000680000-0x0000007f0000 : "rootfs_data"
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 0.620000] 0x0000007f0000-0x000000800000 : "art"
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 0.620000] 0x000000020000-0x0000007f0000 : "firmware"
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 0.630000] Realtek RTL8366RB ethernet switch driver version 0.2.3
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.750000] rtl8366rb rtl8366rb: using GPIO pins 18 (SDA) and 19 (SCK)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.750000] rtl8366rb rtl8366rb: RTL5937 ver. 3 chip found
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.930000] rtl8366rb: probed
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 0.940000] eth0: Atheros AG71xx at 0xb9000000, irq 4
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 1.240000] TCP cubic registered
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 1.250000] NET: Registered protocol family 17
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 1.250000] Bridge firewalling registered
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 1.260000] Ebtables v2.0 registered
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 1.260000] 8021q: 802.1Q VLAN Support v1.8
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 1.270000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 1.280000] Freeing unused kernel memory: 220k freed
Jan 1 01:00:41 Gargoyle kern.debug kernel: [ 3.550000] ar71xx: pll_reg 0xb8050014: 0x1a000000
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 3.550000] eth0: link up (1000Mbps/Full duplex)
Jan 1 01:00:41 Gargoyle kern.debug kernel: [ 3.720000] Registered led device: tp-link:green:usb
Jan 1 01:00:41 Gargoyle kern.debug kernel: [ 3.720000] Registered led device: tp-link:green:system
Jan 1 01:00:41 Gargoyle kern.debug kernel: [ 3.720000] Registered led device: tp-link:green:qss
Jan 1 01:00:41 Gargoyle kern.debug kernel: [ 3.720000] Registered led device: tp-link:green:wlan
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 7.040000] JFFS2 notice: (440) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 33 of xref (0 dead, 5 orphan) found.
Jan 1 01:00:41 Gargoyle kern.notice kernel: [ 7.900000] SCSI subsystem initialized
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.140000] usbcore: registered new interface driver usbfs
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.140000] usbcore: registered new interface driver hub
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.150000] usbcore: registered new device driver usb
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.680000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.690000] ehci-platform ehci-platform: Generic Platform EHCI Controller
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.690000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.730000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.750000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.750000] hub 1-0:1.0: USB hub found
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.760000] hub 1-0:1.0: 1 port detected
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.820000] Initializing USB Mass Storage driver...
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.830000] usbcore: registered new interface driver usb-storage
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 8.840000] USB Mass Storage support registered.
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 9.000000] usbcore: registered new interface driver ums-alauda
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 9.010000] usbcore: registered new interface driver ums-cypress
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 9.020000] usbcore: registered new interface driver ums-datafab
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 9.040000] usbcore: registered new interface driver ums-freecom
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 9.050000] usbcore: registered new interface driver ums-isd200
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 9.060000] usbcore: registered new interface driver ums-jumpshot
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 9.080000] usbcore: registered new interface driver ums-karma
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 9.090000] usbcore: registered new interface driver ums-sddr09
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 9.110000] usbcore: registered new interface driver ums-sddr55
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 9.120000] usbcore: registered new interface driver ums-usbat
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.690000] usb 1-1: MAC-Address: 0x0c:0x5b:0x8f:0x27:0x9a:0x64
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.700000] cdc_ncm 1-1:1.1: wwan0: register 'cdc_ncm' at usb-ehci-platform-1, Mobile Broadband Network Device, 0c:5b:8f:27:9a:64
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.710000] usbcore: registered new interface driver cdc_ncm
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.800000] usbcore: registered new interface driver qmi_wwan
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.830000] usbcore: registered new interface driver rndis_host
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.940000] USB Serial support registered for GSM modem (1-port)
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.940000] option 1-1:1.0: GSM modem (1-port) converter detected
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.950000] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.960000] usbcore: registered new interface driver option
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.960000] option: v0.7.2:USB Driver for GSM modems
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.990000] USB Serial support registered for Qualcomm USB modem
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 39.990000] usbcore: registered new interface driver qcserial
Jan 1 01:00:41 Gargoyle kern.info kernel: [ 40.160000] fuse init (API version 7.18)
Jan 1 01:00:47 Gargoyle kern.debug kernel: [ 47.680000] ar71xx: pll_reg 0xb8050014: 0x1a000000
Jan 1 01:00:48 Gargoyle daemon.notice netifd: Interface 'lan' is now up
Jan 1 01:00:48 Gargoyle daemon.notice netifd: Interface 'loopback' is now up
Jan 1 01:00:48 Gargoyle user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 47.980000] eth0: link up (1000Mbps/Full duplex)
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 47.980000] device eth0.1 entered promiscuous mode
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 47.990000] device eth0 entered promiscuous mode
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 47.990000] br-lan: port 1(eth0.1) entered forwarding state
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.000000] br-lan: port 1(eth0.1) entered forwarding state
Jan 1 01:00:48 Gargoyle kern.info kernel: [ 48.680000] ADDRCONF(NETDEV_CHANGE): eth0.1: link becomes ready
Jan 1 01:00:48 Gargoyle daemon.notice netifd: wan (907): Trying to set mode
Jan 1 01:00:49 Gargoyle user.notice usb-modeswitch: 1-0:1.0: Manufacturer=Linux_3.3.8_ehci_hcd Product=Generic_Platform_EHCI_Controller Serial=ehci-platform
Jan 1 01:00:50 Gargoyle kern.info kernel: [ 50.000000] br-lan: port 1(eth0.1) entered forwarding state
Jan 1 01:00:52 Gargoyle kern.info kernel: [ 52.690000] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jan 1 01:00:52 Gargoyle kern.info kernel: [ 52.690000] device wlan0 entered promiscuous mode
Jan 1 01:00:52 Gargoyle daemon.notice netifd: wan (907): Trying to set mode
Jan 1 01:00:53 Gargoyle kern.info kernel: [ 53.030000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:00:53 Gargoyle kern.info kernel: [ 53.040000] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Jan 1 01:00:55 Gargoyle kern.info kernel: [ 55.030000] br-lan: port 2(wlan0) entered forwarding state
Jan 1 01:07:54 Gargoyle daemon.notice netifd: wan (1201): udhcpc (v1.19.4) started
Jan 1 01:07:54 Gargoyle daemon.notice netifd: wan (1201): Sending discover...
