Podaj log po podłączeniu modemu.
Feb 21 13:27:54 Gargoyle daemon.info dnsmasq-dhcp[17405]: DHCPINFORM(br-lan) 192.168.1.133 00:1c:bf:aa:24:45
Feb 21 13:27:54 Gargoyle daemon.info dnsmasq-dhcp[17405]: DHCPACK(br-lan) 192.168.1.133 00:1c:bf:aa:24:45 BoB-Lap001
Feb 21 13:27:55 Gargoyle kern.info kernel: [154789.850000] usb 1-1.1: new high-speed USB device number 45 using ehci-platform
Feb 21 13:27:55 Gargoyle kern.info kernel: [154789.980000] scsi36 : usb-storage 1-1.1:1.0
Feb 21 13:27:55 Gargoyle user.notice usb-modeswitch: 1-1.1:1.0: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=FFFFFFFFFFFFFFFF
Feb 21 13:27:55 Gargoyle user.notice usb-modeswitch: 1-1.1:1.0: Selecting /etc/usb_modeswitch.d/12d1:1f01 for mode switching
Feb 21 13:27:55 Gargoyle syslog.notice usb_modeswitch: switching device 12d1:1f01 on 001/045
Feb 21 13:27:55 Gargoyle kern.info kernel: [154790.380000] usb 1-1.1: USB disconnect, device number 45
Feb 21 13:27:55 Gargoyle kern.info kernel: [154790.620000] usb 1-1.1: new high-speed USB device number 46 using ehci-platform
Feb 21 13:27:56 Gargoyle kern.info kernel: [154790.750000] cdc_ether 1-1.1:1.0: eth2: register 'cdc_ether' at usb-ehci-platform-1.1, CDC Ethernet Device, 58:2c:80:13:92:63
Feb 21 13:28:26 Gargoyle user.notice usb-modeswitch: 1-1.1:1.0: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Feb 21 13:28:26 Gargoyle user.notice usb-modeswitch: 1-1.1:1.1: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Feb 21 13:28:30 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 IEEE 802.11: authenticated
Feb 21 13:28:30 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 IEEE 802.11: associated (aid 2)
Feb 21 13:28:30 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 WPA: pairwise key handshake completed (WPA)
Feb 21 13:28:30 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 WPA: group key handshake completed (WPA)
Feb 21 13:28:30 Gargoyle daemon.info dnsmasq-dhcp[17405]: DHCPREQUEST(br-lan) 192.168.1.133 00:1c:bf:aa:24:45
Feb 21 13:28:30 Gargoyle daemon.info dnsmasq-dhcp[17405]: DHCPACK(br-lan) 192.168.1.133 00:1c:bf:aa:24:45 BoB-Lap001
Feb 21 13:28:33 Gargoyle daemon.info dnsmasq-dhcp[17405]: DHCPINFORM(br-lan) 192.168.1.133 00:1c:bf:aa:24:45
Feb 21 13:28:33 Gargoyle daemon.info dnsmasq-dhcp[17405]: DHCPACK(br-lan) 192.168.1.133 00:1c:bf:aa:24:45 BoB-Lap001
Success
Modem jest poprawnie wykryty.
W gargoyle ustaw DHCP przewodowo i interfejs WAN wybierz eth2
Ustawiłem jak napisałeś. Pierwsze co zaobserwowałem to, że gargulec strasznie zwolnił. Odpowiedź na kliknięcie trwa ok 30sek.
Na komputerze zmienił mi się status komunikatora tlen.pl na widoczny ale nie mogę wejść do netu.
Poniżej log. Skopiowałem cały bo zmienił się zegar w gargulcu i nie wiem co było ostatnio.
