Router umarł przez złe GUI
Kontrolka USB na routerze się zapala?
Wklej na forum: system - log systemowy
Kontrolka się nie zapala. Miga dioda na modemie że znalazło sieć ale nie ma opcji aby się połączyło bo nie ma takiej opcji w sofcie. Sprawdzałem wszystkie opcje.
OTO LOGI:
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.080000] Mount-cache hash table entries: 512
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.090000] NET: Registered protocol family 16
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.100000] MIPS: machine is TP-LINK TL-MR3220 v2
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.550000] bio: create slab <bio-0> at 0
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.560000] Switching to clocksource MIPS
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.560000] NET: Registered protocol family 2
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.570000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.570000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.570000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.580000] TCP: Hash tables configured (established 1024 bind 1024)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.590000] TCP reno registered
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.590000] UDP hash table entries: 256 (order: 0, 4096 bytes)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.600000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.600000] NET: Registered protocol family 1
Jan  1 01:00:39 Gargoyle kern.info kernel: [   11.100000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
Jan  1 01:00:39 Gargoyle kern.info kernel: [   11.140000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
Jan  1 01:00:39 Gargoyle kern.info kernel: [   11.160000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
Jan  1 01:00:39 Gargoyle kern.info kernel: [   11.160000] hub 1-0:1.0: USB hub found
Jan  1 01:00:39 Gargoyle kern.info kernel: [   11.160000] hub 1-0:1.0: 1 port detected
Jan  1 01:00:39 Gargoyle kern.info kernel: [   11.180000] Initializing USB Mass Storage driver...
Jan  1 01:00:39 Gargoyle kern.info kernel: [   11.190000] usbcore: registered new interface driver usb-storage
Jan  1 01:00:39 Gargoyle kern.info kernel: [   11.190000] USB Mass Storage support registered.
Jan  1 01:00:39 Gargoyle kern.info kernel: [   32.620000] eth0: link down
Jan  1 01:00:39 Gargoyle kern.info kernel: [   33.160000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
Jan  1 01:00:39 Gargoyle kern.info kernel: [   33.170000] Backport generated by backports.git backports-20140320-37-g5c33da0
Jan  1 01:00:39 Gargoyle kern.info kernel: [   33.350000] cfg80211: Calling CRDA to update world regulatory domain
Jan  1 01:00:39 Gargoyle kern.info kernel: [   33.350000] cfg80211: World regulatory domain updated:
Jan  1 01:00:39 Gargoyle kern.info kernel: [   33.360000] cfg80211:  DFS Master region: unset
Jan  1 01:00:39 Gargoyle kern.info kernel: [   33.360000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Jan  1 01:00:39 Gargoyle kern.info kernel: [   33.370000] cfg80211:   (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
Jan  1 01:00:39 Gargoyle kern.info kernel: [   33.380000] cfg80211:   (5140000 KHz - 5860000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
Jan  1 01:00:39 Gargoyle kern.debug kernel: [   34.390000] ath: EEPROM regdomain: 0x0
Jan  1 01:00:39 Gargoyle kern.debug kernel: [   34.390000] ath: EEPROM indicates default country code should be used
Jan  1 01:00:39 Gargoyle kern.debug kernel: [   34.390000] ath: doing EEPROM country->regdmn map search
Jan  1 01:00:39 Gargoyle kern.debug kernel: [   34.390000] ath: country maps to regdmn code: 0x3a
Jan  1 01:00:39 Gargoyle kern.debug kernel: [   34.390000] ath: Country alpha2 being used: US
Jan  1 01:00:39 Gargoyle kern.debug kernel: [   34.390000] ath: Regpair used: 0x3a