Jan 1 01:07:55 Gargoyle user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Jan 1 01:07:55 Gargoyle user.notice usb-modeswitch: 1-1:1.1: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Jan 1 01:07:56 Gargoyle authpriv.info dropbear[1275]: Running in background
Jan 1 01:07:56 Gargoyle user.notice usb-modeswitch: 1-1:1.2: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Jan 1 01:07:56 Gargoyle daemon.crit httpd_gargoyle[1342]: bind 0.0.0.0 - Address already in use
Jan 1 01:07:56 Gargoyle daemon.warn httpd_gargoyle[1344]: started as root without requesting chroot(), warning only
Jan 1 01:07:56 Gargoyle daemon.notice httpd_gargoyle[1344]: httpd_gargoyle/1.0 14mar2008 starting on Gargoyle, port 80
Jan 1 01:07:57 Gargoyle user.notice usb-modeswitch: 1-1:1.3: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Jan 1 01:07:57 Gargoyle daemon.notice netifd: wan (1201): Sending discover...
Jan 1 01:08:00 Gargoyle user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Jan 1 01:08:00 Gargoyle user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Jan 1 01:08:00 Gargoyle user.notice dnsmasq: Allowing RFC1918 responses for domain free.aero2.net.pl
Jan 1 01:08:01 Gargoyle daemon.notice netifd: wan (1201): Sending discover...
Jan 1 01:08:03 Gargoyle daemon.info dnsmasq[1721]: started, version 2.66 cachesize 150
Jan 1 01:08:03 Gargoyle daemon.info dnsmasq[1721]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan 1 01:08:03 Gargoyle daemon.info dnsmasq-dhcp[1721]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Jan 1 01:08:03 Gargoyle daemon.info dnsmasq[1721]: using local addresses only for domain lan
Jan 1 01:08:03 Gargoyle daemon.info dnsmasq[1721]: reading /tmp/resolv.conf.auto
Jan 1 01:08:03 Gargoyle daemon.warn dnsmasq[1721]: ignoring nameserver 192.168.1.1 - local interface
Jan 1 01:08:03 Gargoyle daemon.info dnsmasq[1721]: read /etc/hosts - 2 addresses
Jan 1 01:08:03 Gargoyle daemon.info dnsmasq-dhcp[1721]: read /etc/ethers - 0 addresses
Jan 1 01:08:04 Gargoyle user.err syslog: error starting threads: errno 89 (Function not implemented)
Jan 1 01:08:04 Gargoyle user.info sysinit: exportfs: could not open /var/lib/nfs/.etab.lock for locking: errno 2 (No such file or directory)
Jan 1 01:08:04 Gargoyle user.info sysinit: exportfs: can't lock /var/lib/nfs/etab for writing
Jan 1 01:08:04 Gargoyle user.info sysinit: exportfs: could not open /var/lib/nfs/.xtab.lock for locking: errno 2 (No such file or directory)
Jan 1 01:08:04 Gargoyle user.info sysinit: exportfs: can't lock /var/lib/nfs/xtab for writing
Jan 1 01:08:07 Gargoyle user.info sysinit: ERROR: No valid dynamic DNS service configurations defined
Jan 1 01:08:07 Gargoyle user.info sysinit: (Did you specify correct configuration file path?)
Success
takie mam logi.
router e3276 się pali czyli działa w porcie USB, ale w w statusie nie mam żadnego IP tylko mac adres sprzętu.
oczywiście net nie działa.
proszę o poradę