Feb 21 12:00:02 Gargoyle authpriv.info dropbear[1610]: Running in background
Feb 21 12:00:02 Gargoyle daemon.warn httpd_gargoyle[1635]: started as root without requesting chroot(), warning only
Feb 21 12:00:02 Gargoyle daemon.notice httpd_gargoyle[1635]: httpd_gargoyle/1.0 14mar2008 starting on Gargoyle, port 80
Feb 21 12:00:03 Gargoyle user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Feb 21 12:00:03 Gargoyle user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Feb 21 12:00:06 Gargoyle daemon.info dnsmasq[1670]: started, version 2.66 cachesize 150
Feb 21 12:00:06 Gargoyle daemon.info dnsmasq[1670]: compile time options: no-IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Feb 21 12:00:06 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Feb 21 12:00:06 Gargoyle daemon.info dnsmasq[1670]: using local addresses only for domain lan
Feb 21 12:00:06 Gargoyle daemon.info dnsmasq[1670]: reading /tmp/resolv.conf.auto
Feb 21 12:00:06 Gargoyle daemon.info dnsmasq[1670]: using nameserver 192.168.1.1#53
Feb 21 12:00:06 Gargoyle daemon.warn dnsmasq[1670]: ignoring nameserver 192.168.1.2 - local interface
Feb 21 12:00:06 Gargoyle daemon.info dnsmasq[1670]: read /etc/hosts - 2 addresses
Feb 21 12:00:06 Gargoyle daemon.info dnsmasq-dhcp[1670]: read /etc/ethers - 0 addresses
Feb 21 12:00:06 Gargoyle user.info sysinit: ERROR: No valid dynamic DNS service configurations defined
Feb 21 12:00:06 Gargoyle user.info sysinit: (Did you specify correct configuration file path?)
Feb 21 12:00:07 Gargoyle user.info sysinit: setting up led WAN
Feb 21 12:00:07 Gargoyle user.info sysinit: setting up led LAN1
Feb 21 12:00:07 Gargoyle user.info sysinit: setting up led LAN2
Feb 21 12:00:07 Gargoyle user.info sysinit: setting up led LAN3
Feb 21 12:00:07 Gargoyle user.info sysinit: setting up led LAN4
Feb 21 12:00:07 Gargoyle user.info sysinit: setting up led WLAN
Feb 21 12:00:07 Gargoyle user.info sysinit: setting up led USB
Feb 21 12:00:19 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 IEEE 802.11: authenticated
Feb 21 12:00:19 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 IEEE 802.11: associated (aid 1)
Feb 21 12:00:19 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 WPA: pairwise key handshake completed (WPA)
Feb 21 12:00:19 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 WPA: group key handshake completed (WPA)
Feb 21 12:00:20 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPREQUEST(br-lan) 192.168.1.133 00:1c:bf:aa:24:45
Feb 21 12:00:20 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPACK(br-lan) 192.168.1.133 00:1c:bf:aa:24:45 BoB-Lap001
Feb 21 12:00:21 Gargoyle daemon.info hostapd: wlan0: STA d0:51:62:39:ce:9b IEEE 802.11: authenticated
Feb 21 12:00:21 Gargoyle daemon.info hostapd: wlan0: STA d0:51:62:39:ce:9b IEEE 802.11: associated (aid 2)
Feb 21 12:00:21 Gargoyle daemon.info hostapd: wlan0: STA d0:51:62:39:ce:9b WPA: pairwise key handshake completed (WPA)
Feb 21 12:00:21 Gargoyle daemon.info hostapd: wlan0: STA d0:51:62:39:ce:9b WPA: group key handshake completed (WPA)
Feb 21 12:00:22 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPREQUEST(br-lan) 192.168.1.177 d0:51:62:39:ce:9b
Feb 21 12:00:22 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPACK(br-lan) 192.168.1.177 d0:51:62:39:ce:9b android-4df48e5c6a1fc6b6
Feb 21 12:00:23 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPINFORM(br-lan) 192.168.1.133 00:1c:bf:aa:24:45
Feb 21 12:00:23 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPACK(br-lan) 192.168.1.133 00:1c:bf:aa:24:45 BoB-Lap001
Feb 21 12:00:25 Gargoyle user.notice firewall: Reloading firewall due to ifup of wan (eth2)
Feb 21 12:00:57 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPINFORM(br-lan) 192.168.1.150 00:1a:4d:52:15:f5