Jan  1 01:00:39 Gargoyle kern.debug kernel: [   34.400000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Jan  1 01:00:39 Gargoyle kern.debug kernel: [   34.400000] Registered led device: ath9k-phy0
Jan  1 01:00:39 Gargoyle kern.info kernel: [   34.400000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
Jan  1 01:00:39 Gargoyle kern.info kernel: [   34.410000] cfg80211: Calling CRDA for country: US
Jan  1 01:00:39 Gargoyle kern.info kernel: [   34.410000] cfg80211: Regulatory domain changed to country: US
Jan  1 01:00:39 Gargoyle kern.info kernel: [   34.420000] cfg80211:  DFS Master region: unset
Jan  1 01:00:39 Gargoyle kern.info kernel: [   34.420000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Jan  1 01:00:39 Gargoyle kern.info kernel: [   34.430000] cfg80211:   (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
Jan  1 01:00:39 Gargoyle kern.info kernel: [   34.440000] cfg80211:   (5140000 KHz - 5860000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
Jan  1 01:00:39 Gargoyle kern.info kernel: [   34.680000] PPP generic driver version 2.4.2
Jan  1 01:00:39 Gargoyle kern.info kernel: [   34.830000] ip_tables: (C) 2000-2006 Netfilter Core Team
Jan  1 01:00:39 Gargoyle kern.info kernel: [   35.250000] NET: Registered protocol family 24
Jan  1 01:00:39 Gargoyle kern.info kernel: [   35.320000] nf_conntrack version 0.5.0 (456 buckets, 1824 max)
Jan  1 01:00:39 Gargoyle kern.info kernel: [   35.950000] xt_time: kernel timezone is -0000
Jan  1 01:00:39 Gargoyle kern.info kernel: [   36.670000] 	Hooked IMQ after mangle on PREROUTING
Jan  1 01:00:39 Gargoyle kern.info kernel: [   36.670000] 	Hooked IMQ after nat on POSTROUTING
Jan  1 01:00:39 Gargoyle kern.info kernel: [   36.670000] IMQ driver loaded successfully. (numdevs = 2, numqueues = 1)
Jan  1 01:00:39 Gargoyle kern.info kernel: [   36.880000] Netfilter messages via NETLINK v0.30.
Jan  1 01:00:39 Gargoyle kern.notice kernel: [   36.900000] ip_set: protocol 6
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.510000] usbcore: registered new interface driver cdc_acm
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.510000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.650000] usbcore: registered new interface driver usbserial
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.650000] USB Serial support registered for generic
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.660000] usbcore: registered new interface driver usbserial_generic
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.660000] usbserial: USB Serial Driver core
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.710000] usbcore: registered new interface driver cdc_ether
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.860000] usbcore: registered new interface driver cdc_ncm
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.970000] USB Serial support registered for GSM modem (1-port)
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.970000] usbcore: registered new interface driver option
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.980000] option: v0.7.2:USB Driver for GSM modems
Jan  1 01:00:39 Gargoyle kern.info kernel: [   38.100000] USB Serial support registered for Sierra USB modem
Jan  1 01:00:39 Gargoyle kern.info kernel: [   38.110000] usbcore: registered new interface driver sierra
Jan  1 01:00:39 Gargoyle kern.info kernel: [   38.110000] sierra: v.1.7.16:USB Driver for Sierra Wireless USB modems
Jan  1 01:00:42 Gargoyle user.notice usb-modeswitch: 1-0:1.0: Manufacturer=Linux_3.3.8_ehci_hcd Product=Generic_Platform_EHCI_Controller Serial=ehci-platform
Jan  1 01:00:47 Gargoyle daemon.notice netifd: Interface 'lan' is now up
Jan  1 01:00:47 Gargoyle kern.info kernel: [   47.190000] device eth0 entered promiscuous mode
Jan  1 01:00:47 Gargoyle daemon.notice netifd: Interface 'loopback' is now up
