adres routera musi pozostać 192.168.1.1 ???
Mam zmieniony zakres IP na 10.10.10.1
W tej samej podsieci nie będzie działał serwer vpn-owy.
zmieniłem IP na 192.168.1.1 i nadal nic. kopiuje wygenerowane i wypakowane certyfikaty do folderu config klienta openVPN na kompie i staram się połączyć ale niestety bez skutku
Zrobił bym na twoim miejscu reset do ustawień fabrycznych (firstboot) i ponownie skonfigurowal router.
Logi z łączenia się klienta z serwerem z ostatniej próby po wszystkich zmianach.
Wed Aug 06 16:59:36 2014 Warning: cannot open --log file: C:\Program Files\OpenVPN\log\klient1_win.log: Odmowa dostêpu. (errno=5)
Wed Aug 06 16:59:36 2014 OpenVPN 2.3.4 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on May 2 2014
Wed Aug 06 16:59:36 2014 library versions: OpenSSL 1.0.1g 7 Apr 2014, LZO 2.05
Wed Aug 06 16:59:36 2014 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25341
Wed Aug 06 16:59:36 2014 Need hold release from management interface, waiting...
Wed Aug 06 16:59:36 2014 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25341
Wed Aug 06 16:59:36 2014 MANAGEMENT: CMD 'state on'
Wed Aug 06 16:59:36 2014 MANAGEMENT: CMD 'log all on'
Wed Aug 06 16:59:36 2014 MANAGEMENT: CMD 'hold off'
Wed Aug 06 16:59:36 2014 MANAGEMENT: CMD 'hold release'
Wed Aug 06 16:59:36 2014 Note: cannot open current_status for WRITE
Wed Aug 06 16:59:36 2014 Control Channel Authentication: using 'ta.key' as a OpenVPN static key file
Wed Aug 06 16:59:36 2014 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Aug 06 16:59:36 2014 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Wed Aug 06 16:59:36 2014 Socket Buffers: R=[8192->8192] S=[8192->8192]
Wed Aug 06 16:59:36 2014 UDPv4 link local: [undef]
Wed Aug 06 16:59:36 2014 UDPv4 link remote: [AF_INET]91.235.22.150:1194
Wed Aug 06 16:59:36 2014 MANAGEMENT: >STATE:1407337176,WAIT,,,
Wed Aug 06 16:59:36 2014 UDPv4 link remote: [AF_INET]91.235.22.150:1194 Wed Aug 06 16:59:36 2014 MANAGEMENT: >STATE:1407337176,WAIT,,,Nadal nie ma serwera VPN,
Na routerze jest niby że serwer działa
Zrobiłeś reset do ustawień fabrycznych routera? Nic tam w firewall-u nie siedzi ze starych przekierowań?
Używasz tego klienta - openvpn-gui-1.0.3
Przed resetem się bronie jeszcze bo to w ostateczności chciałbym zrobić ( za dużo ustawień już zdefiniowanych) W firewallu mam tylko 1 przekierowanie do NAS nic więcej. Klienta VPN używam openVPN GUI V5
zrobiłem reset bo poległem. zainstalowałem nawet tą wersje klienta co mi podałeś w linku ale skutek ten sam. Magia jakaś czy co?
Nadal logi zatrzymują się w tym samym miejscu?
Dokladnie. Jak sprawdzic inaczej czy na routerze port przypisany do serwera VPN jest czynny?