Feb 21 12:00:57 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPACK(br-lan) 192.168.1.150 00:1a:4d:52:15:f5 os-09a64055b3cf
Feb 21 12:01:22 Gargoyle kern.warn kernel: [ 133.410000] ipt_bandwidth: timezone shift of 60 minutes detected, adjusting
Feb 21 12:01:22 Gargoyle kern.warn kernel: [ 133.420000] old minutes west=0, new minutes west=-60
Feb 21 12:01:47 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPINFORM(br-lan) 192.168.1.133 00:1c:bf:aa:24:45
Feb 21 12:01:47 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPACK(br-lan) 192.168.1.133 00:1c:bf:aa:24:45 BoB-Lap001
Feb 21 12:10:08 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 WPA: group key handshake completed (WPA)
Feb 21 12:10:09 Gargoyle daemon.info hostapd: wlan0: STA d0:51:62:39:ce:9b WPA: group key handshake completed (WPA)
Feb 21 12:11:50 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPINFORM(br-lan) 192.168.1.133 00:1c:bf:aa:24:45
Feb 21 12:11:50 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPACK(br-lan) 192.168.1.133 00:1c:bf:aa:24:45 BoB-Lap001
Feb 21 12:13:51 Gargoyle daemon.notice netifd: wan (992): Sending renew...
Feb 21 12:13:51 Gargoyle daemon.notice netifd: wan (992): Performing a DHCP renew
Feb 21 12:15:08 Gargoyle daemon.info hostapd: wlan0: STA d0:51:62:39:ce:9b IEEE 802.11: disassociated
Feb 21 12:15:09 Gargoyle daemon.info hostapd: wlan0: STA d0:51:62:39:ce:9b IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Feb 21 12:16:35 Gargoyle kern.info kernel: [ 1045.540000] usb 1-1.3: USB disconnect, device number 3
Feb 21 12:16:35 Gargoyle kern.info kernel: [ 1045.540000] cdc_ether 1-1.3:1.0: eth2: unregister 'cdc_ether' usb-ehci-platform-1.3, CDC Ethernet Device
Feb 21 12:16:35 Gargoyle daemon.notice netifd: wan (992): udhcpc: SIOCGIFINDEX: No such device
Feb 21 12:16:35 Gargoyle daemon.notice netifd: wan (992): Received SIGTERM
Feb 21 12:16:35 Gargoyle daemon.notice netifd: Interface 'wan' is now down
Feb 21 12:16:40 Gargoyle daemon.info dnsmasq[1670]: reading /tmp/resolv.conf.auto
Feb 21 12:16:40 Gargoyle daemon.warn dnsmasq[1670]: ignoring nameserver 192.168.1.2 - local interface
Feb 21 12:16:40 Gargoyle daemon.info dnsmasq[1670]: using local addresses only for domain lan
Feb 21 12:18:45 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 IEEE 802.11: authenticated
Feb 21 12:18:45 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 IEEE 802.11: associated (aid 1)
Feb 21 12:18:45 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 WPA: pairwise key handshake completed (WPA)
Feb 21 12:18:45 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 WPA: group key handshake completed (WPA)
Feb 21 12:18:45 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPREQUEST(br-lan) 192.168.1.133 00:1c:bf:aa:24:45
Feb 21 12:18:45 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPACK(br-lan) 192.168.1.133 00:1c:bf:aa:24:45 BoB-Lap001
Feb 21 12:18:48 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPINFORM(br-lan) 192.168.1.133 00:1c:bf:aa:24:45
Feb 21 12:18:48 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPACK(br-lan) 192.168.1.133 00:1c:bf:aa:24:45 BoB-Lap001
Feb 21 12:20:08 Gargoyle daemon.info hostapd: wlan0: STA 00:1c:bf:aa:24:45 WPA: group key handshake completed (WPA)
Feb 21 12:20:17 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPINFORM(br-lan) 192.168.1.133 00:1c:bf:aa:24:45
Feb 21 12:20:17 Gargoyle daemon.info dnsmasq-dhcp[1670]: DHCPACK(br-lan) 192.168.1.133 00:1c:bf:aa:24:45 BoB-Lap001
Success
aha, modem przekładam ciągle z laptopa do routera więc niektóre wpisy mogą być o tym
Zmień Adres IP urządzenia na 192.168.0.1 w gargoyle na stronie konfiguracja podstawowa. Od tego momentu konfiguracja będzie odbywała się przez adres http://192.168.0.1/
MISTRZU !!!! JESTEŚ WIELKI !!!! Dziękuję
Czy ten router nadaje się do zasilenia tego modemu? Czy trzeba wykorzystywać dodatkowe zasilanie?