Jan  1 01:00:47 Gargoyle daemon.notice netifd: Interface 'wan' is now up
Jan  1 01:00:47 Gargoyle user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Jan  1 01:00:47 Gargoyle kern.info kernel: [   47.790000] eth0: link up (1000Mbps/Full duplex)
Jan  1 01:00:47 Gargoyle kern.info kernel: [   47.790000] br-lan: port 1(eth0) entered forwarding state
Jan  1 01:00:47 Gargoyle kern.info kernel: [   47.800000] br-lan: port 1(eth0) entered forwarding state
Jan  1 01:00:49 Gargoyle kern.info kernel: [   49.800000] br-lan: port 1(eth0) entered forwarding state
Jan  1 01:00:52 Gargoyle kern.info kernel: [   52.350000] device wlan0 entered promiscuous mode
Jan  1 01:00:52 Gargoyle kern.info kernel: [   52.700000] br-lan: port 2(wlan0) entered forwarding state
Jan  1 01:00:54 Gargoyle kern.info kernel: [   54.700000] br-lan: port 2(wlan0) entered forwarding state
Jan  1 01:00:02 Gargoyle authpriv.info dropbear[1430]: Running in background
Jan  1 01:00:03 Gargoyle daemon.warn httpd_gargoyle[1455]: started as root without requesting chroot(), warning only
Jan  1 01:00:03 Gargoyle daemon.notice httpd_gargoyle[1455]: httpd_gargoyle/1.0 14mar2008 starting on Gargoyle, port 80
Jan  1 01:00:04 Gargoyle user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Jan  1 01:00:04 Gargoyle user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Jan  1 01:00:04 Gargoyle user.notice dnsmasq: Allowing RFC1918 responses for domain free.aero2.net.pl
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq[1518]: started, version 2.66 cachesize 150
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq[1518]: compile time options: no-IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq-dhcp[1518]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq[1518]: using local addresses only for domain lan
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq[1518]: reading /tmp/resolv.conf.auto
Jan  1 01:00:07 Gargoyle daemon.warn dnsmasq[1518]: ignoring nameserver 192.168.1.1 - local interface
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq[1518]: read /etc/hosts - 2 addresses
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq-dhcp[1518]: read /etc/ethers - 0 addresses
Jan  1 01:00:08 Gargoyle user.info sysinit: ERROR: No valid dynamic DNS service configurations defined
Jan  1 01:00:08 Gargoyle user.info sysinit: (Did you specify correct configuration file path?)
Jan  1 01:00:08 Gargoyle user.info sysinit: setting up led WAN
Jan  1 01:00:08 Gargoyle user.info sysinit: setting up led LAN1
Jan  1 01:00:08 Gargoyle user.info sysinit: setting up led LAN2
Jan  1 01:00:08 Gargoyle user.info sysinit: setting up led LAN3
Jan  1 01:00:08 Gargoyle user.info sysinit: setting up led LAN4
Jan  1 01:00:08 Gargoyle user.info sysinit: setting up led WLAN
Jan  1 01:00:08 Gargoyle user.info sysinit: setting up led USB
Jan  1 01:00:09 Gargoyle daemon.info dnsmasq-dhcp[1518]: DHCPREQUEST(br-lan) 192.168.1.207 00:24:8c:f7:7f:9f
Jan  1 01:00:09 Gargoyle daemon.info dnsmasq-dhcp[1518]: DHCPACK(br-lan) 192.168.1.207 00:24:8c:f7:7f:9f Wick3DPC
Jan  1 01:00:24 Gargoyle user.notice firewall: Reloading firewall due to ifup of wan (eth1)
Jan  1 01:00:46 Gargoyle kern.info kernel: [  101.190000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Jan  1 01:00:46 Gargoyle kern.info kernel: [  101.440000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Jan  1 01:00:47 Gargoyle kern.info kernel: [  101.690000] usb 1-1: new high-speed USB device number 4 using ehci-platform
Jan  1 01:00:47 Gargoyle kern.err kernel: [  102.110000] usb 1-1: device not accepting address 4, error -71
Jan  1 01:00:47 Gargoyle kern.info kernel: [  102.230000] usb 1-1: new high-speed USB device number 5 using ehci-platform
Jan  1 01:00:48 Gargoyle kern.err kernel: [  102.650000] usb 1-1: device not accepting address 5, error -71