U mnie pojawiają się znowu dziwne problemy... Modem jest wykrywalny, następuje próba połączenia, po niej kolejna, jednak już bez rezultatów. Modem muszę odłączyć i podpiąć ponownie wtedy proces zaczyna się od początku (od poprawnie wysłanych już komend AT).
Jan 2 00:37:26 PLAY kern.info kernel: [ 2295.150000] usb 1-1: new high-speed USB device number 8 using ehci-platform
Jan 2 00:37:26 PLAY kern.info kernel: [ 2295.310000] scsi9 : usb-storage 1-1:1.0
Jan 2 00:37:26 PLAY user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=FFFFFFFFFFFFFFFF
Jan 2 00:37:26 PLAY user.notice usb-modeswitch: 1-1:1.0: Selecting /etc/usb_modeswitch.d/12d1:14fe for mode switching
Jan 2 00:37:26 PLAY syslog.notice usb_modeswitch: switching device 12d1:14fe on 001/008
Jan 2 00:37:26 PLAY kern.info kernel: [ 2295.510000] usb 1-1: USB disconnect, device number 8
Jan 2 00:37:26 PLAY kern.info kernel: [ 2295.960000] usb 1-1: new high-speed USB device number 9 using ehci-platform
Jan 2 00:37:27 PLAY kern.info kernel: [ 2296.110000] option 1-1:1.1: GSM modem (1-port) converter detected
Jan 2 00:37:27 PLAY kern.info kernel: [ 2296.120000] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Jan 2 00:37:27 PLAY kern.info kernel: [ 2296.130000] usb 1-1: MAC-Address: [b][i]<mac>[/i][/b]
Jan 2 00:37:27 PLAY kern.info kernel: [ 2296.140000] cdc_ncm 1-1:1.2: wwan0: register 'cdc_ncm' at usb-ehci-platform-1, Mobile Broadband Network Device, 0c:5b:8f:27:9a:64
Jan 2 00:37:27 PLAY kern.info kernel: [ 2296.150000] scsi10 : usb-storage 1-1:1.3
Jan 2 00:37:27 PLAY kern.info kernel: [ 2296.160000] scsi11 : usb-storage 1-1:1.4
Jan 2 00:37:28 PLAY kern.notice kernel: [ 2297.160000] scsi 10:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Jan 2 00:37:28 PLAY kern.notice kernel: [ 2297.170000] scsi 11:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
Jan 2 00:37:28 PLAY kern.notice kernel: [ 2297.180000] sd 11:0:0:0: [sda] Attached SCSI removable disk
Jan 2 00:37:59 PLAY user.notice usb-modeswitch: 1-1:1.0: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Jan 2 00:38:00 PLAY user.notice usb-modeswitch: 1-1:1.1: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Jan 2 00:38:00 PLAY user.notice usb-modeswitch: 1-1:1.2: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Jan 2 00:38:00 PLAY user.notice usb-modeswitch: 1-1:1.3: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Jan 2 00:38:00 PLAY user.notice usb-modeswitch: 1-1:1.4: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Jan 2 00:38:02 PLAY daemon.notice netifd: wan (14166): Trying to set mode
Jan 2 00:38:06 PLAY daemon.notice pppd[14282]: pppd 2.4.5 started by root, uid 0
Jan 2 00:38:07 PLAY local2.info chat[14286]: abort on (BUSY)
Jan 2 00:38:07 PLAY local2.info chat[14286]: abort on (NO CARRIER)
Jan 2 00:38:07 PLAY local2.info chat[14286]: abort on (ERROR)
Jan 2 00:38:07 PLAY local2.info chat[14286]: report (CONNECT)
Jan 2 00:38:07 PLAY local2.info chat[14286]: timeout set to 10 seconds
Jan 2 00:38:07 PLAY local2.info chat[14286]: send (AT&F^M)
Jan 2 00:38:07 PLAY local2.info chat[14286]: expect (OK)
Jan 2 00:38:11 PLAY local2.info chat[14286]: AT&F^MAT^CURC=0^M^M
Jan 2 00:38:11 PLAY local2.info chat[14286]: OK
Jan 2 00:38:11 PLAY local2.info chat[14286]: -- got it
Jan 2 00:38:11 PLAY local2.info chat[14286]: send (ATE1^M)
Jan 2 00:38:11 PLAY local2.info chat[14286]: expect (OK)
Jan 2 00:38:11 PLAY local2.info chat[14286]: ^M^M
Jan 2 00:38:11 PLAY local2.info chat[14286]: send (AT+CGDCONT=1,"IP","internet"^M)
Jan 2 00:38:11 PLAY local2.info chat[14286]: timeout set to 30 seconds
Jan 2 00:38:11 PLAY local2.info chat[14286]: send (ATD*99***1#^M)
Jan 2 00:38:11 PLAY local2.info chat[14286]: expect (CONNECT)
Jan 2 00:38:11 PLAY local2.info chat[14286]: CONNECT
Jan 2 00:38:11 PLAY local2.info chat[14286]: send ( ^M)
Jan 2 00:38:12 PLAY local2.info chat[14286]: alarm
Jan 2 00:38:12 PLAY daemon.info pppd[14282]: Serial connection established.
Jan 2 00:38:12 PLAY daemon.info pppd[14282]: Using interface 3g-wan
Jan 2 00:38:12 PLAY daemon.notice pppd[14282]: Connect: 3g-wan <--> /dev/ttyUSB0
Jan 2 00:38:44 PLAY daemon.warn pppd[14282]: LCP: timeout sending Config-Requests
Jan 2 00:38:44 PLAY daemon.notice pppd[14282]: Connection terminated.
Jan 2 00:38:45 PLAY daemon.notice pppd[14282]: Modem hangup
Jan 2 00:38:45 PLAY daemon.info pppd[14282]: Exit.
Jan 2 00:38:45 PLAY daemon.notice netifd: Interface 'wan' is now down
Jan 2 00:39:19 PLAY daemon.notice pppd[15579]: pppd 2.4.5 started by root, uid 0
Jan 2 00:39:20 PLAY local2.info chat[15583]: abort on (BUSY)
Jan 2 00:39:20 PLAY local2.info chat[15583]: abort on (NO CARRIER)
Jan 2 00:39:20 PLAY local2.info chat[15583]: abort on (ERROR)
Jan 2 00:39:20 PLAY local2.info chat[15583]: report (CONNECT)
Jan 2 00:39:20 PLAY local2.info chat[15583]: timeout set to 10 seconds
Jan 2 00:39:20 PLAY local2.info chat[15583]: send (AT&F^M)
Jan 2 00:39:20 PLAY local2.info chat[15583]: expect (OK)
Jan 2 00:39:30 PLAY local2.info chat[15583]: alarm
Jan 2 00:39:30 PLAY local2.info chat[15583]: Failed
Jan 2 00:39:30 PLAY daemon.err pppd[15579]: Connect script failed
Jan 2 00:39:31 PLAY daemon.info pppd[15579]: Exit.