Jan  1 01:00:48 Gargoyle kern.err kernel: [  102.650000] hub 1-0:1.0: unable to enumerate USB device on port 1
Jan  1 01:00:56 Gargoyle kern.info kernel: [  111.310000] usb 1-1: new high-speed USB device number 6 using ehci-platform
Jan  1 01:00:56 Gargoyle kern.info kernel: [  111.560000] usb 1-1: new high-speed USB device number 7 using ehci-platform
Jan  1 01:00:57 Gargoyle kern.info kernel: [  111.810000] usb 1-1: new high-speed USB device number 8 using ehci-platform
Jan  1 01:00:57 Gargoyle kern.err kernel: [  112.230000] usb 1-1: device not accepting address 8, error -71
Jan  1 01:00:57 Gargoyle kern.info kernel: [  112.350000] usb 1-1: new high-speed USB device number 9 using ehci-platform
Jan  1 01:00:58 Gargoyle kern.err kernel: [  112.780000] usb 1-1: device not accepting address 9, error -71
Jan  1 01:00:58 Gargoyle kern.err kernel: [  112.780000] hub 1-0:1.0: unable to enumerate USB device on port 1
Jan  1 01:01:08 Gargoyle daemon.info dnsmasq[1518]: exiting on receipt of SIGTERM
Jan  1 01:01:08 Gargoyle kern.info kernel: [  123.050000] device wlan0 left promiscuous mode
Jan  1 01:01:08 Gargoyle kern.info kernel: [  123.050000] br-lan: port 2(wlan0) entered disabled state
Jan  1 01:01:10 Gargoyle kern.info kernel: [  124.850000] eth0: link down
Jan  1 01:01:10 Gargoyle kern.info kernel: [  124.850000] br-lan: port 1(eth0) entered disabled state
Jan  1 01:01:11 Gargoyle kern.info kernel: [  125.980000] device eth0 left promiscuous mode
Jan  1 01:01:11 Gargoyle kern.info kernel: [  125.980000] br-lan: port 1(eth0) entered disabled state
Jan  1 01:01:12 Gargoyle daemon.notice netifd: Interface 'lan' is now up
Jan  1 01:01:12 Gargoyle kern.info kernel: [  127.030000] device eth0 entered promiscuous mode
Jan  1 01:01:12 Gargoyle daemon.notice netifd: Interface 'loopback' is now up
Jan  1 01:01:12 Gargoyle user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Jan  1 01:01:13 Gargoyle kern.info kernel: [  127.630000] eth0: link up (1000Mbps/Full duplex)
Jan  1 01:01:13 Gargoyle kern.info kernel: [  127.630000] br-lan: port 1(eth0) entered forwarding state
Jan  1 01:01:13 Gargoyle kern.info kernel: [  127.640000] br-lan: port 1(eth0) entered forwarding state
Jan  1 01:01:15 Gargoyle kern.info kernel: [  129.640000] br-lan: port 1(eth0) entered forwarding state
Jan  1 01:01:16 Gargoyle kern.warn kernel: [  131.070000] ipt_bandwidth: timezone shift of 60 minutes detected, adjusting
Jan  1 01:01:16 Gargoyle kern.warn kernel: [  131.080000]                old minutes west=0, new minutes west=-60
Jan  1 01:01:19 Gargoyle user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Jan  1 01:01:19 Gargoyle user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Jan  1 01:01:19 Gargoyle user.notice dnsmasq: Allowing RFC1918 responses for domain free.aero2.net.pl
Jan  1 01:01:22 Gargoyle daemon.info dnsmasq[2715]: started, version 2.66 cachesize 150
Jan  1 01:01:22 Gargoyle daemon.info dnsmasq[2715]: compile time options: no-IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan  1 01:01:22 Gargoyle daemon.info dnsmasq-dhcp[2715]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Jan  1 01:01:22 Gargoyle daemon.info dnsmasq[2715]: using local addresses only for domain lan
Jan  1 01:01:22 Gargoyle daemon.info dnsmasq[2715]: reading /tmp/resolv.conf.auto
Jan  1 01:01:22 Gargoyle daemon.warn dnsmasq[2715]: ignoring nameserver 192.168.1.1 - local interface
Jan  1 01:01:22 Gargoyle daemon.info dnsmasq[2715]: read /etc/hosts - 2 addresses
Jan  1 01:01:22 Gargoyle daemon.info dnsmasq-dhcp[2715]: read /etc/ethers - 0 addresses
Jan  1 01:01:29 Gargoyle daemon.info dnsmasq-dhcp[2715]: DHCPREQUEST(br-lan) 192.168.1.207 00:24:8c:f7:7f:9f
Jan  1 01:01:29 Gargoyle daemon.info dnsmasq-dhcp[2715]: DHCPACK(br-lan) 192.168.1.207 00:24:8c:f7:7f:9f Wick3DPC
Success
Zbyt mało prądu w porcie USB. Dokup aktywny HUB USB.