Jan 2 00:39:31 PLAY daemon.notice netifd: Interface 'wan' is now down
Jan 2 00:39:35 PLAY daemon.notice pppd[15612]: pppd 2.4.5 started by root, uid 0
Jan 2 00:39:36 PLAY local2.info chat[15616]: abort on (BUSY)
Jan 2 00:39:36 PLAY local2.info chat[15616]: abort on (NO CARRIER)
Jan 2 00:39:36 PLAY local2.info chat[15616]: abort on (ERROR)
Jan 2 00:39:36 PLAY local2.info chat[15616]: report (CONNECT)
Jan 2 00:39:36 PLAY local2.info chat[15616]: timeout set to 10 seconds
Jan 2 00:39:36 PLAY local2.info chat[15616]: send (AT&F^M)
Jan 2 00:39:36 PLAY local2.info chat[15616]: expect (OK)
Jan 2 00:39:46 PLAY local2.info chat[15616]: alarm
Jan 2 00:39:46 PLAY local2.info chat[15616]: Failed
Jan 2 00:39:46 PLAY daemon.err pppd[15612]: Connect script failed
Jan 2 00:39:47 PLAY daemon.info pppd[15612]: Exit.
Jan 2 00:39:47 PLAY daemon.notice netifd: Interface 'wan' is now down
Witaj,
Mój Huawei E3272 ma również ten sam problem, może pracować samodzielnie, ale z routerem TP-Link, to nie może działać dobrze, może ktoś mi pomóc?
Witam bardzo prosze o pomoc,
mam podobny problem jak rbobin ale niestety u mnie nie zadzialalo to co pomoglo u niego bardzo prosze o pomoc
Ustawiam wszystko jak opisane - oprócz interfejsu WAN bo nie mogę wybrać eth2??? ale internet nie działa. Modem jest poprawnie wykryty - Siweci ciągłym niebieskiem
Co dalej ?
WAŻNE! Jeśli router nie wykrywa wam nowego modemu, lub zaczyna go identyfikować, ale nie może skończyć to musicie zrobić to:
Wszystko na pewno działa. Jeśli posiadacie ten modem TP w wersji 2.2 lub wyższej to na pewno zadziała bez żadnych dodatkowych eksperymentów. Być może zadziała także z niższymi wersjami. Otóż należy powrócić do instrukcji obsługi. Jeśli mieliście do Routera podpięty jakiś inny model modemu a teraz po prostu wkładacie tam nowy, to nic z tego. Należy po kolei: Włączyć router. Wyjąć stary modem. Oczywiście odłączyć sieć WIFI. Router i komputer spiąć zwykłym kablem ethernet (dołączony do routera był na pewno), do portu usb routera wpiąć nowy modem (tutaj E3272 - warto tutaj wyłączyć zabezpieczenie kodem sim - robimy to w aplikacji do samego modemu LTE, menadżerze połączeń). Teraz należy włączyć Router. Połączyć się z nim przez przeglądarkę (ale wszystko idzie przez kabel, nie przez WIFI!) i gwarantuję, że odpali. E3272 powinien zostać szybko zidentyfikowany. Router po prostu stara się włączyć modem, który był w nim zainstalowany, lub podobne do niego modemy. Natomiast modemy LTE są nieco bardziej zaawansowane. Stąd warto to zrobić to po kolei. Żaden update routera, żadne pliki bin, aplikacje dodatkowe - spróbujcie zrobić tak jak robiliście z pierwszym modemem 3g/4g jaki odpalaliście. Nie trzeba kasować sieci wifi, ani nic takiego, tylko na czas działań trzeba kompa/lapa od niej odłączyć i wszystko ma iść przez kabel. Po tym jak modem zostanie wykryty odpinacie kabel i tyle! Jeśli macie modem 4g lte to Router może pokazywać, że jesteście połączeni z siecią, ale moc sygnału napisze 0%, tym się nie przejmujcie, mi cały czas pokazuje 0% a hula.
No właśnie tylko na Gargulcu trzeba za każdym razem po zmianie modemu ustawiać wszystko na fabrycznym wpinam inny modem i łączy bez problemu.