Mam HUB aktywny i z niego korzystam. Akurat teraz podpiąłem bezpośrednio bo na to samo wychodzi że się nie łączy.
Daj log jak podłączysz HUB.
Jan  1 01:00:39 Gargoyle syslog.info syslogd started: BusyBox v1.19.4
Jan  1 01:00:39 Gargoyle kern.notice kernel: klogd started: BusyBox v1.19.4 (2014-09-27 09:44:51 CEST)
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    0.000000] Linux version 3.3.8 (cezary@eko.one.pl) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #67 Sat Sep 27 09:51:31 CEST 2014
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] bootconsole [early0] enabled
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] CPU revision is: 00019374 (MIPS 24Kc)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] SoC: Atheros AR9330 rev 1
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] Determined physical RAM map:
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000]  memory: 02000000 @ 00000000 (usable)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] Initrd not found or empty - disabling initrd
Jan  1 01:00:39 Gargoyle kern.warn kernel: [    0.000000] Zone PFN ranges:
Jan  1 01:00:39 Gargoyle kern.warn kernel: [    0.000000]   Normal   0x00000000 -> 0x00002000
Jan  1 01:00:39 Gargoyle kern.warn kernel: [    0.000000] Movable zone start PFN for each node
Jan  1 01:00:39 Gargoyle kern.warn kernel: [    0.000000] Early memory PFN ranges
Jan  1 01:00:39 Gargoyle kern.warn kernel: [    0.000000]     0: 0x00000000 -> 0x00002000
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    0.000000] On node 0 totalpages: 8192
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    0.000000] free_area_init_node: node 0, pgdat 802ed700, node_mem_map 81000000
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    0.000000]   Normal zone: 64 pages used for memmap
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    0.000000]   Normal zone: 0 pages reserved
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    0.000000]   Normal zone: 8128 pages, LIFO batch:0
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    0.000000] pcpu-alloc: [0] 0
Jan  1 01:00:39 Gargoyle kern.warn kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    0.000000] Kernel command line:  board=TL-MR3220-v2 console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan  1 01:00:39 Gargoyle kern.warn kernel: [    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Jan  1 01:00:39 Gargoyle kern.warn kernel: [    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] Writing ErrCtl register=00000000
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] Readback ErrCtl register=00000000
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] Memory: 29044k/32768k available (2224k kernel code, 3724k reserved, 391k data, 184k init, 0k highmem)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] NR_IRQS:51
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.080000] pid_max: default: 32768 minimum: 301
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    0.610000] PCI: CLS 0 bytes, default 32
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.620000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.630000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.640000] msgmni has been set to 56
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.640000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.650000] io scheduler noop registered
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.650000] io scheduler deadline registered (default)
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.660000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.670000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.680000] console [ttyATH0] enabled, bootconsole disabled
Jan  1 01:00:39 Gargoyle kern.warn kernel: [    0.690000] m25p80 spi0.0: found s25sl032a, expected m25p80
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.690000] m25p80 spi0.0: s25sl032a (4096 Kbytes)
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    0.700000] 5 tp-link partitions found on MTD device spi0.0
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    0.700000] Creating 5 MTD partitions on "spi0.0":
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    0.710000] 0x000000000000-0x000000020000 : "u-boot"
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    0.720000] 0x000000020000-0x000000109740 : "kernel"
Jan  1 01:00:39 Gargoyle kern.warn kernel: [    0.720000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    0.730000] 0x000000109740-0x0000003f0000 : "rootfs"
Jan  1 01:00:39 Gargoyle kern.warn kernel: [    0.740000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    0.750000] mtd: partition "rootfs" set to be root filesystem
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.760000] mtd: partition "rootfs_data" created automatically, ofs=3A0000, len=50000
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    0.760000] 0x0000003a0000-0x0000003f0000 : "rootfs_data"
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    0.770000] 0x0000003f0000-0x000000400000 : "art"
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    0.780000] 0x000000020000-0x0000003f0000 : "firmware"
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.800000] ag71xx_mdio: probed
Jan  1 01:00:39 Gargoyle kern.info kernel: [    0.800000] eth0: Atheros AG71xx at 0xba000000, irq 5
Jan  1 01:00:39 Gargoyle kern.info kernel: [    1.360000] eth0: Found an AR7240/AR9330 built-in switch
Jan  1 01:00:39 Gargoyle kern.info kernel: [    2.390000] eth1: Atheros AG71xx at 0xb9000000, irq 4
Jan  1 01:00:39 Gargoyle kern.info kernel: [    2.940000] ag71xx ag71xx.0: eth1: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
Jan  1 01:00:39 Gargoyle kern.info kernel: [    2.950000] TCP cubic registered
Jan  1 01:00:39 Gargoyle kern.info kernel: [    2.950000] NET: Registered protocol family 17
Jan  1 01:00:39 Gargoyle kern.notice kernel: [    2.960000] Bridge firewalling registered
Jan  1 01:00:39 Gargoyle kern.info kernel: [    2.960000] Ebtables v2.0 registered
Jan  1 01:00:39 Gargoyle kern.info kernel: [    2.960000] 8021q: 802.1Q VLAN Support v1.8
Jan  1 01:00:39 Gargoyle kern.info kernel: [    2.970000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Jan  1 01:00:39 Gargoyle kern.info kernel: [    2.980000] Freeing unused kernel memory: 184k freed
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    6.360000] Registered led device: tp-link:green:lan1
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    6.360000] Registered led device: tp-link:green:lan2
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    6.360000] Registered led device: tp-link:green:lan3
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    6.360000] Registered led device: tp-link:green:lan4
Jan  1 01:00:39 Gargoyle kern.debug kernel: [    6.370000] Registered led device: tp-link:green:qss
Jan  1 01:00:39 Gargoyle kern.notice kernel: [   36.820000] ip_set: protocol 6
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.420000] usbcore: registered new interface driver cdc_acm
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.430000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.560000] usbcore: registered new interface driver usbserial
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.570000] USB Serial support registered for generic
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.570000] usbcore: registered new interface driver usbserial_generic
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.580000] usbserial: USB Serial Driver core
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.630000] usbcore: registered new interface driver cdc_ether
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.780000] usbcore: registered new interface driver cdc_ncm
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.880000] USB Serial support registered for GSM modem (1-port)
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.890000] usbcore: registered new interface driver option
Jan  1 01:00:39 Gargoyle kern.info kernel: [   37.890000] option: v0.7.2:USB Driver for GSM modems
Jan  1 01:00:39 Gargoyle kern.info kernel: [   38.020000] USB Serial support registered for Sierra USB modem
Jan  1 01:00:39 Gargoyle kern.info kernel: [   38.030000] usbcore: registered new interface driver sierra
Jan  1 01:00:39 Gargoyle kern.info kernel: [   38.030000] sierra: v.1.7.16:USB Driver for Sierra Wireless USB modems
Jan  1 01:00:43 Gargoyle kern.info kernel: [   43.270000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Jan  1 01:00:43 Gargoyle kern.info kernel: [   43.520000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Jan  1 01:00:43 Gargoyle kern.info kernel: [   43.830000] usb 1-1: new high-speed USB device number 4 using ehci-platform
Jan  1 01:00:44 Gargoyle kern.err kernel: [   44.330000] usb 1-1: device not accepting address 4, error -71
Jan  1 01:00:44 Gargoyle kern.info kernel: [   44.450000] usb 1-1: new high-speed USB device number 5 using ehci-platform
Jan  1 01:00:44 Gargoyle kern.err kernel: [   44.870000] usb 1-1: device not accepting address 5, error -71
Jan  1 01:00:44 Gargoyle kern.err kernel: [   44.870000] hub 1-0:1.0: unable to enumerate USB device on port 1
Jan  1 01:00:45 Gargoyle kern.info kernel: [   45.740000] eth0: link up (1000Mbps/Full duplex)
Jan  1 01:00:46 Gargoyle kern.info kernel: [   46.190000] eth0: link down
Jan  1 01:00:47 Gargoyle kern.info kernel: [   47.250000] device eth0 entered promiscuous mode
Jan  1 01:00:47 Gargoyle kern.info kernel: [   47.850000] eth0: link up (1000Mbps/Full duplex)
Jan  1 01:00:47 Gargoyle kern.info kernel: [   47.850000] br-lan: port 1(eth0) entered forwarding state
Jan  1 01:00:49 Gargoyle kern.info kernel: [   49.850000] br-lan: port 1(eth0) entered forwarding state
Jan  1 01:00:02 Gargoyle authpriv.info dropbear[1331]: Running in background
Jan  1 01:00:02 Gargoyle daemon.warn httpd_gargoyle[1356]: started as root without requesting chroot(), warning only
Jan  1 01:00:02 Gargoyle daemon.notice httpd_gargoyle[1356]: httpd_gargoyle/1.0 14mar2008 starting on Gargoyle, port 80
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq[1447]: started, version 2.66 cachesize 150
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq[1447]: compile time options: no-IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq-dhcp[1447]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq[1447]: using local addresses only for domain lan
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq[1447]: reading /tmp/resolv.conf.auto
Jan  1 01:00:07 Gargoyle daemon.warn dnsmasq[1447]: ignoring nameserver 192.168.1.1 - local interface
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq[1447]: read /etc/hosts - 2 addresses
Jan  1 01:00:07 Gargoyle daemon.info dnsmasq-dhcp[1447]: read /etc/ethers - 0 addresses
Jan  1 01:00:07 Gargoyle user.info sysinit: ERROR: No valid dynamic DNS service configurations defined
Jan  1 01:00:07 Gargoyle user.info sysinit: (Did you specify correct configuration file path?)
Jan  1 01:00:13 Gargoyle daemon.info dnsmasq-dhcp[1447]: DHCPREQUEST(br-lan) 192.168.1.207 00:24:8c:f7:7f:9f
Jan  1 01:00:13 Gargoyle daemon.info dnsmasq-dhcp[1447]: DHCPACK(br-lan) 192.168.1.207 00:24:8c:f7:7f:9f Wick3DPC
Success
Spróbuj czy np pendrive zadziała w tym porcie USB.
Próbowałeś na tym routerze ( bez huba) wyjąć i włożyć ponownie modem? lub hub z modemem wyjąć i włożyć?
Podłączyłem pendrive i lampka się nie świeci. Tak próbowałem wielu rzeczy z tym przełączaniem i resetowaniem ;/ Niestety nic. Kiedyś działało. To chyba faktycznie uszkodzone usb.
Skoro nawet pendrive nie działa to na to wygląda.
No trudno. Opłaca się odsyłać na gwarancję? I tak miałem kupować nowy router to nie wiem.
Zawsze warto. Tylko wgraj oficjalny soft przez wysłaniem. Potem możesz sprzedać tego który przyjdzie z gwarancji.
Ok, dzięki za pomoc. Jeszcze małe pytanie. Co pisało w tych ostatnich logach z hubem usb?
Z Hubem jak i bez huba wyszedł ten sam błąd:
